drwxr-xr-x 2 root root 4096 Aug 26 00:03 iobroker
root@DS214play:/opt# cd iobroker
root@DS214play:/opt/iobroker# npm install iobroker
npm WARN cannot run in wd iobroker@1.0.1 node lib/setup.js (wd=/opt/iobroker/node_modules/iobroker)
iobroker@1.0.1 node_modules/iobroker
??? yargs@7.1.0 (get-caller-file@1.0.2, decamelize@1.2.0, y18n@3.2.1, camelcase@3.0.0, which-module@1.0.0, set-blocking@2.0.0, yargs-parser@5.0.0,
require-main-filename@1.0.1, require-directory@2.1.1, cliui@3.2.0, os-locale@1.4.0, string-width@1.0.2, read-pkg-up@1.0.1)
root@DS214play:/opt/iobroker# ./iobroker start
-ash: ./iobroker: No such file or directory
root@DS214play:/opt/iobroker# cd /opt/iobroker
root@DS214play:/opt/iobroker# node node_modules/iobroker/lib/setup.js setup first
npm install iobroker.discovery --production --prefix /opt/iobroker
npm install iobroker.admin --production --prefix /opt/iobroker
npm install iobroker.js-controller --production --prefix /opt/iobroker
gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.4"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram/.node-gyp"
gyp ERR! build error
gyp ERR! stack Error: not found: make
gyp ERR! stack at getNotFoundError (/usr/local/lib/node_modules/npm/node_modules/which/which.js:14:12)
gyp ERR! stack at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:69:19)
gyp ERR! stack at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:81:29)
gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/which.js:90:16
gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
gyp ERR! System Linux 3.2.40
gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram
gyp ERR! node -v v4.8.4
gyp ERR! node-gyp -v v3.4.0
gyp ERR! not ok
npm WARN optional dep failed, continuing unix-dgram@0.2.3
gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa/.node-gyp"
gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa
gyp ERR! not ok
npm WARN optional dep failed, continuing ursa@0.9.4
Cannot write file. Not critical: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
fs.js:794
return binding.mkdir(pathModule._makeLong(path),
Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../iobroker-data/'
at Error (native)
at Object.fs.mkdirSync (fs.js:794:18)
at mkpathSync (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:23:24)
at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:145:13)
at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:601:27
at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:633:15)
at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2993:5)
at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100)
at Module._compile (module.js:409:26)
at Object.Module._extensions..js (module.js:416:10)
npm ERR! Linux 3.2.40
npm ERR! argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production" "--prefix"
"/opt/iobroker"
npm ERR! node v4.8.4
npm ERR! npm v2.15.11
npm ERR! code ELIFECYCLE
npm ERR! iobroker.js-controller@1.1.3 install: `node iobroker.js setup first`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the iobroker.js-controller@1.1.3 install script 'node iobroker.js setup first'.
npm ERR! This is most likely a problem with the iobroker.js-controller package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node iobroker.js setup first
npm ERR! You can get information on how to open an issue for this project with:
npm ERR! npm bugs iobroker.js-controller
npm ERR! Or if that isn't available, you can get their info via:
npm ERR!
npm ERR! npm owner ls iobroker.js-controller
npm ERR! There is likely additional logging output above.
npm ERR! Please include the following file with any support request:
npm ERR! /opt/iobroker/npm-debug.log
Cannot install as normal user. Try sudo...
sudo npm install iobroker.js-controller --production --prefix /opt/iobroker
gyp ERR! not ok
gyp ERR! not ok
Write "./iobroker start" to start the ioBroker
Starting iobroker controller daemon...
iobroker controller daemon started. PID: 19738
