Host synology-winterberg.dyndns.org (89.217.240.129) is up (0.077s latency).
Scanned at 2010-01-11 21:44:59 CET for 274s
Interesting ports on synology-winterberg.dyndns.org (89.217.240.129):
Not shown: 996 closed ports
PORT STATE SERVICE VERSION
21/tcp filtered ftp
23/tcp filtered telnet
80/tcp filtered http
8080/tcp open http-proxy?
Device type: broadband router|switch
Running (JUST GUESSING) : Huawei embedded (86%), ZyXEL ZyNOS 2.X|3.X (86%), Telewell embedded (86%), HP embedded (86%), Netopia embedded (86%)
OS fingerprint not ideal because: Host distance (9 network hops) is greater than five
Aggressive OS guesses: ADSL router: Huawei MT800u-T; or ZyXEL Prestige 623ME-T1, 782, or 2602R-61 (86%), Telewell TW-EA501 ADSL modem (86%), ZyXEL P-2602HW-D1A wireless DSL modem (ZyNOS 3.40) (86%), HP GbW2c Ethernet Blade Switch (86%), Netopia 3346N, 3347NWG, or 3397GPB ADSL router (86%)
No exact OS matches for host (test conditions non-ideal).
TCP/IP fingerprint:
SCAN(V=5.00%D=1/11%OT=8080%CT=1%CU=36763%PV=N%DS=9%G=N%TM=4B4B8EDE%P=powerpc-603e-linux-gnu)
SEQ(SP=10%GCD=A000%ISR=B0%TI=I%CI=I%TS=U)
SEQ(SP=23%GCD=A000%ISR=AF%TI=I%CI=I%TS=U)
OPS(O1=M550%O2=M550%O3=M550%O4=M550%O5=M550%O6=M550)
WIN(W1=800%W2=800%W3=800%W4=800%W5=800%W6=800)
ECN(R=Y%DF=N%T=100%W=800%O=M550%CC=N%Q=)
T1(R=Y%DF=N%T=100%S=O%A=S+%F=AS%RD=0%Q=)
T2(R=Y%DF=N%T=100%W=0%S=Z%A=S%F=AR%O=%RD=0%Q=)
T3(R=N)
T4(R=Y%DF=N%T=100%W=0%S=A%A=Z%F=R%O=%RD=0%Q=)
T5(R=Y%DF=N%T=100%W=0%S=Z%A=S+%F=AR%O=%RD=0%Q=)
T6(R=Y%DF=N%T=100%W=0%S=A%A=Z%F=R%O=%RD=0%Q=)
T7(R=N)
U1(R=Y%DF=N%T=100%IPL=38%UN=0%RIPL=G%RID=G%RIPCK=G%RUCK=G%RUD=G)
IE(R=N)
Network Distance: 9 hops
TCP Sequence Prediction: Difficulty=35 (Good luck!)
IP ID Sequence Generation: Incremental
TRACEROUTE (using port 135/tcp)
HOP RTT ADDRESS
1 237.44 F5d8233-4v3 (192.168.2.254)
2 96.52 lo1.br12.ber.de.hansenet.net (213.191.64.23)
3 39.59 ae0-101.cr01.ber.de.hansenet.net (62.109.108.61)
4 57.94 so-1-0-0-0.cr01.fra.de.hansenet.net (213.191.66.21)
5 57.13 ae0-0.pr03.decix.de.hansenet.net (62.109.109.172)
6 58.90 decix.sunrise.ch (80.81.192.141)
7 ...
8 71.53 212.161.254.162
9 70.59 194.230.86.26
10 76.59 synology-winterberg.dyndns.org (89.217.240.129)
Read data files from: /opt/share/nmap
OS and Service detection performed. Please report any incorrect results at http://nmap.org/submit/ .
Nmap done: 1 IP address (1 host up) scanned in 307.18 seconds
Raw packets sent: 1189 (55.340KB) | Rcvd: 1062 (42.972KB)
Ok... Es sind definitiv alle benötigten Ports offen (allerdings statt 23 hab ich 22 offen). Auf Dyndns stimmt auch alles und im Router ebenfalls. Funktionieren tuts trozdem nicht. Hilfe! Anfänglichs hatte ich ja richtig freude an der DS, aber langsam schmälert sich diese
Also ich denke, daß Du ein Problem mit der Portweiterleitung hast, oder auf Router oder DS vielleicht ne Firewall dazwischenfunkt.
Poste doch mal die Portweiterleitungen auf Deinem Router hier.
Kannst Du auf Deinen Router vielleicht mit Telnet oder so drauf und von dort ein Kommando in richtung DS absetzen ?
Dein dyndns zeigt schon wieder auf die interne IP, was machst Du da?
Hallo an alle
Nur als Idee
wie wäre es, wenn du der Name des DOMAIN anstatt der IP benütz?
so habe ich gemacht bei mir, weil der IP Adresse sich regelmäßig ändern...
