[Beta] DSM 6.1 - 14871: Erfahrungen, Probleme, Bugs
blinddark
03. Jan 2013
DSM 6.1 Beta 1 (14871) ist verfügbar.
https://www.synology.com/de-de/beta/2017_DSM61Beta
Downloads:
http://download.synology.com/download/DSM/beta/6.1/14871/
Release notes
Compatibility and Installation
1. DSM 6.1 Beta can only be installed on Synology products running DSM 6.0. Before starting, please log in to DSM and go to Control Panel > Update & Restore
to install the latest DSM.
2. Time Backup and HiDrive Backup will not be supported in DSM 6.1 and above.
3. We can not guarantee the accuracy or completeness of third party packages, which are not developed by Synology.
4. The desktop search widget “Search Now” does not support accessibility.
5. Manual re-indexing is required for all files after upgrading to DSM 6.1 Beta. The file indexing service in Control Panel has been moved to the preference
settings in Synology Universal Search.
6. File Station requires manual installation on EDS14 launched for the first time.
7. Due to infrastructure update, packages will need re-initialization after upgrading to DSM 6.1 Beta. The process will occupy a higher CPU usage and can
take up to an hour depending on the number of packages installed.
What’s New in DSM 6.1 Beta
1. File Self-Healing
?DSM is now capable of detecting and repairing silent data corruption if your Synology NAS meets the following criteria:
Liste mit 3 Einträgen Verschachtelung 2
?Running Btrfs file system
?Built on RAID 1, RAID 5, RAID 6, RAID 10, or non-1 disk SHR
?Without any SSD read-write cache mounted (This limitation will be removed in the coming release.)
Listenende Verschachtelung 2
2. Shared Folder Encryption
?In addition to encrypting a shared folder as you create it, you can now encrypt an existing shared folder anytime you want.
?With Key Manager, you can now use a USB storage device as a physical key to mount encrypted shared folders automatically without having to memorize all
the encryption keys.
?Removed the "Mount automatically on startup" function from the edit page of shared folders.
3. Resource Monitor
?IT administrators will receive notifications regarding performance issues of the CPU, memory, disks, or LUNs (available on XS+ and XS models).
?I/O throughput of each process can now be monitored in Task Manager (available on models with Intel 64-bit processors).
?Added the service-based view, allowing you to monitor resource usage of each service and application (available on models with Intel 64-bit processors).
4. File Services
?Windows File Services and Mac File Services have been renamed SMB and AFP, respectively.
?SMB service is now running Samba 4.4.
?Supports Time Machine via SMB3 in Mac OS 10.12 and above.
?Supports Bonjour service, allowing you to back up data to multiple shared folders via Time Machine.
?Supports sparse files over the SMB protocol to enhance usage efficiency of file system space and network bandwidth.
?You can now restore to a previous version from Windows Explorer when mounting your home folder via the SMB protocol.
?After enabling Btrfs fast clone in SMB advanced settings, files can be copied at a faster speed when the source and destination are within the same Btrfs
volume.
5. Storage Manager
?RAID type can now be changed from SHR-1 to SHR-2, providing greater flexibility of storage expansion and better data protection. Note: Depending on your
disk configuration, two additional disks may be required when changing your RAID type from SHR-1 to SHR-2. For more information, please refer to
DSM Help.
?Provides more types of disk health status to help you grasp the health info of your disks.
?You can now migrate a single volume to a disk group and then create multiple volumes while using SHR (more flexiable for models built on the 32-bit architecture
with a single volume size limit of 16TB) .
6. Flexible Update Options
?You can apply important fixes without unnecessary system reboots.
?In case a reboot is required to complete an update, the system will notify you via Email and in DSM, allowing you the flexibility to reboot at a time
of your choice.
7. Service Modularization
?Some of DSM’s built*-in features have been modularized into packages to ensure better system maintenance and update flexibility.
?Modularization in DSM 6.1 Beta includes USB Copy, File Station, and File indexing.
8. Package Center
?Automatically updates incompatible packages after the installation of DSM 6.1 Beta to boost your upgrading experience.
What’s New in Packages
1. SMI-S Provider
?Introduces SMI-S Provider, optimized for Microsoft’s System Center Virtual Machine Manager (SCVMM)
?SMI-S allows an IT administrator to manage multiple Synology NAS servers as storage destinations via SCVMM's centralized user interface.
