+ VER=3.0.8
+ PROJECT_NAME=acme.sh
+ PROJECT_ENTRY=acme.sh
+ PROJECT=https://github.com/acmesh-official/acme.sh
+ DEFAULT_INSTALL_HOME=/root/.acme.sh
+ _WINDOWS_SCHEDULER_NAME=acme.sh.cron
+ _SCRIPT_=/usr/local/bin/acme.sh
+ _SUB_FOLDER_NOTIFY=notify
+ _SUB_FOLDER_DNSAPI=dnsapi
+ _SUB_FOLDER_DEPLOY=deploy
+ _SUB_FOLDERS='dnsapi deploy notify'
+ CA_LETSENCRYPT_V2=https://acme-v02.api.letsencrypt.org/directory
+ CA_LETSENCRYPT_V2_TEST=https://acme-staging-v02.api.letsencrypt.org/directory
+ CA_BUYPASS=https://api.buypass.com/acme/directory
+ CA_BUYPASS_TEST=https://api.test4.buypass.no/acme/directory
+ CA_ZEROSSL=https://acme.zerossl.com/v2/DV90
+ _ZERO_EAB_ENDPOINT=https://api.zerossl.com/acme/eab-credentials-email
+ CA_SSLCOM_RSA=https://acme.ssl.com/sslcom-dv-rsa
+ CA_SSLCOM_ECC=https://acme.ssl.com/sslcom-dv-ecc
+ CA_GOOGLE=https://dv.acme-v02.api.pki.goog/directory
+ CA_GOOGLE_TEST=https://dv.acme-v02.test-api.pki.goog/directory
+ DEFAULT_CA=https://acme.zerossl.com/v2/DV90
+ DEFAULT_STAGING_CA=https://acme-staging-v02.api.letsencrypt.org/directory
+ CA_NAMES='
ZeroSSL.com,zerossl
LetsEncrypt.org,letsencrypt
LetsEncrypt.org_test,letsencrypt_test,letsencrypttest
BuyPass.com,buypass
BuyPass.com_test,buypass_test,buypasstest
SSL.com,sslcom
Google.com,google
Google.com_test,googletest,google_test
+ CA_SERVERS=https://acme.zerossl.com/v2/DV90,https://acme-v02.api.letsencrypt.or
g/directory,https://acme-staging-v02.api.letsencrypt.org/directory,https://api.bu
ypass.com/acme/directory,https://api.test4.buypass.no/acme/directory,https://acme
.ssl.com/sslcom-dv-rsa,https://dv.acme-v02.api.pki.goog/directory,https://dv.acme
+ DEFAULT_USER_AGENT='acme.sh/3.0.8 (https://github.com/acmesh-official/acme.sh)'
+ DEFAULT_ACCOUNT_KEY_LENGTH=ec-256
+ DEFAULT_DOMAIN_KEY_LENGTH=ec-256
+ DEFAULT_OPENSSL_BIN=openssl
+ VTYPE_HTTP=http-01
+ VTYPE_DNS=dns-01
+ VTYPE_ALPN=tls-alpn-01
+ ID_TYPE_DNS=dns
+ ID_TYPE_DNS=dns
+ ID_TYPE_IP=ip
+ LOCAL_ANY_ADDRESS=0.0.0.0
+ DEFAULT_RENEW=60
+ NO_VALUE=no
+ W_DNS=dns
+ W_ALPN=alpn
+ DNS_ALIAS_PREFIX='='
+ MODE_STATELESS=stateless
+ STATE_VERIFIED=verified_ok
+ NGINX=nginx:
+ NGINX_START='#ACME_NGINX_START'
+ NGINX_END='#ACME_NGINX_END'
+ BEGIN_CSR='-----BEGIN [NEW ]\{0,4\}CERTIFICATE REQUEST-----'
+ END_CSR='-----END [NEW ]\{0,4\}CERTIFICATE REQUEST-----'
+ BEGIN_CERT='-----BEGIN CERTIFICATE-----'
+ END_CERT='-----END CERTIFICATE-----'
+ CONTENT_TYPE_JSON=application/jose+json
+ RENEW_SKIP=2
+ CODE_DNS_MANUAL=3
+ B64CONF_START=__ACME_BASE64__START_
B64CONF_END=__ACME_BASE64__END_
+ ECC_SEP=_
+ ECC_SUFFIX=_ecc
+ LOG_LEVEL_1=1
+ LOG_LEVEL_2=2
+ LOG_LEVEL_3=3
+ DEFAULT_LOG_LEVEL=2
+ DEBUG_LEVEL_1=1
+ DEBUG_LEVEL_2=2
+ DEBUG_LEVEL_3=3
+ DEBUG_LEVEL_DEFAULT=2
+ DEBUG_LEVEL_NONE=0
+ DOH_CLOUDFLARE=1
+ DOH_GOOGLE=2
+ DOH_ALI=3
+ DOH_DP=4
+ HIDDEN_VALUE='[hidden](please add '"'"'--output-insecure'"'"' to see this value
+ SYSLOG_ERROR=user.error
+ SYSLOG_INFO=user.info
YSLOG_DEBUG=user.debug
+ SYSLOG_LEVEL_ERROR=3
+ SYSLOG_LEVEL_INFO=6
+ SYSLOG_LEVEL_DEBUG=7
+ SYSLOG_LEVEL_DEBUG_2=8
+ SYSLOG_LEVEL_DEBUG_3=9
+ SYSLOG_LEVEL_DEFAULT=3
+ SYSLOG_LEVEL_NONE=0
+ NOTIFY_LEVEL_DISABLE=0
+ NOTIFY_LEVEL_ERROR=1
+ NOTIFY_LEVEL_RENEW=2
+ NOTIFY_LEVEL_SKIP=3
+ NOTIFY_LEVEL_DEFAULT=2
