Neuer Firefox-Syncserver (Rust) in Docker mit MariaDB-Datenbank
Habe folgendes durchgeführt:
docker exec -it firefox_mariadb mysql -u root -p
-> dann kam:
mysql: Deprecated program name. It will be removed in a future release, use '/usr/bin/mariadb' instead
Enter password:
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
-> ohne -p hat es dann geklappt (mit Putty über SSH)
CREATE DATABASE IF NOT EXISTS syncstorage_rs;
CREATE DATABASE IF NOT EXISTS tokenserver_rs;
CREATE USER sync@"172.%" IDENTIFIED BY 'syncpass';
GRANT ALL PRIVILEGES ON syncstorage_rs.* TO sync@"172.%";
GRANT ALL PRIVILEGES ON tokenserver_rs.* TO sync@"172.%";
quit
mariadb-log:
GID/UID
User UID:    911
User GID:    911
Linuxserver.io version: 11.4.5-r0-ls177
Build-date: 2025-03-11T07:42:29+00:00
[custom-init] No custom files found, skipping...
250320 20:03:22 mysqld_safe Logging to '/config/log/mysql/mariadb-error.log'.
250320 20:03:22 mysqld_safe Starting mariadbd daemon with databases from /config/databases
Connection to localhost (127.0.0.1) 3306 port [tcp/mysql] succeeded!
Logrotate is enabled
[ls.io-init] done.
syncserver-log:
Could not connect to database via `mysql://sync:syncpass@firefox_mariadb:3306/syncstorage_rs`: Can't connect to server on 'firefox_mariadb' (115)
Could not connect to database via `mysql://sync:syncpass@firefox_mariadb:3306/tokenserver_rs`: Can't connect to server on 'firefox_mariadb' (115)
ERROR 2002 (HY000): Can't connect to server on 'firefox_mariadb' (115)
thread 'main' panicked at syncserver/src/main.rs:61:55:
called `Result::unwrap()` on an `Err` value: ApiError { kind: Db(DbError { kind: Mysql(SqlError { kind: DieselConnection(BadConnection("Can't connect to server on 'firefox_mariadb' (115)")), status: 500, backtrace:    0: <syncserver_db_common::error::SqlError as core::convert::From<syncserver_db_common::error::SqlErrorKind>>::from
             at /app/syncserver-db-common/src/error.rs:37:24
      <T as core::convert::Into<U>>::into
             at /rustc/4eb161250e340c8f48f66e2b929ef4a5bed7c181/library/core/src/convert/mod.rs:761:9
      <syncserver_db_common::error::SqlError as core::convert::From<diesel::result::ConnectionError>>::from
             at /app/syncserver-common/src/lib.rs:50:33
   1: <syncstorage_mysql::error::DbError as core::convert::From<diesel::result::ConnectionError>>::from::{{closure}}
             at /app/syncstorage-mysql/src/error.rs:148:79
             at /app/syncserver-common/src/lib.rs:50:17
      <core::result::Result<T,F> as core::ops::try_trait::FromResidual<core::result::Result<core::convert::Infallible,E>>>::from_residual
             at /rustc/4eb161250e340c8f48f66e2b929ef4a5bed7c181/library/core/src/result.rs:2014:27
      syncstorage_mysql::pool::run_embedded_migrations
             at /app/syncstorage-mysql/src/pool.rs:33:16
      syncstorage_mysql::pool::MysqlDbPool::new
             at /app/syncstorage-mysql/src/pool.rs:65:9
   2: syncserver::server::Server::with_settings::{{closure}}
             at /app/syncserver/src/server/mod.rs:271:23
      syncserver::main::{{closure}}
             at /app/syncserver/src/main.rs:61:49
   3: <tokio::task::local::RunUntil<T> as core::future::future::Future>::poll::{{closure}}
             at /usr/local/cargo/registry/src/index.crates.io-1949cf8c6b5b557f/tokio-1.38.0/src/task/local.rs:978:42
      tokio::task::local::LocalSet::with::{{closure}}
             at /usr/local/cargo/registry/src/index.crates.io-1949cf8c6b5b557f/tokio-1.38.0/src/task/local.rs:730:13
      std::thread::local::LocalKey<T>::try_with
             at /rustc/4eb161250e340c8f48f66e2b929ef4a5bed7c181/library/std/src/thread/local.rs:308:12
      std::thread::local::LocalKey<T>::with
             at /rustc/4eb161250e340c8f48f66e2b929ef4a5bed7c181/library/std/src/thread/local.rs:272:9
             at /usr/local/cargo/registry/src/index.crates.io-1949cf8c6b5b557f/tokio-1.38.0/src/task/local.rs:728:17
             at /usr/local/cargo/registry/src/index.crates.io-1949cf8c6b5b557f/tokio-1.38.0/src/task/local.rs:968:22
   4: tokio::task::local::LocalSet::run_until::{{closure}}
             at /usr/local/cargo/registry/src/index.crates.io-1949cf8c6b5b557f/tokio-1.38.0/src/task/local.rs:635:19
      <core::pin::Pin<P> as core::future::future::Future>::poll
             at /rustc/4eb161250e340c8f48f66e2b929ef4a5bed7c181/library/core/src/future/future.rs:124:9
      tokio::runtime::scheduler::current_thread::CoreGuard::block_on::{{closure}}::{{closure}}::{{closure}}
             at /usr/local/cargo/registry/src/index.crates.io-1949cf8c6b5b557f/tokio-1.38.0/src/runtime/scheduler/current_thread/mod.rs:659:57
      tokio::runtime::coop::with_budget
Also irgendwas scheint noch nicht zu passen.
