Neuer Firefox-Syncserver (Rust) in Docker mit MariaDB-Datenbank
Habe folgendes durchgeführt:
docker exec -it firefox_mariadb mysql -u root -p
-> dann kam:
mysql: Deprecated program name. It will be removed in a future release, use '/usr/bin/mariadb' instead
Enter password:
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
-> ohne -p hat es dann geklappt (mit Putty über SSH)
CREATE DATABASE IF NOT EXISTS syncstorage_rs;
CREATE DATABASE IF NOT EXISTS tokenserver_rs;
CREATE USER sync@"172.%" IDENTIFIED BY 'syncpass';
GRANT ALL PRIVILEGES ON syncstorage_rs.* TO sync@"172.%";
GRANT ALL PRIVILEGES ON tokenserver_rs.* TO sync@"172.%";
quit
mariadb-log:
GID/UID
User UID:    911
User GID:    911
Linuxserver.io version: 11.4.5-r0-ls177
Build-date: 2025-03-11T07:42:29+00:00
[custom-init] No custom files found, skipping...
250320 20:03:22 mysqld_safe Logging to '/config/log/mysql/mariadb-error.log'.
250320 20:03:22 mysqld_safe Starting mariadbd daemon with databases from /config/databases
Connection to localhost (127.0.0.1) 3306 port [tcp/mysql] succeeded!
Logrotate is enabled
[ls.io-init] done.
syncserver-log:
Could not connect to database via `mysql://sync:syncpass@firefox_mariadb:3306/syncstorage_rs`: Can't connect to server on 'firefox_mariadb' (115)
Could not connect to database via `mysql://sync:syncpass@firefox_mariadb:3306/tokenserver_rs`: Can't connect to server on 'firefox_mariadb' (115)
ERROR 2002 (HY000): Can't connect to server on 'firefox_mariadb' (115)
thread 'main' panicked at syncserver/src/main.rs:61:55:
called `Result::unwrap()` on an `Err` value: ApiError { kind: Db(DbError { kind: Mysql(SqlError { kind: DieselConnection(BadConnection("Can't connect to server on 'firefox_mariadb' (115)")), status: 500, backtrace:    0: <syncserver_db_common::error::SqlError as core::convert::From<syncserver_db_common::error::SqlErrorKind>>::from
             at /app/syncserver-db-common/src/error.rs:37:24
      <T as core::convert::Into<U>>::into
             at /rustc/4eb161250e340c8f48f66e2b929ef4a5bed7c181/library/core/src/convert/mod.rs:761:9
      <syncserver_db_common::error::SqlError as core::convert::From<diesel::result::ConnectionError>>::from
             at /app/syncserver-common/src/lib.rs:50:33
   1: <syncstorage_mysql::error::DbError as core::convert::From<diesel::result::ConnectionError>>::from::{{closure}}
             at /app/syncstorage-mysql/src/error.rs:148:79
             at /app/syncserver-common/src/lib.rs:50:17
      <core::result::Result<T,F> as core::ops::try_trait::FromResidual<core::result::Result<core::convert::Infallible,E>>>::from_residual
             at /rustc/4eb161250e340c8f48f66e2b929ef4a5bed7c181/library/core/src/result.rs:2014:27
      syncstorage_mysql::pool::run_embedded_migrations
             at /app/syncstorage-mysql/src/pool.rs:33:16
      syncstorage_mysql::pool::MysqlDbPool::new
             at /app/syncstorage-mysql/src/pool.rs:65:9
   2: syncserver::server::Server::with_settings::{{closure}}
             at /app/syncserver/src/server/mod.rs:271:23
      syncserver::main::{{closure}}
             at /app/syncserver/src/main.rs:61:49
   3: <tokio::task::local::RunUntil<T> as core::future::future::Future>::poll::{{closure}}
             at /usr/local/cargo/registry/src/index.crates.io-1949cf8c6b5b557f/tokio-1.38.0/src/task/local.rs:978:42
      tokio::task::local::LocalSet::with::{{closure}}
             at /usr/local/cargo/registry/src/index.crates.io-1949cf8c6b5b557f/tokio-1.38.0/src/task/local.rs:730:13
      std::thread::local::LocalKey<T>::try_with
             at /rustc/4eb161250e340c8f48f66e2b929ef4a5bed7c181/library/std/src/thread/local.rs:308:12
      std::thread::local::LocalKey<T>::with
             at /rustc/4eb161250e340c8f48f66e2b929ef4a5bed7c181/library/std/src/thread/local.rs:272:9
             at /usr/local/cargo/registry/src/index.crates.io-1949cf8c6b5b557f/tokio-1.38.0/src/task/local.rs:728:17
             at /usr/local/cargo/registry/src/index.crates.io-1949cf8c6b5b557f/tokio-1.38.0/src/task/local.rs:968:22
   4: tokio::task::local::LocalSet::run_until::{{closure}}
             at /usr/local/cargo/registry/src/index.crates.io-1949cf8c6b5b557f/tokio-1.38.0/src/task/local.rs:635:19
      <core::pin::Pin<P> as core::future::future::Future>::poll
             at /rustc/4eb161250e340c8f48f66e2b929ef4a5bed7c181/library/core/src/future/future.rs:124:9
      tokio::runtime::scheduler::current_thread::CoreGuard::block_on::{{closure}}::{{closure}}::{{closure}}
             at /usr/local/cargo/registry/src/index.crates.io-1949cf8c6b5b557f/tokio-1.38.0/src/runtime/scheduler/current_thread/mod.rs:659:57
      tokio::runtime::coop::with_budget
Also irgendwas scheint noch nicht zu passen.
