Wie groß ist zu groß?
das hier scheint mir ein relevanter Abschnitt (die # sind nur Maskierungen) :
Jul 16 20:17:47 kernel: [ 1542.630000] sd 2:0:0:0:
 rejecting I/O to offline device
Jul 16 20:17:47 kernel: [ 1542.650000] Aborting journal on device sdq1.
Jul 16 20:17:47 kernel: [ 1542.650000] sd 2:0:0:0: rejecting I/O to offline device
Jul 16 20:17:47 kernel: [ 1542.660000] sd 2:0:0:0: rejecting I/O to offline device
Jul 16 20:17:47 kernel: [ 1542.670000] sd 2:0:0:0: rejecting I/O to offline device
Jul 16 20:17:47 kernel: [ 1542.700000] ext3_abort called.
Jul 16 20:17:47 kernel: [ 1542.700000] EXT3-fs error (device sdq1): ext3_journal_start_sb: Detected aborted journal
Jul 16 20:17:47 kernel: [ 1542.710000] Remounting filesystem read-only
Jul 16 20:17:47 kernel: [ 1542.710000] JBD: Detected IO errors while flushing file data on sdq1
Jul 16 20:17:47 synolocalbkp: localbkp_copy_file.c:156 Fail to write file /volumeUSB1/usbshare/SYNA_1/######/######/######/######/######!! errno=[30/Read-only file system]
Jul 16 20:17:47 synolocalbkp: localbkp_copy_file.c:100 Failed to open file [/volumeUSB1/usbshare/SYNA_1/######/######/######/######/######.###], errno=[30/Read-only file system]
Jul 16 20:17:47 synolocalbkp: localbkp_upload_share_data.c:146 utime(2) error directory:/volumeUSB1/usbshare/SYNA_1/######/######, errno=[30/Read-only file system]
Jul 16 20:17:48 kernel: [ 1543.110000] sd 2:0:0:0: rejecting I/O to offline device
Jul 16 20:17:48 synolocalbkp: main.c:371 SYNOLocalBkpMoveFile() failed.
Jul 16 20:17:48 kernel: [ 1543.140000] EXT3-fs error (device sdq1): ext3_find_entry: reading directory #16385 offset 0
Jul 16 20:17:49 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:17:55 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:01 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:07 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:12 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:18 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:23 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:29 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:35 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:41 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:48 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:54 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:19:00 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:19:27 kernel: [ 1642.410000] sd 2:0:0:0: rejecting I/O to offline device
Jul 16 20:19:31 kernel: [ 1646.610000] sd 2:0:0:0: rejecting I/O to offline device
Jul 16 20:21:34 kernel: [ 1769.600000] sd 2:0:0:0: rejecting I/O to offline device
Jul 16 20:21:52 kernel: [ 1787.570000] __journal_remove_journal_head: freeing b_committed_data
Jul 16 20:21:52 kernel: [ 1787.630000] usb 1-1: lock for hub EH
Jul 16 20:21:52 kernel: [ 1787.910000] usb 1-1: unlock for hub EH
Jul 16 20:21:52 kernel: [ 1788.020000] hub 1-1:1.0: hub_port_status failed (err = -19)
Jul 16 20:21:52 kernel: [ 1788.030000] hub 1-1:1.0: hub_port_status failed (err = -19)
Jul 16 20:21:52 kernel: [ 1788.040000] hub 1-1:1.0: activate --> -19
Jul 16 20:21:53 kernel: [ 1788.490000] Got empty serial number. Generate serial number from product.
