Probleme beim Synchronisieren von Iphone/Android mit Z-push
leppy0815
15. Mrz 2012
Ich bekomme es nicht hin, mit dem IPhone oder Android den Kalender oder Kontkte zu syncronisieren. Nur E-Mails klappern per Exchange.
Hier ein Auszug aus meiner debug.txt von z-push:
03/17/12 21:52:53 [17190] [leppy] Start
03/17/12 21:52:53 [17190] [leppy] Z-Push version: 1.5.7RC-1082
03/17/12 21:52:53 [17190] [leppy] Client IP: 192.168.1.100
03/17/12 21:52:53 [17190] [leppy] Client supports version 2.5
03/17/12 21:52:53 [17190] [leppy] IMAP connection opened sucessfully
03/17/12 21:52:53 [17190] [leppy] POST cmd: Sync
03/17/12 21:52:53 [17190] [leppy] Sync folder:Contacts
03/17/12 21:52:53 [17190] [leppy] Initializing folder diff engine
03/17/12 21:52:54 [17190] [leppy] Found 11 folder changes
03/17/12 21:52:54 [17190] [leppy] Unknown:0 Unknown: SECURITY PROBLEM: insecure server advertised AUTH=PLAIN (errflg=1) (8)
03/17/12 21:52:54 [17462] [leppy] Start
03/17/12 21:52:54 [17462] [leppy] Z-Push version: 1.5.7RC-1082
03/17/12 21:52:54 [17462] [leppy] Client IP: 192.168.1.100
03/17/12 21:52:54 [17462] [leppy] Client supports version 2.5
03/17/12 21:52:55 [17462] [leppy] IMAP connection opened sucessfully
03/17/12 21:52:55 [17462] [leppy] POST cmd: FolderSync
03/17/12 21:52:55 [17462] [leppy] Initializing folder diff engine
03/17/12 21:52:55 [17462] [leppy] Found 10 folder changes
03/17/12 21:52:55 [17462] [leppy] Change for folder 'Sent' will not be sent as modification is not relevant
03/17/12 21:52:55 [17462] [leppy] /volume1/web/z-push/include/utils.php:396 iconv(): Unknown error (22) (8)
03/17/12 21:52:55 [17462] [leppy] Change for folder '' will not be sent as modification is not relevant
03/17/12 21:52:55 [17462] [leppy] Change for folder 'Inbox' will not be sent as modification is not relevant
03/17/12 21:52:55 [17462] [leppy] IMAP-errors: SECURITY PROBLEM: insecure server advertised AUTH=PLAIN
03/17/12 21:52:55 [17462] [leppy] IMAP connection closed
03/17/12 21:52:55 [17462] [leppy] end
03/17/12 21:52:55 [17462] [leppy] --------
Kann mir jenand Helfen???
Ach ja, ich hab die DS 211
leppy
Jdo2002
24. Dez 2011
Was hast du denn für eine DSM Version? Hast du etwas an der zpush config geändert? Verwendest du die Version aus dem SPK?
leppy0815
15. Mrz 2012
Also ich habe die aktuelle 4er Version installiert. Die Version ist auch aus der SPK.
Z-Pusch config:
<?php
* File : config.php
* Project : Z-Push
* Descr : Main configuration file
* Created : 01.10.2007
* Copyright 2007 - 2010 Zarafa Deutschland GmbH
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU Affero General Public License, version 3,
* as published by the Free Software Foundation with the following additional
* term according to sec. 7:
* According to sec. 7 of the GNU Affero General Public License, version 3,
* the terms of the AGPL are supplemented with the following terms:
* "Zarafa" is a registered trademark of Zarafa B.V.
* "Z-Push" is a registered trademark of Zarafa Deutschland GmbH
* The licensing of the Program under the AGPL does not imply a trademark license.
* Therefore any rights, title and interest in our trademarks remain entirely with us.
* However, if you propagate an unmodified version of the Program you are
* allowed to use the term "Z-Push" to indicate that you distribute the Program.
* Furthermore you may use our trademarks where it is necessary to indicate
* the intended purpose of a product or service provided you use it in accordance
* with honest practices in industrial or commercial matters.
* If you want to propagate modified versions of the Program under the name "Z-Push",
* you may only do so if you have a written permission by Zarafa Deutschland GmbH
* (to acquire a permission please contact Zarafa at trademark@zarafa.com).
