php module imagick
ralle2k
30. Mrz 2009
ich möchte in meiner Netxcloud das php modul imagick nutzen, um endlich die previews für mov files zu bekommen.
Installiert ist das modul über den Oberfläche (siehe Screenshot) aber wenn ich php74 -m aufrufe wird das modul nicht gelistet.
Muss ich das noch irgendwie aktivieren? In der php.ini ist die bibliothek gelistet
output php74 -m
[PHP Modules]
apcu
bcmath
bz2
calendar
Core
ctype
curl
date
dba
dom
exif
fileinfo
filter
ftp
gd
gettext
gmp
hash
iconv
imap
intl
json
ldap
libxml
mailparse
mbstring
mysqli
mysqlnd
openssl
pcntl
pcre
PDO
pdo_dblib
pdo_mysql
pdo_pgsql
pdo_sqlite
pgsql
Phar
posix
readline
Reflection
session
shmop
SimpleXML
soap
sockets
sodium
SPL
sqlite3
ssh2
standard
sysvmsg
sysvsem
sysvshm
tokenizer
xml
xmlreader
xmlrpc
xmlwriter
xsl
zip
zlib
[Zend Modules]
cat php.ini
[core]
sendmail_path = /usr/bin/ssmtp -t
ignore_repeated_source = 0
xmlrpc_error_number = 0
memory_limit = 512M
output_buffering = 4096
auto_globals_jit = 1
include_path = .:/usr/share/pear
log_errors = On
allow_url_fopen = 1
enable_dl = Off
upload_max_filesize = 32M
enable_post_data_reading = 1
ignore_user_abort = 0
display_startup_errors = 0
sys_temp_dir = /var/services/tmp
extension_dir = /usr/local/lib/php74/modules
register_argc_argv = Off
hard_timeout = 2
smtp_port = 25
realpath_cache_size = 4096K
default_socket_timeout = 60
html_errors = off
max_file_uploads = 20
max_input_nesting_level = 64
disable_classes =
default_mimetype = text/html
expose_php = Off
log_errors_max_len = 1024
post_max_size = 32M
report_memleaks = 1
variables_order = GPCS
short_open_tag = On
upload_tmp_dir = /var/services/tmp
max_execution_time = 240
docref_ext =
serialize_precision = -1
precision = 14
unserialize_max_depth = 4096
implicit_flush = 1
track_errors = 0
xmlrpc_errors = 0
SMTP = localhost
ignore_repeated_errors = 0
request_order = GP
allow_url_include = 0
disable_functions =
file_uploads = 1
docref_root =
max_input_time = 60
auto_detect_line_endings = 0
max_input_vars = 1000
report_zend_debug = 0
error_reporting = E_ALL & ~E_NOTICE & ~E_STRICT & ~E_DEPRECATED
default_charset = UTF-8
realpath_cache_ttl = 120
[pdo_mysql]
pdo_mysql.default_socket = /run/mysqld/mysqld.sock
[zlib]
zlib.output_compression = 0
zlib.output_compression_level = -1
zlib.output_handler =
[mailparse]
mailparse.def_charset = us-ascii
[dba]
dba.default_handler = flatfile
[intl]
intl.use_exceptions = 0
intl.error_level = 0
[zend]
zend.multibyte = 0
zend.assertions = 1
zend.signal_check = 0
zend.detect_unicode = 1
zend.exception_ignore_args = 0
zend.enable_gc = 1
[phar]
phar.readonly = Off
phar.cache_list =
phar.require_hash = 1
[syslog]
syslog.facility = LOG_USER
syslog.filter = no-ctrl
syslog.ident = php
[imagick]
imagick.locale_fix = 0
imagick.skip_version_check = 1
imagick.progress_monitor = 0
[gd]
gd.jpeg_ignore_warning = 1
[apc]
apc.enabled = 1
apc.coredump_unmap = 0
apc.shm_size = 32M
apc.mmap_file_mask =
apc.entries_hint = 4096
apc.use_request_time = 1
apc.smart = 0
