Assistant Update auf DSM 2.2 funktioniert nicht
ocram-71
26. Aug 2009
immer schön langsam:)
Weiter geht es mit
cd /
du -x -d 1
Hallo Götz
Das kam raus bei der Eingabe
CubeStation> du -x -d 1
du: ./var/lock/lvm: Permission denied
du: ./var/spool/postfix/bounce: Permission denied
du: ./var/spool/postfix/hold: Permission denied
du: ./var/spool/postfix/defer: Permission denied
du: ./var/spool/postfix/private: Permission denied
du: ./var/spool/postfix/saved: Permission denied
du: ./var/spool/postfix/public: Permission denied
du: ./var/spool/postfix/maildrop: Permission denied
du: ./var/spool/postfix/active: Permission denied
du: ./var/spool/postfix/trace: Permission denied
du: ./var/spool/postfix/flush: Permission denied
du: ./var/spool/postfix/deferred: Permission denied
du: ./var/spool/postfix/corrupt: Permission denied
du: ./var/spool/postfix/incoming: Permission denied
du: ./var/lib/postfix: Permission denied
du: ./var/log/cores: Permission denied
2097768 ./var
16 ./dev
du: ./usr/syno/etc/ssl/ssl.key: Permission denied
du: ./usr/syno/synoman/audio/help/krn: Permission denied
du: ./usr/syno/synoman/audio/help/ptg: Permission denied
du: ./usr/syno/synoman/audio/help/help_style.css: Permission denied
du: ./usr/syno/synoman/audio/help/sve: Permission denied
du: ./usr/syno/synoman/audio/help/ger: Permission denied
du: ./usr/syno/synoman/audio/help/dan: Permission denied
du: ./usr/syno/synoman/audio/help/enu: Permission denied
du: ./usr/syno/synoman/audio/help/trk: Permission denied
du: ./usr/syno/synoman/audio/help/jpn: Permission denied
du: ./usr/syno/synoman/audio/help/nor: Permission denied
du: ./usr/syno/synoman/audio/help/cht: Permission denied
du: ./usr/syno/synoman/audio/help/chs: Permission denied
du: ./usr/syno/synoman/audio/help/csy: Permission denied
du: ./usr/syno/synoman/audio/help/fre: Permission denied
du: ./usr/syno/synoman/audio/help/spn: Permission denied
du: ./usr/syno/synoman/audio/help/rus: Permission denied
du: ./usr/syno/synoman/audio/help/nld: Permission denied
du: ./usr/syno/synoman/audio/help/ita: Permission denied
du: ./usr/syno/synoman/audio/help/ptb: Permission denied
du: ./usr/syno/synoman/audio/help/plk: Permission denied
du: ./usr/syno/synoman/audio/help/hun: Permission denied
du: ./usr/syno/synoman/audio/images/box/corners-vista.gif: Permission denied
du: ./usr/syno/synoman/audio/images/box/tb-vista.gif: Permission denied
du: ./usr/syno/synoman/audio/images/box/l-vista.gif: Permission denied
du: ./usr/syno/synoman/audio/images/box/r-vista.gif: Permission denied
du: ./usr/syno/synoman/download/help/krn: Permission denied
du: ./usr/syno/synoman/download/help/ptg: Permission denied
du: ./usr/syno/synoman/download/help/sve: Permission denied
du: ./usr/syno/synoman/download/help/ger: Permission denied
du: ./usr/syno/synoman/download/help/dan: Permission denied
du: ./usr/syno/synoman/download/help/enu: Permission denied
du: ./usr/syno/synoman/download/help/trk: Permission denied
du: ./usr/syno/synoman/download/help/jpn: Permission denied
du: ./usr/syno/synoman/download/help/nor: Permission denied
du: ./usr/syno/synoman/download/help/cht: Permission denied
du: ./usr/syno/synoman/download/help/chs: Permission denied
