Ultimate Backup Ultimate Backup
dachserl
24. Sep 2015
Hallo Tommes,
danke - war bisher stiller Leser ;)
Hier einmal das komplette Debug - entweder habe ich Tomaten auf den Augen oder foundbackups.txt ist dort nicht zu finden.
Danke schonmal vorab!
Gesetzte Variablen:
BASH=/bin/bash
BASHOPTS=cmdhist:complete_fullquote:extquote:force_fignore:hostcomplete:interactive_comments:progcomp:promptvars:sourcepath
BASH_ALIASES=()
BASH_ARGC=([0]="1")
BASH_ARGV=([0]="./debug.sh")
BASH_CMDS=()
BASH_LINENO=([0]="145" [1]="0")
BASH_SOURCE=([0]="./debug.sh" [1]="/usr/syno/synoman/webman/3rdparty/UltimateBackup/index.cgi")
BASH_VERSINFO=([0]="4" [1]="3" [2]="48" [3]="1" [4]="release" [5]="armle-unknown-linux-gnu")
BASH_VERSION='4.3.48(1)-release'
CONTENT_LENGTH=
CONTENT_TYPE=
DIRSTACK=()
DOCUMENT_ROOT=/usr/syno/synoman
DOCUMENT_URI=/webman/3rdparty/UltimateBackup/index.cgi
ENABLE_X_ACCEL_REDIRECT=yes
EUID=0
GATEWAY_INTERFACE=CGI/1.1
GROUPS=()
HOSTNAME=DachsStation
HOSTTYPE=armle
HTTPS=on
HTTP_ACCEPT='text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8'
HTTP_ACCEPT_ENCODING='gzip, deflate, sdch, br'
HTTP_ACCEPT_LANGUAGE='de-DE,de;q=0.8,en-US;q=0.6,en;q=0.4'
HTTP_CONNECTION=keep-alive
HTTP_COOKIE='stay_login=0; id=m7UhBJz9pjofY1510MYN335101'
HTTP_HOST=nas.dachs.lan:5001
HTTP_REFERER=https://nas.dachs.lan:5001/webman/3rdparty/UltimateBackup/index.cgi
HTTP_UPGRADE_INSECURE_REQUESTS=1
HTTP_USER_AGENT='Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36'
IFS=$' \t\n'
INSTANCE=
JOB=apparmor
MACHTYPE=armle-unknown-linux-gnu
OPTERR=1
OPTIND=1
OSTYPE=linux-gnu
PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/syno/bin:/usr/syno/sbin
PATH_INFO=
PIPESTATUS=([0]="0")
PPID=5539
PS4='+ '
PWD=/volume1/@appstore/UltimateBackup
QUERY_STRING=page=debug
REMOTE_ADDR=192.168.179.90
REMOTE_PORT=53946
REQUEST_METHOD=GET
REQUEST_SCHEME=https
REQUEST_URI='/webman/3rdparty/UltimateBackup/index.cgi?page=debug'
SCGI=1
SCRIPT_FILENAME=/usr/syno/synoman/webman/3rdparty/UltimateBackup/index.cgi
SCRIPT_NAME=/webman/3rdparty/UltimateBackup/index.cgi
SERVER_ADDR=192.168.179.119
SERVER_NAME=nas.dachs.lan
SERVER_PORT=5001
SERVER_PROTOCOL=HTTP/1.1
SERVER_SOFTWARE=nginx/1.11.3
SHELL=/bin/ash
SHELLOPTS=braceexpand:hashall:interactive-comments
SHLVL=1
SOCKET=/run/synoscgi.sock
TERM=linux
UID=0
UPSTART_EVENTS='syno.network.ready started'
UPSTART_INSTANCE=
UPSTART_JOB=synoscgi
_='
Gesetzte Variablen:
backifs=$' \t\n'
debuginfo=$'foundbackups.txt\nvar.txt'
decode_value=debug
dir=/volume1/@appstore/UltimateBackup
encode_page=debug
encode_value=debug
login=$'\ntoken: B7bY4WYTDdpmI user: admin\n admin: 1'
login_admin=1
login_user=admin
mainpage=debug
page=debug
script=debug.sh
site=debug
siteless=
sitemore=
stop=/volume1/@appstore/UltimateBackup/usersettings/stop.txt
usersettings=/volume1/@appstore/UltimateBackup/usersettings
var=/volume1/@appstore/UltimateBackup/usersettings/var.txt
variable=page
Tommes
26. Okt 2009
Das ist ja seltsam. Kannst du bitte mal unter "Aufträge" die Auftragsliste aktualisieren, also das Symbol mit den beiden sich drehenden Pfeilen, oben rechts! Nach dem Suchlauf bitte nochmal die Seite "Debug" aufrufen und schauen ob jetzt eine foundbackups.txt existiert. Falls ja, dann sollten die Aufträge auch im Zeitplaner auftauchen. Falls nicht, tja dann... müssen wir weiter suchen.
