DSM 6.x und darunter DSM 6.2.1-23824 Update 4
Puppetmaster
03. Feb 2012
Warum kein Neustart?
Puppetmaster
03. Feb 2012
Solche Infos sind immer hilfreich.
Hast du mal geschaut, ob ggf. die Systempartition vollgelaufen ist?
DS_Starter
15. Jan 2012
Ja, sieht mir völlig ok aus:
root@SDS1:~# df -k
Filesystem      1K-blocks       Used  Available Use% Mounted on
/dev/md0          2385528    1604228     662516  71% /
none              4078044          0    4078044   0% /dev
/tmp              4082312       6464    4075848   1% /tmp
/run              4082312       4836    4077476   1% /run
/dev/shm          4082312        664    4081648   1% /dev/shm
none                    4          0          4   0% /sys/fs/cgroup
cgmfs                 100          0        100   0% /run/cgmanager/fs
/dev/vg1000/lv 5804830888 5330241112  474470992  92% /volume1
/dev/md3       2808426764  304829236 2503597528  11% /volume2
/dev/sdr1      1922697108  899063536 1023514788  47% /volumeUSB1/usbshare
/dev/sdq1      1922688292  311513880 1611055628  17% /volumeUSB2/usbshare
none           5804830888 5330241112  474470992  92% /volume1/@docker/aufs/mnt/8eae3669df0cef569cf69b19d67605e14f964071c015d519f2a98e60c63ab1b0
shm                 65536          0      65536   0% /volume1/@docker/containers/b0e29b9ce5a6b204e5a97a880b608e3df97795914f5c497f3806c49dfdb67b4b/shm
tmpfs          1073741824          0 1073741824   0% /dev/virtualization
none           5804830888 5330241112  474470992  92% /volume1/@docker/aufs/mnt/3d64b4ef69c37870cd0e1b4195526b39bec1dfca15bea87f2b83da30c6445b3b
shm                 65536          0      65536   0% /volume1/@docker/containers/9b90e09ab9204f22495fb919bc2ede66ea9c8dc3d3739b38717a4822119ec327/shm
none           5804830888 5330241112  474470992  92% /volume1/@docker/aufs/mnt/00c1d7cec79ca7b7f21a45badb853e5d26ebbfcb6a70e987540fc0131bc0d884
shm                 65536          0      65536   0% /volume1/@docker/containers/402ff75b21be7a4fcc678398c62ea632d2281479e9ee6a0f0b746dd6da070810/shm
Top zeigt auch keine Auffälligkeiten
top - 15:38:52 up 12 min,  1 user,  load average: 9.16, 11.93, 7.55
Tasks: 942 total,   2 running, 940 sleeping,   0 stopped,   0 zombie
%Cpu(s): 11.5 us,  4.6 sy,  2.0 ni, 22.3 id, 59.3 wa,  0.0 hi,  0.3 si,  0.0 st
GiB Mem :    7.786 total,    0.135 free,    3.209 used,    4.443 buff/cache
GiB Swap:    6.672 total,    6.671 free,    0.001 used.    3.940 avail Mem
  PID USER      PR  NI    VIRT    RES  %CPU %MEM     TIME+ S COMMAND
25254 mysql     20   0 2372.3m 188.6m  17.9  2.4   1:29.63 S /usr/local/mariadb10/bin/mysqld --basedir=/usr/local/mariadb10 --datadir=/var/p+
22046 root      30  10  110.3m   6.9m   9.0  0.1   0:00.21 R /usr/syno/sbin/synomediaparserd
22066 system    20   0  253.7m   9.2m   5.8  0.1   0:00.09 S /usr/syno/synoman/webapi/auth.cgi
22058 system    20   0  253.7m   9.2m   5.1  0.1   0:00.08 S /usr/syno/synoman/webapi/auth.cgi
22057 root      20   0   28.0m   2.6m   3.8  0.0   0:00.24 R top
  505 root       0 -20    0.0m   0.0m   3.2  0.0   0:00.28 S [kswapd0]
29747 postgres  20   0  565.8m  61.8m   2.6  0.8   0:09.29 S postgres: postgres mediaserver [local] idle
Audi
01. Jan 2017
Bei mir lief heute das DSM 6.2.1-23824 Update 4 auf der DS glatt.
sweb
06. Jan 2019
gleiches Problem, alle gemeinsamen Ordner WEG ! Neustart erfolglos! Panik kommt auf! Wie komme ich nun an meine Daten ran? Es können keinerlei Berechtigungen mehr gesetzt werden !!
Wie kann man solch ein Rotz Upate für ein Final Upadte einspielen ?!
DS_Starter
15. Jan 2012
Ich gebe dir recht !
Aber versuche ruhig zu bleiben und keine unüberlegten Handlungen durchzuführen. Mach ein Ticket auf !! Und lass dich nicht mit "machen sie mal ein Reset" abzuspeisen !