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU Affero General Public License for more details.
* You should have received a copy of the GNU Affero General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
* Consult LICENSE file for details
// Defines the default time zone
if (function_exists("date_default_timezone_set")){
date_default_timezone_set("Europe/Amsterdam");
// Defines the base path on the server, terminated by a slash
define('BASE_PATH', dirname($_SERVER['SCRIPT_FILENAME']) . "/");
// Define the include paths
ini_set('include_path',
BASE_PATH. "include/" . PATH_SEPARATOR .
BASE_PATH. PATH_SEPARATOR .
ini_get('include_path') . PATH_SEPARATOR .
"/volume1/web/webaccess/include/" . PATH_SEPARATOR .
"/usr/share/php5/" . PATH_SEPARATOR .
"/usr/share/pear/");
define('STATE_DIR', BASE_PATH.'/state');
// Try to set unlimited timeout
define('SCRIPT_TIMEOUT', 0);
//Max size of attachments to display inline. Default is 1MB
define('MAX_EMBEDDED_SIZE', 1048576);
// Device Provisioning
define('PROVISIONING', true);
// This option allows the 'loose enforcement' of the provisioning policies for older
// devices which don't support provisioning (like WM 5 and HTC Android Mail) - dw2412 contribution
// false (default) - Enforce provisioning for all devices
// true - allow older devices, but enforce policies on devices which support it
define('LOOSE_PROVISIONING', false);
// Default conflict preference
// Some devices allow to set if the server or PIM (mobile)
// should win in case of a synchronization conflict
// SYNC_CONFLICT_OVERWRITE_SERVER - Server is overwritten, PIM wins
// SYNC_CONFLICT_OVERWRITE_PIM - PIM is overwritten, Server wins (default)
define('SYNC_CONFLICT_DEFAULT', SYNC_CONFLICT_OVERWRITE_PIM);
// Global limitation of items to be synchronized
// The mobile can define a sync back period for calendar and email items
// For large stores with many items the time period could be limited to a max value
// If the mobile transmits a wider time period, the defined max value is used
// Applicable values:
// SYNC_FILTERTYPE_ALL (default, no limitation)
// SYNC_FILTERTYPE_1DAY, SYNC_FILTERTYPE_3DAYS, SYNC_FILTERTYPE_1WEEK, SYNC_FILTERTYPE_2WEEKS,
// SYNC_FILTERTYPE_1MONTH, SYNC_FILTERTYPE_3MONTHS, SYNC_FILTERTYPE_6MONTHS
define('SYNC_FILTERTIME_MAX', SYNC_FILTERTYPE_ALL);
// Interval in seconds before checking if there are changes on the server when in Ping.
// It means the highest time span before a change is pushed to a mobile. Set it to
// a higher value if you have a high load on the server.
define('PING_INTERVAL', 30);
// The data providers that we are using (see configuration below)
$BACKEND_PROVIDER = "BackendIMAP";
// BackendICS settings
// Defines the server to which we want to connect
define('MAPI_SERVER', 'file:///var/run/zarafa');
// BackendIMAP settings
// recommended to use local servers only
define('IMAP_SERVER', 'localhost');
// connecting to default port (143)
define('IMAP_PORT', 143);
// best cross-platform compatibility (see http://php.net/imap_open for options)
define('IMAP_OPTIONS', '/notls/norsh');
// overwrite the "from" header if it isn't set when sending emails
// options: 'username' - the username will be set (usefull if your login is equal to your emailaddress)
// 'domain' - the value of the "domain" field is used
// '@mydomain.com' - the username is used and the given string will be appended
define('IMAP_DEFAULTFROM', '');
// copy outgoing mail to this folder. If not set z-push will try the default folders
define('IMAP_SENTFOLDER', '');
// forward messages inline (default off - as attachment)
define('IMAP_INLINE_FORWARD', false);
// use imap_mail() to send emails (default) - off uses mail()
define('IMAP_USE_IMAPMAIL', false);
// BackendMaildir settings
define('MAILDIR_BASE', '/tmp');
define('MAILDIR_SUBDIR', 'Maildir');
// BackendVCDir settings
define('VCARDDIR_DIR', '/home/%u/.kde/share/apps/kabc/stdvcf');
// Alternative backend to perform SEARCH requests (GAL search)
// if an empty value is used, the default search functionality of the main backend is used
// use 'SearchLDAP' to search in a LDAP directory (see backend/searchldap/config.php)
define('SEARCH_PROVIDER', '');
Leppy
Jdo2002
24. Dez 2011
warum hast du denn die config.php angepasst? Da sind keine Änderungen notwendig. So wie du es jetzt konfiguriert hast wird als Abfrage IMAP verwendet. Als Backendprovider muss aber ICS => MAPI/Zarafa verwendet werden. Folgende Änderungen sollten es wieder zum laufen bringen:
$BACKEND_PROVIDER = "BackendICS";
Das hier ist auch geändert sollte aber eigentlich nicht so wichtig sein:
leppy0815
15. Mrz 2012
Dies habe ich jetzt geändert. Jetzt klapt es garnicht mehr.
