Fragen zum iStat-Server
sonicwave3
12. Mrz 2011
DS1511> ipkg list_installed binutils
Successfully terminated.
DS1511>
bin mir jetzt nicht sicher ob die ausgabe so ok ist oder ob er sie nur abgebrochen hat
ich tippe auf abgebrochen
DS1511> ipkg install binutils
Installing binutils (2.19.1-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/binutils_2.19.1-1_i686.ipk
Configuring binutils
update-alternatives: Linking //opt/bin/strings to /opt/bin/binutils-strings
DS1511>
tadaaaaaa ;)
vielen lieben dank
DS1511> ./configure --prefix=/opt --sysconfdir=/opt/etc
checking for a BSD-compatible install... /opt/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /opt/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for ranlib... ranlib
checking for g++... g++
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for style of include used by make... GNU
checking dependency style of g++... gcc3
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking for ar... ar
checking if the compiler supports -Wall... yes
checking if the linker supports -rdynamic... yes
checking for sensors_init in -lsensors... no
checking for xml2-config... xml2-config
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /opt/bin/grep
checking for egrep... /opt/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking libxml/parser.h usability... yes
checking libxml/parser.h presence... yes
checking for libxml/parser.h... yes
checking for xmlFileOpen... yes
checking for kstat_open in -lkstat... no
checking for kvm_open in -lkvm... no
checking for perfstat_cpu_total in -lperfstat... no
checking for getloadavg... yes
checking whether time.h and sys/time.h may both be included... yes
checking for clock_gettime... no
checking for sysctl... yes
checking for swapctl... no
checking for statvfs... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking mntent.h usability... yes
checking mntent.h presence... yes
checking for mntent.h... yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking paths.h usability... yes
checking paths.h presence... yes
checking for paths.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/statfs.h usability... yes
checking sys/statfs.h presence... yes
checking for sys/statfs.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking sys/mnttab.h usability... no
checking sys/mnttab.h presence... no
checking for sys/mnttab.h... no
checking sys/loadavg.h usability... no
checking sys/loadavg.h presence... no
checking for sys/loadavg.h... no
checking kstat.h usability... no
checking kstat.h presence... no
checking for kstat.h... no
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking sys/sysinfo.h usability... yes
checking sys/sysinfo.h presence... yes
checking for sys/sysinfo.h... yes
checking sys/processor.h usability... no
checking sys/processor.h presence... no
checking for sys/processor.h... no
checking sys/swap.h usability... yes
checking sys/swap.h presence... yes
checking for sys/swap.h... yes
checking kvm.h usability... no
checking kvm.h presence... no
checking for kvm.h... no
checking alloca.h usability... yes
checking alloca.h presence... yes
checking for alloca.h... yes
checking sys/resource.h usability... yes
checking sys/resource.h presence... yes
checking for sys/resource.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking sys/sysctl.h usability... yes
checking sys/sysctl.h presence... yes