apc.ttl = 0
apc.shm_segments = 1
apc.enable_cli = 0
apc.serializer = php
apc.gc_ttl = 3600
apc.slam_defense = 0
[curl]
curl.cainfo =
[pcre]
pcre.recursion_limit = 100000
pcre.jit = 0
pcre.backtrack_limit = 1000000
[iconv]
iconv.input_encoding =
iconv.output_encoding =
iconv.internal_encoding =
[xdebug]
xdebug.show_local_vars = 0
xdebug.trace_format = 0
xdebug.gc_stats_output_dir = /tmp
xdebug.remote_addr_header =
xdebug.profiler_append = 0
xdebug.profiler_enable_trigger = 0
xdebug.trace_enable_trigger = 0
xdebug.cli_color = 0
xdebug.collect_params = 0
xdebug.dump_once = 1
xdebug.gc_stats_output_name = gcstats.%p
xdebug.overload_var_dump = 2
xdebug.var_display_max_children = 128
xdebug.remote_connect_back = 0
xdebug.halt_level = 0
xdebug.dump_undefined = 0
xdebug.trace_enable_trigger_value =
xdebug.profiler_enable = 0
xdebug.remote_enable = 0
xdebug.show_error_trace = 0
xdebug.file_link_format =
xdebug.remote_host = localhost
xdebug.remote_cookie_expire_time = 3600
xdebug.collect_vars = 0
xdebug.remote_timeout = 200
xdebug.profiler_enable_trigger_value =
xdebug.trace_output_name = trace.%c
xdebug.scream = 0
xdebug.remote_log =
xdebug.force_display_errors = 0
xdebug.auto_trace = 0
xdebug.trace_output_dir = /var/services/tmp
xdebug.collect_assignments = 0
xdebug.trace_options = 0
xdebug.var_display_max_data = 512
xdebug.max_nesting_level = 256
xdebug.profiler_output_name = cachegrind.out.%p
xdebug.remote_log_level = 7
xdebug.dump_globals = 1
xdebug.remote_port = 9000
xdebug.show_mem_delta = 0
xdebug.collect_includes = 1
xdebug.idekey =
xdebug.max_stack_frames = -1
xdebug.collect_return = 0
xdebug.profiler_output_dir = /var/services/tmp
xdebug.coverage_enable = 1
xdebug.var_display_max_depth = 3
xdebug.default_enable = 1
xdebug.show_exception_trace = 0
xdebug.remote_mode = req
xdebug.gc_stats_enable = 0
xdebug.filename_format =
xdebug.force_error_reporting = 0
xdebug.remote_autostart = 0
[cli]
cli.pager =
cli.prompt = \b \>
[exif]
exif.decode_jis_intel = JIS
exif.decode_unicode_motorola = UCS-2BE
exif.encode_unicode = ISO-8859-15
exif.decode_jis_motorola = JIS
exif.decode_unicode_intel = UCS-2LE
exif.encode_jis =
[pgsql]
pgsql.max_links = -1
pgsql.allow_persistent = 1
pgsql.log_notice = 0
pgsql.auto_reset_persistent = 0
pgsql.ignore_notice = 0
pgsql.max_persistent = -1
[mbstring]
mbstring.encoding_translation = 0
mbstring.regex_retry_limit = 1000000
mbstring.regex_stack_limit = 100000
mbstring.language = neutral
mbstring.func_overload = 0
mbstring.http_output_conv_mimetypes = "^(text/|application/xhtml\+xml)"
mbstring.strict_detection = 0
[ldap]
ldap.max_links = -1
[mail]
mail.add_x_header = 0
[soap]
soap.wsdl_cache_limit = 5
soap.wsdl_cache_ttl = 86400
soap.wsdl_cache_dir = /var/services/tmp
soap.wsdl_cache_enabled = 1
soap.wsdl_cache = 1
[bcmath]
bcmath.scale = 0
[assert]
assert.exception = 0
assert.warning = 1
assert.bail = 0
assert.quiet_eval = 0
assert.active = 1
[date]
date.default_latitude = 31.7667
date.sunrise_zenith = 90.583333
date.sunset_zenith = 90.583333
