- 30. Dez. 2012
Maybe raw48:54 is not correct for my IronWolf drives? But I have no idea what other raw settings to try.
ok, very interesting, but no idea from my side?
smartctl -ia -v 1,raw48:54 -v 7,raw48:54 -v 195,raw48:54 /dev/sda
smartctl 6.5 (build date Sep 26 2022) [x86_64-linux-4.4.302+] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Iron Wolf PRO
Device Model: ST6000NE000-2KR101
Serial Number: WKD02NQB
LU WWN Device Id: 5 000c50 0cbf65a7f
Firmware Version: EN01
User Capacity: 6,001,175,126,016 bytes [6.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: Unknown(0x0fe0) (minor revision not indicated)
SATA Version is: SATA >3.2 (0x1ff), 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Jan 2 10:03:36 2025 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 567) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 580) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x50bd) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
3 Spin_Up_Time 0x0003 087 085 000 Pre-fail Always - 0
4 Start/Stop_Count 0x0032 100 100 020 Old_age Always - 795
5 Retired_Sectors_Count 0x0033 100 100 010 Pre-fail Always - 0
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 4829
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Drive_Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 334
18 Read_Error_Rate_Self-Test 0x000b 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrectables 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout_Count 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature 0x0022 071 047 040 Old_age Always - 29 (Min/Max 19/29)
192 Emergency_Retract_Counnt 0x0032 100 100 000 Old_age Always - 51
193 Load/Unload_Count 0x0032 099 099 000 Old_age Always - 3905
194 Temperature 0x0022 029 053 000 Old_age Always - 29 (0 15 0 0 0)
197 Pending-Sparing_Count 0x0012 100 100 000 Old_age Always - 0
198 Uncorrectable_Sectors_Count 0x0010 100 100 000 Old_age Offline - 0
199 Ultra_DMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flight_Hours 0x0000 100 253 000 Old_age Offline - 76450417873174
241 Lifetime_Writes_From_Host 0x0000 100 253 000 Old_age Offline - 50122403769
242 Lifetime_Reads_From_host 0x0000 100 253 000 Old_age Offline - 162915700421
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 4163 -
# 2 Short offline Completed without error 00% 4149 -
# 3 Short offline Completed without error 00% 4138 -
# 4 Short offline Completed without error 00% 4130 -
# 5 Short offline Completed without error 00% 4115 -
# 6 Short offline Completed without error 00% 4070 -
# 7 Extended offline Completed without error 00% 4050 -
# 8 Short offline Completed without error 00% 4039 -
# 9 Short offline Completed without error 00% 4027 -
#10 Extended offline Completed without error 00% 4012 -
#11 Short offline Completed without error 00% 4003 -
#12 Short offline Completed without error 00% 3867 -
#13 Short offline Completed without error 00% 3843 -
#14 Short offline Completed without error 00% 3819 -
#15 Short offline Completed without error 00% 3795 -
#16 Short offline Completed without error 00% 3771 -
#17 Short offline Completed without error 00% 3747 -
#18 Short offline Completed without error 00% 3723 -
#19 Short offline Completed without error 00% 3699 -
#20 Short offline Completed without error 00% 3675 -
#21 Short offline Completed without error 00% 3651 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Nein, der wurde definitiv neu aufgesetzt.Wurde der Speicherpool migriert?
Filesystem Size Used Avail Use% Mounted on
/dev/md0 7.9G 1.5G 6.3G 20% /
devtmpfs 16G 0 16G 0% /dev
tmpfs 16G 244K 16G 1% /dev/shm
tmpfs 16G 26M 16G 1% /run
tmpfs 16G 0 16G 0% /sys/fs/cgroup
tmpfs 16G 29M 16G 1% /tmp
/dev/loop0 27M 767K 24M 4% /tmp/SynologyAuthService
/dev/mapper/cryptvol_1 849G 83G 767G 10% /volume1
/dev/mapper/cryptvol_2 1.8T 1.3T 507G 72% /volume2
/dev/mapper/cryptvol_3 11T 3.8T 6.7T 37% /volume3
/dev/mapper/cryptvol_3 11T 3.8T 6.7T 37% /volume3/ActiveBackup/#snapshot
tmpfs 1.0T 0 1.0T 0% /dev/virtualization
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 32M 0 loop /tmp/SynologyAuthService
sda 8:0 0 5.5T 0 disk
├─sda1 8:1 0 8G 0 part
│ └─md0 9:0 0 8G 0 raid1 /
├─sda2 8:2 0 2G 0 part
│ └─md1 9:1 0 2G 0 raid1 [SWAP]
└─sda3 8:3 0 5.4T 0 part
└─md4 9:4 0 10.9T 0 raid10
├─vg3-syno_vg_reserved_area 249:2 0 12M 0 lvm
└─vg3-volume_3 249:3 0 10.9T 0 lvm
└─cachedev_0 249:6 0 10.9T 0 dm
└─cryptvol_3 249:9 0 10.9T 0 crypt /volume3/ActiveBackup/#snapshot
/volume3
sdb 8:16 0 5.5T 0 disk
├─sdb1 8:17 0 8G 0 part
├─sdb2 8:18 0 2G 0 part
└─sdb3 8:19 0 5.4T 0 part
/volume3
sdc 8:32 0 5.5T 0 disk
├─sdc1 8:33 0 8G 0 part
├─sdc2 8:34 0 2G 0 part
└─sdc3 8:35 0 5.4T 0 part
/volume3
sdd 8:48 0 5.5T 0 disk
├─sdd1 8:49 0 8G 0 part
├─sdd2 8:50 0 2G 0 part
└─sdd3 8:51 0 5.4T 0 part
/volume3
sdf 8:80 0 894.3G 0 disk
├─sdf1 8:81 0 8G 0 part