2. RADIUS Server
?The new cache mechanism supports offline authentication when Active Directory is unavailable.
?In addition to selecting only one authentication source, you can now select local system accounts plus one additional source against which RADIUS Server
authenticates users:
?Local system accounts + AD domain accounts
?Local system accounts + LDAP service accounts
?Supports TLS 1.2 protocols to enhance the security on web browsers.
3. PHP 7.0
?Introduces PHP 7.0, the latest PHP version, which has a much better performance than previous ones.
4. Directory Server
?Supports Nested Group to provide better management methods.
5. File Station
Liste mit 3 Einträgen Verschachtelung 1
?Supports tile view for browsing files.
?Supports browsing history as a drop-down list at a quick glance.
?File path is now editable and supports autocomplete to help you locate folders effortlessly. Minor bug fixes.
6. Apache HTTP Server 2.2
?Apache server has become an independent package to allow more flexible choices.
blinddark
03. Jan 2013
Weitere Infos:
DSM 6.1
NAS OS und seine Kernfunktionen
Im Bereich DSM-Architektur und der zugehörigen Pakete geht Synology neue Wege. Als ein vollständig ausgereiftes Betriebssystem, konzentriert sich DSM auf
die grundlegenden Tools zur Ausführung Ihres Synology NAS. Dadurch lassen sich andere wesentliche Dienste und Funktionen unabhängig und mit weniger Rücksicht
auf DSM selbst weiterentwickeln. Diese neuartige Herangehensweise sorgt für einen leichteren, reaktionsfähigeren DSM sowie eine besser individualisierte
NAS-Erfahrung. Nachstehend finden Sie eine Auflistung der für DSM 6.1 Beta entwickelten oder verbesserten Kernfunktionen.
Resource Monitor
Resource Monitor dient zur Überwachung der CPU- und Speicherauslastung, der Datenträgerauslastung sowie des Netzwerkflusses. Der NAS kann in Echtzeit überwacht
oder ältere Daten überprüft werden. Um komplizierte Fehler zu umgehen und IT-Administratoren rechtzeitig bei der Durchführung notwendiger Maßnahmen zu
unterstützen, unterstützt Resource Monitor nun die Performance Alarm-Funktion auf Intel-basierten XS und XS Modellen von Synology NAS. Performance Alarm
ist ein Benachrichtigungstool, welches Warnungen basierend auf der jeweiligen Ressourcenauslastung verschickt. Mithilfe von unter Task Manager verfügbaren
Prozessen erhalten Sie einen ausführlicheren Bericht ausgeführter Dienste unter Angabe des jeweiligen Anwendungsnamen sowie bereitgestellter Informationen
bezüglich Ausführzeit und Hardware-Auslastung.1
Storage Manager
Das Dienstprogramm Storage Manager hilft Ihnen bei der Speicherplatzverwaltung und -überwachung auf Ihrem Synology NAS. DSM 6.1 Beta ermöglicht nun einen
Wechsel von SHR-1 (einfache Datenträgerredundanz) auf SHR-2 (zweifache Datenträgerredundanz) für gesteigerte Flexibilität bei der Speichererweiterung sowie
verbesserten Datenschutz.
Datei-Selbstreparatur
DSM 6.1 verfügt über eine Selbstreparaturfunktion für beschädigte Dateien auf freigegebenen Datenträgern, welche auf Btrfs und RAID als Dateisysteme zurückgreift.
Btrfs ist zur Behebung von häufig auftretenden Problemen bei Speichersystemen von Unternehmen konzipiert, darunter Fehlertoleranz, Verwaltung sowie Datenschutz.
Mithilfe von Metadaten-Spiegelung und Fehlererkennung sowie -behebung lassen sich durch Btrfs bestimmte fehlerhafte Stellen beschädigter Daten wiederherstellen.
Zu den unterstützten RAID-Datenträgern gehören RAID5, 6, 10, 1 und SHR.
Flexible Aktualisierung
Für Nutzer, die Betriebsstörungen unbedingt vermeiden wollen, gestaltet sich die Installation kleinerer Updates für den vorhandenen Synology NAS jetzt
noch flexibler. Dank Veränderungen in DSM können wichtige Patches ohne Systemneustart installiert werden, während andere Updates, die den Systemneustart
erfordern auf den nächsten Termin der Systemwartung verschoben werden können.
