Baïkal contacts (CardDAV) and calendar (CardDAV) installation package for Synology
ok Basalt, i understand, but it isn't working :-/
which web services do i need?
Please read the PDF manual on SourceForge.
Chapter 1...
now the window open:
[h=1]Baïkal Install Tool is locked.[/h]To unlock it, create (or re-create if it exists already) an empty file named ENABLE_INSTALL (uppercase, no file extension) in the Specific/ folder of Baïkal.
RTFM, chapter 4: "Initializing the Baïkal server" :)
ich geb auf, ich bin zu doof
i give up, i am too stupid for this stuff.
the baikal wan admin ask for a Login Password, i write my login/password, it is not accepted. so i have to use a other caldav :-/
i have error when change to MySQL ?
Validation error
MySQL error: These tables, required by Baïkal, are missing: addressbooks, calendarobjects, calendars, cards, groupmembers, locks, principals, users
You may want create these tables using the file Core/Resources/Db/MySQL/db.sql
Nothing has been saved
Did you follow the manual? (Chapter 2: "MySQL only: Creating database with phpMyAdmin")
The manual is available as PDF on SourceForge.
/Erik
EDIT:
Just realised that the PDF manual is not that easy to find, so I added some texts to the SourceForge page :)
@Basalt
i can now synchron from Android to Thunderbird and reserved and work fine.
But i can not from my iphone the Contacts ?
So on the iphone, the whole works only partially. The existing contacts are not synced to Baikal.
When I select Contacts, Groups, only the Synology then a new contact is snycronisiert. But as soon as I select iCloud and synology will not work anymore.
Welche globalen Rechte muss der nutzer für die datenbank haben? Ich bin blind und kann den screenshoot leider nicht auslesen, der sich in der pdf-Datei befindet..
Global privileges: Ich habe einfach denn Haken bei Alle Auswählen gemacht, aber laut der PDF soll es auch ohne die Rechte gehen so habe ich das zumindest verstanden
Nur das dumme ist, die vorhandene Kontakte und Kalendereinträge werden nicht syncronisiert, habe es zumindest nicht gefunden wie es gehen soll
Ich danke dir.. Dann werde ich es mal versuchen.
Was hast du eigentlich für Endgeräte iOS oder Android ?
ios.. carddav konnte ich schon aktivieren. Nun muss ich nur irgendwie alle kontakte auf den Server bekommen..
Einrichtung in Kurzform.
- Baikal installieren
- danach datenbaank über mysql anlegen (Globlale Rechte sind nicht notwendig)
- Admin anlegen (http://syno/baikal)
- danach ggf. Datenbankeinstellungen für mysql anpassen (localhost, Datenbank, passwort)
- save klicken
- neuen user unter Baikal anlegen z. B. vornname.nachname. Anzeigename Vorname Nachname, Kalender und Adressbuch anpassen
- im IOS Carddavaccount hinzufügen. Server: syno/baical/card.php, Benutzer: Vorname.nachname, Beschreibung egal.
- bei Zertifikatsmeldung nach dem Klick auf weiter einfach fortsetzen klicken.. Nun muss der Carddav account noch als Std für neue Kontakte gesetzt werden.
Berichte mal ob das bei dir klappt mit denn Kontakte weil bei mir geht es leider nicht. Hast du auch ios 7 ?
Ich habe einen Testkontakt angelegt. Das ging ohne Probleme.. Leider weiß ich nicht, wie ich die anderen Kontakte in das Adressbuch von Baikal bekommen soll. gibt es auf IOS eine Möglichkeit?
Ja ich nutze ios7.1
Soweit bin ich auch gekommen, meine vorhandene Kontakte habe ich auch nicht auf Baikal kopiert bekommen warum auch immer.
Ich werde mal versuchen, baikal im Outlook einzurichten und die Kontakte vom Iphone zu exportieren.. So bekomme ich sie dann sicher rüber.
Und bist du inzwischen weiter gekommen?
im Zuge des Updates auf DSM5.0 bin ich mit meinen gesamten Kontakten und Kalendern inkl. denen der gesamten Familie für den Cal/Card-DAV Sync von Owncloud auf den Baikal-Server umgezogen. Parallel hatte ich bis gestern Abend noch die Owncloud laufen, habe inzwischen den Sync aber komplett auf Baikal umgestellt. Soweit läuft bei mir der Sync zwischen Baikal auf der DS und diversen iOS und MacOS Geräten jetzt einwandfrei.
Um die Daten (Adressbücher und Kalender) in die Baikal-DB zu bekommen, habe ich meine Backups aus der Owncloud einfach über die Mac Programme importiert, nachdem ich die jeweiligen Baikal-Adressbücher und Kalender im Baikal und in den Programmen angelegt habe. Die importierten Kalender und Adressbücher werden ja dann in die Baikal-DB gesynct und sind somit nach Einrichtung aller Endgeräte auf diesen verfügbar.
Um also die Daten auf den Server zu bekommen, kann man die Standardprogramme eines Macs nutzen. Danach kann man die Baikal-Konten auf dem Mac ja wieder löschen, falls man den Mac eines Freundes benutzt hat oder der Mac nicht gesynct werden soll. Evtl kann man die Erstsyncronisation auch mit anderen Programmen machen, zbsp. Thunderbird. Mit Outlook wird es wohl nicht klappen, da CalDAV und CardDAV nicht unterstützt werden.
Gruss
XL
Selbiges bei mir, läuft seit einer Woche mit 3 Mac´s 2 iPhones und iPads wunderbar, sync nun Kalender, Erinnerungen, Notizen, Adressen mit Baikal …:o
