Sep 19 23:19:53 update.cgi: UnpackFirmware: Clean //upd@te.pat...
Sep 19 23:19:53 update.cgi: update.cpp(641): Remove //upd@te...cmd=[/bin/rm -rf //upd@te > /dev/null 2>&1]
Sep 19 23:19:53 update.cgi: update.cpp(657): Create //upd@te...cmd=[/bin/mkdir -p //upd@te > /dev/null 2>&1]
Sep 19 23:19:53 update.cgi: update.cpp(613): Untar //upd@te.pat...cmd=[/bin/tar xpf "//upd@te.pat" -C //upd@te > /dev/null 2>&1]
Sep 19 23:19:56 update.cgi: update.cpp(559): Verify checksum of [//upd@te]...
Sep 19 23:19:59 update.cgi: update.cpp(566): Pass checksum of //upd@te...
Sep 19 23:20:00 update.cgi: LaunchUpdater: Executing //upd@te/updater -v /
Sep 19 23:20:00 updater: main(5194): Start of the updater...
Sep 19 23:20:00 updater: This is junior, gszDevMtdPartition=[/dev/mtd5]
Sep 19 23:20:00 updater: updater.c:1682 pList->nItem=[1], cVolExternal=[0]
Sep 19 23:20:00 updater: updater.c:1091 Failed to set php configuration: [register_globals], synoerr=[0x0900]
Sep 19 23:20:00 updater: updater.c:1106 Failed to set php configuration: [apc.enabled], synoerr=[0x0900]
Sep 19 23:20:00 updater: updater.c:1114 SLIBFileGetKeyValue() failed!! szFile=[/usr/syno/etc/php.ini], szKey=[open_basedir], synoerr=[0x0100]
Sep 19 23:20:00 updater: updater.c:1117 Failed to set php configuration: [open_basedir], synoerr=[0x0900]
Sep 19 23:20:00 updater: number of partitions = [6]
Sep 19 23:20:00 updater: [RedBoot] 0xF8000000 0x00080000 0x00071E0C
Sep 19 23:20:00 updater: [zImage] 0xF8080000 0x00200000 0x001D68DC
Sep 19 23:20:00 updater: [rd.gz] 0xF8280000 0x00140000 0x000C7F48
Sep 19 23:20:00 updater: [vendor] 0xF83C0000 0x00010000 0x00010000
Sep 19 23:20:00 updater: [RedBoot Config] 0xF83D0000 0x00020000 0x00020000
Sep 19 23:20:00 updater: [FIS directory] 0xF83F0000 0x00010000 0x00000600
Sep 19 23:20:00 updater: flashsize = 0x00380000, eraseblock = 0x00010000
Sep 19 23:20:00 updater: UPDTBackupOldPartition(2763): command=[/bin/dd if="/dev/mtd0" of="/upd@te/b@ckup/mtd_RedBoot" bs=16384]
Sep 19 23:20:00 updater: UPDTBackupOldPartition(2763): command=[/bin/dd if="/dev/mtd1" of="/upd@te/b@ckup/mtd_zImage" bs=16384]
Sep 19 23:20:01 updater: UPDTBackupOldPartition(2763): command=[/bin/dd if="/dev/mtd2" of="/upd@te/b@ckup/mtd_rd.gz" bs=16384]
Sep 19 23:20:02 updater: UPDTBackupOldPartition(2763): command=[/bin/dd if="/dev/mtd3" of="/upd@te/b@ckup/mtd_vendor" bs=16384]
Sep 19 23:20:02 updater: UPDTBackupOldPartition(2763): command=[/bin/dd if="/dev/mtd4" of="/upd@te/b@ckup/mtd_RedBoot Config" bs=16384]
Sep 19 23:20:02 updater: UPDTBackupOldPartition(2763): command=[/bin/dd if="/dev/mtd5" of="/upd@te/b@ckup/mtd_FIS directory" bs=16384]
Sep 19 23:20:02 updater: UPDTDoPatch: skip updating [RedBoot]
Sep 19 23:20:02 updater: updater.c:2864(UPDTDoPatch) Try to Erase MTD Partition(/dev/mtd1), [0/3]...
Sep 19 23:20:24 updater: updater.c:2875(UPDTDoPatch) Try to Write MTD Partition(/dev/mtd1), [0/3]...
