Antwort Support
Ich glaube die haben den Fehler noch nicht lokalisiert..... siehe mail von heute und meine antwort dazu. Sorry mein Englisch is net so guat.
My cameras and Java are the latest! Since version 4.1 are randomly in the management / event list records for the period -: - generated. Regardless of the camera! If these records deletes the timeline is restored. This problem started only on version 4.1. Wherein the beta 4.0, this was not the case. I've made in the meantime also keien hardware changes. In the forum there are other people with the same problem. Multiple cameras and timeline does not work if the event list one or more files with runtime -: - were generated.
Sincerely yours
Erich Walter
Am 20.09.2012 12:55, schrieb Synology Technical Support:
> Dear Sir/Madam:
> Thanks for your inquiry and please allow us reply in English.
> To avoid the auto language translation misunderstanding, we have to double check your issue again.
> Did you mean that the Timeline on the Surveillance couldn't work well when you connected three IP-cams in the same time?
> If you did, may I know that what the exactly issue about the Timeline? Could it not play the recorded videos on the Timeline?
> Besides, may I know that what kind of model of your IP-cam and what the browser did you use?
> We would suggest you to update the JRE (Jave Runtime Environment) and the Surveillance to the latest version to see if the
> problem still persist or not.
> Please feel free to contact us again if you have further questions or suggestions.
> Best Regards
> Derek Chung
> 2012/9/15 <e.walter@kabsi.at>
> Problem Explanation: Seit der Umstellung auf 4.1 funktioniert die Timeline im Zeitbalken nicht mehr richtig. Tageweise wird keine Timeline angezeigt obwohl es Aufnahmen gibt!! Wenn man die einzelnen Kameras einzel noch einmal auswählt erscheint die Timeline bis auf eine Kamera!!!! Wobei es egal ist in welcher Linie diese sich befindet.
> Bis zur letzten Beta Version hat alles einwandfrei funktioniert!!! Im Forum gibt es auch schon mehrere Leute die das selbe Problem haben - bitte schauen Sie auch im Forum nach.
> Problem Reproduce Steps: Zeitbalken starten und einen Aufnahmetag nach dem anderen anklicken - eingei Tage erscheinen nicht in der Timeline!!!
> Ich habe derzeit 3 Kameras installiert. Ein anderer User hat 5 Kameras und das selbe Problem.
> Wie gesagt erst nach der Umstellung auf 4.1 trat dieses Phänomen auf.
> Product Information/Question Personal Information
> Product: DS211+ Type of Customer: Endkunde
> Product Version: DSM 4.1-2636 Company Name:
> Product Serial Number: B3J3N01476 Full Name: Erich Walter
> Type of Usage: Zu privaten Zwecken Job Title:
> Hard Drive Model: WD20EARS E-mail:
e.walter@kabsi.at
> Printer Model:
> Address:
> Language: Deutsch, Location: Europe & Russia / Austria
> Client Operating System: Windows 7, Telephone:
> LAN Setting: Statische IP Fax:
> Type of Message: Ich benötige technische Unterstützung
Erich Walter
www.erich-walter.info
