Bookstack im Docker, Rechtevergabe
Kein Thema.
Melde dich halt morgen noch mal
cat
05. Jan 2023
Mist, schau mal:
230104 16:45:04 mysqld_safe Logging to '/config/databases/a7f5a3e12d3a.err'.
230104 16:45:04 mysqld_safe Starting mariadbd daemon with databases from /config/databases
[ls.io-init] done.
Caught SIGTERM signal!
[custom-init] No custom services found, skipping...
[migrations] started
[migrations] no migrations found
usermod: no changes
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
Brought to you by linuxserver.io
To support LSIO projects visit:
https://www.linuxserver.io/donate/
GID/UID
User uid: 1026
User gid: 100
[custom-init] No custom files found, skipping...
230105 12:05:43 mysqld_safe Logging to '/config/databases/a7f5a3e12d3a.err'.
230105 12:05:43 mysqld_safe Starting mariadbd daemon with databases from /config/databases
[ls.io-init] done.
usermod: no changes
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
GID/UID
User uid: 1026
User gid: 100
Warning: World-writable config file '/etc/my.cnf.d/custom.cnf' is ignored
230105 13:39:58 mysqld_safe Logging to '/config/databases/a7f5a3e12d3a.err'.
230105 13:39:58 mysqld_safe Starting mariadbd daemon with databases from /config/databases
[ls.io-init] done.
usermod: no changes
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
GID/UID
User uid: 1026
User gid: 100
230105 21:50:51 mysqld_safe Logging to '/config/databases/a7f5a3e12d3a.err'.
230105 21:50:51 mysqld_safe Starting mariadbd daemon with databases from /config/databases
[ls.io-init] done.
Ich melde mich morgen noch mal bei dir!
Kannst du mal noch die Einrichtung des mariaDB-Containers durchgeben?
Und wenn du den Stack noch hast, mit dem du bei dir die Container via portainer erstellt hast, den auch
cat
05. Jan 2023
Meinst du das hier:
docker run -d -p 8000:8000 -p 9000:9000 --name=portainer --restart=always -v /var/run/docker.sock:/var/run/docker.sock -v /volume1/docker/portainer:/data portainer/portainer
version: "2"
services:
bookstack:
image: linuxserver/bookstack container_name: bookstack environment:
- PUID=1026
- PGID-108
- DB_ HOST-bookstack db
- DB_USER-bookstack
- DB_PASS-password
- DB_DATABASE-bookstackapp volumes:
- /volume1/docker/bookstack: /config ports:
-8912:80
restart: unless-stopped depends on:
1 - bookstack_db bookstack_db:
image: linuxserver/mariadb container_name: bookstack_ db environment:
- PUID-1026
- PGID-100
- MYSQL_ROOT_PASSWORD-password
- TZ-America/Detroit
- MYSQL_DATABASE-bookstackapp
- MYSQL_USER-bookstack
- MYSQL_PASSWORD-password volumes:
-/volume1/docker/bookstack:/config restart: unless-stopped
So ganz stimmt das alles nicht bei dir.
Erstens hast du meist da wo ein "=" sein müsste, ein "-" stehen.
Also bei dir: PGID-108. Korrekt wäre aber PGID=108 und so weiter.
Und wieso verwendest du bei der MariaDB eine andere PGID als bei bookstack?
müsste bei dir ja eigentlich "DB_HOST=bookstack_db" heißen.
Dass DB_PASS falsch ist, hatte ich ja schon geschrieben.
In deinem PDF von gestern vom bookstack Container wird aber der Port 6875 verwendet und nicht 8192???
Das ist ein ziemliches Durcheinander.
Außerdem fehlt komplett die "APP_URL" beim bookstack Container. Das kann gar nicht funktionieren.
Gib mir mal folgende Infos und ich bau dir ein Installscript:
-IP deines NAS
-gewünschten Port für Bookstack
-deine Timezone (bist du tatsächlich in Detroit?)
cat
05. Jan 2023
Oh wow. Das ist echt sowas von cool von dir.
-IP deines NAS: 192.168.178.94
-gewünschten Port für Bookstack: hatte die 6875 gelassen. Aber an sich egal oder?
-deine Timezone (bist du tatsächlich in Detroit?): hä ne. Bin in Bad Saulgau, BW, Deutschland.
Oben in der Konfig hattest du ja folgendes stehen:
TZ-America/Detroit
Deswegen hatte ich gefragt.
Aber is ja jetz auch egal :ROFLMAO:
Mit dem Script, dass ich dir in den Anhang gepackt habe, habe ich bei mir erfolgreich eine Testumgebung aufsetzen können.
