- Mitglied seit
- 17. Dez 2014
- Punkte für Reaktionen
- 1.857
Angezeigt schon, aber es entsteht bei Werten über 10.000 keine Warnung bzw. es findet keine Überwachung statt.nahezu immer angezeigt wird
SMART Attributes Data Structure revision number: 1
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 6376
12 Power_Cycle_Count 0x0032 098 098 000 Old_age Always - 1073
177 Wear_Leveling_Count 0x0013 099 099 000 Pre-fail Always - 49
179 Used_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 0
181 Program_Fail_Cnt_Total 0x0032 100 100 010 Old_age Always - 0
182 Erase_Fail_Count_Total 0x0032 100 100 010 Old_age Always - 0
183 Runtime_Bad_Block 0x0013 100 100 010 Pre-fail Always - 0
187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0032 074 048 000 Old_age Always - 26
195 ECC_Error_Rate 0x001a 200 200 000 Old_age Always - 0
199 CRC_Error_Count 0x003e 100 100 000 Old_age Always - 0
235 POR_Recovery_Count 0x0012 099 099 000 Old_age Always - 70
241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 13889239785
2020.06.30 07:17:49 BaseException in : "cgi_main.main"
Called Page : [Hdd-+]
Traceback (most recent call last):
File "/usr/syno/synoman/webman/3rdparty/AvrLogger/AvrLogger.cgi", line 206, in Main
sNext = cgi_main.main ( mainpage, site, more )
File "/usr/syno/synoman/webman/3rdparty/AvrLogger/gui/cgi_main.py", line 131, in main
if index != None : objModule[ index ].sub( site, more )
File "/usr/syno/synoman/webman/3rdparty/AvrLogger/gui/mod_Hdd.py", line 101, in sub
f = Smart.Smart( )
File "/usr/syno/synoman/webman/3rdparty/AvrLogger/lib/Smart.py", line 65, in __init__
self._Scan( forceReload )
File "/usr/syno/synoman/webman/3rdparty/AvrLogger/lib/Smart.py", line 552, in _Scan
sSerial = self._getInfoAttr( 'Serial Number', sDev )
File "/usr/syno/synoman/webman/3rdparty/AvrLogger/lib/Smart.py", line 505, in _getInfoAttr
self._readSmartInfo( sDev )
File "/usr/syno/synoman/webman/3rdparty/AvrLogger/lib/Smart.py", line 495, in _readSmartInfo
sKey, sValue = sLine.split( ':', 1 )
ValueError: not enough values to unpack (expected 2, got 1)
root@IronWolf:/volume1/homes/admin/AvrLoggerSPK# ./pool.py
Storage Pool Infos :
Query Time : 1.662324
Storage Pool 1 : [internal] DSM (Raid 5 - BTRFS)
SpacePath : /dev/md2
RaidPath : /dev/md2
Disks : ['sda', 'sdb', 'sdc', 'sdd']
Storage Pool 2 : [internal] WD-Green
SpacePath : /dev/vg1
RaidPath : /dev/md3
Disks : ['sde', 'sdf', 'sdg', 'sdh']
Storage Pool 3 : [internal] WD-RED (Raid 5 BTRFS)
SpacePath : /dev/md4
RaidPath : /dev/md4
Disks : ['sdi', 'sdj', 'sdk', 'sdl']
Process Time : 0.007244
SMART Device Infos :
Model Family : Samsung based SSDs
Device Model : Samsung SSD 860 PRO 256GB
Serial Number : S42VNF0K208702D
LU WWN Device Id : 5 002538 e4019ad34
Firmware Version : RVM01B6Q
User Capacity : 256,060,514,304 bytes [256 GB]
Sector Size : 512 bytes logical/physical
Rotation Rate : Solid State Device
Form Factor : 2.5 inches
Device is : In smartctl database [for details use: -P show]
ATA Version is : Unknown(0x09fc), ACS-4 T13/BSR INCITS 529 revision 5
SATA Version is : SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is : Tue Jun 30 14:13:09 2020 CEST
SMART support is : Available - device has SMART capability.
