! Warung Speicher Pool 1 sind Probleme aufgetreten
Hey. Habe die "tote" Platte (Disk1) getauscht. Aber die Meldung ist leider immer noch da.
Kannst Du mal bitte die Smart Werte gegenlesen ?
Hier von der "neuen" Platte. 8 Stunden nach inbetriebnahme:
=== START OF INFORMATION SECTION ===
Model Family: Seagate IronWolf
Device Model: ST12000VN0007-2GS116
Serial Number: ZJV2VCTF
LU WWN Device Id: 5 000c50 0b375501e
Firmware Version: SC60
User Capacity: 12,000,138,625,024 bytes [12.0 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Feb 23 00:59:26 2025 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 567) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off supp ort.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: (1118) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x50bd) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
ID# ATTRIBUTE_NAME FLAG VA LUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 07 8 064 044 Pre-fail Always - 0
3 Spin_Up_Time 0x0003 08 8 088 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 10 0 100 020 Old_age Always - 8
5 Reallocated_Sector_Ct 0x0033 10 0 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 07 6 060 045 Pre-fail Always - 0
9 Power_On_Hours 0x0032 09 7 097 000 Old_age Always - 3114
10 Spin_Retry_Count 0x0013 10 0 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 10 0 100 020 Old_age Always - 8
187 Reported_Uncorrect 0x0032 10 0 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 10 0 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 05 6 053 040 Old_age Always - 44 (Min/Max 40/47)
192 Power-Off_Retract_Count 0x0032 10 0 100 000 Old_age Always - 97
193 Load_Cycle_Count 0x0032 10 0 100 000 Old_age Always - 134
194 Temperature_Celsius 0x0022 04 4 047 000 Old_age Always - 44 (0 22 0 0 0)
195 Hardware_ECC_Recovered 0x001a 00 7 003 000 Old_age Always - 0
197 Current_Pending_Sector 0x0012 10 0 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 10 0 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 20 0 200 000 Old_age Always - 0
200 Pressure_Limit 0x0023 10 0 100 001 Pre-fail Always - 0
240 Head_Flying_Hours 0x0000 10 0 253 000 Old_age Offline - 3094h+15m+48.642s
241 Total_LBAs_Written 0x0000 10 0 253 000 Old_age Offline - 31694041413
242 Total_LBAs_Read 0x0000 10 0 253 000 Old_age Offline - 13148217985
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Welche Meldung?
Poste mal die SMART Werte der anderen HDD?
Hast du die richtige HDD getauscht, Seriennummern verglichen?
Na die Meldung, das es Stromausfall gab etc. weswegen ich den Thread eröffnet hatte. Ja ich habe DIESMAL die richtige getauscht.
Hier die Werte der 2. Platte
Serial Number: ZJV26GM1
LU WWN Device Id: 5 000c50 0b3f59e79
Firmware Version: CN03
Local Time is: Sun Feb 23 01:15:16 2025 CET
been run.
command.
power-saving mode.
recommended polling time: (1081) minutes.
1 Raw_Read_Error_Rate 0x000f 08 3 069 044 Pre-fail Always - 0
3 Spin_Up_Time 0x0003 09 8 098 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 10 0 100 020 Old_age Always - 2
7 Seek_Error_Rate 0x000f 06 5 060 045 Pre-fail Always - 0
9 Power_On_Hours 0x0032 10 0 100 000 Old_age Always - 13
12 Power_Cycle_Count 0x0032 10 0 100 020 Old_age Always - 2
190 Airflow_Temperature_Cel 0x0022 05 7 056 040 Old_age Always - 43 (Min/Max 24/44)
192 Power-Off_Retract_Count 0x0032 10 0 100 000 Old_age Always - 2
193 Load_Cycle_Count 0x0032 10 0 100 000 Old_age Always - 2
194 Temperature_Celsius 0x0022 04 3 044 000 Old_age Always - 43 (0 22 0 0 0)
195 Hardware_ECC_Recovered 0x001a 00 8 008 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 10 0 253 000 Old_age Offline - 13h+29m+19.259s
241 Total_LBAs_Written 0x0000 10 0 253 000 Old_age Offline - 9547537910
242 Total_LBAs_Read 0x0000 10 0 253 000 Old_age Offline - 187178661
No Errors Logged
Was heißt ist das überhaupt eine neue Meldung? Sie poppt ja direkt auf dem Dashboard auf wenn ich mich einloggen…
Ja das mit Sata1 und Sata2 🤬
In den Logs steht komischer Weise KEIN neuer Eintrag seit dem letzen Log Post. Also auch nicht, dass die HDD getauscht wurde oder so 🤷‍♂️ ich versuche gleich mal deinen Lösungsansatz.
Ich gebe es auf:
sudo -s /volume1/scripts/syno_clear_drive_error.sh
Synology_Clear_Drive_Error v1.0.3
0 status_critical entries found
Ich mache jetzt noch den S.M.A.R.T Test im Dashboard und den IronWolfHealth Test und wenn die beiden ebenfalls okay sind dann ignoriere ich einfach diese schöne WARNMELDUNG
Screenshots sind immer hilfreich! Mit Fehlermeldung im Dashboard kann ich z.B. wenig anfangen.