Time Machine
Bei der Datensicherung von Inhalten eines MacOS Computers auf Synology NAS unter Zuhilfenahme der Anwendung Time Machine, können nun mehrere freigegebene
Ordner als Speicherziele festgelegt werden. So lassen sich Zugriffsberechtigungen effektiver steuern und Daten sind vor versehentlichem Zugriff durch nicht
autorisierte Benutzer besser geschützt. Zusätzlich sorgt ein Kontingent für freigegebene Ordner (auf Btrfs-Datenträgern verfügbar) für die problemlose
Einrichtung spezifischer Speichernutzungsregeln eines jeden freigegebenen Ordners.
Active Directory Server in Kürze
Die neue Active Directory Server-Anwendung ermöglicht bestimmten Modellen des Synology NAS als Domänencontroller zu fungieren und zu einem wesentlichen
Bestandteil der IT-Infrastruktur Ihres Büros zu werden. Anhand der einfach bedienbaren Benutzeroberfläche können Sie Richtlinien zur Batch-Verwaltung all
Ihrer Benutzer, Gruppen und Arbeitsplätze an einem zentralen Ort einrichten. So lassen sich bspw. Wartungsaufgaben durch Einsatz einer Richtlinie zum automatischen
Installieren bestimmter Software oder System-Updates auf sämtlichen Mitarbeiter-PCs optimieren, ohne dafür jeden einzelnen persönlich aufsuchen zu müssen.
Weitere Funktion(en)
• Automatische Reparatur mit Package Center: Falls einige Pakete aufgrund einer DSM-Aktualisierung Fehler aufweisen und ein Update benötigen, kann DSM
jetzt diese Fehler während der Aktualisierung automatisch beheben, um so einen reibungslosen Prozessablauf zu gewährleisten.
• DSM-Codezeichen: Genau wie Ihr Telefon Anwendungen nicht vertrauenswürdiger Quellen blockieren kann, kann Ihr Synology NAS DSM-Patches blockieren, die
mit den entsprechenden Zeichencodes übereinstimmen. So werden Ihre gespeicherten Daten zusätzlich gesichert.
• SMB 4.4-Aktualisierung für geringe Dateiunterstützung zur Speicherplatzeinsparung während der Archivierung von Bilddateien virtueller Maschinen.
Hafer
03. Okt 2014
Danke für die Info. Wer traut sich :)
PS: auf die Samba-4.4 Aktualisierung zur geringen Dateiunterstützung bin ich besonders gespannt.
raymond
10. Sep 2009
Für mich ist nur Samba 4.4 interessant. Die Intel NAS User wirds freuen dass endlich btrfs Funktion aufgebohrt werden.
Soll nicht mit DSM 6.1 auch ein Chat Server kommen oder wird der auf Beta2 verschoben?
PS: gefunden: https://www.synology.com/de-de/beta/2017_Chat/ReleaseNotes/#Chat
Ich bin beim testen nicht dabei. Vielleicht bei späteren Betas oder RC. Es lohnt sich, find ich, auch immer weniger im nicht Firmenumfeld zu testen (hier natürlich auf separater Maschine).
Erweiterter Resource Monitor: nur für Intel NAS? Was soll das?!
Jedenfalls für mich: sehr dünne Beta.
Thonav
16. Feb 2014
Chat Server läuft schon, Raymond. Funktioniert sogar sehr gut. Eine Art Privat-Whatsapp :)
So - Installation auf DS1515+ und DS213 ist problemlos durchgelaufen..
Ressoursen Monitor ist schon mal ganz übersichtlich...
amarthius
Super-Moderator
Teammitglied
03. Jun 2009
DIe Übersetzung ist wieder der Knaller :)
  • DSM-Codezeichen: Genau wie Ihr Telefon Anwendungen nicht vertrauenswürdiger Quellen blockieren kann, kann Ihr Synology NAS DSM-Patches blockieren, die mit den entsprechenden Zeichencodes übereinstimmen. So werden Ihre gespeicherten Daten zusätzlich gesichert.
