[Beta] Traccar - GPS Trackingserver
LoganMCV
15. Apr 2014
@ All
Leider kann ich nichts finden auf alle fälle nicht bei Java
Synology-DS213> java
Usage: java [-options] class [args...]
(to execute a class)
or java [-options] -jar jarfile [args...]
(to execute a jar file)
where options include:
-d32 use a 32-bit data model if available
-d64 use a 64-bit data model if available
-client to select the "client" VM
-server is a synonym for the "client" VM [deprecated]
-hotspot is a synonym for the "client" VM [deprecated]
The default VM is client.
-cp <class search path of directories and zip/jar files>
-classpath <class search path of directories and zip/jar files>
A : separated list of directories, JAR archives,
and ZIP archives to search for class files.
-D<name>=<value>
set a system property
-verbose:[class|gc|jni]
enable verbose output
-version print product version and exit
-version:<value>
require the specified version to run
-showversion print product version and continue
-jre-restrict-search | -no-jre-restrict-search
include/exclude user private JREs in the version search
-? -help print this help message
-X print help on non-standard options
-ea[:<packagename>...|:<classname>]
-enableassertions[:<packagename>...|:<classname>]
enable assertions with specified granularity
-da[:<packagename>...|:<classname>]
-disableassertions[:<packagename>...|:<classname>]
disable assertions with specified granularity
-esa | -enablesystemassertions
enable system assertions
-dsa | -disablesystemassertions
disable system assertions
-agentlib:<libname>[=<options>]
load native agent library <libname>, e.g. -agentlib:hprof
see also, -agentlib:jdwp=help and -agentlib:hprof=help
-agentpath:<pathname>[=<options>]
load native agent library by full pathname
-javaagent:<jarpath>[=<options>]
load Java programming language agent, see java.lang.instrument
-splash:<imagepath>
show splash screen with specified image
See http://www.oracle.com/technetwork/java/javase/documentation/index.html for more details.
Ich weiß nicht ob hier ein Fehler ist.
Wie kann man das Programm Manuel starten ?
Gruß LoganMCV
LoganMCV
15. Apr 2014
@ALL
Habe das Programm mal per Hand versucht zu starten .
Diese Fehlermeldung erscheint :
Synology-DS213> /volume1/@appstore/traccar/bin/traccar start
Starting traccar...
Illegal instruction (core dumped)
Waiting for traccar..................
WARNING: traccar may have failed to start.
Synology-DS213>
Ich hoffe man kann mir jetzt weiter helfen ( bis nachher ich geh jetzt schlafen )
Gruß LoganMCV
DKeppi
01. Apr 2011
Sehr gut, er fragt nach java Argumenten, dh. es ist korrekt installiert
Die Fehlermeldung sagt mir auch nicht mehr als dir...
Im Ordner /volume1/@appstore/traccar/ müsste es einen Log Ordner mit Logfiles geben - viell. siehst du hier genaueres!?
LoganMCV
15. Apr 2014
@ All
Jetzt habe ich mal versucht die anderen Versionen zu installieren und siehe da die Version traccar2.4-012-ppc.spk funzt
die anderen leider nicht mehr.
So jetzt bräuchte ich noch ein wenig HILFE beim Einrichten des Trackers TK104 auf dem Portal .
Gruß LoganMCV
1sthandy
27. Feb 2011
Hi, leider habe ich das Problem, dass ich nur eine Synology mit arm habe, so kann ich leider nur diese Version testen.
Es wäre durchaus hilfreich, wenn ich Logfiles bekommen könnte, da ich so den Fehler suchen und ggf beheben kann.
LoganMCV
15. Apr 2014
@ All
Leider steht in den Log files nichts drin.
Habe ich nachgeschaut.
Oder wie macht dieses damit man im log files was hat.
Gruß CSM
Kann man noch eine Sachen hinzufügen ( wie zum Beispiel Befehle senden zum Tracker , Position mit Straßenamen u.s.w.
DKeppi
01. Apr 2011
LoganMCV
15. Apr 2014
Kannst du mir bitte sagen wo und wie ich das ändern kann .
Danke schon mal im vorraus
LoganMCV
1sthandy
27. Feb 2011
@LoganMCV kannst Du es bitte unterlassen, mir ständig diesen Thead als PM zu schicken. Was soll das? Ich antworte, wenn ich Zeit habe. Danke
die traccar.cfg muss in den Zeilen um die Fett markierten Felder(address) ergänzt werden, dann wird google als geocoder genutzt.
