nafets1511
- 31. Aug. 2012
Due to codec licensing issues, DTS transcoding has been removed from DSM. This change will cause videos embedded with DTS audio not to be played normally in Video Station and DS video. For streaming DTS videos in Video Station, we suggest you install VLC media player for playback. However, currently there is no officially supported 3rd party player supporting DTS integrated with DS video. We sincerely apologize for the inconvenience this will cause and will continue to negotiate with DTS to obtain codec licenses for Synology products.
The codec licensing issues will also result in the removal of video transcoding from Media Server. If the file formats of videos to be played are not supported by your smart TV, we suggest you connect a DLNA-certificated set-top box supporting the formats in question to your TV.
As a workaround you may wish to try as below:
Reinstall Video Station/Media Server by using the beta version released in DSM 4.3 if your DiskStations is running with DSM 4.3. The previous stable packages can be downloaded from below link: http://global.download.synology.com/download/beta/DSM4.3_beta/packages/
(Recommended version: Video Station: v1.2-0423; Media Server: 1.1-2403)
Please go to Package Center to remove the current packages and manually install the spk files above.
