Die lieben Lüfter der 1512p
itari
15. Mai 2008
Ich habe die alte Datei leider nicht gespeichert, weshalb ich die Werte nicht vergleichen kann.
wenn es die Originaldatei war, dann ist sie natürlich in der Firmware-Installationsdatei vorhanden ... einfach mal entpacken und nachschauen (und vergleichen)
Itari
crick
29. Mai 2008
/usr/syno/etc.defaults/scemd.xml
<scemd>
        <fan_config period="20" threshold="6" type="DUAL_MODE_HIGH" hibernation_speed="UNKNOWN">
                <disk_temperature fan_speed="30%20hz"    action="NONE">0</disk_temperature>
                <disk_temperature fan_speed="40%20hz"    action="NONE">42</disk_temperature>
                <disk_temperature fan_speed="50%20hz"    action="NONE">47</disk_temperature>
                <disk_temperature fan_speed="60%20hz"    action="NONE">51</disk_temperature>
                <disk_temperature fan_speed="99%20hz"    action="ALERT_LED">53</disk_temperature>
                <disk_temperature fan_speed="99%20hz"    action="SHUTDOWN">61</disk_temperature>
                <cpu_temperature fan_speed="30%20hz"    action="NONE">0</cpu_temperature>
                <cpu_temperature fan_speed="50%20hz"    action="NONE">55</cpu_temperature>
                <cpu_temperature fan_speed="99%20hz"    action="ALERT_LED">80</cpu_temperature>
                <cpu_temperature fan_speed="99%20hz"    action="SHUTDOWN">95</cpu_temperature>
        </fan_config>
        <fan_config period="20" threshold="6" type="DUAL_MODE_LOW" hibernation_speed="UNKNOWN">
                <disk_temperature fan_speed="40%20hz"    action="NONE">47</disk_temperature>
                <disk_temperature fan_speed="50%20hz"    action="NONE">52</disk_temperature>
                <disk_temperature fan_speed="60%20hz"    action="NONE">56</disk_temperature>
                <disk_temperature fan_speed="99%20hz"    action="ALERT_LED">58</disk_temperature>
        </fan_config>
        <fan_config period="20" threshold="6" type="DUAL_MODE_LOW_STOP" hibernation_speed="UNKNOWN">
        </fan_config>
/usr/syno/etc/scemd.xml
<scemd>
        </fan_config>
        </fan_config>
        </fan_config>
Patch-Datei
<scemd>
		<disk_temperature fan_speed="30%40hz"    action="NONE">0</disk_temperature>
		<disk_temperature fan_speed="40%40hz"    action="NONE">42</disk_temperature>
		<disk_temperature fan_speed="50%40hz"    action="NONE">47</disk_temperature>
		<disk_temperature fan_speed="60%40hz"    action="NONE">51</disk_temperature>
		<disk_temperature fan_speed="99%40hz"    action="ALERT_LED">53</disk_temperature>
		<disk_temperature fan_speed="99%40hz"    action="SHUTDOWN">61</disk_temperature>
		<cpu_temperature fan_speed="30%40hz"    action="NONE">0</cpu_temperature>
		<cpu_temperature fan_speed="50%40hz"    action="NONE">55</cpu_temperature>
		<cpu_temperature fan_speed="99%40hz"    action="ALERT_LED">80</cpu_temperature>
		<cpu_temperature fan_speed="99%40hz"    action="SHUTDOWN">95</cpu_temperature>
	</fan_config>
		<disk_temperature fan_speed="40%40hz"    action="NONE">47</disk_temperature>
		<disk_temperature fan_speed="50%40hz"    action="NONE">52</disk_temperature>
		<disk_temperature fan_speed="60%40hz"    action="NONE">56</disk_temperature>
		<disk_temperature fan_speed="99%40hz"    action="ALERT_LED">58</disk_temperature>
	</fan_config>
	</fan_config>
crick
29. Mai 2008
So wie es scheint, wurde mit der DSM 4.0 2219 Version der Patch inkludiert.
Ken Ishi
09. Apr 2012
Hallo, Crick,
ich habe eine 1512 mit neuster Firmware und mir kommen die Lüfter viel zu laut vor. Auch bei mir steht die DS neben mir auf dem Schreibtisch.
In deinem ersten Post hast du die Noiseblocker XC1 ausprobiert. Ist hier die Temperatur auf einen kritischen Wert geklettert. Du schreibst ja nur dass dir der Luftstrom zu gering vorkam.
Laut Specs haben die NB sogar eine höhere Fördermenge bei 50% weniger Lautstärke.
Kannst du hierzu noch etwas sagen ?
Grüße Ken Ishi
crick
29. Mai 2008
Ja, mit der neusten Firmware wurden die Umdrehungen der Luefter erhoeht. Dadurch lauter.
Die Noiseblocker XC1 gaben bei mir keinen Error aus, aber ich habe sie nicht einmal zwei Minuten drin gelassen, da mir die Leistung zu gering erschien. Ich verstehe nicht ganz, weshalb die NAS sie nicht hoeher regelt. Leiser sind die CX1 aber definitiv! Ich bin bei meinen Stations nie der Modding-Freund gewesen. Eventuell werde ich es bei Gelegenheit doch mal testen. Die Temperaturen sind seit den neuen Festplatten laut DSM auf ~44°C im idle gesunken.
donie
27. Apr 2012
Musste echt machen.
denke anders wirds nicht klappen.
TheDopeofLife
13. Apr 2012
Jap sind die.
Hab sie auch hier liegen aber noch nicht eingebaut, da mir die zeit fehlt.