SMART support is : Enabled
AAM feature is : Unavailable
APM feature is : Unavailable
Rd look-ahead is : Enabled
Write cache is : Enabled
ATA Security is : Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder : Unknown
SMART Values :
5 Reallocated_Sector_Ct : 0
9 Power_On_Hours : 10152
12 Power_Cycle_Count : 27
177 Wear_Leveling_Count : 419
179 Used_Rsvd_Blk_Cnt_Tot : 0
181 Program_Fail_Cnt_Total : 0
182 Erase_Fail_Count_Total : 0
183 Runtime_Bad_Block : 0
187 Uncorrectable_Error_Cnt : 0
190 Airflow_Temperature_Cel : 34
195 ECC_Error_Rate : 0
199 CRC_Error_Count : 0
235 POR_Recovery_Count : 4
241 Total_LBAs_Written : 33000838272
[root@DS916AH] .../_WARTUNGS-SCRIPTE_/avr-logger > ./pool.py
Query Time : 3.457016
Storage Pool 1 : [internal] Diskgruppe intern SHR
RaidPath : /dev/md6
Storage Pool 2 : [ebox] Diskgruppe DX513 SHR
SpacePath : /dev/vg2
RaidPath : /dev/md4
Disks : ['sdea', 'sdeb', 'sdec', 'sded', 'sdee']
Process Time : 0.002495
Model Family : WD Red
Device Model : WDC WD100EFAX-68LHPN0
Serial Number : ********
LU WWN Device Id : 5 000cca 27ecd5a92
Firmware Version : 83.H0A83
User Capacity : 10,000,831,348,736 bytes [10.0 TB]
Sector Sizes : 512 bytes logical, 4096 bytes physical
Rotation Rate : 5400 rpm
Form Factor : 3.5 inches
ATA Version is : ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is : SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is : Tue Jun 30 16:16:47 2020 CEST
APM feature is : Disabled
Wt Cache Reorder : Enabled
SMART Values :
1 Raw_Read_Error_Rate : 0
2 Throughput_Performance : 108
3 Spin_Up_Time : 34389033402
4 Star/Stop_Count : 13
5 Reallocated_Sector_Count : 0
7 Seek_Error_Rate : 0
8 Seek_Time_Performance : 18
9 Power-On_Hours_Count : 1373
10 Spin_Retry_Count : 0
12 Device_Power_Cycle_Count : 13
22 Helium_Level : 100
192 Power_off_Retrace_count : 58
193 Load_Cycle_count : 58
194 Temperature_Celsius : 35
196 Reallocation_Event_Count : 0
197 Current_Pending_Sector_Count : 0
198 Off-Line_Scan_Uncorrectable_Sector_Count : 0
199 Ultra_DMA_CRC_Error_Count : 0
Test finished
[root@DS118AH] .../_WARTUNGS-SCRIPTE_/avr-logger > ./pool.py
Query Time : 0.761881
Process Time : 0.001452
Device Model : Samsung SSD 850 PRO 256GB
Serial Number : ***************
LU WWN Device Id : 5 002538 8a07edff6
Firmware Version : EXM04B6Q
ATA Version is : ACS-2, ATA8-ACS T13/1699-D revision 4c
SATA Version is : SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is : Tue Jun 30 16:19:45 2020 CEST
Split Error in Line 19 : [Unexpected SCT status 0x0001 (action_code=4, function_code=2)]
Wt Cache Reorder : Unknown (SCT Feature Control command failed)
SMART Values :
9 Power_On_Hours : 6385
12 Power_Cycle_Count : 1073
177 Wear_Leveling_Count : 49
190 Airflow_Temperature_Cel : 32
235 POR_Recovery_Count : 70
241 Total_LBAs_Written : 13899011745
Test finished
In meiner DS118 ist ne SSD verbaut, und nun habe ich weissen Adler auf weissem Grund ....
wenn ich so wie Andi in seinem Bild mit meiner DDNS Synology Adresse Aufrufe.
Brauchst Du die TXT-Files auch noch?
Nur weil keine IP-Adresse benutzt wird, heist das noch lande nicht, dass das nicht mehr intern ist.da steht keine interne IP von deinem Netzwerk...
