Wann kommt ipkg für DSM5?
Calle
30. Jan 2013
Interessant. Jetzt beschwert sich das Gerät, dass kein ./opt vorhanden sei:
NAS-SERVER> sh syno-x07-bootstrap_1.2-7_arm.xsh
Optware Bootstrap for syno-x07.
Extracting archive... please wait
bootstrap/
bootstrap/bootstrap.sh
bootstrap/ipkg-opt.ipk
1226+1 records in
1226+1 records out
bootstrap/ipkg.sh
bootstrap/optware-bootstrap.ipk
bootstrap/wget.ipk
Creating temporary ipkg repository...
Installing optware-bootstrap package...
Unpacking optware-bootstrap.ipk...Done.
Configuring optware-bootstrap.ipk...mount: mounting /volume1/@optware on /opt failed: No such file or directory
mkdir: can't create directory '/opt/etc': No such file or directory
chmod: /opt/etc: No such file or directory
mkdir: can't create directory '/opt/var/': No such file or directory
chmod: /opt/var: No such file or directory
mkdir: can't create directory '/opt/tmp': No such file or directory
chmod: /opt/tmp: No such file or directory
mkdir: can't create directory '/opt/lib': No such file or directory
chmod: /opt/lib: No such file or directory
//tmp/ipkg/info/optware-bootstrap.ipk.preinst failed. Aborting installation of optware-bootstrap.ipk
Installing ipkg...
Unpacking ipkg-opt.ipk...Done.
Configuring ipkg-opt.ipk...WARNING: can't open config file: /usr/syno/ssl/openssl.cnf
tar: ./opt/share: Cannot mkdir: No such file or directory
tar: ./opt/share/ipkg: Cannot mkdir: No such file or directory
tar: ./opt/share/ipkg/intercept: Cannot mkdir: No such file or directory
tar: ./opt/share/ipkg/intercept/update-modules: Cannot open: No such file or directory
tar: ./opt/share/ipkg/intercept/ldconfig: Cannot open: No such file or directory
tar: ./opt/share/ipkg/intercept/depmod: Cannot open: No such file or directory
tar: ./opt/lib: Cannot mkdir: No such file or directory
tar: ./opt/lib/libipkg.so.0.0.0: Cannot open: No such file or directory
tar: ./opt/lib/libipkg.so.0: Cannot create symlink to `libipkg.so.0.0.0': No such file or directory
tar: ./opt/lib/libipkg.so: Cannot create symlink to `libipkg.so.0.0.0': No such file or directory
tar: ./opt/etc: Cannot mkdir: No such file or directory
tar: ./opt/etc/ipkg.conf: Cannot open: No such file or directory
tar: ./opt/bin: Cannot mkdir: No such file or directory
tar: ./opt/bin/update-alternatives: Cannot open: No such file or directory
tar: ./opt/bin/ipkg-opt: Cannot create symlink to `ipkg': No such file or directory
tar: ./opt/bin/ipkg: Cannot open: No such file or directory
tar: Exiting with failure status due to previous errors
Done.
Removing temporary ipkg repository...
rm: /tmp/ipkg: is a directory
Installing wget...
bootstrap.sh: line 45: /opt/bin/ipkg: not found
Ich denke, dass da der Link fehlt...
Die Installation per bootstrap nutzt keinen Symlink, sondern mountet /volume1/@optware mit "mount -bind ..." nach /opt.
Wenn du neu aufsetzen möchtest, lösche /opt und /volume1/@optware vorher.
Puppetmaster
03. Feb 2012
Bist du auch als 'root' auf der Konsole unterwegs?
Calle
30. Jan 2013
@Banares: Wurde gemacht. Klappt immer noch nicht. :D
login as: root
root@192.168.178.2's password:
BusyBox v1.16.1 (2014-05-29 11:35:48 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
NAS> sh /volume1/public/bootstrap/bootstrap.sh
ln: /tmp/ipkg/ipkg-bootstrap: File exists
sed: ./ipkg.sh: No such file or directory
sh: can't open './ipkg.sh'
Installing ipkg...
Installing wget...
/volume1/public/bootstrap/bootstrap.sh: line 45: /opt/bin/ipkg: not found
NAS>
Puppetmaster
03. Feb 2012
Da liegen wohl auch noch irgendwelche Reste in /tmp rum. Räum vorher mal ein wenig auf.
Calle
30. Jan 2013
Was soll ich denn alles löschen?
Alles, was nach ipkg oder optware klingt.
goetz
Super-Moderator
Teammitglied
18. Mrz 2009
ist aber die falsche Version, Du wirst keine DS107+ mit DSM 5 haben.