Tommes
dachserl
24. Sep 2015
Na klar - bin nun auf die beiden Pfeile, habe dann auf dem externen Datenträger nach dem Script suchen lassen, dieses wurde auch gefunden.
Neues Debug:
Gesetzte Variablen:
BASH=/bin/bash
BASH_ALIASES=()
BASH_ARGC=([0]="1")
BASH_CMDS=()
CONTENT_LENGTH=
CONTENT_TYPE=
DIRSTACK=()
EUID=0
GROUPS=()
HOSTTYPE=armle
HTTP_ACCEPT_ENCODING='gzip, deflate, sdch'
HTTP_COOKIE='stay_login=0; id=kzcCFoeSRMGzE1510MYN335101'
HTTP_HOST=192.168.179.119:5000
HTTP_REFERER='http://192.168.179.119:5000/webman/3rdparty/UltimateBackup/index.cgi?page=start'
HTTP_USER_AGENT='Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36'
IFS=$' \t\n'
INSTANCE=
JOB=apparmor
OPTERR=1
OPTIND=1
OSTYPE=linux-gnu
PATH_INFO=
PPID=6017
PS4='+ '
REMOTE_ADDR=192.168.179.94
REMOTE_PORT=61372
REQUEST_METHOD=GET
REQUEST_SCHEME=http
SCGI=1
SERVER_NAME=192.168.179.119
SERVER_PORT=5000
SERVER_SOFTWARE=nginx/1.11.10
SHELL=/bin/ash
SHLVL=1
TERM=linux
UID=0
UPSTART_INSTANCE=
_='
Gesetzte Variablen:
backifs=$' \t\n'
decode_value=debug
encode_page=debug
encode_value=debug
login=$'\ntoken: vzdUeD8FWW8kU user: admin\n admin: 1'
login_admin=1
login_user=admin
mainpage=debug
page=debug
script=debug.sh
site=debug
siteless=
sitemore=
variable=page
PsychoHH
03. Jul 2013
Ah alles klar.
Haben zuletzt die ganze Suche geändert.
Ich schaue mir das bald mal an.
Danke
Swp2000
29. Nov 2013
Kann man mit UB auch eine bereits gesicherten Datenkopie wieder aufnehmen? Sprich, wenn das Quell NAS neu installiert werden musste, sodass ich meine bereits gesicherten Daten an der Stelle wieder fortführen kann, oder ist dies nicht möglich?
Das vermisste ich bei der "Remote Datenkopie" von Synology schon. Ich möchte ungern nochmal x- TB an Daten neu sichern nur weil der Backup Job weg ist.
Tommes
26. Okt 2009
Ehrlich gesagt habe ich dieses Szenario noch nie durchgespielt, aber theoretisch sollte dein Vorhaben funktionieren. Das setzt jedoch voraus, das weder an den Daten in der Qelle noch im Ziel zwischenzeitlich etwas verändert wurde. Wirklich aussagekräftig wäre aber wohl nur ein Selbstversuch... also nur zu. Wenn ich die Zeit dafür finde (aktuell leide ich mal wieder unter akutem Zeitmangel), werde ich das auch gerne mal selber austesten. Ich kann dir aber nicht sagen, wann das sein wird.
Tommes
PsychoHH
03. Jul 2013
Sollte klappen.
WoodyT
13. Jan 2017
Ich habe dieses Szenario schon getestet, mit Erfolg. Und da muss ich leider dem Entwickler widersprechen, eine Änderung auf dem Quell NAS ist unerheblich. Genau das ist ja das gewünschte. Rsync vergleicht die Daten und sichert die Änderungen. Eine Voraussetzung gibt es aber schon, der Pfad zur Sicherung und die Freigaben auf der Quell NAS müssen identisch sein.
m0useP4d
08. Okt 2012
Was ist mit "Remote Datenkopie" gemeint und welches Backup Programm?
Es gibt in dem Paket Hyper Backup eine Option namens "Remote Datenkopie", mit der die Daten ins Filesystem einer andere DiskStation geschrieben werden kann (siehe Screenshot).
m0useP4d
08. Okt 2012
@dil88
Danke für die Info!
Es gibt tatsächlich keine Möglichkeit ein vorhandenes filebasiertes Backup wieder zu verknüpfen :eek:
@Swp2000
Hast Du schon neuen Job auf vorhandenes Backup angelegt und trotz der Daten wird alles komplett neu kopiert?
Was sagt Syno-Support dazu?
Ich vermute, dass Synology die Datenkopie nur wieder hinzugenommen hat (hieß vorher "Datensicherung & Replikation"), weil sie mitbekommen haben, dass viele User nur mit einer datenbankbasierten Backuplösung unglücklich sind. Ich kann mir aber nicht vorstellen, dass sie die ernsthaft supporten werden, sondern auf die datenbankbasierte Variante verweisen werden. Mit Ultimate Backup und den passenden Pfaden sollte es m.E. klappen, sehe das wie PsychoHH und Tommes.
