[Beta] Traccar - GPS Trackingserver
rttm
30. Okt 2019
done - beides .... am verzeweifeln
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:842)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:771)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(DOMParser.java:243)
at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(DocumentBuilderImpl.java:339)
at sun.util.xml.PlatformXmlPropertiesProvider.getLoadingDoc(PlatformXmlPropertiesProvider.java:106)
at sun.util.xml.PlatformXmlPropertiesProvider.load(PlatformXmlPropertiesProvider.java:78)
... 6 more
2019-10-30 19:49:25 ERROR: Main method error - Premature end of file. - SAXParseException (... < Config:37 < Context:269 < Main:110 < ...)
Exception in thread "main" java.lang.RuntimeException: java.lang.RuntimeException: Configuration file is not a valid XML document
at org.traccar.Main.run(Main.java:152)
at org.traccar.Main.main(Main.java:104)
Caused by: java.lang.RuntimeException: Configuration file is not a valid XML document
at org.traccar.config.Config.<init>(Config.java:52)
at org.traccar.Context.init(Context.java:269)
at org.traccar.Main.run(Main.java:110)
... 1 more
Caused by: java.util.InvalidPropertiesFormatException: org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 1; Premature end of file.
at sun.util.xml.PlatformXmlPropertiesProvider.load(PlatformXmlPropertiesProvider.java:80)
at java.util.Properties$XmlSupport.load(Properties.java:1201)
at java.util.Properties.loadFromXML(Properties.java:881)
at org.traccar.config.Config.<init>(Config.java:37)
... 3 more
Caused by: org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 1; Premature end of file.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:203)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:177)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:400)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:327)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1472)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:1014)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
... 6 more
rttm
30. Okt 2019
hab deinen input in mein file reinkopiert ... sitll not a valid xml file
was mach ich da falsch?
adahmen
12. Okt 2009
Wie hast Du die Datei denn erstellt (welcher Editor). Scheint ein falsches Format zu haben ...
rttm
30. Okt 2019
putty -> sh ->
ins verzeichnis gewechsel
nano <return>
rechte maus - kopiert deinen inhalt rein
crtl o -> fragt nach namen zum speichern -> traccar.xml
quit
adahmen
12. Okt 2009
Ich habe nochmal geschaut und würde sagen das Deine Datei weiterhin leer ist.
Denn die Fehlermeldung ist die gleiche wie vorher: "lineNumber: 1; columnNumber: 1; Premature end of file."
Wieso editierst Du die Datei nicht ganz normal mit einem Windows oder Mac-Editor?
Die Datei befindet sich ja ganz normal auf der Synology und kann somit auch vom Rechner aus bearbeitet werden.
rttm
30. Okt 2019
adahmen .... held des abends
up and running
sorry ... manchmal hat mann ein brett vorm kopf
vielen dank -
du lagst richtig -> conf war weiterhin leeg
edit via synology oberfläche editor ... und gut war
DANKE!
BG Thomas
adahmen
12. Okt 2009
Puuhhh ... geschafft :)
VG Albert
adahmen
12. Okt 2009
Habe nun testweise folgendes Device am laufen: https://www.mictrack.com/shop/nb-iot-gps-tracker-mt550/
Device nutzt das neue Narrow-Band.
Läuft bisher einwandfrei ... Daten kommen in Traccar an :)
Drin habe ich eine SIM-Karte: 10 Jahre Laufzeit / 500 MB für 10 Euro ....
Welche Devices nutzt "Ihr" so?
peterhoffmann
17. Dez 2014
Euch beiden muss ich mal meinen Dank aussprechen.
Dank euch habe ich die traccar.xml nun auch hinbekommen. 2min später war das erste Gerät erfolgreich verbunden. :)
Testweise habe ich erst mal mein Handy (Android) genommen und die App "Traccar Client". Ich habe gesehen, dass es für Traccar noch ein paar weitere Apps für gibt.
