[18:46:50] Running Rootkit Hunter version 1.4.2 on alphaproxima
[18:46:57] Info: This version : 2007060601
[18:46:57] Info: Latest version: 2007060601
[18:46:57] Checking file mirrors.dat [ No update ]
[18:46:57] Info: Executing download command '/usr/bin/wget -q -O "/usr/syno/synoman/webman/3rdparty/rkhunter/rkhunter/files/rkhunter.upd.12792" http://rkhunter.sourceforge.net/1.3/programs_bad.dat 2>/dev/null'
[18:46:59] Info: This version : 2010111601
[18:47:00] Info: Latest version: 2010111601
[18:47:00] Checking file programs_bad.dat [ No update ]
[18:47:00] Info: Executing download command '/usr/bin/wget -q -O "/usr/syno/synoman/webman/3rdparty/rkhunter/rkhunter/files/rkhunter.upd.12792" http://rkhunter.sourceforge.net/1.3/backdoorports.dat 2>/dev/null'
[18:47:01] Info: This version : 2010111401
[18:47:01] Info: Latest version: 2010111401
[18:47:01] Checking file backdoorports.dat [ No update ]
[18:47:02] Info: Executing download command '/usr/bin/wget -q -O "/usr/syno/synoman/webman/3rdparty/rkhunter/rkhunter/files/rkhunter.upd.12792" http://rkhunter.sourceforge.net/1.3/suspscan.dat 2>/dev/null'
[18:47:03] Info: This version : 2009112901
[18:47:03] Info: Latest version: 2009112901
[18:47:05] Checking file suspscan.dat [ No update ]
[18:47:07] Info: Executing download command '/usr/bin/wget -q -O "/usr/syno/synoman/webman/3rdparty/rkhunter/rkhunter/files/rkhunter.upd.12792" http://rkhunter.sourceforge.net/1.3/i18n/1.4.2/i18n.ver 2>/dev/null'
Wechsel in der Konfiguration, dann Eintrag "IMMUTWHITELIST" anwählen und den Text "/tmp/locking.tdb" in "/run/samba/locking.tdb" ändern, die restlichen Einträge in dem Abschnitt entfernen.Danke hat funktioniert.
Update geht soweit.
UpdateDB aber nicht. Hier kommt folgende Fehlermeldung:
Invalid IMMUTWHITELIST configuration option: Non-existent pathname: /tmp/locking.tdb
Invalid IMMUTWHITELIST configuration option: Non-existent pathname: /tmp/.db.synoshare.tdb*
Gleiche wie oben, nur anderer Eintrag. Wechsel auf "RTKT_FILE_WHITELIST" und den Text "/tmp/locking.tdb" in "/run/samba/locking.tdb" ändern.Genauso kommt bei Scan folgender Fehler:
Invalid RTKT_FILE_WHITELIST configuration option: Non-existent pathname: /tmp/locking.tdb
Diese "?" sind Farbcodes die nicht dargestellt werden können. In RKHunter wurde die Farbdarstellung verändert, ich hatte immer die Option --nocolors angeben, damit keine Farbe benutzt wird. Da es noch weitere Ausführungsfehler bezüglich Display etc. gibt, erscheint auch dieses Meldungsfenster am Ende des Scans.Im DSM werden die Fehlermeldungen mit komischen "?" im Pfadnamen angezeigt ( /?mp/?o?in?g.?db )
Auf Kommandozeile nicht. Also da stehts Richtig. Sowohl im DSM als auch auf Kommandozeile passen die Pfade im Config-File (rkhunter.conf).
Frage müssen die Dateien denn existieren? Die gibt es nämlich noch nicht. Wo müssten die liegen und wie müssen die Rechte gesetzt sein?
PATH="/opt/bin:/opt/sbin:$PATH"
PATH="/opt/bin:/opt/sbin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/syno/sbin:/usr/syno/bin:/usr/local/sbin:/usr/local/bin"
export PATH
./rkhunter $RKHUPDDB--check --sk --configfile $RKHWEB/rkhunter.conf --logfile $RKHLOGS/rkhunter_$DATETIME.log --nocolors
./installer.sh --layout custom . --install --nocolors | tee -a $RKHLOGS/rkh-inst_$DATETIME.log 2>&1