Tommes
26. Okt 2009
Soweit ich informiert bin, funktioniert das Neuverknüfen nur bei einer datenbankbasierten Sicherung, bei einer dateibasierten jedoch nicht. Selbst wenn man anfängt zu tricksen, indem man eine neue Remote Backup Aufgabe konfiguriert, diese kurz startet und kurz danach abbricht. Benennt man dann sein altes Backup-Ziel in das neue um und kopiert die von Synology erstellten Datein des neu erstellten Backups, so werden nach dem erneutem Start des Jobs trotzdem nochmal alle Daten neu geschrieben. So jedenfalls war es, als ich das vor etwas längerer Zeit mal probiert hatte.
Tommes
Swp2000
29. Nov 2013
Mh.. ich versuche es mal. Bei mir kommt es in gewissen Abständen bzw. Spätestens bei einer neues Major DSM zu diesem Vorgang. Evtl. Ist das mit der Datenbank für mich dann besser geeignet. Leider habe ich jedoch schonmal gelesen ( wo kann ich nun nicht genau sagrn) das bei dem Datenbank Backup die Dateien später defekt waren und konnten nicht entpackt werden. Das wäre natürlich "Worst Case"
Tommes
26. Okt 2009
Genau aus diesem Grund ist Ultimate Backup entstanden.
matt42
13. Jan 2015
ich hatte in Beitrag #856 schon mal gefragt, warum meine Skripts über den "alle auf einmal" Button nicht funktionieren, und kann nun nach langer Suche endlich die Lösung präsentieren: alle Skripte verwenden die gleiche temporäre Datei "stop.txt".
Wenn also eines der Skripte aus irgendeinem Grund auf einen Fehler läuft (ich komme gleich zu meinem), dann brechen alle Skripte ab - und zwar an unterschiedlichen Stellen (was es so schwierig machte, das ganze einzugrenzen).
Es gibt m.E. eine einfache Lösung dafür:
stop="${dir}/stop_${scriptname}.txt"
Eines meiner Skripte lief übrigens immer sofort auf einen Fehler, da ich als eine der zu sichernden Quellen eine Datei und kein Verzeichnis angegeben hatte. Gibt es einen speziellen Grund, warum Dateinamen als Quelle nicht erlaubt sind? (Sie werden über das "share_mount=$(find ... -type d ..." abgefangen.)
Dabei ist mir übrigens aufgefallen, dass bei Angabe mehrerer Quellen nicht bei einem Fehler abgebrochen wird, sondern weiter versucht wird, die verbleibenden Quellen zu sichern. Dies führt wiederum dazu, dass ein anderer Exit Code und Fehlermeldung angezeigt werden kann, da dieser mit der "nächsten" Quelle überschrieben werden. Es kann sogar Erfolg vermeldet werden, obwohl mehrere Quellen davor auf Fehler liefen, lediglich die letzte korrekt gesichert wurde.
Schöne Grüße, Matt
PS Danke für die schnelle Änderung des "nv" Parameters.
matt42
13. Jan 2015
Nachtrag für alle, die mit mehreren Skripten gleichzeitig auf eine andere DS sichern wollen:
der Standard-Wert für die Anzahl gleichzeitiger ssh Verbindungen liegt bei 10.
Wenn also scheinbar zusammenhanglose Verbindungsabbrüche, oder Sicherungsfehler auftauchen, kann es auch daran liegen.
Dies kann man über den Parameter MaxSessions in der Datei /etc/ssh/sshd_config ändern. Dabei auch den Parameter MaxStartups nicht vergessen. Ggf beide Werte auch in /etc.defaults/ssh/sshd_config übertragen.
Swp2000
29. Nov 2013
@Swp2000
Habe beim gestrigen Backup dem Job den gleichen Namen (Storage_1) verpasst, aber leider ohne Erfolg. Er meckert das dieser Job schon vorhanden ist.
So musste ich alles erneut kopieren. Das ist sehr schade. Für mich ist das von großer Bedeutung, im Falle eine Neuinstallation ist sowas natürlich extrem komfortabel.oder wie macht ihr sowas? Bei Szenarirn mit x TB ist das schon sehr sinnvoll.
Tommes
26. Okt 2009
@matt42
Wow, da hast du dich ja wirklich intensiv mit unserem Script auseinandergesetzt. Vielen Dank schon mal, das du deine gewonnenen Erkenntnisse mit uns teilst. Wir werden uns das anschauen und ggf. einbauen/ändern. Wann wir das aber veröffentlichen, können wir noch nicht genau sagen, da wir im Verborgenen bereits an einer neuen Sache dran sind und wir hierfür ziemlich viel umbauen müssen. Leider ist dieser Umbau sehr Zeitintensiv und Zeit ist bei PsychoHH und mir grad Mangelware. Aber wir bleiben am Ball... dauert halt alles nur was länger.
Tommes
matt42
13. Jan 2015
Zeit ist bei mir auch Mangelware, aber wenn Ihr was braucht, pingt mich einfach an. Ich kenn mich mit dem Skript ja jetzt aus ;) und unterstütze gerne.