Andere Empfehlungen oder bei der Traccar Client bleiben?
adahmen
12. Okt 2009
Ich nutze parallel zu meinem IOT-Tracker auch testweise die IOS-Traccar Client App.
Läuft einwandfrei und Batterieverbrauch ist absolut im Rahmen.
Mehr habe ich auch noch nicht ausprobiert.
Heute habe ich mal testweise ein paar GEO-Zäune eingerichtet und die eMail-Anbindung eingerichtet. Morgen werde ich sehen, ob die Mail-Notifications funktionieren.
rttm
30. Okt 2019
bin gerade erst am aufsetzen - werde testen mit ios und android client; melde mich mit ergebnissen.
adahmen
12. Okt 2009
Ja, wobei ich vorher mit einem der Mitarbeiter per Mail diversen Kontakt hatte (wobei ich keine Ahnung habe ob die Firma viele Mitarbeiter hat :)).
Dann habe ich am Ende per Webshop bestellt. Versand und Lieferung hat einwandfrei geklappt.
Mein MT550 soll in unser Wohnmobil kommen. Der MT821 Tracker sieht auch nicht schlecht aus ... da das Wohnmobil 2 Batterien hat, reicht der 550 aber wohl aus.
Eine SIM habe ich hier gekauft: https://1nce.com/ --> Wichtig: Man kann nur als Gewerbekunde eine Karte bestellen.
adahmen
12. Okt 2009
Hat jemand Erfahrung mit Benachrichtigungen?
Ich habe gestern 3 Geozäune eingerichtet, die Mail-Verbindung konfiguriert und Benachrichtigungen beim Betreten der Geozäune eingerichtet.
Auf der Karte mit dem Tracking von heute sehe ich, dass ich diverse Male die Geozäune betreten und verlassen habe ---> aber eine Mail habe ich nicht bekommen.
Leider finde ich im Logfile keinen Hinweis auf diese Ereignisse oder einem Problem beim Mail-Versand.
Hat jemand einen Tipp, wie ich dem Problem auf die Spur komme.
rttm
30. Okt 2019
hi Albert
ich habe noch keine geozäune - aber maibenachrichtigung mittels 'goes online/goes offline' benachrichtigungen geprüft.
mailbenachrichtigung funkt bei mir nach folgenden einstellungen (bei traccar via Docker):
Benutzer - edit ('Stift') - Eigenschaften - '+' clicken und eins nach dem anderen hinzufügen
Mail: SMTP Host beimir.eineigener.server
Mail: SMTP Port 465
Mail: SMTP Authentifizierung aktivieren true
Mail: SMTP Benutzername hehe
Mail: SMTP Passwort hihi
Mail: SMTP SSL aktivieren true
Mail: SMTP Absender meineemailadr
adahmen
12. Okt 2009
Danke für den Hinweis ... ich denke jedoch das ich meinen Fehler selber gefunden habe :)
Ich habe Geo-Zäune eingerichtet und bei Benachrichtigungen auch das Häkchen bei "Alle Devices" gesetzt. Damit dachte ich es wäre genug.
Ist es aber nicht --- man muss auch noch jedes Device den Geozäunen zuordnen. Das hatte ich aber nicht gemacht.
Ausprobiert habe ich es noch nicht, da wir seit gestern Abend nicht mehr unterwegs waren. Morgen werde ich sehen ob es geklappt hat.
rttm
30. Okt 2019
traccar läuft bei mir auf synology im docker; haben nun die Ports adaptiert. Um etwaige Konflikte mit Syno-Diensten zu vermeiden bei allen einen 5er 'vorangesetzt'.
Was ist zu tun?
- am Router eine Portweiterleitung / bei mir 50000-53000 als Gruppe auf die IP meiner Synology
- im traccar.xml den nachfolgenden inhalt eintragen
- in den portweiterleitungen des containers die für die im Einsatz befindlichen Tracker' Ports 'durchreichen.
- bei mir zb 55013 auf 55013 für einen Incutex Tracker
- was hilft?