Sep 19 23:20:31 updater: updater.c:2881(UPDTDoPatch) Try to Verify MTD Partition(/dev/mtd1), [0/3]...
Sep 19 23:20:32 updater: UPDTDoPatch: Finish updating [zImage]
Sep 19 23:20:32 updater: updater.c:2864(UPDTDoPatch) Try to Erase MTD Partition(/dev/mtd2), [0/3]...
Sep 19 23:20:43 updater: updater.c:2875(UPDTDoPatch) Try to Write MTD Partition(/dev/mtd2), [0/3]...
Sep 19 23:20:46 updater: updater.c:2881(UPDTDoPatch) Try to Verify MTD Partition(/dev/mtd2), [0/3]...
Sep 19 23:20:47 updater: UPDTDoPatch: Finish updating [rd.gz]
Sep 19 23:20:47 updater: UPDTDoPatch: skip updating [vendor]
Sep 19 23:20:47 updater: UPDTDoPatch: skip updating [RedBoot Config]
Sep 19 23:20:47 updater: UPDTDoPatch: skip updating [FIS Directory]
Sep 19 23:20:47 updater: main(5604): Turn on the reinstall library flag...!!
Sep 19 23:20:52 synoindex: synoindex.c (286) Indexing daemon is not running
Sep 19 23:20:52 updater: updater.c:3597 file does not exists [/etc/synoIPs.deny], errno=[2/No such file or directory]
Sep 19 23:20:52 updater: updater.c:3597 file does not exists [/tmp/login_fail.list], errno=[2/No such file or directory]
Sep 19 23:20:52 updater: updater.c:4217 updater.c:4217(UpdateMySQLPass)SYNONetBkpS3ConfSetOne() failed!!
Sep 19 23:21:01 updater: Congratulation!! The update has been completed!!
Sep 19 23:21:01 updater: szCmd=[/bin/rm -rf /upd@te/b@ckup]
Sep 19 23:21:01 update.cgi: update.cpp(641): Remove //upd@te...cmd=[/bin/rm -rf //upd@te > /dev/null 2>&1]
Sep 19 23:21:31 update.cgi: update.cpp(358): Reboot system
Sep 19 23:21:33 root: /usr/syno/etc/rc.d/S98findhostd.sh stop findhostd
Sep 19 23:21:40 kernel: force close libz.so.1.2.3 file(3) dentry(1)
Sep 19 23:21:40 kernel: force close libcrypto.so.0.9.8 file(3) dentry(1)
Sep 19 23:21:40 kernel: force close sshd file(2) dentry(1)
Sep 19 23:23:39 syslogd started: BusyBox v1.16.1
Sep 19 23:23:39 kernel: [ 1.100000] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Sep 19 23:23:39 kernel: [ 1.170000] Delay 10 seconds to wait for disk 1 ready.
Sep 19 23:23:39 kernel: [ 18.410000] ata2: link is slow to respond, please be patient (ready=0)
Sep 19 23:23:39 kernel: [ 22.910000] ata2: SRST failed (errno=-16)
Sep 19 23:23:39 kernel: [ 24.670000] SPI Serial flash detected @ 0xf8000000, 4096KB (64sec x 64KB)
Sep 19 23:23:39 kernel: [ 24.730000] vender Mac1 checksum error ucSum:0x00 Buf:0x00 Sum:0.