AUszug aus der Debug.txt
03/18/12 08:53:37 [25538] [leppy] Start
03/18/12 08:53:37 [25538] [leppy] Z-Push version: 1.5.7RC-1082
03/18/12 08:53:37 [25538] [leppy] Client IP: 192.168.1.100
03/18/12 08:53:37 [25538] [leppy] Client supports version 2.5
03/18/12 08:53:37 [10111] [leppy] Start
03/18/12 08:53:37 [10111] [leppy] Z-Push version: 1.5.7RC-1082
03/18/12 08:53:37 [10111] [leppy] Client IP: 192.168.1.100
03/18/12 08:53:37 [10111] [leppy] Client supports version 2.5
03/18/12 08:53:38 [25538] [leppy] User leppy logged on
03/18/12 08:53:38 [25538] [leppy] Store supports properties containing Unicode characters.
03/18/12 08:53:38 [25538] [leppy] POST cmd FolderSync denied: Retry after sending a PROVISION command
03/18/12 08:53:38 [25538] [leppy] end
03/18/12 08:53:38 [25538] [leppy] --------
03/18/12 08:53:38 [10111] [leppy] User leppy logged on
03/18/12 08:53:38 [10111] [leppy] Store supports properties containing Unicode characters.
03/18/12 08:53:38 [10111] [leppy] POST cmd FolderSync denied: Retry after sending a PROVISION command
03/18/12 08:53:38 [10111] [leppy] end
03/18/12 08:53:38 [10111] [leppy] --------
03/18/12 08:53:49 [10504] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit I (2)
03/18/12 08:53:49 [10504] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit n (2)
03/18/12 08:53:49 [10504] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit v (2)
03/18/12 08:53:49 [10504] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit l (2)
03/18/12 08:53:49 [10504] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit i (2)
03/18/12 08:53:49 [10504] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit T (2)
03/18/12 08:53:49 [10504] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit s (2)
03/18/12 08:53:49 [10504] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit k (2)
03/18/12 08:53:49 [10504] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit N (2)
03/18/12 08:53:49 [10504] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit O (2)
03/18/12 08:53:49 [10504] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit X (2)
03/18/12 08:53:54 [30252] [leppy] Start
03/18/12 08:53:54 [30252] [leppy] Z-Push version: 1.5.7RC-1082
03/18/12 08:53:54 [30252] [leppy] Client IP: 192.168.1.100
03/18/12 08:53:54 [30252] [leppy] Client supports version 2.5
03/18/12 08:53:55 [30252] [leppy] User leppy logged on
03/18/12 08:53:55 [30252] [leppy] Store supports properties containing Unicode characters.
03/18/12 08:53:55 [30252] [leppy] POST cmd: Ping
03/18/12 08:53:55 [30252] [leppy] Ping received
03/18/12 08:53:55 [30252] [leppy] Ping init
03/18/12 08:53:55 [30252] [leppy] reusing saved state for Tasks
03/18/12 08:53:55 [30252] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit I (2)
03/18/12 08:53:55 [30252] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit n (2)
03/18/12 08:53:55 [30252] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit v (2)
03/18/12 08:53:55 [30252] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit l (2)
03/18/12 08:53:55 [30252] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit i (2)
03/18/12 08:53:55 [30252] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit T (2)
03/18/12 08:53:55 [30252] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit s (2)
03/18/12 08:53:55 [30252] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit k (2)
03/18/12 08:53:55 [30252] [leppy] Exporter could not be configured: result: 80070057
03/18/12 08:53:55 [30252] [leppy] Unable to update state: 8004011C
03/18/12 08:53:55 [30252] [leppy] Waiting for changes... (lifetime 1200)
Jdo2002
24. Dez 2011
Verwendest du die aktuelle Version des SPK (0.2.5)? Wenn nicht, bitte updaten.
