Hi, ich habe nun den Pfad auch noch angepasst siehe Logdatei ganz unten im Ordner scripts ist nun ein File mit 3.2 kb. Leider geht es noch immer nicht.
root@Server:/volume1/volume/data/scripts# wget -O ffmpegwrapper-setup.sh
https://git.os-guru.de/attachments/7619d40e-1add-4ec8-9e76-f053aa9f07e8
Will not apply HSTS. The HSTS database must be a regular and non-world-writable file.
ERROR: could not open HSTS store at '/root/.wget-hsts'. HSTS will be disabled.
--2022-11-26 12:07:27--
Resolving git.os-guru.de... 161.97.93.200, 2a02:c207:3006:2681::1
Connecting to git.os-guru.de|161.97.93.200|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 3261 (3.2K) [text/plain]
Saving to: 'ffmpegwrapper-setup.sh'
ffmpegwrapper-setup 100%[===================>] 3.18K --.-KB/s in 0s
2022-11-26 12:07:27 (479 MB/s) - 'ffmpegwrapper-setup.sh' saved [3261/3261]
--2022-11-26 12:08:31--
2022-11-26 12:08:31 (540 MB/s) - 'ffmpegwrapper-setup.sh' saved [3261/3261]
root@Server:/volume1/volume/data/scripts# chmod +x ffmpegwrapper-setup.sh
root@Server:/volume1/volume/data/scripts# ./ffmpegwrapper-setup.sh
ffmpeg wrapper setup by Philipp S.
Wrapper by AlexPresso
USE AT YOUR OWN RISK!
What should the script do?
1 - Install // 2 - Update // 3 - Uninstall // other letters oder numbers = quit
Enter a number:
Download and install the new ffmpeg...
--2022-11-26 12:12:08--
https://raw.githubusercontent.com/AlexPresso/VideoStation-FFMPEG-Patcher/main/ffmpeg-wrapper.sh
Resolving raw.githubusercontent.com... 185.199.110.133, 185.199.109.133, 185.199.111.133, ...
Connecting to raw.githubusercontent.com|185.199.110.133|:443... connected.
Length: 869 [text/plain]
Saving to: 'STDOUT'
- 100%[===================>] 869 --.-KB/s in 0s
2022-11-26 12:12:08 (41.8 MB/s) - written to stdout [869/869]
Set new permissions...
Backup the original libsynovte.so...
Apply the wrapper to the decoder...
Patch the libsynovte.so...
Restarting the VideoStation...
Done! Thank you for using the script