-- deinstall!! traccer.pkg! und reboot (weil sonst reklamiert das paket dir ports für sich)
reinkopieren in traccar.xml
<entry key='gps103.port'>55001</entry>
<entry key='tk103.port'>55002</entry>
<entry key='gl100.port'>55003</entry>
<entry key='gl200.port'>55004</entry>
<entry key='t55.port'>55005</entry>
<entry key='xexun.port'>55006</entry>
<entry key='xexun.extended'>false</entry>
<entry key='totem.port'>55007</entry>
<entry key='enfora.port'>55008</entry>
<entry key='meiligao.port'>55009</entry>
<entry key='trv.port'>55010</entry>
<entry key='suntech.port'>55011</entry>
<entry key='progress.port'>55012</entry>
<entry key='h02.port'>55013</entry>
<entry key='jt600.port'>55014</entry>
<entry key='huabao.port'>55015</entry>
<entry key='v680.port'>55016</entry>
<entry key='pt502.port'>55017</entry>
<entry key='tr20.port'>55018</entry>
<entry key='navis.port'>55019</entry>
<entry key='meitrack.port'>55020</entry>
<entry key='skypatrol.port'>55021</entry>
<entry key='gt02.port'>55022</entry>
<entry key='gt06.port'>55023</entry>
<entry key='megastek.port'>55024</entry>
<entry key='navigil.port'>55025</entry>
<entry key='gpsgate.port'>55026</entry>
<entry key='teltonika.port'>55027</entry>
<entry key='mta6.port'>55028</entry>
<entry key='tzone.port'>55029</entry>
<entry key='tlt2h.port'>55030</entry>
<entry key='taip.port'>55031</entry>
<entry key='wondex.port'>55032</entry>
<entry key='cellocator.port'>55033</entry>
<entry key='galileo.port'>55034</entry>
<entry key='ywt.port'>55035</entry>
<entry key='tk102.port'>55036</entry>
<entry key='intellitrac.port'>55037</entry>
<entry key='gpsmta.port'>55038</entry>
<entry key='wialon.port'>55039</entry>
<entry key='carscop.port'>55040</entry>
<entry key='apel.port'>55041</entry>
<entry key='manpower.port'>55042</entry>
<entry key='globalsat.port'>55043</entry>
<entry key='atrack.port'>55044</entry>
<entry key='pt3000.port'>55045</entry>
<entry key='ruptela.port'>55046</entry>
<entry key='topflytech.port'>55047</entry>
<entry key='laipac.port'>55048</entry>
<entry key='aplicom.port'>55049</entry>
<entry key='gotop.port'>55050</entry>
<entry key='sanav.port'>55051</entry>
<entry key='gator.port'>55052</entry>
<entry key='noran.port'>55053</entry>
<entry key='m2m.port'>55054</entry>
<entry key='osmand.port'>55055</entry>
<entry key='easytrack.port'>55056</entry>
<entry key='gpsmarker.port'>55057</entry>
<entry key='khd.port'>55058</entry>
<entry key='piligrim.port'>55059</entry>
<entry key='stl060.port'>55060</entry>
<entry key='cartrack.port'>55061</entry>
<entry key='minifinder.port'>55062</entry>
<entry key='haicom.port'>55063</entry>
<entry key='eelink.port'>55064</entry>
<entry key='box.port'>55065</entry>
<entry key='freedom.port'>55066</entry>
<entry key='telic.port'>55067</entry>
<entry key='trackbox.port'>55068</entry>
<entry key='visiontek.port'>55069</entry>
<entry key='orion.port'>55070</entry>
<entry key='riti.port'>55071</entry>
<entry key='ulbotech.port'>55072</entry>
<entry key='tramigo.port'>55073</entry>
<entry key='tr900.port'>55074</entry>
<entry key='ardi01.port'>55075</entry>
<entry key='xt013.port'>55076</entry>
<entry key='autofon.port'>55077</entry>
<entry key='gosafe.port'>55078</entry>