checking for sys/sysctl.h... yes
checking sys/vmmeter.h usability... no
checking sys/vmmeter.h presence... no
checking for sys/vmmeter.h... no
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sensors/sensors.h usability... no
checking sensors/sensors.h presence... no
checking for sensors/sensors.h... no
checking libperfstat.h usability... no
checking libperfstat.h presence... no
checking for libperfstat.h... no
checking for sys/mount.h... yes
checking for net/if.h... yes
checking for net/if_mib.h... no
checking for stdbool.h that conforms to C99... yes
checking for _Bool... yes
checking for pid_t... yes
checking vfork.h usability... no
checking vfork.h presence... no
checking for vfork.h... no
checking for fork... yes
checking for vfork... yes
checking for working fork... yes
checking for working vfork... (cached) yes
checking for library containing getmntent... none required
checking for gethostbyname... yes
checking for getmntent... (cached) yes
checking for getmntinfo... no
checking for inet_ntoa... yes
checking for memset... yes
checking for mkdir... yes
checking for select... yes
checking for socket... yes
checking for strerror... yes
checking for statvfs... (cached) yes
checking for setmntent... yes
checking for struct mnttab.mnt_special... no
checking for struct mntent.mnt_fsname... yes
checking for struct statvfs.f_frsize... yes
checking for default location of configuration file... /opt/etc/istat.conf
checking CPU usage probe type... procfs
checking load average probe type... getloadavg
checking memory usage probe type... procfs
checking swap probe type... procfs
checking uptime probe type... procfs
checking network activity probe type... procfs
checking disk space probe type... statvfs
configure: creating ./config.status
config.status: creating Makefile
config.status: creating resource/Makefile
config.status: creating probes/Makefile
config.status: creating libfslabel/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
DS1511>
sonicwave3
12. Mrz 2011
damn it, kann das nicht einfach mal einfach sein? *grummel
ich resette das ding gleich und lebe ohne istat
dennoch vielen lieben dank
DS1511> make
make  all-recursive
make[1]: Entering directory `/volume1/public/istatd-057'
Making all in probes
make[2]: Entering directory `/volume1/public/istatd-057/probes'
gcc -DHAVE_CONFIG_H -I. -I..   -Wall -I/opt/include/libxml2  -g -O2 -MT kstat.o -MD -MP -MF .deps/kstat.Tpo -c -o kstat.o kstat.c
mv -f .deps/kstat.Tpo .deps/kstat.Po
gcc -DHAVE_CONFIG_H -I. -I..   -Wall -I/opt/include/libxml2  -g -O2 -MT swapctl.o -MD -MP -MF .deps/swapctl.Tpo -c -o swapctl.o swapctl.c
mv -f .deps/swapctl.Tpo .deps/swapctl.Po
gcc -DHAVE_CONFIG_H -I. -I..   -Wall -I/opt/include/libxml2  -g -O2 -MT procfs.o -MD -MP -MF .deps/procfs.Tpo -c -o procfs.o procfs.c
mv -f .deps/procfs.Tpo .deps/procfs.Po
gcc -DHAVE_CONFIG_H -I. -I..   -Wall -I/opt/include/libxml2  -g -O2 -MT getloadavg.o -MD -MP -MF .deps/getloadavg.Tpo -c -o getloadavg.o getloadavg.c
mv -f .deps/getloadavg.Tpo .deps/getloadavg.Po
gcc -DHAVE_CONFIG_H -I. -I..   -Wall -I/opt/include/libxml2  -g -O2 -MT statfs.o -MD -MP -MF .deps/statfs.Tpo -c -o statfs.o statfs.c
mv -f .deps/statfs.Tpo .deps/statfs.Po
gcc -DHAVE_CONFIG_H -I. -I..   -Wall -I/opt/include/libxml2  -g -O2 -MT kvm.o -MD -MP -MF .deps/kvm.Tpo -c -o kvm.o kvm.c
mv -f .deps/kvm.Tpo .deps/kvm.Po
