- Mitglied seit
- 17. Dez 2014
- Punkte für Reaktionen
- 1.726
sudo -i
root@918 ~ $
Smartctl open device: /dev/sata1 [SAT] failed: No such device
root@DS918:~# smartctl -iA -d sat /dev/sda
smartctl 6.5 (build date Sep 26 2022) [x86_64-linux-4.4.302+] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Red Plus
Device Model: WDC WD101EFBX-68B0AN0
Serial Number:
LU WWN Device Id: 5 000cca 0b0db71db
Firmware Version: 85.00A85
User Capacity: 10,000,831,348,736 bytes [10.0 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Sep 17 10:17:44 2024 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART Attributes Data Structure revision number: 16
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0004 129 129 054 Old_age Offline - 104
3 Spin_Up_Time 0x0007 130 130 024 Pre-fail Always - 623 (Average 623)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 70
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000a 100 100 067 Old_age Always - 0
8 Seek_Time_Performance 0x0004 128 128 020 Old_age Offline - 18
9 Power_On_Hours 0x0012 097 097 000 Old_age Always - 24591
10 Spin_Retry_Count 0x0012 100 100 060 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 69
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1072
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 1072
194 Temperature_Celsius 0x0002 158 158 000 Old_age Always - 41 (Min/Max 20/46)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
root@DS918:~# smartctl -iA -d sat /dev/sdb
Model Family: Red
Device Model: WDC WD120EFAX-68UNTN0
Serial Number:
LU WWN Device Id: 5 000cca 291dd1a77
Firmware Version: 81.00A81
User Capacity: 12,000,138,625,024 bytes [12.0 TB]
Rotation Rate: 5400 rpm
Local Time is: Tue Sep 17 10:21:31 2024 CEST
2 Throughput_Performance 0x0004 126 126 054 Old_age Offline - 114
3 Spin-up_Time 0x0007 158 158 024 Pre-fail Always - 34387067296
4 Start/Stop_Count 0x0012 100 100 000 Old_age Always - 64
5 Re-allocated_Sector_Count 0x0033 100 100 005 Pre-fail Always - 0
8 Seek_Time_Performance 0x0004 140 140 020 Old_age Offline - 15
9 Power-on_Hours_Count 0x0012 096 096 000 Old_age Always - 32661
12 Drive_Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 60
22 Internal_Environment_Status_Helium_Status 0x0023 100 100 025 Pre-fail Always - 100
192 Power_Off_Restart_Count 0x0032 099 099 000 Old_age Always - 1389
193 Load/Unload_Cycles 0x0012 099 099 000 Old_age Always - 1389
194 Temperature 0x0002 175 175 000 Old_age Always - 37 (Min/Max 21/42)
196 Relocation_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector_Count 0x0022 100 100 000 Old_age Always - 0
198 Off-Line_Scan_Uncorrectable_Sector_Count 0x0008 100 100 000 Old_age Offline - 0
199 Ultra_DMA_CRC_Error_Count/Frame_Error_Count 0x000a 200 200 000 Old_age Always - 0
root@DS918:~# smartctl -iA -d sat /dev/sdc
Device Model: WDC WD80EFAX-68KNBN0
Serial Number:
LU WWN Device Id: 5 000cca 0bbe3907f
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Local Time is: Tue Sep 17 10:21:57 2024 CEST
2 Throughput_Performance 0x0004 128 128 054 Old_age Offline - 108
3 Spin_Up_Time 0x0007 153 153 024 Pre-fail Always - 534 (Average 528)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 89
9 Power_On_Hours 0x0012 095 095 000 Old_age Always - 36881
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 77
192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 1594
193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 1594
194 Temperature_Celsius 0x0002 151 151 000 Old_age Always - 43 (Min/Max 22/46)
root@DS918:~# smartctl -iA -d sat /dev/sdd
Model Family: Red
Serial Number:
LU WWN Device Id: 5 000cca 291dd3888
Local Time is: Tue Sep 17 10:22:06 2024 CEST
2 Throughput_Performance 0x0004 127 127 054 Old_age Offline - 112
3 Spin-up_Time 0x0007 162 162 024 Pre-fail Always - 34386411926
4 Start/Stop_Count 0x0012 100 100 000 Old_age Always - 59
9 Power-on_Hours_Count 0x0012 096 096 000 Old_age Always - 31746
12 Drive_Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 59
192 Power_Off_Restart_Count 0x0032 099 099 000 Old_age Always - 1353
193 Load/Unload_Cycles 0x0012 099 099 000 Old_age Always - 1353
194 Temperature 0x0002 180 180 000 Old_age Always - 36 (Min/Max 22/40)
Das Rasseln habe ich noch nicht herausbekommen.Das das ein aussergewöhnlicher Wert ist, habe ich so noch nie bei WD gesehen. Ich würde vermuten, dass die bald auch andere Fehler anzeigt. Konntest du denn herausfinden welche HDD "rasselt"?
Wenn die ID 3 so extrem ungewöhnlich hoch ist hier "34387067296"
34387067296 (HDD2 hier aus dem Thread)
34386411926 (HDD4 hier aus dem Thread)
Andere HDDs:
34388574566
34388902250
34388640185
34388967871
Im Anhang mal eine Tonaufnahme, wobei es heut verhältnismäßig leise ist.Tonaufnahme eine Lösung damit man das "Rasseln" selbst beurteilen kann.
