- 19. Feb. 2014
Alles gut, das waren wohl die 3TB die ch da verschoben habe, natürlich auch alle 4 HDDs3 HDDs
smartctl -iA -d sat /dev/sda
smartctl -iA -d sat /dev/sdb
smartctl -iA -d sat /dev/sdc
smartctl -iA -d sat /dev/sde
smartctl 6.5 (build date Sep 26 2022) [aarch64-linux-4.4.302+] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Red (CMR)
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WCC4N3EYEFXK
LU WWN Device Id: 5 0014ee 20ee8a22d
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Dec 26 23:00:45 2024 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART Attributes Data Structure revision number: 16
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 605
3 Spin_Up_Time 0x0027 177 177 021 Pre-fail Always - 6108
4 Start_Stop_Count 0x0032 095 095 000 Old_age Always - 5520
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 040 040 000 Old_age Always - 44487
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 097 097 000 Old_age Always - 3770
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 26
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 5604
194 Temperature_Celsius 0x0022 126 105 000 Old_age Always - 24
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 3
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 2
Serial Number: WD-WCC4N0ZD16PX
LU WWN Device Id: 5 0014ee 20ee89bc2
Local Time is: Thu Dec 26 23:00:46 2024 CET
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 45
3 Spin_Up_Time 0x0027 175 174 021 Pre-fail Always - 6241
4 Start_Stop_Count 0x0032 095 095 000 Old_age Always - 5515
7 Seek_Error_Rate 0x002e 199 199 000 Old_age Always - 41
9 Power_On_Hours 0x0032 040 040 000 Old_age Always - 44472
12 Power_Cycle_Count 0x0032 097 097 000 Old_age Always - 3764
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 21
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 5550
194 Temperature_Celsius 0x0022 126 104 000 Old_age Always - 24
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
Serial Number: WD-WCC4N0AECKAY
LU WWN Device Id: 5 0014ee 2b9939376
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 5
3 Spin_Up_Time 0x0027 178 178 021 Pre-fail Always - 6066
9 Power_On_Hours 0x0032 040 040 000 Old_age Always - 44467
12 Power_Cycle_Count 0x0032 097 097 000 Old_age Always - 3765
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 5542
194 Temperature_Celsius 0x0022 126 103 000 Old_age Always - 24
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
Smartctl open device: /dev/sde [SAT] failed: No such device
Oh wie peinlichNach c kommt d und nicht e.
Local Time is: Thu Dec 26 23:16:17 2024 CET
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 612
194 Temperature_Celsius 0x0022 123 105 000 Old_age Always - 27
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 52
194 Temperature_Celsius 0x0022 123 104 000 Old_age Always - 27
Local Time is: Thu Dec 26 23:16:18 2024 CET
9 Power_On_Hours 0x0032 040 040 000 Old_age Always - 44468
194 Temperature_Celsius 0x0022 123 103 000 Old_age Always - 27
Serial Number: WD-WCC4N6KX2R45
LU WWN Device Id: 5 0014ee 2b9a74713
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 40
3 Spin_Up_Time 0x0027 178 177 021 Pre-fail Always - 6100
4 Start_Stop_Count 0x0032 098 098 000 Old_age Always - 2515
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 15
9 Power_On_Hours 0x0032 057 057 000 Old_age Always - 32010
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 1505
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 4
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 3235
194 Temperature_Celsius 0x0022 122 103 000 Old_age Always - 28
Was bedeuten diese Werte?ID 1, 197, 200