Tscherno
29. Mrz 2008
Tausch eben erfolgt. Ergebnis: Der Wahnsinn. Lautstärketechnisch uneingeschränkt empfehlenswert. Temperaturtechnisch kann ich momentan noch keine Aussage treffen, da ich zwei defekte Platten geliefert bekommen habe und daher nur mit einer laufe.
TheDopeofLife
13. Apr 2012
Hehe hab sie "dank" Krankheit auch eingebaut ^^
Thermal Status im DSM sagt bei mir im idle 49 Grad (vorher 45 Grad) und die HD204UI sind im idle zwischen 29 und 31 Grad (vorher 27-29 Grad).
Man hört praktisch nur noch das Spinning der Platten :)
crick
29. Mai 2008
Da ich die Luefter auch noch herumliegen habe, wuerde ich mich freuen, wenn Ihr weiterhin die Temperaturen ueberprueft, was ja sowieso empfehlenswert ist und die Daten durchgebt. Das sie viel leiser sind habe ich in einem Test auch schon gemerkt, allerdings merkte man auch, dass sie langsamer drehen und daher nicht so performant kuehlen. Die Frage ist, ob es noch im Rahmen ist, oder man versuchen sollte, die Drehzahl an zu heben (scemd.xml).
Marst
28. Jan 2012
Ich schließe mich an, berichtet bitte wie sich die Temperaturen verhalten.
Meine aktuellen Temperaturen der DS1512+ & 3 HDDs: (alles im Original Zustand!)
DiskStation => 41°C
WD10EAVS => 30°C
WD25EZRX => 30°C
WD30EZRX => 31°C
Laufzeit: 18:31:10 Stunden
Welche Temperaturen sollten Festplatten max. haben? Habe mal etwas von 40°C gelesen...
crick
29. Mai 2008
Alles original im idle, aber ohne Ruhezustand (deaktiviert):
DS: 42°C
5x WD20EARX: 29°C
Laufzeit: 31 Tage
Allerdings waren die Temperaturen der DS, nicht HDDs, vor dem Sommer niedriger (~38°C). DS steht normal auf einem Schreibtisch im Buero.
Weiterhin habe ich bemerkt, dass die Temperaturen wohl niedriger sind, desto mehr Festplatten drin stecken. Ich vermute, dass mit voller Bestueckun der "Kuehlluft-Strom" besser durchzieht.
Fakt ist, dass es schwierig ist zu vergleichen. Je nach Standort, Jahreszeit, Festplatten, Belastung im Idle, Ruhemodus ja/nein und warscheinlich auch von DS1512+ zu DS1512+ variieren die Temperaturen. Daher wäre es am besten, wenn einer mit Original-Lueftern die Werte notiert und dann die XC1-Kuehler einbaut und die Temperaturen dann vergleicht.
Ich kann nur wiederholen, dass der XC1 wesentlich leiser ist, jedoch (zumindest ohne Eingriff in die Lueftersteuerung) auch fuer weniger Zirkulation sorgen, da die Drehzahlen wohl geringer sind.
Je nach Hersteller und Modell werden unterschiedliche Temperaturen "freigegeben" sein, aber man kann sagen, dass so lange eine HDD nicht dauerhaft ueber 60°C hat, nichts passieren sollte.
Marst
28. Jan 2012
Dann werde ich mir einfach die Lüfter bestellen und schauen was passiert :) Sonst kommen wir hier wahrscheinlich nie zu einen vernünftigen Ergebnis :(
crick
29. Mai 2008
Löblich. Ich warte gespannt. Am besten jetzt schon ab und zu die Temperaturen notieren, damit man dann einen Durchschnitt ermitteln kann, wenn die neuen Luefter da sind.
Tag1: X Grad
Tag2: Y Grad
Tag3: Z Grad
Beispiel:
(X+Y+Z) : 3 = durchschnittliche Temperatur innerhalb von 3 Tagen
.. dann die Temperaturen der neuen Luefter durchgeben.
hector
26. Mrz 2012
Wo liegt denn die Temperatur mit Serienlüfter im Idle-Mode?
Ich habe aktuell nur eine Platte drin (5x2TB warten noch auf ihren Einbau) und die Temperatur meiner DS liegt aktuell bei 54°C! Egal, ob "Kühlmodus" oder "stiller Modus". Die HDD-Temp liegt bei ca. 30°C.
Marst
28. Jan 2012
Schau dir meinen und tricks Post weiter oben an, da siehst du wie unsere DS mit den Serienlüfter laufen.
54°C ist eigentlich zu warm, vll erstellt deine DS noch Vorschaubilder so?!
hector
26. Mrz 2012
Nein, Idle! Es handelt sich doch um jene Temperatur, die man in den Systeminformationen unter "Thermal Status" ablesen kann, oder?
EDIT: Die Kühlkörper sind gerade mal handwarm. Fühlt sich nicht wie annähernd 50°C an.
EDIT2: Auch nach einem Reset und Neuaufspielen der Firmware ohne weitere Pakete keine Temperaturänderung.
Marst
28. Jan 2012
Richtig, Systeminformationen und da auf die zwei virtuellen LEDs schauen, da bekommst du die Temperatur angezeigt.
Handwar ist OK. Hat deine DS von vorn Freiraum um die Luft zirkulieren zu lassen?
hector
26. Mrz 2012
@Marst: Jau, klar! Ich habe zwischenzeitlich Kontakt zum Support und habe denen mein Kernel-Log geschickt.
Wenn die DS kalt ist und ich sie starte, hat sie schon nach einer Minute Betriebszeit 42°C. Und steigt dann weiter auf 53-54°C.