du: ./usr/syno/synoman/download/help/csy: Permission denied
du: ./usr/syno/synoman/download/help/fre: Permission denied
du: ./usr/syno/synoman/download/help/spn: Permission denied
du: ./usr/syno/synoman/download/help/rus: Permission denied
du: ./usr/syno/synoman/download/help/nld: Permission denied
du: ./usr/syno/synoman/download/help/ita: Permission denied
du: ./usr/syno/synoman/download/help/ptb: Permission denied
du: ./usr/syno/synoman/download/help/plk: Permission denied
du: ./usr/syno/synoman/download/help/hun: Permission denied
150184 ./usr
368 ./etc.defaults
du: ./etc/lvm/cache: Permission denied
448 ./etc
du: ./var.defaults/spool/postfix/bounce: Permission denied
du: ./var.defaults/spool/postfix/hold: Permission denied
du: ./var.defaults/spool/postfix/defer: Permission denied
du: ./var.defaults/spool/postfix/private: Permission denied
du: ./var.defaults/spool/postfix/saved: Permission denied
du: ./var.defaults/spool/postfix/public: Permission denied
du: ./var.defaults/spool/postfix/maildrop: Permission denied
du: ./var.defaults/spool/postfix/active: Permission denied
du: ./var.defaults/spool/postfix/trace: Permission denied
du: ./var.defaults/spool/postfix/flush: Permission denied
du: ./var.defaults/spool/postfix/deferred: Permission denied
du: ./var.defaults/spool/postfix/corrupt: Permission denied
du: ./var.defaults/spool/postfix/incoming: Permission denied
du: ./var.defaults/lib/postfix: Permission denied
128 ./var.defaults
8 ./root
102456 ./lib
3968 ./sbin
4 ./mnt
du: ./lost+found: Permission denied
4 ./volumeUSB1
4 ./initrd
1476 ./bin
2356848 .
CubeStation>
Daraus werde ich nicht schlau.
Sorry das es so lange gedauert hat ich war unterwegs.
Danke ocram
jahlives
19. Aug 2008
Bist du wirklich als root mit Admin-Passwort angemeldet?
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
bitte log Dich als username root und dem Passwort von admin ein.
Wie bereits von anderen vermutet ist Dein var Verzeichnis der Übeltäter.
Gib bitte noch mal
du /var
ein und poste hier das Ergebnis.
ocram-71
26. Aug 2009
root ?
Hello,
ich habe Eric´s TelNet98
und melde mich bei meine cs407e an
Cubestation login: admin
password: xxxxx
dann bin ich drin.
Mit root als login geht mein admin-passwort nicht.
Als Ergebnis von du /var bekomme ich
CubeStation login: admin
Password:
warning: cannot change to home directory
BusyBox v1.1.0 (2009.09.03-23:14+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
CubeStation> du /var
4 /var/services/blog
8 /var/services
4 /var/run/printing
4 /var/run/saslauthd
324 /var/run
4 /var/state/ups
8 /var/state
4 /var/empty
du: /var/lock/lvm: Permission denied
8 /var/lock
du: /var/spool/postfix/bounce: Permission denied
du: /var/spool/postfix/hold: Permission denied
du: /var/spool/postfix/defer: Permission denied
du: /var/spool/postfix/private: Permission denied
du: /var/spool/postfix/saved: Permission denied
du: /var/spool/postfix/public: Permission denied
du: /var/spool/postfix/maildrop: Permission denied
du: /var/spool/postfix/active: Permission denied
du: /var/spool/postfix/trace: Permission denied
4 /var/spool/postfix/pid
du: /var/spool/postfix/flush: Permission denied
du: /var/spool/postfix/deferred: Permission denied
du: /var/spool/postfix/corrupt: Permission denied