docker compose:
services:
  firefox_mariadb:
    container_name: firefox_mariadb
    image: linuxserver/mariadb:latest
    volumes:
      - /volume1/docker/syncstorage/config:/config
    restart: unless-stopped
    environment:
      MYSQL_ROOT_PASSWORD: rootpass
      MYSQL_DATABASE: syncstorage
      MYSQL_USER: sync
      MYSQL_PASSWORD: syncpass
  syncserver:
    container_name: firefox_syncserver
    image: syncstorage-rs:0.18.2
    labels:
      com.centurylinklabs.watchtower.enable: "false"
    ports:
      - "1050:8000"
    depends_on:
      - firefox_mariadb
    environment:
      LOGLEVEL: info
      SYNC_URL: https://syncstorage.beispiel.dynv6.net
      SYNC_CAPACITY: 5
      SYNC_MASTER_SECRET: mastersecret
      METRICS_HASH_SECRET: metricssecret
      SYNC_SYNCSTORAGE_DATABASE_URL: mysql://sync:syncpass@firefox_mariadb:3306/syncstorage_rs
      SYNC_TOKENSERVER_DATABASE_URL: mysql://sync:syncpass@firefox_mariadb:3306/tokenserver_rs
Als ich gerade noch die Firewall in Synology deaktiviert habe kommt folgendes:
Could not connect to database via `mysql://sync:syncpass@firefox_mariadb:3306/syncstorage_rs`: Access denied for user 'sync'@'%' to database 'syncstorage_rs'
Could not connect to database via `mysql://sync:syncpass@firefox_mariadb:3306/tokenserver_rs`: Access denied for user 'sync'@'%' to database 'tokenserver_rs'
ERROR 1044 (42000): Access denied for user 'sync'@'%' to database 'tokenserver_rs'
Das kann mit dem Image nicht funktionieren, das enthält keine MySQL-Unterstützung mehr sondern nur noch Spanner. Du musst entweder das Image selber builden oder 0.13.7 nehmen...
doch zu früh gefreut. Bekomme dieses log:
1742590189178    Sync.LogManager    DEBUG    Flushing file log
1742590189190    Sync.LogManager    DEBUG    Log cleanup threshold time: 1741726189190
1742590189192    Sync.LogManager    DEBUG    Done deleting files.
1742590190175    FirefoxAccounts    INFO    Polling device commands.
1742590190175    Sync.Service    DEBUG    User-Agent: Firefox/136.0.2 (Windows NT 10.0; Win64; x64) FxSync/1.138.0.20250317120031.desktop
1742590190175    Sync.Service    INFO    Starting sync at 2025-03-21 21:49:50 in browser session 3PSMX63RUVI6
1742590190175    Sync.Service    DEBUG    In sync: should login.
1742590190175    Sync.Service    INFO    User logged in successfully - verifying login.
1742590190176    FirefoxAccounts    TRACE    not checking freshness of profile as it remains recent
1742590190176    Sync.SyncAuthManager    DEBUG    unlockAndVerifyAuthState already has (or can fetch) sync keys
1742590190176    Sync.Status    DEBUG    Status.login: error.login.reason.network => success.status_ok
1742590190176    Sync.Status    DEBUG    Status.service: error.login.failed => error.login.failed
1742590190176    Sync.Service    DEBUG    Fetching unlocked auth state returned success.status_ok
1742590190177    FirefoxAccounts    TRACE    not checking freshness of profile as it remains recent
1742590190180    Services.Common.RESTRequest    DEBUG    GET request to https://api.accounts.firefox.com/v1/account/device/commands?index=0
1742590190186    Sync.Resource    WARN    GET request to https://syncstorage.beispiel.dyvn6.net/1.5/4/info/collections failed: [Exception... "The lookup of the hostname failed"  nsresult: "0x804b001e (NS_ERROR_UNKNOWN_HOST)"  location: "<unknown>"  data: no] No traceback available
1742590190186    Sync.Service    DEBUG    verifyLogin failed: [Exception... "The lookup of the hostname failed"  nsresult: "0x804b001e (NS_ERROR_UNKNOWN_HOST)"  location: "<unknown>"  data: no] No traceback available
1742590190186    Sync.Status    DEBUG    Status.login: success.status_ok => error.login.reason.network
1742590190186    Sync.Status    DEBUG    Status.service: error.login.failed => error.login.failed
1742590190186    Sync.Status    DEBUG    Status.login: error.login.reason.network => error.login.reason.network
1742590190186    Sync.ErrorHandler    ERROR    Sync encountered a login error
1742590190187    Sync.SyncScheduler    DEBUG    Clearing sync triggers and the global score.
1742590190187    Sync.SyncScheduler    DEBUG    Next sync in 3600000 ms. (why=schedule)
1742590190188    Sync.Service    DEBUG    Exception calling WrappedLock: Error: Login failed: error.login.reason.network(resource://services-sync/service.sys.mjs:1041:15) JS Stack trace: onNotify@service.sys.mjs:1041:15
1742590190188    Sync.Service    DEBUG    Not syncing: login returned false.
1742590190189    FirefoxAccounts    TRACE    not checking freshness of profile as it remains recent
