auth-zone:
master: "b.root-servers.net"
master: "c.root-servers.net"
master: "d.root-servers.net"
master: "f.root-servers.net"
master: "g.root-servers.net"
master: "k.root-servers.net"
url: https://www.internic.net/domain/root.zone
fallback-enabled: yes
for-downstream: no
for-upstream: yes
zonefile: "/opt/unbound/etc/unbound/auth-zone/root.zone"
am Beginn der Zeile rauslöscht: #forward-zone:
#name: "."
#forward-tls-upstream: yes
# SecureDNS.eu
#forward-addr: 146.185.167.43@853#dot.securedns.eu
#forward-addr: 2a03:b0c0:0:1010:e9a:3001@853#dot.securedns.eu
# Quad9
#forward-addr: 9.9.9.9@853#dns.quad9.net
#forward-addr: 149.112.112.112@853#dns.quad9.net
#forward-addr: 2620:fe::fe@853#dns.quad9.net
#forward-addr: 2620:fe::9@853#dns.quad9.net
/opt/unbound/etc/unbound/unbound.conf:28: error: expected deny, refuse, deny_non_local, refuse_non_local, allow, allow_setrd, allow_snoop or allow_cookie as access control action
/opt/unbound/etc/unbound/unbound.conf:28: error: unknown keyword 'fc00'
/opt/unbound/etc/unbound/unbound.conf:28: error: stray ':'
/opt/unbound/etc/unbound/unbound.conf:28: error: unknown keyword '/7'
/opt/unbound/etc/unbound/unbound.conf:28: error: unknown keyword 'allow'
/opt/unbound/etc/unbound/unbound.conf:31: error: expected deny, refuse, deny_non_local, refuse_non_local, allow, allow_setrd, allow_snoop or allow_cookie as access control action
/opt/unbound/etc/unbound/unbound.conf:31: error: unknown keyword 'fe80'
/opt/unbound/etc/unbound/unbound.conf:31: error: stray ':'
/opt/unbound/etc/unbound/unbound.conf:31: error: unknown keyword '/10'
read /opt/unbound/etc/unbound/unbound.conf failed: 11 errors in configuration file
[1696961873] unbound[1:0] fatal error: Could not read config file: /opt/unbound/etc/unbound/unbound.conf. Maybe try unbound -dd, it stays on the commandline to see more errors, or unbound-checkconf
[1696961881] unbound[1:0] fatal error: Could not read config file: /opt/unbound/etc/unbound/unbound.conf. Maybe try unbound -dd, it stays on the commandline to see more errors, or unbound-checkconf
access-control: fd00::/8
access-control: fe80::/10
access-control: fd00::/8 allow
access-control: fe80::/10 allow
[1697023137] unbound[1:0] fatal error: Could not read config file: /opt/unbound/etc/unbound/unbound.conf. Maybe try unbound -dd, it stays on the commandline to see more errors, or unbound-checkconf
[1697023142] unbound[1:0] fatal error: Could not read config file: /opt/unbound/etc/unbound/unbound.conf. Maybe try unbound -dd, it stays on the commandline to see more errors, or unbound-checkconf
[1697023148] unbound[1:0] fatal error: Could not read config file: /opt/unbound/etc/unbound/unbound.conf. Maybe try unbound -dd, it stays on the commandline to see more errors, or unbound-checkconf
[1697023155] unbound[1:0] fatal error: Could not read config file: /opt/unbound/etc/unbound/unbound.conf. Maybe try unbound -dd, it stays on the commandline to see more errors, or unbound-checkconf
[1697042207] unbound[1:0] warning: so-rcvbuf 1048576 was not granted. Got 425984. To fix: start with root permissions(linux) or sysctl bigger net.core.rmem_max(linux) or kern.ipc.maxsockbuf(bsd) values.
Fatal glibc error: cannot get entropy for arc4random
Das sollte ja nun mit der aktualisierten conf-Datei behoben sein.hier die Fehlermeldung
so-rcvbuf: 1m
Danke für den Hinweis. Damit ist die eine Fehlermeldung verschwunden, dass nur noch "Fatal glibc error: cannot get entropy for arc4random" vorhanden ist. Könnte wie bei FreeFileSync Docker (https://github.com/jlesage/docker-freefilesync/issues/8) an einem veralteten Kernel (Linux NAS 3.10.108 #64570) im Zusammenhang mit "get entropy" liegen vermute ich mal.Das sollte ja nun mit der aktualisierten conf-Datei behoben sein.
@update-freak
Auf meiner Test-DSM Maschine lief das auf Anhieb problemlos.
Versuche mal, folgende Zeile in der conf-Datei auszukommentieren oder zu löschen:
so-rcvbuf: 1m
