root@Diskstation:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 2.3G 1.4G 862M 62% /
devtmpfs 7.9G 0 7.9G 0% /dev
tmpfs 7.9G 244K 7.9G 1% /dev/shm
tmpfs 7.9G 18M 7.9G 1% /run
tmpfs 7.9G 0 7.9G 0% /sys/fs/cgroup
tmpfs 7.9G 884K 7.9G 1% /tmp
tmpfs 1.6G 0 1.6G 0% /run/user/196791
/dev/mapper/cachedev_0 21T 16T 5.6T 74% /volume1
root@Diskstation:~# du -xhd 1 /
1.2M /.log.junior
40K /.old_patch_info
16K /root
4.0K /lost+found
16K /opt
4.0K /.system_info
190M /var
4.0K /mnt
8.2M /etc
2.5M /etc.defaults
32M /.syno
4.0K /initrd
1.1G /usr
20K /volumeUSB1
9.5M /var.defaults
1.4G /
Warum habe ich so viele „Permission denied“ obwohl ich als Nutzer mit admin Rechten verbunden bin?20K /.system_info
4.0K /mnt
du: cannot read directory '/opt': Permission denied
4.0K /opt
du: cannot read directory '/var/log/systemd': Permission denied
du: cannot read directory '/var/log/sssd': Permission denied
du: cannot read directory '/var/log/synolog': Permission denied
du: cannot read directory '/var/log/supportservice': Permission denied
du: cannot read directory '/var/log/nginx': Permission denied
du: cannot read directory '/var/log/selfcheck': Permission denied
du: cannot read directory '/var/log/samba/cores': Permission denied
du: cannot read directory '/var/log/synomibclient': Permission denied
du: cannot read directory '/var/log/swtpm': Permission denied
du: cannot read directory '/var/tmp/nginx/nginx.tmp': Permission denied
du: cannot read directory '/var/db': Permission denied
du: cannot read directory '/var/spool/webapi': Permission denied
du: cannot read directory '/var/synobackup/HyperBackup-ED': Permission denied
du: cannot read directory '/var/lib/swtpm-localca': Permission denied
du: cannot read directory '/var/lib/sss/pipes/private': Permission denied
du: cannot read directory '/var/lib/sss/db': Permission denied
du: cannot read directory '/var/lib/sss/keytabs': Permission denied
du: cannot read directory '/var/lib/libvirt/qemu/channel/target/domain-6-adffde24-b904-4348-9': Permission denied
du: cannot read directory '/var/lib/libvirt/qemu/domain-6-adffde24-b904-4348-9': Permission denied
du: cannot read directory '/var/lib/libvirt/swtpm': Permission denied
du: cannot access '/var/lib/ha/sync': Permission denied
du: cannot read directory '/var/lib/net-snmp': Permission denied
du: cannot read directory '/var/lib/nfs/sm.bak': Permission denied
du: cannot read directory '/var/lib/nfs/sm': Permission denied
du: cannot read directory '/var/lib/nfs/rpc_pipefs': Permission denied
du: cannot access '/var/lib/heartbeat/crm': Permission denied
du: cannot access '/var/lib/heartbeat/cores': Permission denied
du: cannot access '/var/lib/heartbeat/lrm': Permission denied
du: cannot read directory '/var/lib/synosmartblock': Permission denied
du: cannot read directory '/var/lib/pengine': Permission denied
du: cannot access '/var/lib/datascrubbing/datascrubbing.status': Permission denied
du: cannot read directory '/var/crash': Permission denied
du: cannot read directory '/var/target': Permission denied
145M /var
du: cannot read directory '/var.defaults/log/sssd': Permission denied
du: cannot read directory '/var.defaults/log/nginx': Permission denied
du: cannot read directory '/var.defaults/lib/sss/pipes/private': Permission denied
du: cannot read directory '/var.defaults/lib/sss/db': Permission denied
du: cannot read directory '/var.defaults/lib/sss/keytabs': Permission denied
du: cannot read directory '/var.defaults/lib/nfs/sm.bak': Permission denied
du: cannot read directory '/var.defaults/lib/nfs/sm': Permission denied
du: cannot read directory '/var.defaults/lib/nfs/rpc_pipefs': Permission denied
du: cannot read directory '/var.defaults/lib/synosmartblock': Permission denied
du: cannot read directory '/var.defaults/crash': Permission denied
9.4M /var.defaults
du: cannot read directory '/root': Permission denied
4.0K /root
du: cannot read directory '/usr/syno/share/synotifyd': Permission denied
du: cannot access '/usr/syno/share/SecurityAdvisorReportUI/html': Permission denied
du: cannot access '/usr/syno/share/SecurityAdvisorReportUI/template': Permission denied
du: cannot read directory '/usr/syno/share/healthcheck': Permission denied
du: cannot access '/usr/syno/synoman/webman/help/scrollbar/scss/_flexcrollStyle.scss': Permission denied
du: cannot access '/usr/syno/synoman/webman/help/scrollbar/scss/config.rb': Permission denied
