Photo Station Lightroom Export Plugin: PhotoStation Upload
Danke Martin,
http und https waren Versuche. Auf dem LAN kommt mit https die Meldung:
Booo!!
Initialization of Standard Photo Station at http://xxxxx.local failed!
Reason: ErrorCode: -1003
Ich probiers mal mit der nächst älteren Version. Steht ja noch in Lr zur Verfügung.
Grüsse, chema
Die ältere Version löst das Problem nicht. Wie man Photo Station downgraden kann, ist mir zZ unbekannt.
Anbei das Logfile.
Gruss, chema
21:39:30, TRACE: updateExportSettings: done
21:39:30, INFO : Environment: plugin: 6.4.1.20170424 Lr: 6.12 OS: 10.10.5 Lang: en
21:39:31, INFO : processRenderedPhotos starting
21:39:31, DEBUG: openSession: operation = ProcessRenderedPhotos, publishMode = Publish
21:39:31, DEBUG: openSession: copy second server parameters
21:39:31, DEBUG: openSession: copy collection settings
21:39:31, DEBUG: getCollectionUploadPath() returns '/shared/Lo'
21:39:31, DEBUG: PSConvert.initialize: PSUploaderPath= /Applications/Synology Photo Station Uploader.app/Contents/MacOS
conv: /Applications/Synology Photo Station Uploader.app/Contents/MacOS/ImageMagick/convert
dcraw: /Applications/Synology Photo Station Uploader.app/Contents/MacOS/dcraw/dcraw
ffmpeg: /Applications/Synology Photo Station Uploader.app/Contents/MacOS/ffmpeg/ffmpeg
qt-faststart: /Applications/Synology Photo Station Uploader.app/Contents/MacOS/ffmpeg/qt-faststart
21:39:31, DEBUG: PSPhotoStationAPI.initialize(PhotoStationUrl=http://xxxxx.local/photo/, Timeout=10)
21:39:31, DEBUG: callSynoAPI: LrHttp.post(http://xxxxx.local/photo/webapi/query.php, api=SYNO.API.Info&query=all&method=query&version=1&ps_username=
21:39:32, TRACE: "respHeaders":{
21:39:32, TRACE: "error":{
21:39:32, TRACE: "errorCode":"cannotFindHost"
21:39:32, TRACE: "name":"A server with the specified hostname could not be found."
21:39:32, TRACE: "nativeCode":"-1003"
21:39:32, TRACE: }
21:39:32, TRACE: }
21:39:32, TRACE: Error cannotFindHost on http request: A server with the specified hostname could not be found.
21:39:32, ERROR: Initialization of Standard Photo Station at
http://xxxxx.local
failed!
21:39:32, INFO : Photo StatLr: Publish failed!: Initialization of Standard Photo Station at
http://xxxxx.local
failed!
21:39:33, DEBUG: openSession: operation = GetCommentsFromPublishedCollection, publishMode = Publish
21:39:33, DEBUG: openSession: copy second server parameters
21:39:33, DEBUG: openSession: copy collection settings
21:39:33, DEBUG: getCollectionUploadPath() returns '/shared/Lo'
21:39:33, DEBUG: PSPhotoStationAPI.initialize(PhotoStationUrl=http://xxxxx.local/photo/, Timeout=10)
21:39:33, DEBUG: callSynoAPI: LrHttp.post(http://xxxxx.local/photo/webapi/query.php, api=SYNO.API.Info&query=all&method=query&version=1&ps_username=
21:39:33, TRACE: "respHeaders":{
21:39:33, TRACE: "error":{
21:39:33, TRACE: "errorCode":"cannotFindHost"
21:39:33, TRACE: "name":"A server with the specified hostname could not be found."
21:39:33, TRACE: "nativeCode":"-1003"
21:39:33, TRACE: }
21:39:33, TRACE: }
21:39:33, TRACE: Error cannotFindHost on http request: A server with the specified hostname could not be found.
21:39:33, ERROR: Initialization of Standard Photo Station at
http://xxxxx.local
failed!
21:39:33, INFO : Photo StatLr: Get comments failed!: Initialization of Standard Photo Station at
http://xxxxx.local
failed!
21:39:34, DEBUG: openSession: operation = GetRatingsFromPublishedCollection, publishMode = Publish
21:39:34, DEBUG: openSession: copy second server parameters
21:39:34, DEBUG: openSession: copy collection settings
21:39:34, DEBUG: getCollectionUploadPath() returns '/shared/Lo'
21:39:34, DEBUG: PSPhotoStationAPI.initialize(PhotoStationUrl=http://xxxxx.local/photo/, Timeout=10)
21:39:34, DEBUG: callSynoAPI: LrHttp.post(http://xxxxx.local/photo/webapi/query.php, api=SYNO.API.Info&query=all&method=query&version=1&ps_username=
21:39:34, TRACE: "respHeaders":{
21:39:34, TRACE: "error":{
21:39:34, TRACE: "errorCode":"cannotFindHost"
21:39:34, TRACE: "name":"A server with the specified hostname could not be found."