Bin gespannt auf die Ersten Rückmeldungen.
tschortsch
16. Dez 2008
Falls sie Active Directory gut einbinden wird das für kleine Arbeisgruppen, Büros oder auch Familienumfelder eine gute alternative zum Windows Server oder eben auch schon vorhandenen Linux-Alternativen die separat gehostet und verwaltet werden müssen.
frankyst72
01. Jun 2015
- DSM-Codezeichen: Genau wie Ihr Telefon Anwendungen nicht vertrauenswürdiger Quellen blockieren kann, kann Ihr Synology NAS DSM-Patches blockieren, die mit den entsprechenden Zeichencodes übereinstimmen. So werden Ihre gespeicherten Daten zusätzlich gesichert.
- SMB 4.4-Aktualisierung für geringe Dateiunterstützung zur Speicherplatzeinsparung während der Archivierung von Bilddateien virtueller Maschinen..
Der englische Text lautet:
- DSM code sign: Much like your phone is able to block applications from untrusted sources, your Synology NAS can also block DSM patches that don't match the right sign code, adding an extra layer of security to your stored data.
- SMB 4.4 upgrade for sparse file support, saving space while archiving image files of virtual machines.
Finde die Beta aber schon recht interessant.
Da läuft es einem kalt den Rücken 'runter, aber wir sind das ja leider gewöhnt.
TheTwist76
21. Apr 2013
uname -a sagt folgendes:
Linux TheTwist 3.10.102 #14871 SMP Tue Nov 1 15:27:42 CST 2016 x86_64 GNU/Linux synology_avoton_415+
PsychoHH
03. Jul 2013
Mit Ultimate Backup haben wir ja das automatische mounten per Keyfile ermöglicht. Ich bin mal gespannt was sie jetzt wie geändert haben...
Mal schauen wie Time Machine über SMB läuft und das neue btrfs...
tschortsch
16. Dez 2008
Wenn sie das gleich auch zusätzlich noch für einen Netzwerkshare machen würden wäre es noch sinnvoller.
Iarn
16. Jun 2012
Danke Dir für den schnellen Service.
Ich finde es enttäuschend, dass man sich nicht von den Uralt Kerneln trennen kann. Auch wenn 3.10 immer mal wieder eine Verlängerung spendiert bekommen hat, ist Oktober 2017 endgültig Schluss.
blinddark
03. Jan 2013
Da hat Synology doch noch fast ein Jahr Zeit. ;-)
raymond
10. Sep 2009
Echt schwach. Die bleiben echt der 3.10er Serie treu. Ich habe mit der DS215+ den 3.10.77 mit der aktueller DSM6.0.2 drauf. Die 3.10er hat ein EOL am Oct, 2017. Dann kommt die final vermutlich auch so in der Gegend raus. Das muss man ja schonmal ein bug melden.
Synology hätte auf:
3.16 mit EOL Apr, 2020
oder
4.4 mit EOL Feb, 2018
gehen MÜSSEN (siehe https://www.kernel.org/category/releases.html)
PsychoHH
03. Jul 2013
Kannst mir sagen wie du das genau meinst?
Achso mehrere Time Machine Ziele möglich, d.H. Keine virtuellen Maschinen klingt gut.
blinddark
03. Jan 2013
Bei mir läuft nach dem Update soweit alles. Sogar DVBLink, ich bin begeistert. Nur bei Plex hat er gemeckert. Da werde ich nachher mal eine manuelle Installation der 01.2.4 versuchen.
Matthieu
03. Nov 2008
PsychoHH
03. Jul 2013
1. Ich kann mit dem Script verschlüsselte Ordner noch per Keyfile automatisch mounten lassen.
Der Schlüsselspeicher ist auf einem extern angeschlossenen Gerät festgelegt + Passphrase.
Bietet für mich keinen Mehrwert, da habe ich lieber mein Keyfile auf einen Stick bzw. am entfernten Ort per VPN.
2. Time Backup wird deaktiviert und lässt sich nicht neu installieren es wird die Version 1.4.0-2450 verlangt.
Versionsnummer von der aktuellen auf die 1.4.0-2450 geändert und man kann es wieder installieren. Kommt hier vielleicht doch noch eine Version oder ist das eine "Scheinversion" um die Installation zu verbieten?!
3. JDownloader läuft
4. Unter SMB gibt es die Funktion btrfs schnellklonen? Neu?
5. Time Machine Einstellungen sind nun unter Dateidienste -> Diensterkennung und hier können tatsächlich mehrere
Ordner für Time Machine festgelegt werden, echt gut wenn man mehrere Geräte/Benutzer hat oder dies einfach auf verschiedene Platten haben will.