<entry key='tt8850.port'>55079</entry>
<entry key='bce.port'>55080</entry>
<entry key='xirgo.port'>55081</entry>
<entry key='calamp.port'>55082</entry>
<entry key='mtx.port'>55083</entry>
<entry key='tytan.port'>55084</entry>
<entry key='avl301.port'>55085</entry>
<entry key='castel.port'>55086</entry>
<entry key='mxt.port'>55087</entry>
<entry key='cityeasy.port'>55088</entry>
<entry key='aquila.port'>55089</entry>
<entry key='flextrack.port'>55090</entry>
<entry key='blackkite.port'>55091</entry>
<entry key='adm.port'>55092</entry>
<entry key='watch.port'>55093</entry>
<entry key='t800x.port'>55094</entry>
<entry key='upro.port'>55095</entry>
<entry key='auro.port'>55096</entry>
<entry key='disha.port'>55097</entry>
<entry key='thinkrace.port'>55098</entry>
<entry key='pathaway.port'>55099</entry>
<entry key='arnavi.port'>55100</entry>
<entry key='nvs.port'>55101</entry>
<entry key='kenji.port'>55102</entry>
<entry key='astra.port'>55103</entry>
<entry key='homtecs.port'>55104</entry>
<entry key='fox.port'>55105</entry>
<entry key='gnx.port'>55106</entry>
<entry key='arknav.port'>55107</entry>
<entry key='supermate.port'>55108</entry>
<entry key='appello.port'>55109</entry>
<entry key='idpl.port'>55110</entry>
<entry key='huasheng.port'>55111</entry>
<entry key='l100.port'>55112</entry>
<entry key='granit.port'>55113</entry>
<entry key='carcell.port'>55114</entry>
<entry key='obddongle.port'>55115</entry>
<entry key='hunterpro.port'>55116</entry>
<entry key='raveon.port'>55117</entry>
<entry key='cradlepoint.port'>55118</entry>
<entry key='arknavx8.port'>55119</entry>
<entry key='autograde.port'>55120</entry>
<entry key='oigo.port'>55121</entry>
<entry key='jpkorjar.port'>55122</entry>
<entry key='cguard.port'>55123</entry>
<entry key='fifotrack.port'>55124</entry>
<entry key='smokey.port'>55125</entry>
<entry key='extremtrac.port'>55126</entry>
<entry key='trakmate.port'>55127</entry>
<entry key='at2000.port'>55128</entry>
<entry key='maestro.port'>55129</entry>
<entry key='ais.port'>55130</entry>
<entry key='gt30.port'>55131</entry>
<entry key='tmg.port'>55132</entry>
<entry key='pretrace.port'>55133</entry>
<entry key='pricol.port'>55134</entry>
<entry key='siwi.port'>55135</entry>
<entry key='starlink.port'>55136</entry>
<entry key='dmt.port'>55137</entry>
<entry key='xt2400.port'>55138</entry>
<entry key='dmthttp.port'>55139</entry>
<entry key='alematics.port'>55140</entry>
<entry key='gps056.port'>55141</entry>
<entry key='flexcomm.port'>55142</entry>
<entry key='vt200.port'>55143</entry>
<entry key='owntracks.port'>55144</entry>
<entry key='vtfms.port'>55145</entry>
<entry key='tlv.port'>55146</entry>
<entry key='esky.port'>55147</entry>
<entry key='genx.port'>55148</entry>
<entry key='flespi.port'>55149</entry>
<entry key='dway.port'>55150</entry>
<entry key='recoda.port'>55151</entry>
<entry key='oko.port'>55152</entry>
<entry key='ivt401.port'>55153</entry>
<entry key='sigfox.port'>55154</entry>
<entry key='t57.port'>55155</entry>
<entry key='spot.port'>55156</entry>
<entry key='m2c.port'>55157</entry>
<entry key='austinnb.port'>55158</entry>
<entry key='opengts.port'>55159</entry>
<entry key='cautela.port'>55160</entry>
<entry key='continental.port'>55161</entry>