Calle
30. Jan 2013
Hä? Jetzt habe ich unter volume1 aufgeräumt:
ipkg, bootstrap, gelöscht, sowie den public-Ordner geleert.
Wenn ich nun irgendeinen Befehl eingebe, kommt immer:
ash: getcwd: No such file or directory
edit: Doch nicht. :D
Calle
30. Jan 2013
Habe es mittlerweile mit syno-mvkw-bootstrap_1.2-7_arm.xsh probiert.
Soll ich auch im Hauptverzeichnis den Ordner opt löschen? Also da, wo auch /volume1 usw. liegt?
Sei vorsichtig, lösch nicht wild herum. Nur /opt, /volume1/@optware und ggf. Reste des letzten Versuchs in /tmp löschen.
Danach genau nach Wiki vorgehen.
Calle
30. Jan 2013
Okay, ich habe aufgeräumt und bin wirklich furzgenau nach der Wiki vorgegangen.
Und siehe da ...
die Spannung steigt ...
es hat funktioniert! :D
JAAAAAAAAAAAAAA!!!
Danke euch allen.
Mal sehen, ob ich es schaffe pyLoad zu installieren. :D
Puppetmaster
03. Feb 2012
reimundko
27. Sep 2013
Kann mir bitte jemand helfen.
Bekomme das ipkg nicht installiert.
Beim aufrufen immer die Meldung not found.
Habe eine ds213j und DSM5
Mit Telnet eingelogt.
cd /volume1/public
wget http://ipkg.nslu2-linux.org/feeds/optware/cs08q1armel/cross/stable/syno-mvkw-bootstrap_1.2-7_arm.xsh
sh syno-mvkw-bootstrap_1.2-7_arm.xsh
ipkg update
Fehlermeldung ipkg not found
Dann die Datei /root/.profile editiert.
#PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/syno/sbin:/usr/syno/bin:/usr/local/sbin:/usr/local/bin
#export PATH
reboot
Immer noch file not found.
Was mache ich denn da noch falsch.
Ich wollte lcd4linux installieren.
Finde für meine Station kein fertiges File, sondern nur das lcd4linux_0.10.0+r758-1_arm.ipk
Danke
PS: Habe folgendes nun gemacht .
/etc/rc.local editieren und hinter #!/bin/sh folgendes einfügen:
mount -o bind /volume1/@optware /opt
dann noch /root/.profile editieren und die Linie die mit PATH anfängt bearbeiten damit die dann so aussieht:
PATH=/opt/bin:/opt/sbin:
ln -s /volume1/@optware /opt
reboot
nun kann ich ipkg ausführen .
Allerdings weren nun keine Befehle mehr erkannt.
Am Anfang steht.
-ash: hostname: not found
wget z.b. wird nicht mehr gefunden.... not found.
sh: wget: not found
> ipkg update
Downloading http://ipkg.nslu2-linux.org/feeds/optware/cs08q1armel/cross/unstable
/Packages
sh: wget: not found
An error ocurred, return value: 1.
Collected errors:
ipkg_download: ERROR: Command failed with return value 127: `wget --passive-ftp
-q -P /opt/ipkg-TTsgV4 http://ipkg.nslu2-linux.org/feeds/optware/cs08q1armel/
cross/unstable/Packages'
Was kann das nun schon wieder sein, dass keine Befehle mehr erkannt werden
JudgeDredd
12. Nov 2009
Das kann nicht stimmen. Da fehlt einiges an Pfadangaben.
Was ergibt denn eine echo $PATH ?
In der /root/.profile die PATH Angaben auskommentieren.
In der /etc/profile muss dann sowas stehen wie:
PATH={verschiedene Pfade}
PATH=/opt/bin:/opt/sbin:$PATH
export PATH
atsiz77
21. Dez 2013
Ich möchte gerne IPKG Installieren, welchen Installationsskript muss ich eigentlich benutzen.
Laut Wiki hat der DS114 ARMADA 370 (1C/1T) Prozessor, und der ist leider nicht ausgeführt?
Mir ist dazu nur diese Quelle bekannt. Vielleicht hilft sie Dir weiter.
atsiz77
21. Dez 2013
@dil88,
danke für denn Link ich habe das ganze nun nach der Anleitung installiert. Aber irgendwie wird trotzdem keine IPKG gefunden?
Muss ich noch was anderes, installieren oder reicht die Englische Anleitung?
Was bekommst Du denn für eine Antwort, wenn Du folgenden Befehl abschickst?
echo $PATH
