Hallo Pavion,
jetzt bin ich schon ein Stück weiter. Komme auf den Server, habe Senderstreams (aus EyeTV netstream) hinzugefügt. Habe bei FFMpeg http und upd hinzugefügt. Habe einen Speicherordner angelegt. Habe Aufnahmen mehrfach angelegt, aber diese enden stets nach 7sec. und im Speicherordner kann ich nichts finden. Hier mal ein Log:
2013-03-27 14:06:35 OUT Record: Thread timer for 'Testung' started for 24 seconds
2013-03-27 14:06:35 OUT Record: Stopflag for 'test' received
2013-03-27 14:06:44 OUT Record: Stopflag for 'test' received
2013-03-27 14:07:00 OUT FFMPEG (http) record 'Testung' called with:
2013-03-27 14:07:00 OUT ['ffmpeg', '-i', 'http://192.168.178.35/stream/tunerequest00040000C0FFFFFF00B49A60044D00FF00016DCA010101FF', '-t', '59', '-acodec', 'copy', '-vcodec', 'copy', '/volume 1/public/test/20130327140700 - Testung.ts']
2013-03-27 14:07:07 OUT FFMPEG record 'Testung' ended
2013-03-27 14:10:24 OUT Record: Stopflag for 'Testung' received
2013-03-27 14:10:24 OUT FFMPEG (http) record 'Freit' called with:
2013-03-27 14:10:24 OUT ['ffmpeg', '-i', 'http://192.168.178.35/stream/tunerequest00040000C0FFFFFF00B49A60044D00FF00016DCA010101FF', '-t', '35', '-acodec', 'copy', '-vcodec', 'copy', '/volume1/public/test/20130327141024 - Freit.ts']
2013-03-27 14:10:32 OUT FFMPEG record 'Freit' ended
2013-03-27 14:13:27 OUT Record: Stopflag for 'Freit' received
2013-03-27 14:13:27 OUT Record: Thread timer for 'er' started for 32 seconds
2013-03-27 14:14:00 OUT FFMPEG (http) record 'er' called with:
2013-03-27 14:14:00 OUT ['ffmpeg', '-i', 'http://192.168.178.35/stream/tunerequest00040000C0FFFFFF00B49A60044D00FF00016DCA010101FF', '-t', '59', '-acodec', 'copy', '-vcodec', 'copy', 'home/public/test/20130327141400 - er.ts']
2013-03-27 14:14:07 OUT FFMPEG record 'er' ended
2013-03-27 14:16:25 OUT Record: Stopflag for 'er' received
2013-03-27 14:16:25 OUT Record: Thread timer for 'dfgh' started for 34 seconds
2013-03-27 14:17:00 OUT FFMPEG (http) record 'dfgh' called with:
2013-03-27 14:17:00 OUT ['ffmpeg', '-i', 'http://192.168.178.35/stream/tunerequest00040000C0FFFFFF00B49A60044D00FF00016DCA010101FF', '-t', '59', '-acodec', 'copy', '-vcodec', 'copy', '/volume1/video/test20130327141700 - dfgh.ts']
2013-03-27 14:17:07 OUT FFMPEG record 'dfgh' ended
Wo könnte das Problem liegen?
Bitte um Hilfe.
VG