├─sdf2 8:82 0 2G 0 part
└─sdf3 8:83 0 884G 0 part
└─md3 9:3 0 884G 0 raid1
├─vg2-syno_vg_reserved_area 249:4 0 12M 0 lvm
└─vg2-volume_1 249:5 0 884G 0 lvm
└─cachedev_1 249:7 0 884G 0 dm
└─cryptvol_1 249:10 0 884G 0 crypt /volume1/@docker/btrfs
/volume1/@docker
/volume1
synoboot 135:240 0 120M 0 disk
├─synoboot1 135:241 0 16M 0 part
└─synoboot2 135:242 0 100M 0 part
zram0 248:0 0 4.7G 0 disk [SWAP]
zram1 248:1 0 4.7G 0 disk [SWAP]
zram2 248:2 0 4.7G 0 disk [SWAP]
zram3 248:3 0 4.7G 0 disk [SWAP]
nvme1n1 259:0 0 1.8T 0 disk
├─nvme1n1p1 259:3 0 8G 0 part
├─nvme1n1p2 259:5 0 2G 0 part
└─nvme1n1p3 259:7 0 1.8T 0 part
└─md2 9:2 0 1.8T 0 raid1
├─vg1-syno_vg_reserved_area 249:0 0 12M 0 lvm
└─vg1-volume_2 249:1 0 1.8T 0 lvm
└─cachedev_2 249:8 0 1.8T 0 dm
└─cryptvol_2 249:11 0 1.8T 0 crypt /volume2
nvme0n1 259:1 0 1.8T 0 disk
├─nvme0n1p1 259:2 0 8G 0 part
├─nvme0n1p2 259:4 0 2G 0 part
└─nvme0n1p3 259:6 0 1.8T 0 part
It's not totally dependent on the year the NAS was released. It depends on if the NAS uses device tree or not.Ok, da muss ich nochmals gezielter nachfragen. Auf der DS1621xs+ ist es ebenfalls sda usw.
Ab welcher Modellreihe geht es mit sata1 usw. los?
Device Model: ST12000NM0127
Serial Number: ZJV5ZZZZ
LU WWN Device Id: 5 000000 0000000a
Firmware Version: G006
User Capacity: 12,000,138,625,024 bytes [12.0 TB]
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Jan 2 13:32:01 2025 CET
been run.
command.
power-saving mode.
recommended polling time: (1102) minutes.
1 Raw_Read_Error_Rate 0x000f 100 064 044 Pre-fail Always - 0
3 Spin_Up_Time 0x0003 097 097 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 3
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 072 060 045 Pre-fail Always - 0
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 979
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 3
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 068 065 040 Old_age Always - 32 (Min/Max 31/35)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 29
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 41
194 Temperature_Celsius 0x0022 032 040 000 Old_age Always - 32 (0 22 0 0 0)
195 Hardware_ECC_Recovered 0x001a 100 004 000 Old_age Always - 0
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0023 100 100 001 Pre-fail Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 971 (37 209 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 8806492498
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 4897028775
No Errors Logged
# 1 Short offline Completed without error 00% 423 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Serial Number: ZJVZZZZZ
LU WWN Device Id: 5 000000 00000000c
Local Time is: Thu Jan 2 13:34:58 2025 CET
been run.
command.
power-saving mode.
recommended polling time: (1098) minutes.
1 Raw_Read_Error_Rate 0x000f 084 064 044 Pre-fail Always - 0
3 Spin_Up_Time 0x0003 094 094 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 5
7 Seek_Error_Rate 0x000f 071 060 045 Pre-fail Always - 0
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 1003
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 5
190 Airflow_Temperature_Cel 0x0022 066 062 040 Old_age Always - 34 (Min/Max 32/37)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 18
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 43
194 Temperature_Celsius 0x0022 034 040 000 Old_age Always - 34 (0 22 0 0 0)
195 Hardware_ECC_Recovered 0x001a 007 004 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 996 (95 216 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 8841798407
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 8312108904
No Errors Logged
# 1 Short offline Completed without error 00% 447 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Hier sollte man vielleicht noch anmerken, daß dieser Händler die gleichen HDDs (Seagate Enterprise 12 TB) auch im Amazon Webshop eingestellt hatte, dort etwa 5% teurer als auf der eigenen Webseite, dafür aber mit der Anmerkung “refurbished“. Zudem bot der Händler auf der eigenen Webseite zeitgleich andere HDDs als refurbished an.JB-Computer, die in den Diskussionen im Forum zum Teil als "refurbished" bezeichnet wurden, allerdings vom Händler als neu deklariert wurden.
Vendor: WDC
Product: WD40EFRX-68N32N0
Revision: 82.0
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Logical block size: 512 bytes
Physical block size: 4096 bytes
LU is fully provisioned
Rotation Rate: 5400 rpm
Logical Unit id: 0x50014ee21ffe9139
Serial number: WD-WCC7K1ZZZ8PE
Device type: disk
Local Time is: Thu Jan 2 17:56:20 2025 CET
SMART support is: Unavailable - device lacks SMART capability.
Current Drive Temperature: 0 C
Drive Trip Temperature: 0 C
Error Counter logging not supported
[GLTSD (Global Logging Target Save Disable) set. Enable Save with '-S on']
Device does not support Self Test logging