docker compose:
services:
  firefox_mariadb:
    container_name: firefox_mariadb
    image: linuxserver/mariadb:latest
    volumes:
      - /volume1/docker/syncstorage/config:/config
    restart: unless-stopped
    environment:
      MYSQL_ROOT_PASSWORD: rootpass
      MYSQL_DATABASE: syncstorage
      MYSQL_USER: sync
      MYSQL_PASSWORD: syncpass
  syncserver:
    container_name: firefox_syncserver
    image: syncstorage-rs:0.18.2
    labels:
      com.centurylinklabs.watchtower.enable: "false"
    ports:
      - "1050:8000"
    depends_on:
      - firefox_mariadb
    environment:
      LOGLEVEL: info
      SYNC_URL: https://syncstorage.beispiel.dynv6.net
      SYNC_CAPACITY: 5
      SYNC_MASTER_SECRET: mastersecret
      METRICS_HASH_SECRET: metricssecret
      SYNC_SYNCSTORAGE_DATABASE_URL: mysql://sync:syncpass@firefox_mariadb:3306/syncstorage_rs
      SYNC_TOKENSERVER_DATABASE_URL: mysql://sync:syncpass@firefox_mariadb:3306/tokenserver_rs
Als ich gerade noch die Firewall in Synology deaktiviert habe kommt folgendes:
Could not connect to database via `mysql://sync:syncpass@firefox_mariadb:3306/syncstorage_rs`: Access denied for user 'sync'@'%' to database 'syncstorage_rs'
Could not connect to database via `mysql://sync:syncpass@firefox_mariadb:3306/tokenserver_rs`: Access denied for user 'sync'@'%' to database 'tokenserver_rs'
ERROR 1044 (42000): Access denied for user 'sync'@'%' to database 'tokenserver_rs'
Das kann mit dem Image nicht funktionieren, das enthält keine MySQL-Unterstützung mehr sondern nur noch Spanner. Du musst entweder das Image selber builden oder 0.13.7 nehmen...
doch zu früh gefreut. Bekomme dieses log:
1742590189178    Sync.LogManager    DEBUG    Flushing file log
1742590189190    Sync.LogManager    DEBUG    Log cleanup threshold time: 1741726189190
1742590189192    Sync.LogManager    DEBUG    Done deleting files.
1742590190175    FirefoxAccounts    INFO    Polling device commands.
1742590190175    Sync.Service    DEBUG    User-Agent: Firefox/136.0.2 (Windows NT 10.0; Win64; x64) FxSync/1.138.0.20250317120031.desktop