gcc -DHAVE_CONFIG_H -I. -I..   -Wall -I/opt/include/libxml2  -g -O2 -MT sysctl.o -MD -MP -MF .deps/sysctl.Tpo -c -o sysctl.o sysctl.c
mv -f .deps/sysctl.Tpo .deps/sysctl.Po
gcc -DHAVE_CONFIG_H -I. -I..   -Wall -I/opt/include/libxml2  -g -O2 -MT lm_sensors3.o -MD -MP -MF .deps/lm_sensors3.Tpo -c -o lm_sensors3.o lm_sensors3.c
mv -f .deps/lm_sensors3.Tpo .deps/lm_sensors3.Po
gcc -DHAVE_CONFIG_H -I. -I..   -Wall -I/opt/include/libxml2  -g -O2 -MT lm_sensors4.o -MD -MP -MF .deps/lm_sensors4.Tpo -c -o lm_sensors4.o lm_sensors4.c
mv -f .deps/lm_sensors4.Tpo .deps/lm_sensors4.Po
gcc -DHAVE_CONFIG_H -I. -I..   -Wall -I/opt/include/libxml2  -g -O2 -MT qnap_temp.o -MD -MP -MF .deps/qnap_temp.Tpo -c -o qnap_temp.o qnap_temp.c
mv -f .deps/qnap_temp.Tpo .deps/qnap_temp.Po
gcc -DHAVE_CONFIG_H -I. -I..   -Wall -I/opt/include/libxml2  -g -O2 -MT perfstat.o -MD -MP -MF .deps/perfstat.Tpo -c -o perfstat.o perfstat.c
mv -f .deps/perfstat.Tpo .deps/perfstat.Po
rm -f libprobes.a
ar cru libprobes.a kstat.o swapctl.o procfs.o getloadavg.o statfs.o kvm.o sysctl.o lm_sensors3.o lm_sensors4.o qnap_temp.o perfstat.o
ranlib libprobes.a
make[2]: Leaving directory `/volume1/public/istatd-057/probes'
Making all in libfslabel
make[2]: Entering directory `/volume1/public/istatd-057/libfslabel'
gcc -DHAVE_CONFIG_H -I. -I..   -Wall -I/opt/include/libxml2  -g -O2 -MT fslabel.o -MD -MP -MF .deps/fslabel.Tpo -c -o fslabel.o fslabel.c
mv -f .deps/fslabel.Tpo .deps/fslabel.Po
gcc -DHAVE_CONFIG_H -I. -I..   -Wall -I/opt/include/libxml2  -g -O2 -MT ext.o -MD -MP -MF .deps/ext.Tpo -c -o ext.o ext.c
mv -f .deps/ext.Tpo .deps/ext.Po
rm -f libfslabel.a
ar cru libfslabel.a fslabel.o ext.o
ranlib libfslabel.a
gcc -DHAVE_CONFIG_H -I. -I..   -Wall -I/opt/include/libxml2  -g -O2 -MT fsident.o -MD -MP -MF .deps/fsident.Tpo -c -o fsident.o fsident.c
mv -f .deps/fsident.Tpo .deps/fsident.Po
gcc  -g -O2  -rdynamic -o fsident fsident.o libfslabel.a -L/opt/lib -lxml2 -lz -lm
make[2]: Leaving directory `/volume1/public/istatd-057/libfslabel'
Making all in .
make[2]: Entering directory `/volume1/public/istatd-057'
g++ -DHAVE_CONFIG_H -I.   -Wall -I/opt/include/libxml2  -g -O2 -MT main.o -MD -MP -MF .deps/main.Tpo -c -o main.o main.cpp
mv -f .deps/main.Tpo .deps/main.Po
g++ -DHAVE_CONFIG_H -I.   -Wall -I/opt/include/libxml2  -g -O2 -MT conf.o -MD -MP -MF .deps/conf.Tpo -c -o conf.o conf.cpp
mv -f .deps/conf.Tpo .deps/conf.Po
g++ -DHAVE_CONFIG_H -I.   -Wall -I/opt/include/libxml2  -g -O2 -MT argument.o -MD -MP -MF .deps/argument.Tpo -c -o argument.o argument.cpp
mv -f .deps/argument.Tpo .deps/argument.Po
g++ -DHAVE_CONFIG_H -I.   -Wall -I/opt/include/libxml2  -g -O2 -MT switchboard.o -MD -MP -MF .deps/switchboard.Tpo -c -o switchboard.o switchboard.cpp
mv -f .deps/switchboard.Tpo .deps/switchboard.Po
g++ -DHAVE_CONFIG_H -I.   -Wall -I/opt/include/libxml2  -g -O2 -MT socket.o -MD -MP -MF .deps/socket.Tpo -c -o socket.o socket.cpp
mv -f .deps/socket.Tpo .deps/socket.Po
g++ -DHAVE_CONFIG_H -I.   -Wall -I/opt/include/libxml2  -g -O2 -MT socketset.o -MD -MP -MF .deps/socketset.Tpo -c -o socketset.o socketset.cpp
mv -f .deps/socketset.Tpo .deps/socketset.Po
g++ -DHAVE_CONFIG_H -I.   -Wall -I/opt/include/libxml2  -g -O2 -MT clientset.o -MD -MP -MF .deps/clientset.Tpo -c -o clientset.o clientset.cpp
mv -f .deps/clientset.Tpo .deps/clientset.Po
g++ -DHAVE_CONFIG_H -I.   -Wall -I/opt/include/libxml2  -g -O2 -MT isr.o -MD -MP -MF .deps/isr.Tpo -c -o isr.o isr.cpp
