j-Serie DS215j wacht alle 60 Minuten auf!
ckals90
11. Jun 2015
habe eben diesen Beitrag gefunden und wie ich denke das selbe Problem siehe Log
Stufe	Protokoll	Datum & Zeit	Benutzer	Ereignis
info	System	2015/06/22 19:03:27	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 18:48:43	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 18:21:33	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 18:00:52	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 17:29:36	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 16:58:18	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 16:27:01	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 15:55:43	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 15:24:23	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 15:12:32	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 14:53:09	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 14:21:51	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 13:50:34	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 13:19:16	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 12:44:20	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 12:16:41	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 11:45:24	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 11:14:07	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 10:56:52	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 10:42:46	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 10:30:53	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 10:11:32	SYSTEM	Internal disks woke up from hibernation.
info	System	2015/06/22 09:23:50	Christoph	HDD hibernation time is set to [10 Minuten].
info	System	2015/06/22 09:23:50	Christoph Auto poweroff time is set to [30 Minuten].
info	System	2015/06/22 06:31:53	SYSTEM	[Cloud Sync] service was started.
info	System	2015/06/22 06:31:37	SYSTEM	System successfully registered [IPADRESS] to [????.synology.me] in DDNS server [Synology].
info	System	2015/06/22 06:31:31	SYSTEM	System successfully registered [IPADRESS] to [????.synology.me] in DDNS server [Synology].
info	System	2015/06/22 06:31:29	SYSTEM	System started to boot up.
Es handelt sich dabei um eine DS415play, unter dem Tag ist niemand zuhause und kein Client eingeschaltet.
Habe jetzt mal IPv6 ausgeschaltet und den internen NTP-Dienst.Wenn dass nicht hilft werde ich auch noch den NTP-Client zum Zeitabgleich deaktivien.
Mal sehen was es bringt bzw ob es besser wird....
Ein gutes hat es zumindest: ich bin mit diesem Problem wohl nicht allein...
peterhoffmann
17. Dez 2014
Ich habe das Problem erst mal gelöst, aber ich weiß nicht 100%ig wer der Übeltäter ist/war.
Was habe ich gemacht:
  • IPv6 abgeschaltet
  • NTP Server synchronisieren blieb eingeschaltet
  • Audio Station deinstalliert
  • Photo Station deinstalliert
  • Video Station deinstalliert
  • Cloud Station deinstalliert
  • Cloud Sync angehalten
Seit dem schläft sie brav.
Puppetmaster
03. Feb 2012
Wenn man mehr als einen Parameter gleichzeitig ändert, kann man nie wissen, was die Ursache war. ;)
Davon ab ist CloudSync aber ein üblicher Verdächtiger.
pigeldi
19. Mai 2015
So, Kommando zurück.
Ich dachte ja bisher, das Problem könnte im Netzwerk liegen, weil das NAS meinem Test mit abgezogenem Netzwerkkabel nicht aufgewacht ist. Das war aber scheinbar nur Glück, so wie sie ja auch sonst ab und zu mal einen guten Tag hat, und brav schläft. Heute habe ich das Netzwerkkabel erneut abgezogen, und sie ist aufgewacht! Sogar nachdem ich sie aus- und wieder eingeschaltet habe.
Damit liegt der Fehler doch intern. An Paketen sind nur PhotoStation und VideoStation aktiv.
IPv6 ist aus.
NTP-Zeitabgleich ist aus.
Das kann man nur leider auch so nicht, denn das Problem ist nicht eindeutig reproduzierbar, irgendwas läuft intern einfach verkehrt in dem Ding!:mad:
pigeldi
19. Mai 2015
Ich kann das Thema fast schon nicht mehr hören. Wenn solche unerwünschten Aufwachvorgänge stattfinden, sucht doch einfach mal nach Dateien, die kürzlich (hier 5 Minuten) aktualisiert wurden, z.B. mit
find / -mmin -5 | grep -v /proc | grep -v /sys | grep -v /run | grep -v /tmp | grep -v /dev
Die Latte an "grep -v" schliesst Dateien auf der RAM-Disk und Devices aus (das geht sicherlich auch eleganter, aber was soll's).
Da muss doch was zu finden sein.