du: /var/spool/postfix/incoming: Permission denied
60 /var/spool/postfix
4 /var/spool/cron/crontabs
8 /var/spool/cron
4 /var/spool/php/eaccelerator
8 /var/spool/php
80 /var/spool
du: /var/lib/postfix: Permission denied
4 /var/lib/nfs
12 /var/lib
4 /var/database/pgsql/pg_xlog/archive_status
65624 /var/database/pgsql/pg_xlog
4 /var/database/pgsql/pg_twophase
28 /var/database/pgsql/pg_clog
44 /var/database/pgsql/pg_subtrans
4424 /var/database/pgsql/base/16706
4372 /var/database/pgsql/base/16384
4176 /var/database/pgsql/base/11261
5092 /var/database/pgsql/base/16417
32780 /var/database/pgsql/base/16621
4260 /var/database/pgsql/base/11262
59284 /var/database/pgsql/base
12 /var/database/pgsql/pg_multixact/members
12 /var/database/pgsql/pg_multixact/offsets
28 /var/database/pgsql/pg_multixact
4 /var/database/pgsql/pg_tblspc
268 /var/database/pgsql/global
125300 /var/database/pgsql
125304 /var/database
du: /var/log/cores: Permission denied
1971156 /var/log/lighttpd
1972016 /var/log
4 /var/packages
2097772 /var
CubeStation>
1972016 /var/log
4 /var/packages
2097772 /var
CubeStation>
Ich hoffe das hilfst.
Sag mal du hast auch die Samsung ECO Festplatten.
hast du da ein RAID 5 laufen.
Bis denn Ocram
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
da liegt Dein Problem, knapp 2GB log Dateien.
ls -la /var/log/lighttpd
Webserver mögen es in der Regel nicht, wenn man ihnen die log-Dateien löscht. Gib mal die Ausgabe von ls und dann werden wir löschen und leere Files anlegen.
Zum login als root, hast Du ipkg und openssh installiert?
Wenn ja, funktioniert synopass als Passwort für root?
ocram-71
26. Aug 2009
Web Server ?
bis jetzt nutze ich den CUBE nur alles Massenspeicher.
Ich bin leider noch nicht soweit ihn als Web-Server zu nutzen.
Können wir dann nicht alles löschen.
ipkg und openssh kenn ich nicht. Neuling Sorry.
Der root login mit synopass klappt nicht.
Password:
CubeStation> cd /
CubeStation> ls -la /var/log/lighttpd
drwxr-xr-x 2 admin users 4096 Sep 21 17:04 .
drwxr-xr-x 4 root root 4096 Dec 12 15:08 ..
-rw-r--r-- 1 root root 342987976 Dec 10 00:05 access.log
-rw-r--r-- 1 root root 1673487408 Dec 17 14:44 error.log
CubeStation>
Soweit so gut.
Gruß Ocram
PS Webserver wäre toll dann könnte ich meine Musik auch über umts hören
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
rm /var/log/lighttpd/error.log
touch /var/log/lighttpd/error.log
rm /var/log/lighttpd/access.log
touch /var/log/lighttpd/access.log
dann sollte wieder Ruhe sein.
Wenn das ein Problem mit der mailstation sein sollte, hoffe ich die Experten dafür nehmen dem an.
ocram-71
26. Aug 2009
backup
bin noch am Sichern meiner Daten.
Bin bald so weit.
Danke erstmal
Ich berichte ob es geklappt hat.
Ocram
ocram-71
26. Aug 2009
Vielen Dank.
Die CS läuft wieder 1A.
Ich konnte nach dem Löschen die neue Firmware draufziehen.
Super.
Hast du Erfahrungen mit der PS3 in Verbindung mit der CS als Medienserver.
Oder weißt du wo ich die besten Einstellungen für dieses Päarchen herbekomme.
Vielen Dank nochmal.
Achja hattest die nicht auch diese Energiesparfestplatte samsung ui ??
Ich hatte da versucht ein RAID 5 zu istallierenund bin schön gescheitert.
Welches RAID hast du mit denen laufen.
Bis denn
Ocram