mv -f .deps/isr.Tpo .deps/isr.Po
g++ -DHAVE_CONFIG_H -I.   -Wall -I/opt/include/libxml2  -g -O2 -MT daemon.o -MD -MP -MF .deps/daemon.Tpo -c -o daemon.o daemon.cpp
mv -f .deps/daemon.Tpo .deps/daemon.Po
g++ -DHAVE_CONFIG_H -I.   -Wall -I/opt/include/libxml2  -g -O2 -MT stats.o -MD -MP -MF .deps/stats.Tpo -c -o stats.o stats.cpp
mv -f .deps/stats.Tpo .deps/stats.Po
g++ -DHAVE_CONFIG_H -I.   -Wall -I/opt/include/libxml2  -g -O2 -MT token.o -MD -MP -MF .deps/token.Tpo -c -o token.o token.cpp
mv -f .deps/token.Tpo .deps/token.Po
g++ -DHAVE_CONFIG_H -I.   -Wall -I/opt/include/libxml2  -g -O2 -MT utility.o -MD -MP -MF .deps/utility.Tpo -c -o utility.o utility.cpp
mv -f .deps/utility.Tpo .deps/utility.Po
g++  -g -O2  -rdynamic -o istatd main.o conf.o argument.o switchboard.o socket.o socketset.o clientset.o isr.o daemon.o stats.o token.o utility.o probes/libprobes.a libfslabel/libfslabel.a -L/opt/lib -lxml2 -lz -lm
main.o: In function `__exchange_and_add':
/volume1/@optware/bin/../lib/gcc/i686-linux-gnu/4.2.1/../../../../include/c++/4.2.1/ext/atomicity.h:51: undefined reference to `__sync_fetch_and_add_4'
/volume1/@optware/bin/../lib/gcc/i686-linux-gnu/4.2.1/../../../../include/c++/4.2.1/bits/basic_string.h:288: undefined reference to `__sync_fetch_and_add_4'
main.o:/volume1/@optware/bin/../lib/gcc/i686-linux-gnu/4.2.1/../../../../include/c++/4.2.1/bits/basic_string.h:288: more undefined references to `__sync_fetch_and_add_4' follow
collect2: ld returned 1 exit status
make[2]: *** [istatd] Error 1
make[2]: Leaving directory `/volume1/public/istatd-057'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/volume1/public/istatd-057'
make: *** [all] Error 2
DS1511>
janus
07. Sep 2010
Na geht doch :)
Janus
janus
07. Sep 2010
Na geht doch :)
Janus
Super-Grobi
28. Sep 2010
Hmm, naja, wohl nicht soooo ganz
Super-Grobi
28. Sep 2010
Hmm, nee, der Fehler ist ein Anderer. Die Ursache könnte schon ein falscher Pfad sein, wodurch evtl eine falsche oder keine lib eingebunden wird.
Aber der eigentliche Grund ist, das er eine Reference zu __sync_fetch_and_add_4 nicht hat.
Und das dürfte wohl eine Linkermeldung sein, d.h. würde bedeuten, dass evtl. nur eine richtige Lib fehlt in der dann das
__sync_fetch_and_add_4 defined ist, so dass der Linker die Referenz dazu mit Sinnhaftem füllen kann.
Aber da kann Dir glaub ich nur jemand weiterhelfen, der sich mit dem gcc und den linux standardbibliotheken auskennt.
grüße
Jörg
janus
07. Sep 2010
Moin,
wenn ich das richtig verstanden habe, dann fehlt mindestens ein -march.
Zitat:
"Pass -march=i486 to the compiler. i386 are not supported anymore."
Evtl. sollte es ein "-march=native" besser tun! Das ganze in die CFLAGS und in die CXXFLAGS!
Janus
flostere
09. Mrz 2011
Moin moin,
ich besitze eine DS1511+ und wollte den iStat Server auch einmal ausprobieren. Leider stoße ich auf ähnliche Probleme.
Vielleicht seid ihr hier ja inzwischen weitergekommen?
DiskStation> make
make  all-recursive
make[1]: Entering directory `/volume1/public/istatd-0.5.7'
make[2]: Entering directory `/volume1/public/istatd-0.5.7/probes'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/volume1/public/istatd-0.5.7/probes'
make[2]: Entering directory `/volume1/public/istatd-0.5.7/libfslabel'
make[2]: Leaving directory `/volume1/public/istatd-0.5.7/libfslabel'
Making all in .