Ansonsten würde ich das Konto mal vom Iphone wieder runterschmeißen und neu anlegen. Vermutlich kommt er jetzt durcheinander was den Zustand vorher mit IMAP anging.
leppy0815
15. Mrz 2012
Ja, das aktuelle 0.2.5 hab ich seit gestern abend drauf.
Da nicht alles auf sofort funktionierte, habe ich natürlich was geändert.
Ich versuche es jetzt mal mit dem konto neu einrichten.
Ist ein neuinstallation möglich ohne seine Mails zu verlieren?? Oder muß ich nur mal das z-push mal neu draufwerfe damit alles änderungen weg sind und alles wieder so ist wie vorher??
Jdo2002
24. Dez 2011
Die Mails liegen in der MySQL Datenbank. Wenn du das SPK deinstallierst sind deine Einstellungen (server.cfg) zwar weg, aber die Mails noch vorhanden.
Wenn du nur das z-push auf Auslieferungszustand zurücksetzen willst, einfach das ganze Z-Push Verzeichnis löschen dann das Paket über das PAketzentrum stoppen und wieder starten. Ich prüfe bei jedem Start ob "alles schön/vorhanden" ist, sprich wenn nicht wird z-push wieder deployed.
leppy0815
15. Mrz 2012
Nach neueinrichtung des Kontos läuft es viel besser.
Ein fehler bleibt
03/18/12 09:13:14 [25538] [leppy] /volume1/web/z-push/include/utils.php:100 pack(): Type H: illegal hex digit T (2)
Ich wollte jetzt nicht die ganze log wieder posten, das ist geblieben wie oben.
Auf jedenfall danke für deine Hilfe bis hierher!!!!!!!!!!!
Jdo2002
24. Dez 2011
Funktioniert denn sonst alles?
In der Debug.txt findet sich zum Teil auch viele was wichtig aussieht aber keinerlei praktische Relevanz hat, habe ich festgestellt.
leppy0815
15. Mrz 2012
Sieht so aus, ob alles klapt.
kleinen ersten Test gemacht und sieht gut aus.
Werde jetzt erstmal Frühstück machen und danach frisch gestärt mal ausgibig testen.
Jetzt muß ich nur noch tüffteln, wie ich alle meine Kontakte vom Phone auf den Server synce.
Vielen Dank und bis später vieleicht.
Leppy
leppy0815
15. Mrz 2012
So, alles funktioniert sauber.
Jetzt noch eine letzte Frage :)
Gibt es ein PlugIn für Outlook, damit ich auch alles mit dem PC Syncronisieren kann?????
MS Outlook soll einfach wie die Mobile Geräte per ActiveSync zugreifen.
Leppy
Jdo2002
24. Dez 2011
Leppy
Schön :) es gibt ein Outlook Plugin für Zarafa, damit stellt sich Zarafa wie ein Exchange Server dar => volle Synchronisation aller Outlook Inhalte. Dieses Feature ist für 3 User kostenlos, sofer der Lizenzdienst läuft. Nun kommt der Haken: für die ARM Prozessoren gibt es noch keinen licensed (für x86 schon). Ich hoffe das sich an dieser Situation in den nächsten Wochen was ändert.
Was du aber machen kannst wäre Outlook per IMAP nutzen. oder mit Thundrbird und Lightning per iCal auch auf den Kalender zuzugreifen. Alternativ gäbe es auch noch das Webaccess.
leppy0815
15. Mrz 2012
Das mit der Lizenz habe ich schon gelesen.
Ich kam auf die Idee, das es vieleicht ein PlugIn gibt, das Outlook so wie die MobileGeräte auf Z-Push zugreift und man somit keine Lizenz braucht.
Ich teste schon den Z-Push ausgibig mit IPhone , Android und WindowsPhone 7.5, wenn Du möchtest, kann ich dir dann berichten.
