pyLoad 0.4.9 .spk (armv7) - Armada
Hallo Zusammen,
wollte euch mal fragen ob mir jemand das LOG deuten kann? Was läuft hier schief...Pyload fängt an zu laden (5 Container) dann aber bricht es ab?? :-(
310   27.10.2014 08:44:30   DEBUG   UploadedTo: Get Account Info for Kusselin
311   27.10.2014 08:44:31   DEBUG   UploadedTo: Account Info: {'maxtraffic': 52428800, 'validuntil': 1416919471.3125491, 'trafficleft': 429916160}
312   27.10.2014 08:44:31   DEBUG   UploadedTo: UploadedTo: Use Premium Account (410GB left)
313   27.10.2014 08:44:31   INFO   Download starts: FallSki-XB-PAL-ByMrpiano.part5.rar
314   27.10.2014 08:44:32   DEBUG   Content-Disposition: FallSki-XB-PAL-ByMrpiano.part6.rar
315   27.10.2014 08:44:32   DEBUG   UploadedTo: Get Account Info for Kusselin
316   27.10.2014 08:44:33   DEBUG   UploadedTo: Account Info: {'maxtraffic': 52428800, 'validuntil': 1416919473.0756969, 'trafficleft': 429916160}
317   27.10.2014 08:44:33   DEBUG   UploadedTo: UploadedTo: Use Premium Account (410GB left)
318   27.10.2014 08:44:33   INFO   Download starts: FallSki-XB-PAL-ByMrpiano.part4.rar
319   27.10.2014 08:44:34   DEBUG   Content-Disposition: FallSki-XB-PAL-ByMrpiano.part5.rar
320   27.10.2014 08:44:35   DEBUG   UploadedTo: Get Account Info for Kusselin
321   27.10.2014 08:44:36   DEBUG   UploadedTo: Account Info: {'maxtraffic': 52428800, 'validuntil': 1416919476.4230011, 'trafficleft': 429916160}
322   27.10.2014 08:44:36   INFO   Download starts: FallSki-XB-PAL-ByMrpiano.part3.rar
323   27.10.2014 08:44:36   DEBUG   UploadedTo: UploadedTo: Use Premium Account (410GB left)
324   27.10.2014 08:44:37   DEBUG   UploadedTo: Get Account Info for Kusselin
325   27.10.2014 08:44:37   DEBUG   Content-Disposition: FallSki-XB-PAL-ByMrpiano.part4.rar
326   27.10.2014 08:44:37   DEBUG   UploadedTo: Account Info: {'maxtraffic': 52428800, 'validuntil': 1416919477.7549241, 'trafficleft': 429916160}
327   27.10.2014 08:44:37   DEBUG   UploadedTo: UploadedTo: Use Premium Account (410GB left)
328   27.10.2014 08:44:38   DEBUG   Content-Disposition: FallSki-XB-PAL-ByMrpiano.part3.rar
329   27.10.2014 08:45:27   DEBUG   Chunk 1 failed: (28, 'Operation too slow. Less than 5 bytes/sec transferred the last 30 seconds')
330   27.10.2014 08:45:27   DEBUG   pycurl exception 28: Operation too slow. Less than 5 bytes/sec transferred the last 30 seconds
331   27.10.2014 08:45:27   WARNING   Couldn't connect to host or connection reset, waiting 1 minute and retry.
332   27.10.2014 08:45:27   DEBUG   Chunk 1 failed: (28, 'Operation too slow. Less than 5 bytes/sec transferred the last 30 seconds')
333   27.10.2014 08:45:27   DEBUG   pycurl exception 28: Operation too slow. Less than 5 bytes/sec transferred the last 30 seconds
334   27.10.2014 08:45:27   WARNING   Couldn't connect to host or connection reset, waiting 1 minute and retry.
335   27.10.2014 08:45:27   DEBUG   Chunk 1 failed: (28, 'Operation too slow. Less than 5 bytes/sec transferred the last 30 seconds')
336   27.10.2014 08:45:27   DEBUG   pycurl exception 28: Operation too slow. Less than 5 bytes/sec transferred the last 30 seconds
337   27.10.2014 08:45:27   WARNING   Couldn't connect to host or connection reset, waiting 1 minute and retry.
338   27.10.2014 08:45:27   DEBUG   Chunk 1 failed: (28, 'Operation too slow. Less than 5 bytes/sec transferred the last 30 seconds')
339   27.10.2014 08:45:27   DEBUG   pycurl exception 28: Operation too slow. Less than 5 bytes/sec transferred the last 30 seconds
340   27.10.2014 08:45:27   WARNING   Couldn't connect to host or connection reset, waiting 1 minute and retry.