+ NOTIFY_MODE_BULK=0
+ NOTIFY_MODE_CERT=1
+ NOTIFY_MODE_DEFAULT=0
+ _BASE64_ENCODED_CFGS='Le_PreHook Le_PostHook Le_RenewHook Le_Preferred_Chain Le
_ReloadCmd'
+ _DEBUG_WIKI=https://github.com/acmesh-official/acme.sh/wiki/How-to-debug-acme.s
h
PREPARE_LINK=https://github.com/acmesh-official/acme.sh/wiki/Install-preparati
ons
+ _STATELESS_WIKI=https://github.com/acmesh-official/acme.sh/wiki/Stateless-Mode
+ _DNS_ALIAS_WIKI=https://github.com/acmesh-official/acme.sh/wiki/DNS-alias-mode
+ _DNS_MANUAL_WIKI=https://github.com/acmesh-official/acme.sh/wiki/dns-manual-mod
e
+ _DNS_API_WIKI=https://github.com/acmesh-official/acme.sh/wiki/dnsapi
+ _NOTIFY_WIKI=https://github.com/acmesh-official/acme.sh/wiki/notify
+ _SUDO_WIKI=https://github.com/acmesh-official/acme.sh/wiki/sudo
+ _REVOKE_WIKI=https://github.com/acmesh-official/acme.sh/wiki/revokecert
+ _ZEROSSL_WIKI=https://github.com/acmesh-official/acme.sh/wiki/ZeroSSL.com-CA
+ _SSLCOM_WIKI=https://github.com/acmesh-official/acme.sh/wiki/SSL.com-CA
+ _SERVER_WIKI=https://github.com/acmesh-official/acme.sh/wiki/Server
+ _PREFERRED_CHAIN_WIKI=https://github.com/acmesh-official/acme.sh/wiki/Preferred
-Chain
+ _VALIDITY_WIKI=https://github.com/acmesh-official/acme.sh/wiki/Validity
+ _DNSCHECK_WIKI=https://github.com/acmesh-official/acme.sh/wiki/dnscheck
+ _DNS_MANUAL_ERR='The dns manual mode can not renew automatically, you must issu
e it again manually. You'"'"'d better use the other modes instead.'
+ _DNS_MANUAL_WARN='It seems that you are using dns manual mode. please take care
: The dns manual mode can not renew automatically, you must issue it again manual
+ _DNS_MANUAL_ERROR='It seems that you are using dns manual mode. Read this link
first: https://github.com/acmesh-official/acme.sh/wiki/dns-manual-mode'
+ __INTERACTIVE=
+ '[' -t 1 ]
+ __INTERACTIVE=1
+ _URGLY_PRINTF=
+ printf '\x41'
+ '[' A '!=' A ]
+ _ESCAPE_XARGS=
+ _exists xargs
+ cmd=xargs
+ '[' -z xargs ]
+ eval type type
+ eval type xargs
+ ret=0
+ _debug3 'xargs exists=0'
+ '[' 2 -ge 3 ]
+ '[' 0 -ge 9 ]
+ '[' 0 -ge 3 ]
+ return 0
+ printf '%s' '\\x41'
+ xargs printf
+ '[' A '=' A ]
+ _ESCAPE_XARGS=1
+ echo abc
+ egrep -o b
+ '[' b '=' b ]
+ __USE_EGREP=1
+ main --version
+ '[' -z --version ]
+ _startswith --version -
+ _str=--version
+ _sub=-
+ echo --version
+ grep -- ^-
+ _process --version
+ _CMD=
+ _domain=
+ _altdomains=no
+ _webroot=
+ _challenge_alias=
+ _keylength=ec-256
+ _accountkeylength
+ _accountkeylength=ec-256
+ _cert_file=
+ _key_file=
+ _ca_file=
+ _fullchain_file=
+ _reloadcmd=
+ _password=
+ _accountconf=
+ _useragent=
+ _accountemail=
+ _accountkey=
+ _certhome=
+ _confighome=
+ _httpport=
+ _tlsport=
+ _dnssleep=
+ _listraw=
+ _stopRenewOnError=
+ _ca_bundle=
+ _ca_path=
+ _nocron=
+ _noprofile=
+ _ecc=
+ _csr=
+ _pre_hook=
+ _post_hook
+ _renew_hook=
+ _deploy_hook=
+ _logfile=
+ _log=
+ _local_address=
+ _log_level=
+ _auto_upgrade=
+ _listen_v4=
+ _listen_v6=
+ _openssl_bin=
+ _syslog=
+ _use_wget=
+ _server=
+ _notify_hook=
+ _notify_level=
+ _notify_mode=
+ _notify_source=
+ _revoke_reason=
+ _eab_kid=
+ _eab_hmac_key=
+ _preferred_chain=
+ _valid_from=
+ _valid_to=
+ '[' 1 -gt 0 ]
+ echo https://github.com/acmesh-official/acme.sh
+ echo v3.0.8
v3.0.8
+ return
