Virtual box
You don't need more than ssh or telnet. When that doesn't work how should php do?
can't you just login to phpvirtualbox (http://IPADRESS/phpvirtualbox) and delete the complete VM?
you will lost your complete VM but yout DS wil work again.
dill88: since webstation would still work, maybe I could place a file there that would delete the vdi...
Slide83: Nope, phpvirtualbox doesn't work although it seems to be running in the Package Center
ssh login as root, and delete the complete folder? but watch out! don't delete something wrong!
1.) ssh login as admin
2.) sudo -i
3.) admin/root pw again
4.) NOW YOU ARE root!!
5.) find /root
6.) look how your vm folder is called
7.) rm -r "/root/FOLDERNAME" <- watch out for the EXACT path!!
all risk by your self! maybe wait for someone who approved my steps!!
edit: oh sorry, i just realized your post #226 and your admin/root pw won't work.
Well, SSH doesn't work anymore.... Every known account I try gets "access denies" after 10 seconds...
edit: yup, just saw your edit :-)
I solved it!
I just saw that I really needed to mount all (4) disks to my laptop to be able to delete the file from the raid.
So I just placed disk1 back and booted the nas.
As soon as I got a PING reply I started SSH AND WAS ABLE TO LOG ON!
But just for about 15 seconds.
So I shut down the nas and rebooted again and typed very quickly to get the file deleted from /root.
Now My nas is running again!!!
Thanks for your support.
Blöde Frage, kann ich eigentlich angeschlossene Geräte an der DS dann in einer Windows VM nutzen?
Müsste theroetisch funktionieren. Habs aber selbst noch nicht ausprobiert.
Probier es einfach mal aus :D
Dann freue ich mich über Feedback. :)
USB Geräte kann man durchreichen, hab ich mit einer netzwerkkarte schon erfolgreichen probiert
Perfekt!
Dann weiß ich ja was ich bald mal mit meiner 916+ machen werde.
Für alle die es noch nicht wissen, VitualBox geht wieder auf der aktuellen Version des DSM 6.1. ;)
Einfach die App Updaten!
Und zur Info USB geht, ich habs schon ausprobiert. :D
Super! Die neue Version läuft auch auf meiner 916+. Testweise läuft eine WinXp-VM ohne Probleme.
Ein kleineres Problem habe ich mit der VirtualBox Console. Hier erscheint nach kurzer Zeit ohne Interaktion eine Fehlermeldung:
"Beim Ermitteln der Liste virtueller Maschimen ist ein Fehler aufgetreten. Stellen Sie sicher, dass vboxwebsrv gestartet ist und die Einstellugen in der Datei config.php stimmen.Die Liste der virtuellen Maschinen können Sie durch das erneute Laden dieser Seite aktualisieren.
(EventListener watchdog failure)"
Neustart hat keine Besserung gebracht. Vielen Dank für einen Hinweis.
Moin Andi!
Verstehe ich jetzt nicht - Du hast die Quelle von Diablo angegeben? Dann kannst Du das Paket doch aus dem Paketcenter installieren...
Mögen täte ich schon wollen, aber ...
Passiert übrigens bei beiden Kisten ...
Installier die folgende Datei bitte mal manuell... .spk.
Oh moment - scheinbar gibts gerade bei Diablo ein Server Problem.
Und als Paketquelle hast Du auch http://spk.diablos-netzwerk.de/ eingetragen??
Die brauch ich nimmer runterladen, die habe ich hier schon rumliegen :o
Stünde auch schon in #235 ...
Jedoch wird wohl noch ein Stück Software nachgeladen?
Auch hier habe ich in #235 aufgezeigt, dass es die Datei wohl geben täte, aber aus irgendeinem Grund sind meine DoSen der Ansicht, mich mit einer Fehlermeldung beglücken zu wollen.
Nun meckert er auch noch mit mir :)
Bei mir wird nichts nachgeladen. Von daher bin ich "verwirrt". ;)