Sep 19 23:23:39 kernel: [ 24.730000] Serial Number: 94F6N03419
Sep 19 23:23:39 kernel: [ 24.750000] Loading Marvell Ethernet Driver:
Sep 19 23:23:39 kernel: [ 24.750000] o Cached descriptors in DRAM
Sep 19 23:23:39 kernel: [ 24.760000] o DRAM SW cache-coherency
Sep 19 23:23:39 kernel: [ 24.760000] o 2 Giga ports supported
Sep 19 23:23:39 kernel: [ 24.770000] o Single RX Queue support - ETH_DEF_RXQ=0
Sep 19 23:23:39 kernel: [ 24.770000] o Single TX Queue support - ETH_DEF_TXQ=0
Sep 19 23:23:39 kernel: [ 24.780000] o TCP segmentation offload (TSO) supported
Sep 19 23:23:39 kernel: [ 24.780000] o Receive checksum offload supported
Sep 19 23:23:39 kernel: [ 24.790000] o Transmit checksum offload supported
Sep 19 23:23:39 kernel: [ 24.790000] o Rx descripors: q0=128
Sep 19 23:23:39 kernel: [ 24.790000] o Tx descripors: q0=532
Sep 19 23:23:39 kernel: [ 24.800000] o Loading network interface(s):
Sep 19 23:23:39 kernel: [ 24.800000] o register under mv88fx_eth platform
Sep 19 23:23:39 kernel: [ 24.810000] o eth0, ifindex = 2, GbE port = 0
Sep 19 23:23:39 kernel: [ 24.810000] o eth0, phy chipid = 1410e40, Support WOL = 0
Sep 19 23:23:39 kernel: [ 24.820000]
Sep 19 23:23:39 kernel: [ 25.490000] md: sda2 has different UUID to sda1
Sep 19 23:23:39 kernel: [ 25.500000] md: sdb2 has different UUID to sda1
Sep 19 23:23:39 kernel: [ 25.520000] md: md0: set sda1 to auto_remap [0]
Sep 19 23:23:39 kernel: [ 25.520000] md: md0: set sdb1 to auto_remap [0]
Sep 19 23:23:39 kernel: [ 25.560000] md: md1: set sda2 to auto_remap [0]
Sep 19 23:23:39 kernel: [ 25.570000] md: md1: set sdb2 to auto_remap [0]
Sep 19 23:23:39 kernel: [ 25.770000] VFS: Mounted root (ext2 filesystem) on device 1:0.
Sep 19 23:23:39 kernel: [ 25.790000] ds209_synobios: module license 'Synology Inc.' taints kernel.
Sep 19 23:23:39 kernel: [ 25.800000] Disabling lock debugging due to kernel taint
Sep 19 23:23:39 kernel: [ 25.870000] Brand: Synology
Sep 19 23:23:39 kernel: [ 25.880000] Model: DS-209
Sep 19 23:23:39 kernel: [ 25.900000] synobios: unload
Sep 19 23:23:39 kernel: [ 81.480000] VFS: Mounted root (ext3 filesystem) on device 9:0.
Sep 19 23:23:39 kernel: [ 82.810000] cesadev_init(bf126000)
Sep 19 23:23:39 kernel: [ 82.860000] mvCesaInit: sessions=10240, queue=64, pSram=f0000000
Sep 19 23:23:39 kernel: [ 82.980000] encryptfs using the OCF package.
Sep 19 23:23:39 kernel: [ 83.730000] Brand: Synology
Sep 19 23:23:39 kernel: [ 83.730000] Model: DS-209
Sep 19 23:23:39 kernel: [ 86.630000] md: md2: set sda3 to auto_remap [0]
Sep 19 23:23:39 kernel: [ 86.630000] md: md2: set sdb3 to auto_remap [0]
Sep 19 23:23:47 scemd: scemd.c:118 fan_type=7, raid_type=1, led_type=1, thermal_type=1, fanctrl_type=1, auto_poweron_type=1, dual_power_type=1, usbcopy_type=1, fan_number=1, ebox_type=1, pis_type=1, rtc_type=1
Sep 19 23:23:47 scemd: modules/fan_speed_adjust_common.c:161 Type: INTERNAL Fan Mode: HIGH (suitable for 3.5'' HD)
Sep 19 23:23:48 scemd: modules/raid_sys_volume_check.c:160 MD0 active disks 2, designed disks 2
Sep 19 23:23:48 scemd: modules/raid_sys_volume_check.c:160 MD1 active disks 2, designed disks 2
Sep 19 23:23:48 scemd: modules/disk_hibernation.c:94 Force hibernation enable, idle minutes 20
Sep 19 23:23:49 synoprint: printer_device_open.c:16 bad parameter.
Sep 19 23:23:57 kernel: [ 104.150000] Got empty serial number. Generate serial number from product.
Sep 19 23:23:58 syno_hdd_util: Model:[WD10EADS-00M2B0], Firmware:[01.00A01], S/N:[WD-WCAV51602523] in [/dev/sdb] is not ssd
Sep 19 23:23:58 syno_hdd_util: Model:[WD10EADS-00M2B0], Firmware:[01.00A01], S/N:[WD-WCAV51632708] in [/dev/sda] is not ssd
Sep 19 23:25:56 scemd: scemd.c:306 stop manutild.
Sep 19 23:35:56 root: /usr/syno/etc/rc.d/S98findhostd.sh stop findhostd
Sep 19 23:36:03 syslogd exiting