Habe das gerade mal ausgeführt, nachdem die Synology ohne Netzwerkverbindung aufgewacht ist. Dann sag mir mal bitte, was du da findest:
syno> find / -mmin -10 | grep -v /proc | grep -v /sys | grep -v /run | grep -v /
tmp | grep -v /dev
/etc
/etc/iproute2/config
/etc/iproute2/config/resolv4.conf
/etc/iproute2/config/gateway_database
/etc/iproute2/config/gateway_v4_priority
/etc/init
/etc/inetd.conf
/etc/firewall_rules_security.dump
/etc/firewall_6_rules_security.dump
/etc/firewall_rules.dump
/etc/firewall_6_rules.dump
/usr/syno/bin
/usr/syno/etc
/usr/syno/etc/snmpd.conf
/usr/syno/etc/synorelayd
/usr/syno/etc/synorelayd/services.conf
/usr/syno/etc/synorelayd/synorelayd.conf
/usr/syno/etc/synorelayd/env.conf
/usr/syno/etc/codesign/keyinfo-user
/usr/syno/etc/codesign/VERSION
/usr/syno/etc/codesign/.gnupg
/usr/syno/etc/codesign/.gnupg/pubring.gpg
/usr/syno/etc/codesign/.gnupg/pubring.gpg~
/usr/syno/etc/private
/usr/syno/etc/private/session/current.users.access.time
/usr/syno/etc/private/secrets.tdb.bkp
/usr/syno/etc/synoservice.override
/usr/syno/etc/synoservice.override/telnetd.cfg
/usr/syno/etc/synoservice.override/ssh-shell.cfg
/usr/syno/etc/preference/admin
/usr/syno/etc/preference/admin/appnotify
/usr/syno/etc/preference/master
/usr/syno/etc/preference/master/usersettings
/usr/syno/etc/preference/master/appnotify
/usr/syno/etc/preference/master/bkgtask
/usr/syno/etc/snmpd.conf.bak
/usr/syno/synoman/synoSDSjslib
/usr/syno/synoman/synoSDSjslib/sds.css
/usr/syno/synoman/scripts/ext-3.4/ux
/usr/syno/synoman/scripts/ext-3.4/ux/ux-all.css
/usr/syno/synoman/webman/resources/css
/usr/syno/synoman/webman/resources/css/desktop.css
/var/log/samba/log.nmbd
/var/log/samba/log.smbd
/var/log/upstart/smbd.log
/var/log/upstart/nmbd.log
/var/log/upstart/telnetd.log
/var/log/upstart/ssh-shell.log
/var/log/upstart/sshd.log
/var/log/upstart/ssh-sftp.log
/var/log/kern.log
/var/log/messages
/var/log/synoservice.log
/var/log/scemd.log
/var/log/synolog
/var/log/synolog/synosys.log
/var/log/synolog/.SYNOACCOUNTDB
/var/log/synolog/synoconn.log
/var/log/synolog/.SYNOSYSLOGDB-wal
/var/log/synolog/.SYNOSYSLOGDB-shm
/var/log/router.log
/var/log/ash_history.log
/var/lib
/var/lib/samba
/var/lib/samba/share_info.tdb.bkp
/var/lib/samba/registry.tdb.bkp
/var/lib/samba/group_mapping.tdb
/var/lib/samba/account_policy.tdb.bkp
/var/lib/logrotate.status
/var/cache/samba/smbXsrv_version_global.tdb
/var/cache/samba/smbXsrv_session_global.tdb
/var/cache/samba/smbXsrv_tcon_global.tdb
/var/cache/samba/notify_index.tdb
/volume1/@tmp
/volume1/@tmp/pkglist.tmp
/volume1/@tmp/pkglist.tmp/synoserver.ger
/volume1/@tmp/pkglist.tmp/otherserver.ger
Puppetmaster
03. Feb 2012
Vielleicht sollte man sich einfach mal von der naiven Ansicht verabschieden, dass ein Rechner, auf dem die verschiedensten Dienste und Pakete laufen und in einem Netzwerk eingebunden ist, einen permanent funktionierenden Ruhezustand besitzen kann.
Es gibt allein im DSM ein gutes Dutzend (sinnvoller) Einstellungen, die sich mit einem permanenten Ruhezustand gar nicht vereinbaren lassen.
