"CapAdd" : null,
"CapDrop" : null,
"cmd" : "server",
"cpu_priority" : 0,
"enable_publish_all_ports" : false,
"enable_restart_policy" : false,
"enable_service_portal" : null,
"enabled" : true,
"env_variables" : [
"key" : "PATH",
"value" : "/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
"key" : "OCIS_INSECURE",
"value" : "true"
"key" : "PROXY_HTTP_ADDR",
"value" : "0.0.0.0:9200"
"key" : "OCIS_URL",
"value" : "https://192.168.22.2:9200"
"exporting" : false,
"id" : "e7a238d53d7e3556d182c29be5a52afa6019613be7b7f9e21d4e2f6343848b80",
"image" : "owncloud/ocis:latest",
"is_ddsm" : false,
"is_package" : false,
"labels" : {
"maintainer" : "ownCloud GmbH <devops@owncloud.com>",
"org.opencontainers.image.authors" : "ownCloud GmbH",
"org.opencontainers.image.created" : "2023-07-19T15:54:01Z",
"org.opencontainers.image.description" : "oCIS - ownCloud Infinite Scale is a modern file-sync and share platform",
"org.opencontainers.image.documentation" : "https://github.com/owncloud/ocis",
"org.opencontainers.image.licenses" : "Apache-2.0",
"org.opencontainers.image.revision" : "f34d96ace8eb4d844af9e8a21046f0131d5d1da8",
"org.opencontainers.image.source" : "https://github.com/owncloud/ocis.git",
"org.opencontainers.image.title" : "ownCloud Infinite Scale",
"org.opencontainers.image.url" : "https://github.com/owncloud/ocis",
"org.opencontainers.image.vendor" : "ownCloud GmbH",
"org.opencontainers.image.version" : "latest"
"links" : [],
"memory_limit" : 0,
"name" : "owncloud-ocis-1",
"network" : [
"driver" : "bridge",
"name" : "bridge"
"network_mode" : "bridge",
"port_bindings" : [
"container_port" : 9200,
"host_port" : 9200,
"type" : "tcp"
"privileged" : false,
"service_portals" : [],
"shortcut" : {
"enable_shortcut" : false,
"enable_status_page" : false,
"enable_web_page" : false,
"web_page_url" : ""
"use_host_network" : false,
"version" : 2,
"volume_bindings" : [
"host_volume_file" : "/docker/ocis/ocis-config",
"is_directory" : true,
"mount_point" : "/etc/ocis",
"type" : "rw"
"host_volume_file" : "/docker/ocis/ocis-data",
"mount_point" : "/var/lib/ocis",
"type" : "rw"