<entry key='egts.port'>55162</entry>
<entry key='robotrack.port'>55163</entry>
<entry key='pt60.port'>55164</entry>
<entry key='telemax.port'>55165</entry>
<entry key='sabertek.port'>55166</entry>
<entry key='retranslator.port'>55167</entry>
<entry key='svias.port'>55168</entry>
<entry key='eseal.port'>55169</entry>
<entry key='freematics.port'>55170</entry>
<entry key='avema.port'>55171</entry>
<entry key='autotrack.port'>55172</entry>
<entry key='tek.port'>55173</entry>
<entry key='wristband.port'>55174</entry>
<entry key='applet.port'>55175</entry>
<entry key='milesmate.port'>55176</entry>
<entry key='anytrek.port'>55177</entry>
<entry key='smartsole.port'>55178</entry>
<entry key='its.port'>55179</entry>
<entry key='xrb28.port'>55180</entry>
<entry key='c2stek.port'>55181</entry>
<entry key='nyitech.port'>55182</entry>
<entry key='neos.port'>55183</entry>
<entry key='satsol.port'>55184</entry>
<entry key='globalstar.port'>55185</entry>
<entry key='sanul.port'>55186</entry>
<entry key='minifinder2.port'>55187</entry>
<entry key='radar.port'>55188</entry>
<entry key='techtlt.port'>55189</entry>
<entry key='starcom.port'>55190</entry>
<entry key='mictrack.port'>55191</entry>
<entry key='plugin.port'>55192</entry>
<entry key='leafspy.port'>55193</entry>
<entry key='naviset.port'>55194</entry>
<entry key='racedynamics.port'>55195</entry>
<entry key='rst.port'>55196</entry>
<entry key='pt215.port'>55197</entry>
<entry key='pacifictrack.port'>55198</entry>
durch eintragen a
rttm
30. Okt 2019
nur falls mal ein 'Batterie Langzeit Tracker gesucht wird' ... und Ihr Euch ein Wochenende 'Recherche' ersparen wollt:
(amaz...) Incutex Tracker TK106 ist eigentlich ein
Xeelectech XE209C -> so auch auf https://www.traccar.org/devices/ zu finden
alle Einstgellmöglichkeiten dokumentiert https://www.gps-ortungssystem.com/gps-tracker-mit-langer-akkulaufzeit/incutex-tk106.html
für traccar wichtig: Port 5013 Protocol h02
ich habe in den Einstellungen des Trackers meineServerIP:55013 als GPS portal angegeben; Port 55013 wird bei mir auch an den dockercontainer durchgereicht ... voila
Mahoessen
20. Jul 2016
Hallo, ich habe seit 2-3 Tagen den Fall, dass die Tracking-devices online sind, diese lt. Protokoll auch Positionsupdates senden, im Fenster "Geräte" auch grün gekennzeichnet sind inkl. letzter Aktualisierung, aber die Positionen bzw. die Icons auf der Karte fehlen.
Lt.Herstellerforum liegt es an der Google-API, die man nun kaufen muss.., oder man wechselt auf einen freien Geocoding Anbieter ...
Hat jemand das gleiche Problem oder schon ein Lösung ???
Fehlermeldung lt Protokoll: "19-11-01 16:53:55 WARN: Geocoding failed - Empty address. Error: You must use an API key to authenticate each request to Google Maps Platform APIs."
Traccar läuft seit ca. 3Monaten problemlos im Docker, auf einer DS218+, 6BG, Image ist das Original Traccar/traccar...
viele Grüße und danke vorab
adahmen
12. Okt 2009
Das Problem kenne ich nicht bzw. habe ich nicht.
Habe gerade nochmal auf meine Installation geschaut und ich sehe meine Wege von heute auf der Karte.
Keine Ahnung wann und wo die Google-API und Geocoding eine Rolle spielt. Die Karten jedenfalls ist von OpenStreetsMap.
