Photoprism
Schnitzelbrett
05. Nov 2023
Hi Zusammen,
ich wollte bei mir Photoprism installieren.
Docker und MariaDB laufen.
Leider kann ich im Browser die UI nicht aufrufen.
Kann mir da jemand vielleicht helfen?
version: '3.5'
# Example Docker Compose config file for PhotoPrism (Linux / AMD64)
# Note:
# - Running PhotoPrism on a server with less than 4 GB of swap space or setting a memory/swap limit can cause unexpected
# restarts ("crashes"), for example, when the indexer temporarily needs more memory to process large files.
# - If you install PhotoPrism on a public server outside your home network, please always run it behind a secure
# HTTPS reverse proxy such as Traefik or Caddy. Your files and passwords will otherwise be transmitted
# in clear text and can be intercepted by anyone, including your provider, hackers, and governments:
# https://docs.photoprism.app/getting-started/proxies/traefik/
# Setup Guides:
# - https://docs.photoprism.app/getting-started/docker-compose/
# - https://docs.photoprism.app/getting-started/raspberry-pi/
# - https://www.photoprism.app/kb/activation
# Troubleshooting Checklists:
# - https://docs.photoprism.app/getting-started/troubleshooting/
# - https://docs.photoprism.app/getting-started/troubleshooting/docker/
# - https://docs.photoprism.app/getting-started/troubleshooting/mariadb/
# CLI Commands:
# - https://docs.photoprism.app/getting-started/docker-compose/#command-line-interface
# All commands may have to be prefixed with "sudo" when not running as root.
# This will point the home directory shortcut ~ to /root in volume mounts.
services:
photoprism:
## Use photoprism/photoprism:preview for testing preview builds:
image: photoprism/photoprism:latest
## Don't enable automatic restarts until PhotoPrism has been properly configured and tested!
## If the service gets stuck in a restart loop, this points to a memory, filesystem, network, or database issue:
## https://docs.photoprism.app/getting-started/troubleshooting/#fatal-server-errors
# restart: unless-stopped
stop_grace_period: 10s
depends_on:
- mariadb
security_opt:
- seccomp:unconfined
- apparmor:unconfined
## Server port mapping in the format "Host:Container". To use a different port, change the host port on
## the left-hand side and keep the container port, e.g. "80:2342" (for HTTP) or "443:2342 (for HTTPS):
ports:
- "2342:2342"
## Before you start the service, please check the following config options (and change them as needed):
## https://docs.photoprism.app/getting-started/config-options/
environment:
PHOTOPRISM_ADMIN_USER: "admin" # admin login username
PHOTOPRISM_ADMIN_PASSWORD: "insecure" # initial admin password (8-72 characters)
PHOTOPRISM_AUTH_MODE: "password" # authentication mode (public, password)
PHOTOPRISM_SITE_URL: "http://localhost:2342/" # server URL in the format "http(s)://domain.name:)port)/(path)"
PHOTOPRISM_DISABLE_TLS: "false" # disables HTTPS/TLS even if the site URL starts with https:// and a certificate is available
PHOTOPRISM_DEFAULT_TLS: "true" # defaults to a self-signed HTTPS/TLS certificate if no other certificate is available
PHOTOPRISM_ORIGINALS_LIMIT: 5000 # file size limit for originals in MB (increase for high-res video)
PHOTOPRISM_HTTP_COMPRESSION: "gzip" # improves transfer speed and bandwidth utilization (none or gzip)
PHOTOPRISM_LOG_LEVEL: "info" # log level: trace, debug, info, warning, error, fatal, or panic