du: cannot access '/usr/syno/synoman/webman/help/scrollbar/scss/flexcroll.scss': Permission denied
du: cannot read directory '/usr/syno/etc/codesign/.gnupg': Permission denied
du: cannot read directory '/usr/syno/etc/packages/SynoFinder/appindex.db': Permission denied
du: cannot read directory '/usr/syno/etc/packages/SecureSignIn/preference/guest': Permission denied
du: cannot read directory '/usr/syno/etc/packages/SecureSignIn/preference/ActiveBackup': Permission denied
du: cannot read directory '/usr/syno/etc/packages/SecureSignIn/preference/DhcpServer': Permission denied
du: cannot read directory '/usr/syno/etc/packages/SecureSignIn/preference/SynologyPhotos': Permission denied
du: cannot read directory '/usr/syno/etc/packages/SecureSignIn/preference/CodecPack': Permission denied
du: cannot read directory '/usr/syno/etc/packages/SecureSignIn/preference/SynologyApplicationService': Permission denied
du: cannot read directory '/usr/syno/etc/packages/HybridShare/share': Permission denied
du: cannot read directory '/usr/syno/etc/synology-account/private': Permission denied
du: cannot read directory '/usr/syno/etc/letsencrypt': Permission denied
du: cannot read directory '/usr/syno/etc/ssl/ssl.csr': Permission denied
du: cannot read directory '/usr/syno/etc/ssl/cgi.key': Permission denied
du: cannot read directory '/usr/syno/etc/ccc': Permission denied
du: cannot read directory '/usr/syno/etc/www/certificate': Permission denied
du: cannot read directory '/usr/syno/etc/private/session/current.users.access.time': Permission denied
du: cannot access '/usr/syno/etc/synoha/rc.subr': Permission denied
du: cannot access '/usr/syno/etc/synoha/serv_conf_def.sh': Permission denied
du: cannot access '/usr/syno/etc/synoha/UtilRec.sh': Permission denied
du: cannot access '/usr/syno/etc/synoha/rc.define': Permission denied
du: cannot access '/usr/syno/etc/synoha/init.d': Permission denied
du: cannot access '/usr/syno/etc/synoha/UtilAuthKey.sh': Permission denied
du: cannot access '/usr/syno/etc/synoha/ha.conf': Permission denied
du: cannot access '/usr/syno/etc/synoha/UtilHeartbeatCheck.sh': Permission denied
du: cannot access '/usr/syno/etc/synoha/rc.volume': Permission denied
du: cannot access '/usr/syno/etc/synoha/UtilArp.sh': Permission denied
du: cannot access '/usr/syno/etc/synoha/rc.d': Permission denied
du: cannot access '/usr/syno/etc/synoha/UtilTarSmallupdate.sh': Permission denied
du: cannot access '/usr/syno/etc/synoha/corosync': Permission denied
du: cannot access '/usr/syno/etc/synoha/SxxPost.sh': Permission denied
du: cannot access '/usr/syno/etc/synoha/confsync': Permission denied
du: cannot access '/usr/syno/etc/synoha/drbd.conf': Permission denied
du: cannot access '/usr/syno/etc/synoha/synoha_set_aff.sh': Permission denied
du: cannot access '/usr/syno/etc/synoha/ntpclient.sh': Permission denied
du: cannot access '/usr/syno/etc/synoha/serv.must.conf': Permission denied
du: cannot access '/usr/syno/etc/synoha/drbd.d': Permission denied
du: cannot access '/usr/syno/etc/synoha/synoha.sc': Permission denied
du: cannot access '/usr/syno/etc/synoha/UtilSafemode.sh': Permission denied
du: cannot access '/usr/syno/etc/synoha/rc.ha': Permission denied
du: cannot access '/usr/syno/etc/synoha/model_groups.list': Permission denied
du: cannot access '/usr/syno/etc/synoha/SxxPre.sh': Permission denied
du: cannot access '/usr/syno/etc/synoha/serv.mon.conf': Permission denied
du: cannot read directory '/usr/syno/etc/certificate/_archive': Permission denied
du: cannot read directory '/usr/syno/etc/payment/purchase_info': Permission denied
du: cannot read directory '/usr/syno/etc/synoshare.bak': Permission denied
du: cannot read directory '/usr/syno/etc/synocron.d': Permission denied
du: cannot read directory '/usr/syno/etc/synotifyd': Permission denied
du: cannot read directory '/usr/syno/etc/logcollector/whitelist': Permission denied
du: cannot read directory '/usr/syno/etc/keymanager': Permission denied
du: cannot read directory '/usr/syno/selfcheck': Permission denied
du: cannot read directory '/usr/syno/etc.defaults/synology-account/private': Permission denied
du: cannot read directory '/usr/syno/etc.defaults/letsencrypt': Permission denied
du: cannot read directory '/usr/syno/etc.defaults/ssl': Permission denied
du: cannot read directory '/usr/syno/etc.defaults/payment/purchase_info': Permission denied
du: cannot read directory '/usr/syno/etc.defaults/synocron.d': Permission denied
