Nummer Serie DS413 - "Sie können sich nicht an das System anmelden, da der Speicherplatz voll ist"
Semenchkare
15. Dez 2015
also jetzt 57%, 14M weniger auf /dev/md0
xxxxxx@DS220plus:~$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 2.3G 1.3G 967M 57% /
none 4.8G 0 4.8G 0% /dev
/tmp 4.8G 1.7M 4.8G 1% /tmp
/run 4.8G 3.8M 4.8G 1% /run
/dev/shm 4.8G 4.0K 4.8G 1% /dev/shm
none 4.0K 0 4.0K 0% /sys/fs/cgroup
cgmfs 100K 0 100K 0% /run/cgmanager/fs
/dev/vg1000/lv 5.5T 1.3T 4.2T 23% /volume1
/dev/md3 5.5T 2.1T 3.4T 39% /volume2
Sehe ich die Verzeichnisse an, keine Veränderung...
xxxxxx@DS220plus:~$ sudo du -xhd 1 / | sort -h -r
1.2G /
844M /usr
244M /var
22M /.syno
11M /etc
8.7M /etc.defaults
7.2M /var.defaults
172K /.log.junior
80K /root
40K /.old_patch_info
24K /.system_info
8.0K /boot
4.0K /tmpRoot
4.0K /mnt
4.0K /lost+found
4.0K /initrd
auch bei den logs keine Veränderung
xxxxxx@DS220plus:~$ sudo du -xhd 1 /var/log | sort -h -r
108M /var/log
15M /var/log/upstart
8.8M /var/log/surveillance
6.6M /var/log/disk-latency
4.3M /var/log/SynoFinder
4.1M /var/log/synolog
3.3M /var/log/packages
2.6M /var/log/samba
2.0M /var/log/httpd
220K /var/log/nginx
200K /var/log/smart_result
148K /var/log/fsck
136K /var/log/diskprediction
16K /var/log/selfcheck
4.0K /var/log/sssd
4.0K /var/log/pstore
4.0K /var/log/openvswitch
4.0K /var/log/healthtest
4.0K /var/log/cstn
4.0K /var/log/bios
Semenchkare
15. Dez 2015
jetzt 58%
/dev/md0 2.3G 1.3G 944M 58% /
Password:
108M /var/log
4.2M /var/log/synolog
2.6M /var/log/samba
2.0M /var/log/httpd
220K /var/log/nginx
148K /var/log/fsck
132K /var/log/diskprediction
4.0K /var/log/sssd
4.0K /var/log/cstn
4.0K /var/log/bios
sudo du -xhd 1 /var/ | sort -h -r
244M /var/
108M /var/log
79M /var/cache
47M /var/lib
8.9M /var/packages
2.5M /var/dynlib
240K /var/spool
144K /var/tmp
16K /var/update
16K /var/synobackup
12K /var/target
12K /var/db
8.0K /var/state
8.0K /var/services
4.0K /var/empty
4.0K /var/crash
1.2G /
844M /usr
244M /var
22M /.syno
11M /etc
8.7M /etc.defaults
7.2M /var.defaults
172K /.log.junior
80K /root
24K /.system_info
8.0K /boot
4.0K /tmpRoot
4.0K /mnt
4.0K /lost+found
4.0K /initrd
xxxxxx@DS220plus:~$ ls -lah /
total 80K
drwxr-xr-x 25 root root 4.0K Mar 9 02:21 .
drwxr-xr-x 25 root root 4.0K Mar 9 02:21 ..
lrwxrwxrwx 1 root root 7 Mar 2 18:46 bin -> usr/bin
drwxr-xr-x 3 root root 4.0K Mar 2 18:48 boot
drwxr-xr-x 7 root root 0 Mar 9 02:21 config
drwxr-xr-x 13 root root 19K Mar 9 02:22 dev
drwxr-xr-x 49 root root 4.0K Mar 12 18:56 etc
drwxr-xr-x 43 root root 4.0K Mar 2 18:51 etc.defaults
drwxr-xr-x 2 root root 4.0K May 12 2020 initrd
lrwxrwxrwx 1 root root 7 Mar 2 18:46 lib -> usr/lib
lrwxrwxrwx 1 root root 9 Mar 2 18:46 lib32 -> usr/lib32
lrwxrwxrwx 1 root root 7 Mar 2 18:46 lib64 -> usr/lib
drwxr-xr-x 2 root root 4.0K Mar 2 18:35 .log.junior
drwx------ 2 root root 4.0K May 12 2020 lost+found
drwxr-xr-x 2 root root 4.0K May 12 2020 mnt
drwxr-xr-x 3 root root 4.0K Mar 2 18:46 .old_patch_info
dr-xr-xr-x 300 root root 0 Apr 18 2018 proc
-rw------- 1 root root 1.0K Dec 23 2015 .rnd
drwx------ 5 root root 4.0K Mar 8 08:13 root
drwxr-xr-x 35 root root 2.0K Mar 12 18:56 run
lrwxrwxrwx 1 root root 8 Mar 2 18:46 sbin -> usr/sbin
drwxr-xr-x 4 root root 4.0K Mar 2 18:51 .syno
dr-xr-xr-x 12 root root 0 Mar 9 02:21 sys
drwxr-xr-x 2 root root 4.0K May 28 2020 .system_info
drwxrwxrwt 23 root root 3.9K Mar 12 19:14 tmp
drwxr-xr-x 2 root root 4.0K Mar 2 18:48 tmpRoot
drwxr-xr-x 11 root root 4.0K Mar 2 18:50 usr
drwxr-xr-x 17 root root 4.0K Mar 9 02:21 var
drwxr-xr-x 14 root root 4.0K Mar 2 18:46 var.defaults
drwxr-xr-x 24 root root 4.0K Mar 9 02:21 volume1
drwxr-xr-x 9 root root 4.0K Mar 9 02:21 volume2
habe keine Ahnung, wo die MBs denn hinkommen...
Ich glaube kaum, dass es viel bringt, wenn du ständig deine Ausgaben hier postest. Den Vergleich mit dem letzten Lauf wird dir hier niemand abnehmen.
Auch 58% ist noch im Rahmen.
Semenchkare
15. Dez 2015
Hallo, mir braucht niemand den Vergleich abzunehmen, denn ich seh ja selbst (aufgrund meiner hier dokumentierten Posts ;-)), dass sich ausser /dev/md0 hier nichts ändert! Aber vielleicht hat jemand eine Idee, wie ich noch suchen könnte.
Wahrscheinlich muss ich warten, bis alles wieder voll zugelaufen ist...
Was mich wundert, ist der bisher langsame Anstieg gegenüber dem letzten Mal.