date.default_longitude = 35.2333
[mysqli]
mysqli.reconnect = 0
mysqli.default_socket = /run/mysqld/mysqld.sock
mysqli.max_links = -1
mysqli.max_persistent = -1
mysqli.allow_local_infile = 0
mysqli.rollback_on_cached_plink = 0
mysqli.default_port = 3306
mysqli.allow_persistent = 1
[user_ini]
user_ini.cache_ttl = 300
user_ini.filename = .user.ini
[imap]
imap.enable_insecure_rsh = 0
[url_rewriter]
url_rewriter.tags = "a=href,area=href,frame=src,input=src,form=fakeentry"
url_rewriter.hosts =
[mysqlnd]
mysqlnd.net_read_buffer_size = 32768
mysqlnd.net_read_timeout = 86400
mysqlnd.collect_statistics = 1
mysqlnd.collect_memory_statistics = 0
mysqlnd.net_cmd_buffer_size = 4096
mysqlnd.mempool_default_size = 16000
mysqlnd.fetch_data_copy = 0
mysqlnd.log_mask = 0
[filter]
filter.default = unsafe_raw
[session]
session.cookie_samesite =
session.auto_start = 0
session.cache_limiter = nocache
session.trans_sid_tags = "a=href,area=href,frame=src,form="
session.name = PHPSESSID
session.upload_progress.name = PHP_SESSION_UPLOAD_PROGRESS
session.sid_length = 32
session.use_only_cookies = 0
session.serialize_handler = php
session.cookie_path = /
session.gc_probability = 1
session.cache_expire = 180
session.cookie_secure = 0
session.upload_progress.freq = 1%
session.gc_divisor = 1000
session.upload_progress.min_freq = 1
session.upload_progress.prefix = upload_progress_
session.use_strict_mode = 0
session.cookie_httponly = 0
session.gc_maxlifetime = 1440
session.upload_progress.enabled = 1
session.upload_progress.cleanup = 1
session.referer_check =
session.lazy_write = 1
session.save_handler = files
session.cookie_domain =
session.sid_bits_per_character = 4
session.save_path = /var/services/tmp
session.cookie_lifetime = 0
session.trans_sid_hosts =
session.use_cookies = 1
session.use_trans_sid = 0
[highlight]
highlight.default = #0000BB
highlight.keyword = #007700
highlight.html = #000000
highlight.comment = #FF8000
highlight.string = #DD0000
[arg_separator]
arg_separator.input = "&"
arg_separator.output = "&"
[opcache]
opcache.optimization_level = 0x7fffbfff
opcache.restrict_api =
opcache.revalidate_path = 0
opcache.file_cache_only = 0
opcache.file_update_protection = 2
opcache.interned_strings_buffer = 8
opcache.opt_debug_level = 0
opcache.log_verbosity_level = 1
opcache.force_restart_timeout = 180
opcache.validate_permission = 0
opcache.huge_code_pages = 0
opcache.enable = 1
opcache.dups_fix = 0
opcache.save_comments = 1
opcache.enable_cli = 0
opcache.preferred_memory_model =
opcache.preload =
opcache.use_cwd = 1
opcache.blacklist_filename =
opcache.validate_root = 0
opcache.memory_consumption = 128
opcache.max_accelerated_files = 10000
opcache.validate_timestamps = 1
opcache.protect_memory = 0
opcache.max_file_size = 0
opcache.enable_file_override = 0
opcache.lockfile_path = /tmp
opcache.preload_user =
opcache.file_cache_consistency_checks = 1
opcache.error_log =
opcache.max_wasted_percentage = 5
opcache.revalidate_freq = 2
opcache.consistency_checks = 0