Und in den Paketen ist es nicht anders.
ds_112
12. Aug 2013
Das hat mal jemand geschrieben, damit gebe ich Ihm Recht :D
"Ein NAS ist kein Kaffeevollautomat, der sich abschaltet, wenn nach 30min kein Kaffee gezogen wird. Es ist ein Computer, der verschiedene Dienste zur Verfügung stellt. Manche kannst Du beeinflussen, wie z.B. den Zugriff von Deinem Rechner, manche nur eingeschränkt, andere gar nicht. Wenn das Betriebssystem des NAS der Meinung ist, irgendwas auf den Platten zu lesen/schreiben/prüfen/Cloud/Mediaserver/sonstwas, dann wird er das tun - unabhäng davon, ob Du gerade auf einen Share zugreifst. Es gibt auch Aufgaben zu erledigen, wenn gerade kein LAN-Link besteht.
Solltest also überlegen, Dich nicht mit einer Stoppuhr danebenzusetzen und drauf zu warten, dass die Platten runtergefahren werden, sondern das Ding einfach benutzen."
Lass sie für den Test ruhig mal am Netzwerk und wiederhole es.
Wenn du sie nähmlich erst noch mit dem Netzwerk verbinden musst, wird natürlich noch viel mehr ausgeführt, als das, was zum Aufwachen geführt hat.
Insofern ist die Ausgabe dann nutzlos.
pigeldi
19. Mai 2015
Es geht hier nicht um permanent funktionierend. Ich beschwere mich nicht darüber, dass das NAS ab und zu mal aufwacht, weil irgendwo im Netzwerk ein PC angeschaltet wird und nach Netzwerkquellen scannt.
Wenn aber ein NAS, ohne überhaupt mit dem Netzwerk verbunden zu sein, und ohne dass ich darauf irgendwelche Aufgaben eingeplant habe, exakt alle 60 Minuten aufwacht, dann ist da in der Software etwas nicht in Ordnung. Nenn mich naiv, aber ich erwarte, dass die Entwickler so etwas im Griff haben, vor allem wenn so ein Feature beworben wird. Auch auf meinem Windows 7 PC laufen diverse Mediaserver, BT Sync, usw., aber selbst da bleiben die Festplatten braver im Ruhezustand und der PC wird nicht am automatischen Einschlafen gehindert, als dies momentan bei meiner Synology der Fall ist.
Ist ja prima, dass du dich damit arrangiert hast, ich möchte mir den Stromverbrauch und die Belastung der Festplatten ersparen, wenn es überhaupt keinen Grund dafür gibt. Ich aktzeptiere, dass gewisse Pakete das NAS nicht schlafen lassen, aber wenn ich diese nicht nutze, dann hat das Gerät bei Nichtverwendung Ruhe zu geben.
@Benares: Versuche ich bei nächster Gelegenheit, mal sehen ob die Liste dann deutlich kürzer ist.
Frogman
01. Sep 2012
..., und ohne dass ich darauf irgendwelche Aufgaben eingeplant habe, exakt alle 60 Minuten aufwacht, dann ist da in der Software etwas nicht in Ordnung....
DU bist aber nur einer derjenigen auf dem System, der Aufgaben erledigen läßt.
Was läuft denn sonst so? QuickConnect? NTP-Dienst (damit meine ich nicht die regelmäßige NTP-Aktualisierung)?
pigeldi
19. Mai 2015
So, hier erneut der Befehl kurz nach dem Aufwachen, nun steht nicht mehr viel da:
syno> find / -mmin -5 | grep -v /proc | grep -v /sys | grep -v /run | grep -v /t
mp | grep -v /dev
/var/log/kern.log
/var/log/messages
/var/log/scemd.log
/var/log/synolog
/var/log/router.log
/var/lib
Da scheinen ausschließlich Logs geschrieben zu werden?!
Kein NTP-Dienst. QuickConnect läuft. Habe ich jetzt testweise auch mal deaktiviert und neu gestartet, wobei ich das meiner Erinnerung nach schon mal deaktiviert hatte.
Ansonsten SMB und Webdav, PhotoStation, das war es aber quasi auch schon, bisher macht das NAS nicht viel.