21:39:34, TRACE: "nativeCode":"-1003"
21:39:34, TRACE: }
21:39:34, TRACE: }
21:39:34, TRACE: Error cannotFindHost on http request: A server with the specified hostname could not be found.
21:39:34, ERROR: Initialization of Standard Photo Station at
http://xxxxx.local
failed!
21:39:34, INFO : Photo StatLr: Get ratings/metadata failed!: Initialization of Standard Photo Station at
http://xxxxx.local
failed!
Ich kann die Photo Station über
http
oder
https://xxxxx.local/photo
per Browser ohne Probleme erreichen.
über smb oder afp läuft alles wie geschmiert....
Das "einzige" was ich geändert habe ist das Update von Photo Station (v 6.74) ...
Achso: nach Update von Photo Station gibt es das Problem, unabhängig vom Plugin-Version. Hmm, ich habe letztens auch auf 6.7.4.3433 upgedatet, geht aber noch.
Versuch mal mit der IP-Adresse der Diskstation, die Fehlermeldung deutet schon darauf hin, dass er den Namen 'xxxxx.local' nicht auflösen kann.
Danke flingo!
Mit der IP geht's. Warum aber ist mir noch ein Rätsel, da wie gesagt die xxxxx.local Adresse per Browser etc funktioniert.
Habe ich auf der DS oder in Lr etwas geändert?.... DNS Einstellung?
Das frag ich mich auch. Es gibt momentan mehrere Rückmeldungen mit diesem Fehlerbild, immer von MacOS-Nutzern. Nun gab es in der letzten Zeit Updates Lr 6.12, DSM 6.2.?, Photo Station 6.7.4-3433, PhotoStatLr 6.4.2 und es dauert immer ein bißchen, bis man die tötliche Mischung identifiziert hat. Ich habe das Lr 6.12 Update auf MacOS im Verdacht, da es eine Lightroom-Funktion ist, die da einen Fehler wirft, kann aber auch ein DNS-Fehler sein. Bei mir macht das die Fritzbox und ich hatte auch schon den Effekt, dass die lokalen Adresse 'diskstation' nicht mehr aufgelöst wurde, was letztlich durch Reboot der Diskstation und der Fritzbox behoben wurde. Geht denn ein ping auf den dns-Namen?
Aktion Deutschland Hilft - PhotoStatLr Spendenaktion
Es kommt immer mal wieder die Frage, wie das mit dem Spenden jetzt gemeint ist und wo man denn spenden soll.
Ich habe jetzt eine Spendenaktion bei Aktion Deutschland Hilft (das ist dieses Aktionsbündnis aller großen deutschen Hilforganisationen) eingerichtet für alle, die immer schon mal wollten aber noch nicht dazu gekommen sind:
https://www.aktion-deutschland-hilft.de/de/aktiv-helfen/interaktiv-helfen/starte-deine-spendenaktion?cfd=bahdk#fbIframeDiv
Photo StatLr bedankt sich schon mal im Voraus.
Grüße, Martin
Blöde Frage vielleicht, aber: wie update ich das Plugin? Ich habe bis jetzt immer einfach von Github runtergeladen und einfach im Lr Plugins Verzeichnis überschrieben. Nun habe ich das Plugin Verzeichnis mal neu erstellt und immernoch bekomme ich die Meldung, dass es ein Update gibt...
Ach: was sind abgelehnte Statusänderungen? Ich habe da eine Reihe von Bildern, die immer wieder als "neu Veröffentlichen" aufgeführt werden.
Warte mal einen Tag: der Update-Check wird nur einmal am Tag aktualisiert. Morgen sollte die Meldung nicht mehr kommen.
Seitdem die Photostation auf Version 6.8 ist erhalte ich nur noch Fehlermeldungen und ein Export via Photo StatLr plugin ist nicht möglich. Fehlermeldung "AgPreferences:attempt to write to invalid prefs key value of type table"
Ich habe gestern auch auf PS 6.8.0-3456 und DSM 6.1.3-15152 Update 6 aktualisiert und arbeite heute schon einige Stunden mit dem Plugin v6.4.3, alles ohne Probleme. Ein generelles Problem mit PS 6.8 kann ich nicht erkennen. Da bräuchte ich mal ein ausführliches Logfile an photostatlr[at]messmer-online.de.