make[2]: Entering directory `/volume1/public/istatd-0.5.7'
g++  -march=i686  -rdynamic -o istatd main.o conf.o argument.o switchboard.o socket.o socketset.o clientset.o isr.o daemon.o stats.o token.o utility.o probes/libprobes.a libfslabel/libfslabel.a -L/opt/lib -lxml2 -lz -lm
/opt/lib/gcc/i686-linux-gnu/4.2.1/../../../../include/c++/4.2.1/ext/atomicity.h:51: undefined reference to `__sync_fetch_and_add_4'
/opt/lib/gcc/i686-linux-gnu/4.2.1/../../../../include/c++/4.2.1/bits/basic_string.h:288: undefined reference to `__sync_fetch_and_add_4'
main.o:/opt/lib/gcc/i686-linux-gnu/4.2.1/../../../../include/c++/4.2.1/bits/basic_string.h:288: more undefined references to `__sync_fetch_and_add_4' follow
make[2]: Leaving directory `/volume1/public/istatd-0.5.7'
make[1]: Leaving directory `/volume1/public/istatd-0.5.7'
DiskStation>
Ich kenne mich mit dem Kompilieren nicht so gut aus. Flags müssen doch vor dem make ins ./configure mit eingebaut werden, allerdings ist das für mich nicht ganz verständlich, welche FLAGS und Optionen ich dort setzen muss im Probleme zu lösen.
Hoffentlich könnt ihr hier helfen?
Viele Grüße,
Flo
m4c_e7e
08. Okt 2011
gibt es die möglichkeit die temperatur der festplatten auszulesen ? danke
flostere
09. Mrz 2011
Ja diese Option gibt es, allerdings ist dieser Thread ziemlich tod... Hast du den iStat-Server zum Laufen bekommen? Auf welcher Diskstation willst du den Server denn betreiben?
Grüße
Flostére
m4c_e7e
08. Okt 2011
hi,
hab den istat server auf einer ds411j sauber und ohne probleme zum laufen bekommen.
flostere
09. Mrz 2011
Dann werde ich der sache auf meiner 1511+ auch noch mal auf genauer auf den Grund gehen! Muss ja irgendwie zu machen sein...
Anna_Konda
01. Sep 2010
Zum Thema Temperatur:
Jein. Über smart geht es wohl nicht, wohl aber über lm_sensors. (siehe https://github.com/tiwilliam/istatd/issues/32)
Soweit ich weiss, gibt es für meine Diskstation (210j) kein lm_sensors oder zumindest keinen entsprechenden Sensor.
(Bitte korrigiert mich, wenn das nicht (mehr) stimmt.)
Zum Thema x86 kann ich grundsätzlich nichts sagen, da ich weder eine Diskstation mit so einem Prozessor besitze, noch ein Linux-crack bin, tut mir leid!
Unter dem Link oben kann man leider auch lesen, dass der istatd nicht mehr weiterentwickelt wird.
Schade. Aber der aktuelle Funktionsumfang ist auch nicht schlecht.
Grüße Anna
Anna_Konda
01. Sep 2010
relativ unbemerkt gab es ein update auf istatd 0.5.8.
Da von gefixten memory leaks die Rede ist, macht ein update evtl. Sinn.
iStat ist nun leider im App-Store nicht mehr erhältlich. iStat 2 als Nachfolger kostet jetzt stolze 4,49€!
Hat das mal jemand getestet?
Grüße, Anna
amarthius
Super-Moderator
Teammitglied
03. Jun 2009
Nein und werde ich auch nicht. Für das alte iStat kamen 2 lausige Updates. Es war Monate lang noch im Store vertreten, obwohl es ab einer bestimmten Softwareversion nicht mehr lief.
Jetzt iStat 2 für 4,50€? Hätte man wenigstens mal Einen Einführungspreis machen sollen, oder alle Käufer vom alten iStat anschreiben und Codes verschicken.
Anna_Konda
01. Sep 2010
das verstehe ich nicht ganz. Das alte iStat benutze ich immer noch, auf einem iPod Touch 3 und iPad 2 unter IOS 5.0.1 und auf einem iPhone 4s mit IOS 6.0,
und überall läuft es ohne Probleme, daher habe ich auch im Moment keinen Bedarf an iStat 2, höchstens für das iPad.
Ich will sicher keine Werbung machen, ich habe mit iStat nichts zu tun!
Grüße, Anna
amarthius
Super-Moderator
Teammitglied
03. Jun 2009
Bei mir lief es irgendwann nicht mehr. War auch laut Rezessionen von der alten App auch bei vielen anderen so. Du scheinst die gute Ausnahme zu sein :D
donkhan
22. Mai 2011
was es jemanden Interessiert, mit Istat 2 funktioniert das ganze auch :)
lil-ac
14. Feb 2013
habe nun Istat zum laufen bekommen, läuft auch alles TOP, nur im IOS Interface wird unter IP NA angezeigt. Was ist falsch eingestellt? IP ist feste Eingestellt und folgendes in der Confi: monitor_net ( eth0 )