Frogman
01. Sep 2012
Die hier erscheinen mir am interessantesten um deren Inhalt kurz nach dem Aufwachen mal zu kontrollieren.
 /var/log/synolog/synoconn.log <- deine ssh-Verbindung der letzte Eintrag?
 /var/log/router.log <- gibt's bei mir nicht. Was steht drin?
pigeldi
19. Mai 2015
synoconn.log: Ja, meine Verbindung:
51 SYSTEM: User [root] from [192.168.1.77] logged in successfully via [SSH].
22 SYSTEM: User [root] from [192.168.1.77] logged in successfully via [SSH].
20 SYSTEM: User [root] from [192.168.1.77] logged in successfully via [SSH].
router.log:
2015/06/28 15:26:41 UPnP init: lock
2015/06/28 15:26:41
2015/06/28 15:26:41
2015/06/28 15:26:41
2015/06/28 15:26:41 (libupnpclient.c:530) SEARCH_RESULT [urn:schemas-upnp-org:s
2015/06/28 15:26:42 (libupnpclient.c:480) URLBase: http://192.168.1.1:49000
2015/06/28 15:26:42 UPnP init: unlock
2015/06/28 15:26:42 Upnpd - Normal Loop.
192.168.1.1 ist mein Router. Versucht das NAS da stündlich über UPnP irgendwelche Einstellungen am Router zu ändern?
Frogman
01. Sep 2012
Hast Du Deinen Router denn im DSM zur Konfiguration eingetragen? Falls ja - deaktivieren. Ist ein unnötiges Sicherheitsrisiko!
Siehst du, wir nähern uns dem Problem. Das ist doch schonmal ein wertvoller Hinweis. Hast du unter Systemsteuerung, Externer Zugriff, Routerkonfiguration irgendwas eingerichtet/aktiv?
Wenn ja, wie von Frogman bereits vorgeschlagen: Lösch das mal.
pigeldi
19. Mai 2015
Im Router ist UPnP deaktiviert, eben weil ich da selbst die Kontrolle über freigegebene Ports haben will.
Im DSM sind im besagten Menü alle benötigten Ports eingetragen (wobei z.B. Cloud Station aktuell nicht benötigt wird), aber das müssen sie doch nach meinem Verständnis auch, oder? Zumindest sagt das für mich auch die Hilfe aus, dass hier alle Ports stehen müssen, über die man auf das NAS zugreifen will:
Wenn Ihr Synology NAS sich in einem lokalen Netzwerk befindet, können sich keine anderen Geräte im Internet damit verbinden. Unter Systemsteuerung > Externer Zugriff > Routerkonfiguration können Sie Portweiterleitungsregeln festlegen, damit Synology NAS über das Internet zugänglich ist.
Sprich hier stehen die Ports, in der Fritzbox trage ich sie manuell ein, und dann kann ich drauf zugreifen. Oder interpretiere ich das falsch, und dieses Menü muss komplett leer sein wenn ich kein UPnP nutze, ich kann aber dann dennoch über die freigeschalteten Ports drauf zugreifen?
hopeless
18. Feb 2013
Da braucht nichts stehen, du machst das doch manuell in der FB.
Frogman
01. Sep 2012
Wenn Du dort etwas einträgst, wird das zu den Versuchen führen, den Router zu erreichen, um sie dort per UPnP einzutragen - was regelmäßig scheitert, weil das dort deaktiviert ist. Riecht sehr stark nach dem stündlichen Versuch ;) - lösche das mal (ist eben völlig überflüssig, hopeless hat's ja auch schon geschrieben) und schaue, ob damit das Thema erledigt ist.
peterhoffmann
17. Dez 2014
Auch wenn hier manche was von einer Nichtkaffeemaschine und viel beschäftigter Computer ins Feld führen, das sind Beruhigungstabletten, die man nicht schlucken braucht.
Es funktioniert, meine DS215j hat die letzten Monate brav geschlafen und nun seit Mitte letzter Woche auch wieder zuverlässig. Es lohnt sich da auch am Ball zu bleiben, der Stromverbrauch ist um ca. 40% gesunken.
Man sieht sehr eindeutig, dass ab Mittwoch Nachmittag das Schlafen wieder funktioniert hat.