Lepy
Jdo2002
24. Dez 2011
Aso,
im englischen Zarafa QNAP Forum, hat jemand das mit nem Windows Mobile Emulator geschafft:
I've also an workaround for outlook in use (tested with windows mobile 6.5 emulator).
- download a windows mobile or windows phone emulator from microsofts download page and install it
- on emulator: Active Sync - connect to z-push as an exchange server --> now you have all data on the windows mobile emulator
- connect the emulator via Active Sync / Windows Mobile Device Center with Outlook --> now you can see all data in outlook
As long as the emulator is runing, all data flows directly to Zarafa and back. It's of course not he best way but it works :D ...
Alternativ *könnte* es auch hiermit noch gehen, ist aber Kostenpflichtig: http://ical.gutentag.ch/. Das Tool kann wohl caldav / carddav mit Outlook synchronisieren.
Phoenixfire
22. Mai 2011
ich habe auf meiner DS111 aktuell auch das Zarafa Package mit Z-Push laufe. Leider läuft auch dieses noch nicht so ganz rund.
Wenn ich auf meinem Android Smartphone einen Exchange ActiveSync Acc anlegen will bekomme ich immer die Fehlermeldung:
"Authentifizierung fehlgeschlagen. Prüfen Sie Benutzername / Kennwort"
Via WebAccess kann ich mich allerding mit den Daten anmelden. Dort kann ich dann Emails an benutzer@dyndns-domain.de empfangen aber leider nicht senden. Genauer gesagt ich kann schon senden ( es kommt kein Fehler o.ä. ) aber eben auch keine Email an.
Wenn ich das ganze als Exchange Acc in bspw. iCal einrichte nimmt er zwar den Acc geht dann aber in den offline Modus.
Hat jemand ne Idee woran das liegen könnte?
Ports für SMTP ( 25 ) und IMAPS ( 993 ) sind offen und erreichbar.
Greetz
Jdo2002
24. Dez 2011
z-push bzw. Active Sync basiert auf http bzw. https. Du musst also am besten Port 443 (https) auch von aussen erreichbar machen. Im DSM solltest du bei den Webdiensten natürlich https aktivieren. Dann kannst du mal mit einem normalen Browser testen ob ActiveSync erreichbar ist: https://DEINEEXTERNEADRESSE/Microsoft-Server-ActiveSync
Dann kommt eine Benutzername / Passwort Abfrage => das entspricht deinem Zarafa Account. Als nächstes kommt zwar eine Fehlermeldung, diese ist aber normal wenn man einfach per Browser darauf zugreift.
Gruß Julian
Phoenixfire
22. Mai 2011
Hey,
danke für die schnelle Antwort! Von aussen komme ich mit dem "Link" drauf und werde auch nach Benutzername und Passwort gefragt, allerdings am laufenden Band. Wenn ich dann auf abbrechen klick kommt die besagte Fehlerpage mit "Access denied". Also daran sollte es nicht liegen.
Greetz
Jdo2002
24. Dez 2011
Ne anmelden solltest du dich können, dann sollte eine Meldung ähnlich wie diese erscheinen:
Z-Push - Open Source ActiveSync
Version 1.5.5-790
GET not supported
This is the z-push location and can only be accessed by Microsoft ActiveSync-capable devices.
Das Passwort ist das gleiche wie das welches du für das Webaccess verwendest.
Falls du immer noch nicht draufkommt, leg doch mal einen ZarafaUser mit nem sehr einfachen Passwort an - nicht das da Probleme herkommen.
Ansonsten kannst du auch auf der DS Freigabe \web\z-push eine Datei debug.txt anlegen. Wenn diese existiert loggt Z-push eventuelle Fehler dort rein.
Phoenixfire
22. Mai 2011
Hey also Resultat:
Version 1.5.7RC-1082
GET not supported
More information about Z-Push can be found at:
Z-Push homepage
Z-Push download page at BerliOS
Z-Push Bugtracker and Roadmap
All modifications to this sourcecode must be published and returned to the community.
Please see AGPLv3 License for details.
allerdings NICHT mit einem Zarafa Acc sondern mit einem für die DSM Anmeldung????
EDIT: Mit diesem funktioniert dann auch die ExchangeAnbindung auf dem Smartphone....
EDIT2: Jedenfalls das einrichten des Acc´s sync tut der da nix.. und im debug.txt steht auch nix.