Sollte also bei dir auch so hinhauen.
Die PUID/PGID habe ich weggelassen, um das erstmal als Fehlerquelle auszuschließen. Damit das hinhaut, muss bei dir auf die Unterordner "bookstack" und "bookstackdb" für everyone R/W gesetzt sein (im docker-Share). Hattest du zwar schon bestätigt, dass das so ist, aber ich schreibe es dennoch noch mal. Wenn das so hinhauen sollte, kannst du ggfs. ja dieses Recht wieder entziehen und den Containern die PUID/PGID wieder hinzufügen, wenn du möchtest.
Diesen Stack packst du jetzt in den Portainer Stack Editor (siehe Anleitung Punkt 5 von mariushosting) und sagst dann Bescheid, ob es hinhaut.
  • Bookstack.txt
cat
05. Jan 2023
Habe den alten stack gelöscht und deinen neuen eingespielt. Alle Logs sehen gut aus.
Die Ordnerberechtigungen habe ich in der File Station auf Ebene des Verzeichnis "docker" für everyone auf R/W gesetzt inklusive aller Unterordner.
Fazit: in Safari kommt nach wie vor ein einfacher stiller weißer Screen.
Chrome ist da rabiater:
Diese Seite funktioniert nicht​
192.168.178.94 kann diese Anfrage momentan nicht verarbeiten.
HTTP ERROR 500
Ich bin ratlos. Muss ich vor dem Einspielen, die Container löschen?
Oder die Verzeichnisse in der File Station löschen und neu anlegen?
Jap. Lösche mal alle docker-Ordner, Images und Container, die du vorher angelegt hast.
Der Code 500 besagt: "Internal Server Error". Also kann der Container die Anfrage aufgrund eines Problems nicht beantworten. Dies liegt vermutlich an fehlerhaften Daten, die noch im Docker-Ordner liegen.
Wenn der Stack gestartet wurde, kann es dann auch einige Minuten dauern, bis die Weboberfläche erreichbar ist.
cat
05. Jan 2023
File Station: Ordner bookstack & bookstackdb gelöscht
Portainer: alle Images & Container (bis auf portainer) und Stack gelöscht.
gewartet....
File Station: Ordner bookstack & bookstackdb neu angelegt und nochmal nachgecheckt wegen R/W Rechte. Aus Verzweiflung für everyone "vollständige Kontrolle" eingerichtet.
Portainer: deinen Stack mit Berlin :) hochgeladen.
File Station: Ordner bookstack & bookstackdb wieder gefüllt
Container in Portainer wieder angelegt und running.
gewartet...
Safari, Chrome & Firefox : GEHT NICHT
Gibt es doch nicht oder?
Du hast da aber nix manuell reinkopiert, oder?
Das gibt es echt nicht. Mit welcher URL greifst du auf den Container zu?
Testweise mal DS Firewall ausgemacht?
Gibt es nun einen Fehler in den Container-Logs?
Und wenn nicht, werden dabei die (fehlgeschlagenen) Zugriffe geloggt?
cat
05. Jan 2023
Ne ne. Habe die Ordner nur angelegt und die waren leer. Nach dem ausgeführten stack von dir waren die wieder gefüllt. Installation hat also funktioniert.
Test mit ausgeschalteter Firewall hat auch nicht funktioniert. :(
Könnte es irgendwas mit dem Router zu tun haben? Irgendeine Einstellung da, die den Zugriff blockiert? Aber macht keinen Sinn. Bin ja im gleichen Netzwerk...
Hoffe, du hast noch eine Idee...
Wir haben grad zeitgleich gepostet.
Wie schon im Post vor dir gesagt, mal kurz die Logs prüfen.
Und: Mit welcher URL geifst du zu?
cat
05. Jan 2023
Habe die Logs kontrolliert. Du meinst schon die Logs, die in der Ansicht (Bild anbei) bei den Quick actions über das linke Symbol aufgerufen werden können oder? Da steht nicht viel drin und nein keine fehlgeschlagenen Zugriffe geloggt.
Ich gehe über die
http://192.168.178.94:6875/
oder oft über den Link in der Ansicht (Bild anbei)
Jap die meine ich. Versuche mal, den Slash am Ende wegzulassen
cat
05. Jan 2023
Habe vor 24 Minuten die Logs hochgeladen hier. Nachricht ist immer noch in Prüfung. sollte hoffentlich bald kommen.
ok. dann warten wir mal
cat
05. Jan 2023
Ohne slash geht auch nicht. Anbei die Logs
  • _bookstack_db_logs.txt
  • _Bookstack_logs 2.txt