@flingo
Zunächst vielen Dank für die tolle Entwicklungsarbeit und Support hier im Forum.
Nun zu meinem Problem. Ich habe zur Zeit folgendes Anwendungsszenarium. Ich nutze den Lightroom Publisher, um direkt auf meine Festplatte alle RAW-Datein in JPEGs zu exportieren. Mittels des Cloud Station Drives werden diese zu meiner DiskStation bzw. PhotoStation synchronisiert und von dort weiter zum Amazon Cloud Drive. Der Vorteil ist für mich, dass das Schreiben der JPEGs schnell ist, sowie der Sync zu meiner DiskStation. Für die Synchronisation zu meinem Amazon Cloud Drive kann mein PC dann ausgeschaltet sein. Jetzt möchte ich mittels deines Plugins die MetaDaten zw. PhotoStation und Lightroom synchronisieren, damit ich auch vom iPad aus die Bilder selektieren kann.
1. Gibt es die Möglichkeit, dass auch auf der PhotoStation gelöschte Bilder in Lightroom gelöscht werden?
2. In meiner PhotoStation liegen bereits um die 40.000 Bilder in Form von JPEGs. Diese möchte ich nicht erneut erstellen, da diese wiederum zum Amazon Cloud Drive synchronisiert werden müssten. Gibt es einen Weg, dass dein Publisher Plugin, diese Bilder erkennt und nur die MetaDaten abgleicht?
Falls jemand einen besseren Workflow kennt, wie man seine gesamten Bilder bequem in der Cloud/NAS selektieren und mit Lightroom synchronisieren (zwei Wege Synchronisation) kann, dann würde ich mich darüber sehr freuen. Adobe's Creative Cloud ist hier keine Alternative für mich, da ich für den Upload meinen Rechner ständig eingeschaltet lassen müsste und zudem die Kosten unverhältnismäßig sind.
Nein, das habe ich aus 'Sicherheitsgründen' nicht implementiert. Lr ist der Master, Löschen wird nur von Lr --> PS propagiert
2. In meiner PhotoStation liegen bereits um die 40.000 Bilder in Form von JPEGs....Gibt es einen Weg, dass dein Publisher Plugin, diese Bilder erkennt und nur die MetaDaten abgleicht?
Ja, das geht. Du musst eine (oder mehrere) Published Collection(s) so definieren, dass sie die Bilder genau in der auf der Photo Station vorhanden Albumstruktur /Namenskonvention erportieren würden. Anstelle von "Upload" verwendest Du dann beim Publish den Mode "CheckExisting" und dann werden alle Fotos, die er in der Photo Station an der definierten Stelle findet als 'Published' markiert.
Metadaten, die in der Photo Station geändert wurden, können nun über das Kommentar Panel in Lr nach Lr zurücksynchronisiert werden.
Wurden Metadaten in Lr geändert, muss das Bild komplett neu hochgeladen werden: entweder über das Plugin oder über den bisherigen Weg.
Ich werde es mal probieren, bisher klappte es auf diesem Weg nicht.
Neues Problem. Die Farbmarkierungen werden ohne Probleme von LR zur PS in Form der Allgemeinen Tags geschrieben. Werden diese in PS entfernt, kommt es zum Fehler und werden nicht in LR gelöscht. In PS wurde die Farbe "purple" von Bild "P9214332.jpg" entfernt.
Anhang anzeigen PhotoStatLr.txt
Auch für die Metadaten gilt: Löschungen in PS werden grundstätzlich nicht nach Lr zurückgespielt, 'aus Sicherheitsgründen'. Deshalb wurden auch nicht die in der PS fehlenden/gelöschten Keywords in Lr gelöscht.
Die Synchronisierungsregeln sind hier beschrieben. Es ist mir einfach zu heiß, fehlende Metadaten in PS als Löschauftrag nach Lr weiterzureichen. Es könnte zwar eine bewusste Löschung gewesen sein, es könnte aber auch sein, dass Deine letzten mühevollen Ergänzungen in Lr einfach noch nicht exportiert waren, und wenn dann ein Refresh Comments ausgeführt wird, wären dann Deine letzten Ergänzungen aus Lr weg (ich spreche aus Erfahrung).
Hallo
nutze das Plugin mit LR 6.13
1- Sortiere meine Smart-Listen nach Stichwörter. Beim Upload schiebt das Plugin die Bilder teilweise in die falschen Ordner, keine Ahnung warum.
In LR bzw den Smart-Listen ist alles richtig.
2- Bekomme öfter einen Fehler, siehe Screenshot