341   27.10.2014 08:45:27   DEBUG   Chunk 1 failed: (28, 'Operation too slow. Less than 5 bytes/sec transferred the last 30 seconds')
342   27.10.2014 08:45:27   DEBUG   pycurl exception 28: Operation too slow. Less than 5 bytes/sec transferred the last 30 seconds
343   27.10.2014 08:45:27   WARNING   Couldn't connect to host or connection reset, waiting 1 minute and retry.
Sagt mal hat keiner von euch Probleme mit Pyload?
Über ne kurze info danke ich euch
Gruss
Hallo Kusselin...
nein, ich habe keinerlei Probleme mit diesem PyLoad auf meiner DS213j... ;-)
In deinem LOG sieht es ganz danach aus, als würde ab dem 5. Container nur noch mit weniger als 5kb/sec heruntergeladen werden... dann bricht er ab.
Hallo Kusselin...
Komisch das hatte ich noch nie!! Mit dem account hat das auch nix zu tun oder? Habe premium!! Und egal welches file ich nehme immer abbruch??
Ich habe gerade mal einen testdownload über uploaded gemacht ebenfalls mit premium und hatte keinerlei probleme... eventuell senkt dein Provider die Downloadrate?... Keine Ahnung warum das bei dir so ist...
Hast du zufälligerweise einen Provider der ab einem gewissen Datenvolumen das Internet drosselt? Man muss dazu wissen das die Drosselung allerdings meistens nur auf OCH, torrents etc. stattfindet.
Beispielsweise drosselt Kabel Deutschland ab 60 GB pro Tag den Download bei OCH etc. auf 100 KB/s.
Ich habe ne fritzbox.. Da sieht man das ja oder?
Gruss
Aktuell: DSL 3.5 Mbit/sec.
Wie immer
Hallo Pulpi,
bin bei KabelBW und da wurde bisher noch nichts gedrosselt, auch nach 600GB Tagesdownloadvolumen...
Nein Kusselin, das sieht man eben nicht! Am besten lädst du einfach mal per Hand eine Part-Datei herunter, also direkt von der Uploaded-Seite.
@Echse27: KabelBW hat auch keine Drosselung, wie man diesem Beitrag auf Winfuture beispielsweise entnehmen kann.
Nee ich bin bei der Telekom und habe eine 4000er leitung..ich hatte bis jetzt nie probleme!! hBE AUCH KEIN uPDATE GEMACHT DER ds!!
Sorry aber das habe ich noch nicht gemacht...wie geht das? sorry wenn ich so dumm frage...wie geht das von der Upload seite direkt??
Gruss
so bin jetzt einfach mal nicht auf click & load gegangen sondern auf einen einzelnen Part...und siehe da da steht dann premium download und ich klick drauf und es fängt an zu laden..dann bin ich zb auf part 2 und auch der wird geladen.... also kanns ja nicht an dem liegen!!
irgendwas hat pyload?????
click & load?... hast du eine entsprechende umleitung in deinem Browser zum PyLoad-Downloader...?
Ich lade bisher immer nur die DLC-Container herunter und füge sie dann in PyLoad hinzu... der rest passiert dann automatisch... Download und Entpacken...
Ja mit flasgot geht das.. Hat ja alles funktioniert bis gestern.. Kann jetzt nur sein das an der telekomleitung was nicht stimmt?? Sonst hätten das ja mehr leuts hier also denke ich liegts an der zuleitung weil ich habe nix geändert!!
Das ist gut möglich...
Behalt es einfach mal im Auge, vielleicht gehts morgen ja schon wieder wie gewohnt!? ;-)
Komisch komisch.... Das ich eine kleine geschwindigkeit habe ist mir bewusst aber das pyload jetzt sagt zu langsam!!
Naja mal beobachten
Wie habt ihr die synology angeschlossen? Direkt an router oder an switch?
hat für mich auch noch jemand einen Tipp, mit der "ExtractArchive" Problematik von Post 220
Vielen Dank
@Kusselin, meine DS ist direkt am Router angeschlossen und läuft mit einer 100mbit Leitung sehr gut.
Und pyload funzt auch noch bei dir? Also es bricht nichts ab und auch dein log ist ok?
Ja. Absolut keine Schwierigkeiten. Läuft sauber durch und alle parts werden komplett geladen.Nur entpacken will er bei mir nicht.
Meine Einstellungen sind:
Limit Download Speed: aus
Download interface to bind (ip or Name): None
Skip already existing files: an
Max Download Speed in kb/s: -1
Allow IPv6: an
vielleicht hilft es. mfg