PHOTOPRISM_READONLY: "false" # do not modify originals directory (reduced functionality)
PHOTOPRISM_EXPERIMENTAL: "false" # enables experimental features
PHOTOPRISM_DISABLE_CHOWN: "false" # disables updating storage permissions via chmod and chown on startup
PHOTOPRISM_DISABLE_WEBDAV: "false" # disables built-in WebDAV server
PHOTOPRISM_DISABLE_SETTINGS: "false" # disables settings UI and API
PHOTOPRISM_DISABLE_TENSORFLOW: "false" # disables all features depending on TensorFlow
PHOTOPRISM_DISABLE_FACES: "false" # disables face detection and recognition (requires TensorFlow)
PHOTOPRISM_DISABLE_CLASSIFICATION: "false" # disables image classification (requires TensorFlow)
PHOTOPRISM_DISABLE_VECTORS: "false" # disables vector graphics support
PHOTOPRISM_DISABLE_RAW: "false" # disables indexing and conversion of RAW images
PHOTOPRISM_RAW_PRESETS: "false" # enables applying user presets when converting RAW images (reduces performance)
PHOTOPRISM_JPEG_QUALITY: 85 # a higher value increases the quality and file size of JPEG images and thumbnails (25-100)
PHOTOPRISM_DETECT_NSFW: "false" # automatically flags photos as private that MAY be offensive (requires TensorFlow)
PHOTOPRISM_UPLOAD_NSFW: "true" # allows uploads that MAY be offensive (no effect without TensorFlow)
# PHOTOPRISM_DATABASE_DRIVER: "sqlite" # SQLite is an embedded database that doesn't require a server
PHOTOPRISM_DATABASE_DRIVER: "mysql" # use MariaDB 10.5+ or MySQL 8+ instead of SQLite for improved performance
PHOTOPRISM_DATABASE_SERVER: "mariadb:3306" # MariaDB or MySQL database server (hostname:port)
PHOTOPRISM_DATABASE_NAME: "photoprism" # MariaDB or MySQL database schema name
PHOTOPRISM_DATABASE_USER: "photoprism" # MariaDB or MySQL database user name
PHOTOPRISM_DATABASE_PASSWORD: "insecure" # MariaDB or MySQL database user password
PHOTOPRISM_SITE_CAPTION: "AI-Powered Photos App"
PHOTOPRISM_SITE_DESCRIPTION: "" # meta site description
PHOTOPRISM_SITE_AUTHOR: "" # meta site author
## Video Transcoding (https://docs.photoprism.app/getting-started/advanced/transcoding/):
# PHOTOPRISM_FFMPEG_ENCODER: "software" # H.264/AVC encoder (software, intel, nvidia, apple, raspberry, or vaapi)
# PHOTOPRISM_FFMPEG_SIZE: "1920" # video size limit in pixels (720-7680) (default: 3840)
# PHOTOPRISM_FFMPEG_BITRATE: "32" # video bitrate limit in Mbit/s (default: 50)
## Run/install on first startup (options: update https gpu tensorflow davfs clitools clean):
# PHOTOPRISM_INIT: "https gpu tensorflow"
## Run as a non-root user after initialization (supported: 0, 33, 50-99, 500-600, and 900-1200):
# PHOTOPRISM_UID: 1000
# PHOTOPRISM_GID: 1000
# PHOTOPRISM_UMASK: 0000
## Start as non-root user before initialization (supported: 0, 33, 50-99, 500-600, and 900-1200):
# user: "1000:1000"
## Share hardware devices with FFmpeg and TensorFlow (optional):
# devices:
# - "/dev/dri:/dev/dri" # Intel QSV
# - "/dev/nvidia0:/dev/nvidia0" # Nvidia CUDA
# - "/dev/nvidiactl:/dev/nvidiactl"
# - "/dev/nvidia-modeset:/dev/nvidia-modeset"
# - "/dev/nvidia-nvswitchctl:/dev/nvidia-nvswitchctl"
# - "/dev/nvidia-uvm:/dev/nvidia-uvm"
# - "/dev/nvidia-uvm-tools:/dev/nvidia-uvm-tools"
# - "/dev/video11:/dev/video11" # Video4Linux Video Encode Device (h264_v4l2m2m)
working_dir: "/photoprism" # do not change or remove
## Storage Folders: "~" is a shortcut for your home directory, "." for the current directory
volumes:
# "/host/folder:/photoprism/folder" # Example
- "~/volume1/homes/Schnitzelbrett/Photos:/photoprism/originals" # Original media files (DO NOT REMOVE)
# - "/example/family:/photoprism/originals/family" # *Additional* media folders can be mounted like this
# - "~/Import:/photoprism/import" # *Optional* base folder from which files can be imported to originals
- "./storage:/photoprism/storage" # *Writable* storage folder for cache, database, and sidecar files (DO NOT REMOVE)
## Database Server (recommended)
## see https://docs.photoprism.app/getting-started/faq/#should-i-use-sqlite-mariadb-or-mysql
mariadb:
image: mariadb:11
## If MariaDB gets stuck in a restart loop, this points to a memory or filesystem issue:
stop_grace_period: 5s
security_opt: # see https://github.com/MariaDB/mariadb-docker/issues/434#issuecomment-1136151239
command: --innodb-buffer-pool-size=512M --transaction-isolation=READ-COMMITTED --character-set-server=utf8mb4 --collation-server=utf8mb4_unicode_ci --max-connections=512 --innodb-rollback-on-timeout=OFF --innodb-lock-wait-timeout=120
## Never store database files on an unreliable device such as a USB flash drive, an SD card, or a shared network folder:
volumes:
- "./database:/var/lib/mysql" # DO NOT REMOVE
environment:
MARIADB_AUTO_UPGRADE: "1"
MARIADB_INITDB_SKIP_TZINFO: "1"
MARIADB_DATABASE: "photoprism"
MARIADB_USER: "photoprism"
MARIADB_PASSWORD: "insecure"
MARIADB_ROOT_PASSWORD: "insecure"
## Watchtower upgrades services automatically (optional)
## see https://docs.photoprism.app/getting-started/updates/#watchtower
## activate via "COMPOSE_PROFILES=update docker compose up -d"
watchtower:
image: containrrr/watchtower
profiles: ["update"]
environment:
WATCHTOWER_CLEANUP: "true"
WATCHTOWER_POLL_INTERVAL: 7200 # checks for updates every two hours
volumes:
- "/var/run/docker.sock:/var/run/docker.sock"
- "~/.docker/config.json:/config.json" # optional, for authentication if you have a Docker Hub account
Schnitzelbrett
05. Nov 2023
Hab es irgendwie hinbekommen.
Nach mehrmaligen Probieren läuft es nun mit den Vanilla einstellungen.
Hessi30
23. Nov 2012
Die Software war mir bislang nicht bekannt. Scheint eine echte Alternative zu zum unausgereiften Synology Photos zu sein.
Schnitzelbrett
05. Nov 2023
@Hessi30
Wenn es dir um die Bildqualität auf dem Handy geht, dann ist es viel besser als Photos.
Die Gesichtserkennung läuft bei mir nicht so effektiv.
360 Grad Photos werden aktuell auch noch nicht unterstützt.
metalworker
25. Apr 2023
Was ändert die Software denn an der Bildqualität?
Schnitzelbrett
05. Nov 2023
Also ich meine wenn du die App auf dem Handy benutzt.
Bei meinem Android sind die Bilder okay wenn man nicht herran zoomt.
Bei Photoprism schaut das schon alles viel hochauflösender aus.
metalworker
25. Apr 2023
Ah ok , ist mir ehrlich gesagt noch nie wirklich aufgefallen.
Hessi30
23. Nov 2012
Ich dachte ich installiere mal Prism über Docker. Welche Angaben müssen hier hinterlegt werden, damit die Installation durchgeführt werden kann? Habe bislang nichts in gefunden.
Schnitzelbrett
05. Nov 2023
Hier die YAML im ein Projekt zu machen.
Da Fragt er auch nichts weiter ab.
Volume musst du halt noch ändern. (/volume1/homes/Schnitzelbrett/Photos)
Bei mir: /volume1/homes/Schnitzelbrett/Photos:/photoprism/originals
Passwort kann man dann jederzeit ändern.