Jul 16 20:21:53 kernel: [ 1788.990000] usb 1-1.1: device descriptor read/64, error -32
Jul 16 20:21:53 kernel: [ 1789.180000] usb 1-1.1: device descriptor read/64, error -32
Jul 16 20:21:54 kernel: [ 1789.450000] usb 1-1.1: device descriptor read/64, error -32
Jul 16 20:21:54 kernel: [ 1789.640000] usb 1-1.1: device descriptor read/64, error -32
Jul 16 20:21:54 kernel: [ 1789.870000] usb 1-1.1: device descriptor read/8, error -71
Jul 16 20:21:54 kernel: [ 1790.010000] usb 1-1.1: device descriptor read/8, error -71
Jul 16 20:21:54 kernel: [ 1790.240000] usb 1-1.1: device descriptor read/8, error -71
Jul 16 20:21:55 kernel: [ 1790.380000] usb 1-1.1: device descriptor read/8, error -71
Jul 16 20:21:55 kernel: [ 1790.490000] hub 1-1:1.0: unable to enumerate USB device on port 1
Jul 16 20:21:55 hotplugd: ##### ACTION:remove
Jul 16 20:21:55 hotplugd: DEVICE:/proc/bus/usb/001/003
Jul 16 20:21:55 hotplugd: DEVPATH:1-1.1:1.0
Jul 16 20:21:55 hotplugd: SUBSYSTEM:usb
Jul 16 20:21:55 hotplugd: INTERFACE:8/6/80
Jul 16 20:21:55 hotplugd: DEVICE:/proc/bus/usb/001/002
Jul 16 20:21:55 hotplugd: DEVPATH:1-1:1.0
Jul 16 20:21:55 hotplugd: INTERFACE:9/0/0
Jul 16 20:21:55 hotplugd: ##### ACTION:add
Jul 16 20:21:55 hotplugd: DEVICE:/proc/bus/usb/001/004
Jul 16 20:21:55 hotplugd: hotplugd.c:912 ##### complete device hotplug!!
Jul 16 20:21:59 hotplugd: usb_get_device_id.c:56 failed get usb id Vendor=0000, ProdID=0000, SN=d6a3ebcbfbd5e7a5f6a3
Jul 16 20:21:59 hotplugd: hotplugd.c:1102 failed get usb device id from usb config, DEVICE=/proc/bus/usb/000/000
Jul 16 20:21:59 hotplugd: ##### ACTION:remove
Jul 16 20:21:59 hotplugd: DEVNAME:sdq
Jul 16 20:21:59 hotplugd: DEVICE:/proc/bus/usb/000/000
Jul 16 20:21:59 hotplugd: DEVPATH:sdq
Jul 16 20:21:59 hotplugd: SUBSYSTEM:block
Jul 16 20:21:59 hotplugd: PHYSDEVPATH:/devices/platform/orion-ehci.0/usb1/1-1/1-1.1/1-1.1:1.0/host2/target2:0:0/2:0:0:0
Jul 16 20:21:59 hotplugd: hotplugd.c (1534) ==== USB disk [sdq] plugged out====
Jul 16 20:21:59 hotplugd: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:21:59 hotplugd: volume_parts_info_get_by_dev.c:318 failed to get disk '/dev/sdq' size
Jul 16 20:21:59 scemd: modules/usbcopy.c:55 USBCopy - Unknown Signal: 12
Jul 16 20:22:01 kernel: [ 1796.570000] ext3_abort called.
Jul 16 20:22:01 kernel: [ 1796.580000] EXT3-fs error (device sdq1): ext3_put_super: Couldn't clean up the journal
Jul 16 20:22:56 externaldevices.cgi: airprint_lib.cpp:102 Failed to download driver list.
Jul 16 20:22:56 externaldevices.cgi: externaldevices.cpp:1101 Failed to load driver list.
Jul 16 20:23:03 s2s_service.cgi: s2s_service.cpp (98) no any section if synoS2S.info is empty.
Jul 16 20:23:15 s2s_sharepair.cgi: s2s_sharepair.cpp (67) no any section if synoS2S.info is empty.
Jul 16 20:23:19 s2s_service.cgi: s2s_service.cpp (98) no any section if synoS2S.info is empty.