Manchmal sind es Kleinigkeiten mit großer Wirkung.
DS_Starter
15. Jan 2012
Soll ich euch was sagen ... es läuft plötzlich alles wieder rund. Ohne ! weiteren Aktivitäten meinerseits.
Ich habe das Update ca. gegen Mittag gemacht und bis vor ein paar Minuten diese Schwierigkeiten gehabt. Jetzt habe ich zu meiner eigenen Beruhigung eine Hühnerbrühe getrunken und einen neuen Anlauf unternommen etwas zu lösen. Und plötzlich gehts wieder. Also Hühnerbrühe hilft :rolleyes:
Hat jetzt rund 4 -5 Stunden rumgenudelt, vllt. hilt einfach Geduld.
sweb
06. Jan 2019
TIcket schon aufgrmacht, aber Sonntags geht wohl nichts, oder?
Hab mal einen zweiten freigegeben Ordner ("NAS) eben erstellt für die gleiche Partition, auch hier kein Zugriff.
Problem ist dass ich die DS erst ne Woche habe und gerade dabei bin die Daten auf die NAS zu spielen, Problem, die Daten von der anderen HDD hab ich schon gelöscht weil ich die externe Platte für ein späteres Backup der DS gedacht hatte. 004.jpg
Wie komme ich denn nun an meine Daten des Ordners "Netzwerk" ?!
BIN STINKSAUER :mad:, hätte ich mir gleich nen 30 Euro RasberryPI mit zwei HDDs hingestellt wäre ich deutlich billiger gekommen!
DS_Starter
15. Jan 2012
Nein, erst morgen wieder.
Bin voll bei dir. Aber bisher ! konnte jedes Problem ohne Datenverlust gelöst werden und ich hab die DS schon lange. Also ruhig Blut bewahren und vielleicht auch mal so lange wie ich warten und dann mal neu starten. Ansonsten auf Syno-Support warten.
Dann natürlich schnellstens über eine Backup-Strategie nachdenken. Ich mache täglich Backups auf 2 externen USB-Platten. Die kann man zur Not auch am PC auslesen.
sweb
06. Jan 2019
Was denkst Du, physisch sind die Daten ja noch da (siehe Screenshot) aus meinem letzten Posting, oder?
Hab auch schon mehrmals neu gestartet, aber nada.
Wiegesagt, war erst bei der Einrichtung, da ich alle Daten erstmal auf die NAS haben wollte, externe Platten teils schon gelöscht, da diese als Backup Platten eingesetzt werden sollen. Perspektivisch wollte ich mir Cloud Speicher bei Amazon holen & die wichtigsten Daten verschlüsselt dort spiegeln ...
DS_Starter
15. Jan 2012
Ja.denke schon. Die belegte Größe und andere Parameter werden ja noch angezeigt.
Naja, eine DS kann ja noch mehr als Daten speichern.:) Die Surveillance Station ist bei mir eine der Hauptanwendungen die ich aus FHEM steuere. Also definitiv besser als ein Raspi
sweb
06. Jan 2019
Hab jetzt erstmal automatische Updates deaktiviert !:mad::mad:
Aber so ein Reinfall, sowas darf halt nie passieren, gerade wenn man zum teureren Produkt gegriffen hätte, vieles kann auch ein kleiner selbstgebastelter Server, oder ein RasPi oder ne Qnap oder WD Nas
Prüft mal bitte eure Systempartitionen mit "df -h". Da sollten Werte von <50% bei /dev/md0 normal sein. Die Werte bei DS_Starter erschienen mir recht hoch.
DS_Starter
15. Jan 2012
Das ist eine sehr !! gute Idee.Das ist bei mir Standard. Nichts wird automatisch upgedated.Schon garnicht wenn man Datenübrnahmen macht.
Ja, das timmt. Aber auch bei den anderen läuft nicht alles glatt ... glaub mir.
Also Kopf hoch ! :)
DS_Starter
15. Jan 2012
Hallo Benares,
Ja, meine liegt bei 71%. Muss mal schaue ob irgendwo ein paar Leichen liegen.
gwork
21. Okt 2016
Hatte das gleiche Problem nach dem Einspielen von DSM 6.2.1-23824 Update 4. Nach einem weiteren Neustart war allerdings alles wieder da, sprich sichtbar. Zugriffe per SMB gingen auch problemlos während die FileStation nichts angezeigt hat. Zusätzlich wurden die Benutzerverzeichnisse deaktiviert ("home"). Sehr ominös.
Perry2000
05. Nov 2012
Dann hatte ich Glück. Beide 6x laufen problemlos seit ein paar Tagen auf U4.
sweb
06. Jan 2019
Danke für den Tipp, aber ich hab erst seit ner Woche ne DSM, wie mach ich das?
Ssh im DSM aktivieren und dann mit einem Client - für Windows z.B. putty - eine Shell öffnen, auf dem Du den genannten Befehl df -h absetzen kannst.