du: cannot read directory '/usr/syno/etc.defaults/logcollector/whitelist': Permission denied
du: cannot read directory '/usr/share/pgsql/9.3/etc/postgresql': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/SynoFinder': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/StorageManager': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/SupportService': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/dsm6-ui-compatible': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/SynoOnlinePack_v2': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/USBCopy': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/DhcpServer': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/SMBService': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/FileStation': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/ReplicationService': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/OAuthService': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/Python2': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/QuickConnect': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/ScsiTarget': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/SecureSignIn': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/HybridShare': Permission denied
du: cannot read directory '/usr/local/packages/@apphome/ActiveInsight': Permission denied
du: cannot read directory '/usr/local/packages/@appstore/SMBService/etc/samba/private': Permission denied
du: cannot read directory '/usr/local/packages/@tmp': Permission denied
du: cannot read directory '/usr/local/packages/@appdata/SMBService/log': Permission denied
du: cannot read directory '/usr/local/packages/@appdata/ActiveInsight/zzz': Permission denied
du: cannot read directory '/usr/local/packages/@appdata/ActiveInsight/event': Permission denied
du: cannot read directory '/usr/local/etc/synoschedule.d/StorageAnalyzer': Permission denied
du: cannot read directory '/usr/local/etc/synocron_nonroot.d/ContainerManager': Permission denied
du: cannot read directory '/usr/local/etc/synocron_nonroot.d/SynologyPhotos': Permission denied
du: cannot read directory '/usr/local/etc/synocron_nonroot.d/ReplicationService': Permission denied
du: cannot read directory '/usr/local/etc/synocron_nonroot.d/CodecPack': Permission denied
du: cannot read directory '/usr/local/etc/synocron_nonroot.d/SynologyApplicationService': Permission denied
du: cannot read directory '/usr/local/etc/synocron_nonroot.d/ActiveInsight': Permission denied
du: cannot read directory '/usr/local/etc/synocron.d': Permission denied
du: cannot read directory '/usr/local/etc/synotifyd': Permission denied
1.2G /usr
du: cannot read directory '/etc/sudoers.d': Permission denied
du: cannot read directory '/etc/sssd': Permission denied
du: cannot read directory '/etc/postgresql': Permission denied
du: cannot read directory '/etc/kmip/granted_certs': Permission denied
du: cannot read directory '/etc/kmip/imported_ca_certs': Permission denied
du: cannot read directory '/etc/kmip/revoked_certs': Permission denied
du: cannot read directory '/etc/space': Permission denied
3.9M /etc
2.5M /.log.junior
852M /volume
4.0K /initrd
4.0K /tmpRoot
du: cannot read directory '/etc.defaults/sudoers.d': Permission denied
du: cannot read directory '/etc.defaults/sssd': Permission denied
du: cannot read directory '/etc.defaults/postgresql': Permission denied
du: cannot read directory '/etc.defaults/kmip/granted_certs': Permission denied
du: cannot read directory '/etc.defaults/kmip/imported_ca_certs': Permission denied
du: cannot read directory '/etc.defaults/kmip/revoked_certs': Permission denied
2.5M /etc.defaults
34M /.syno
du: cannot read directory '/lost+found': Permission denied
4.0K /lost+found
28K /.old_patch_info
2.2G /
Eben weil du nur als Nutzer mit admin Rechten angemeldet bist. Du musst dich als root anmelden.Warum habe ich so viele „Permission denied“ obwohl ich als Nutzer mit admin Rechten verbunden bin?
Danke. Ich dachte admin = root. Sorry und danke für die Aufklärung. Jetzt bekomme ich:Eben weil du nur als Nutzer mit admin Rechten angemeldet bist. Du musst dich als root anmelden.
20K /.system_info
4.0K /mnt
16K /opt
251M /var
9.4M /var.defaults
16K /root
1.2G /usr
4.7M /etc
2.5M /.log.junior
852M /volume
4.0K /initrd
4.0K /tmpRoot
2.5M /etc.defaults
34M /.syno
4.0K /lost+found
2.3G /
852M /volume/backup
852M /volume
