Danke für den Tipp
Das habe ich aber schon versucht.
ash-4.3# python get-pip.py
/usr/local/lib/python2.7/site-packages/cffi/model.py:526: UserWarning: 'point_conversion_form_t' has no values explicitly defined; next version will refuse to guess which integer type it is meant to be (unsigned/signed, int/long)
% self._get_c_name())
Collecting pip
Using cached https://files.pythonhosted.org/pack...974d1cd045ab4/pip-10.0.1-py2.py3-none-any.whl
zsi 2.0rc3 requires PyXML>=0.8.3, which is not installed.
pyopenssl 16.0.0 has requirement cryptography>=1.3, but you'll have cryptography 0.9.3 which is incompatible.
caldav 0.1.10 has requirement lxml==2.1.5, but you'll have lxml 3.6.0 which is incompatible.
Installing collected packages: pip
Found existing installation: pip 10.0.1
Uninstalling pip-10.0.1:
Successfully uninstalled pip-10.0.1
Successfully installed pip-10.0.1
ash-4.3#
Wie gesagt das ganze funktioniert erst seit der neuen DSM 6.2 Version nicht mehr.
Collecting pip
ash-4.3#