# Note:
# Setup Guides:
# CLI Commands:
services:
  photoprism:
    ## Use photoprism/photoprismreview for testing preview builds:
    depends_on:
      - mariadb
    security_opt:
    ports:
      - "2342:2342"
    environment:
      PHOTOPRISM_SITE_URL: "http://localhost:2342/"  # server URL in the format "http(s)://domain.nameport)/(path)"
      PHOTOPRISM_DATABASE_SERVER: "mariadb:3306"     # MariaDB or MySQL database server (hostnameort)
    # user: "1000:1000"
    # devices:
    volumes:
      - "/volume1/homes/Schnitzelbrett/Photos:/photoprism/originals"               # Original media files (DO NOT REMOVE)
  mariadb:
    image: mariadb:11
    volumes:
    environment:
  watchtower:
    environment:
    volumes:
Hessi30
23. Nov 2012
Ich komme nicht weiter. Mein Container "Photoprism" hat die IP Adresse 172.17.0.3 . dies ist nicht der IP Kreis meines Netzwerks.
Synchrotron
13. Jul 2019
Eine Bitte: Zugunsten der Lesbarkeit keine seitenlangen Codeausdrucke 1:1 in die Posts kopieren. Bitte ein Textfile daraus machen und als Datei anhängen.
Synchrotron
13. Jul 2019
Zur Auflösung: Synology Photo liefert eine dem Endgerät angepasste Auflösung. Wenn ein Handy Fotos abruft, wird eine reduzierte Auflösung übertragen.
Auf dem kleinen Bildschirm fällt das nicht weiter auf - es spart aber Speicherplatz und Übertragungsvolumen. Das ist durchaus relevant - ein einzelnes Panoramafoto in hoher Auflösung meines iPhones hat locker 70MB Originalbildgröße. Die wird im Normalfall auf dem Handy nicht benötigt.
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
habs in Code Tags gesetzt.
Reaktionen: Synchrotron
Hessi30
23. Nov 2012
danke für die Infos. das hat soweit funktioniert. Photoprism ist über die richtige IP Adresse nun aufrufbar. Wie konfiguriere ich denn der Aufruf für extern. Müsste das dann so aussehen? --> https://meine-domain.de:2342/
version: "3.9"
services:
  db:
    image: mariadb:11.3-jammy
    container_name: PhotoPrism-DB
    hostname: photoprism-db
    mem_limit: 1g
    cpu_shares: 768
    security_opt:
      - no-new-privileges:true
    user: 1026:100
    volumes:
      - /volume2/docker/photoprism/db:/var/lib/mysql:rw
    environment:
      TZ: Europe/Berlin
      MYSQL_ROOT_PASSWORD: [sicheres_passwort]
      MYSQL_DATABASE: photoprism
      MYSQL_USER: photoprism-user
      MYSQL_PASSWORD: [sicheres_passwort]
    restart: on-failure:5
  photoprism:
    mem_limit: 6g
    cpu_shares: 1024
    security_opt:
    user: 1026:100
    ports:
      - 2342:2342
    volumes:
      - /volume2/docker/photoprism/import:/photoprism/import:rw
      - /volume2/docker/photoprism/storage:/photoprism/storage:rw
      - /volume2/docker/photoprism/originals:/photoprism/originals:rw
    environment:
      PHOTOPRISM_ADMIN_USER: [admin_username]
      PHOTOPRISM_ADMIN_PASSWORD: [sicheres_passwort]
      PHOTOPRISM_SITE_URL: https://meine-domain.de:2342/
    depends_on:
      db:
        condition: service_started
Ja. Oder noch besser: Du richtest den Reverse Proxy der DS ein und musst dann für alle Dienste nur noch Port 443 aufmachen. Aber das gehört hier nicht her. Bei Interesse / Fragen bitte einen neuen Thread aufmachen
Hessi30
23. Nov 2012
Verständnisfrage. Welche Auswirkungen hat der Wert HTTP Host.
Derzeit ist das bei mir auf 0.0.0.0
Laut Portainer ist die IP Adresse die 172.23.0.2.... Ich kann allerdings die Anwendung über 192.168.78.111 aufrufen.
Den Zusammenhang erschliesst sich mir nicht.
PHOTOPRISM_HTTP_HOST0.0.0.0
PHOTOPRISM_HTTP_PORT2342
Das passt. Hier geht es um das Binding an IP-Adressen. Wenn man nicht ein sehr spezielles Setup hat, dann lässt man das i.d.R. auf 0.0.0.0