1742590190175    Sync.Service    INFO    Starting sync at 2025-03-21 21:49:50 in browser session 3PSMX63RUVI6
1742590190175    Sync.Service    DEBUG    In sync: should login.
1742590190175    Sync.Service    INFO    User logged in successfully - verifying login.
1742590190176    FirefoxAccounts    TRACE    not checking freshness of profile as it remains recent
1742590190176    Sync.SyncAuthManager    DEBUG    unlockAndVerifyAuthState already has (or can fetch) sync keys
1742590190176    Sync.Status    DEBUG    Status.login: error.login.reason.network => success.status_ok
1742590190176    Sync.Status    DEBUG    Status.service: error.login.failed => error.login.failed
1742590190176    Sync.Service    DEBUG    Fetching unlocked auth state returned success.status_ok
1742590190177    FirefoxAccounts    TRACE    not checking freshness of profile as it remains recent
1742590190180    Services.Common.RESTRequest    DEBUG    GET request to https://api.accounts.firefox.com/v1/account/device/commands?index=0
1742590190186    Sync.Resource    WARN    GET request to https://syncstorage.beispiel.dyvn6.net/1.5/4/info/collections failed: [Exception... "The lookup of the hostname failed"  nsresult: "0x804b001e (NS_ERROR_UNKNOWN_HOST)"  location: "<unknown>"  data: no] No traceback available
1742590190186    Sync.Service    DEBUG    verifyLogin failed: [Exception... "The lookup of the hostname failed"  nsresult: "0x804b001e (NS_ERROR_UNKNOWN_HOST)"  location: "<unknown>"  data: no] No traceback available
1742590190186    Sync.Status    DEBUG    Status.login: success.status_ok => error.login.reason.network
1742590190186    Sync.Status    DEBUG    Status.service: error.login.failed => error.login.failed
1742590190186    Sync.Status    DEBUG    Status.login: error.login.reason.network => error.login.reason.network
1742590190186    Sync.ErrorHandler    ERROR    Sync encountered a login error
1742590190187    Sync.SyncScheduler    DEBUG    Clearing sync triggers and the global score.
1742590190187    Sync.SyncScheduler    DEBUG    Next sync in 3600000 ms. (why=schedule)
1742590190188    Sync.Service    DEBUG    Exception calling WrappedLock: Error: Login failed: error.login.reason.network(resource://services-sync/service.sys.mjs:1041:15) JS Stack trace: onNotify@service.sys.mjs:1041:15
1742590190188    Sync.Service    DEBUG    Not syncing: login returned false.
1742590190189    FirefoxAccounts    TRACE    not checking freshness of profile as it remains recent
glaub ich hab den Fehler entdeckt. In der .env war bei der URL ein Buchstabe mit dem anderen vertauscht. Schätze daran liegt es -> Rebuild läuft
Kann bestätigen, dass es jetzt läuft :)
Kurz noch meine Vorgehensweise:
  1. Dateien von https://github.com/dan-r/syncstorage-rs-docker herunterladen und in den Ordner docker/syncstorage auf dem Server kopieren
  2. example.env in .env umbenennen und die Parameter in der Datei ausfüllen
  3. den Ordner config unter docker/syncstorage/data/config erstellen
  4. Im docker-compose.yaml die Verzeichnisse anpassen, sprich:
    /volume1/docker/syncstorage/data/config:/config
    /volume1/docker/syncstorage/data/initdb.d/init.sql:/config/initdb.d/init.sql
    /volume1/docker/syncstorage/app/
  5. Im docker-compose.yaml "mariadb:10.6.13" auf "mariadb:latest" ändern
  6. mit SSH verbinden und in den Ordner volume1/docker/syncstorage wechseln, dann docker-compse up
  7. Warten bis die Container laufen
  8. Kontrollieren, dass die IP der beiden Container nicht von der Firewall von Synology geblockt wird
  9. Reverse Proxy anlegen für https://syncstorage.beispiel.dynv6.net
  10. Port 443 in der Fritzbox freigeben
@update-freak Welche Version zieht die Methode von dan-r jetzt? Bisher hat man nie die neueste Version bekommen, die Versions-Pflege für den Syncserver lässt etwas zu wünschen übrig.
Meine Variante basiert ja auf seinem Repository, ich hab aber das so umgebaut, dass man explizit die Syncserver-Version auswählen kann.
Reaktionen: update-freak
@update-freak Das siehst du, wenn du die Heartbeat-Seite aufrufst:
http(s)://adresse:port/__heartbeat__
Also hat sich die Versions-Pflege nicht gebessert, aktuell ist eigentlich 0.18.2...
ja leider hat es da nicht die aktuelle Version gezogen.
Habe anschließend das als Feature-Request angemerkt, dass es gut wäre wenn es die aktuelle Version nimmt:
https://github.com/dan-r/syncstorage-rs-docker/issues/5
Die Antwort war folgende:
"no version set in the Dockerfile so you just need to build your image again and redeploy"
-> komisch warum es dann die 0.17.15 nimmt
gemäß dem Kommentar in Github ist es doch die aktuelle Version, jedoch wurde in der Cargo.toml die Version nicht angepasst.
Schreibe deine Antwort....