Jul 16 20:23:42 PkgSynoMan.cgi: pkgcurltool.cpp:221 Failed to curl perform, code=6, err=Couldn't resolve host name
Jul 16 20:25:04 PkgSynoMan.cgi: pkgcurltool.cpp:221 Failed to curl perform, code=6, err=Couldn't resolve host name
Jul 16 20:26:25 PkgSynoMan.cgi: pkgcurltool.cpp:221 Failed to curl perform, code=6, err=Couldn't resolve host name
Jul 16 20:26:26 PkgSynoMan.cgi: pkgcurltool.cpp:330 Failed to curl perform, https://payment.synology.com/api/getPackageList.php
So, mit Putty komme ich jetzt auch rein (nur als Info um zu vermeiden das noch jemand über mein Problem mit Putty nachdenkt)
Lösung war das Passwort des Nutzers "admin" für den Nutzer "root" zu verwenden. (Ist das so banal das man es wissen muß, oder ist das sowas wie ein easteregg für Leute mit Humor?)
Michael
Ähm, steht doch auch so im Wiki...
So ist es!
und das hier:
sagt auch eindeutig, dass - warum auch immer - das File-System der externen Platte nicht in Ordnung ist.
...sagt auch eindeutig, dass - warum auch immer - das File-System der externen Platte nicht in Ordnung ist.
Vorstellbar wäre auch, dass es es Probleme auf dem Signalweg (Controller, Kontakte in der Dockingstation,etc.) gibt.
Aber klar!
Sobald auch nur eine zusätzliche Verbindung im Spiel ist, könnte sogar das schnöde Kabel ein Problem sein! ;-)
ja, sicher. Ist denn aber aus meinen Posts nicht zu merken das ich Linux-Laie bin und meine Bemerkung eher darauf zielte das mir nicht klar ist ob das eine Besonderheit beim Synology-NAS ist oder eher etwas Generelles unter Linux.
Michael
So ist es!
und das hier:
Die externen USB-Platten formatiere ich, solange ich die DS211j habe mit den dortigen Mitteln. Sollte ich doch besser Acronis Disk Editor nehmen (den nehme ich sonst für alles Andere)?
Michael
Ja, das ist mir einleuchtend. Aber wie soll ich vorgehen, denn ich habe ja schon testweise zwei andere Platten genutzt.
Nochmal im Detail: die Dockingstation wird für diverse Platten genutzt, keine Frage das dort die Kontakte ausgeleiert sein können, nur die anderen 2 Platte sind fest eingebaute Platten in USB-Gehäusen und deren USB-Stecker ist sicher nicht ausgeleiert.
Entschuldigung, die Frage soll gar nicht blöd klingen, nur alles was ich glaube tun zu können ist ins Auto zu steigen, eine weitere USB-Platte zu kaufen und es damit zu testen.
Wenn das alles nervt, tut es mir leid, nur ich kann auch nicht so schnell reagieren weil die Backups ewig brauchen, das gestern benannte Backup (mit Dritt-Backupsoftware) lief faktisch jetzt noch die ganze Nacht durch und erst heute morgen sah ich dann das es auch bei 93% abgebrochen war.
Aktuell habe ich seit einigen Stunden ein neues Backup gestartet, was aber wohl auch bis heute Abend braucht ehe ich weiss ob es klappt oder nicht.
Michael
Nein, das würde nichts bringen!
Ich vermute eher, dass es an deinen Dockingstattionen im Zusammenspiel mit den neuen Platten liegen könnte.
Wenn du mal suchen würdest, dann würdest du hier jede Menge Threads mit inkompatiblen oder halb kompatiblen Geräten und Controllern finden. Bis ungefähr vor einem halben (oder ganzen) Jahr wurde da fast jede Woche drüber diskutiert.
Deine Platten solltest du auch mal mit den entsprechenden Herstellertool testen.
Es gab auch hier schon Fälle, in denen "alle" bis zu 5 nagelneuen Platten einfach von Anfang an defekt waren und eingeschickt werden mussten.