INSERT INTO positions (device_id, time, valid, latitude, longitude, altitude, speed, course, power, other, address)
VALUES (:device_id, :time, :valid, :latitude, :longitude, :altitude, :speed, :course, :power, :extended_info, :address);
zusätzlich muss
<!-- Geocoder options -->
    <entry key='geocoder.enable'>true</entry>
in die Traccar.cfg hinzugefügt werden.
Das wars schon...
1sthandy
27. Feb 2011
update auf Version 2.8
Tester für ppc und x86 gesucht
Downloadlink sucht bitte entsprechend Eurer Diskstation den Unterordner raus.
Bitte gebt mir ein Feedback, damit ich entweder Fehler bereinigen oder das Packet auf Cphub laden kann.
Danke
LoganMCV
15. Apr 2014
@1sthandy
Erstmal Tschuldigung wird nicht mehr vorkommen ! Hatte nur gedacht das Du nur antwortest wenn ich Dir ne PM schreibe.
Habe mir die Version heruntergeladen :
Immer noch das selbe Ergebnis:
Starting traccar...
Gruß LoganMCV
LoganMCV
15. Apr 2014
@ All
Leider kann ich nichts auf der Synology DS412+ installieren
Bekomme immer diesen Fehler
Synology-DS412> ipkg update
/opt/bin/ipkg: line 1: syntax error: unexpected "("
Synology-DS412>
Wie kann ich das lösen?
Gruß LoganMCV
DKeppi
01. Apr 2011
Danke
Konnte das x86 Package installieren und es läuft. Komme auf die Weboberfläche...
Sofern ich Fehler bei der Handhabung entdecke muss ich mich ja sowieso an den Entwickler von traccar wenden ;)
LoganMCV
15. Apr 2014
1sthandy
27. Feb 2011
@ All
Gruß LoganMCV
Bitte stelle Deine Frage nicht in meinem Thread, hier geht es nur um das Traccar-Packet, welches ich geschrieben habe.
Schau mal hier eventuell hilft dir das.
Die Fehlermeldung kann ich leider nicht deuten ...
@DKeppi danke für die Rückmeldung
LoganMCV
15. Apr 2014
zusätzlich muss
Das wars schon...
@ ALL
Leider funktioniert das irgendwie nicht , ich habe die traccar.cfg mal angehangen.
Vielleicht könnt ihr mir mal den Fehler sagen - schreiben.
Weiterhin gehen die anderen Versionen
traccar2.5-013-ppc.spk , traccar2.6-014-ppc.spk , traccar2.8-016-ppc.spk
nicht.
Kommt immer die gleiche Fehlermeldung
Starting traccar...
Es geht nur diese
Gruß LoganMCV
Synology DS213+
  • traccar.txt
DKeppi
01. Apr 2011
@1sthandy
Was noch super wäre für das neue 2.8 Package:
Ein hochauflösendes Icon für DSM5 - ein 128er wenigstens ;)
Wie das hier zB.
LoganMCV
15. Apr 2014
@ All
Jetzt habe ich es hinbekommen Traccar auf die DS412+ zu installieren.
Hier mal die Vorgehensweise von mir zur Installation für´s Tracker Portal auf Synology DS412+
mit einem Programm was SSH kann auf die Synology zugreifen
1. Verzeichnis erstellen , wenns nicht vorhanden ist
rm -rf /volume1/@optware
rm -rf /usr/lib/ipkg
mkdir /volume1/public
cd /volume1/public
## Für Intel Atom:
wget http://ipkg.nslu2-linux.org/feeds/o...s/unstable/syno-i686-bootstrap_1.2-7_i686.xsh
sh syno-i686-bootstrap_1.2-7_i686.xsh
Paketquellen eingerichtet:
CPH: http://www.cphub.net
PCLoadLetter: http://packages.pcloadletter.co.uk zur Zeit nicht erreichbar
Quadrat4: http://packages.quadrat4.de
auf der Synology mit SSH die Pakete installieren:
ipkg update
ipkg install gettext
ipkg install coreutils
ipkg install -force-overwrite textutils
Über den Packetmanager installieren :
- Java installieren bitte über den Java Manager ( Anweisungen folgen )
- MariaDB
- SQL Buddy
- zum Schluß jetzt noch traccar
So nun ausprobieren und freuen
Gruß LoganMCV
P.S. Jetzt muß man nur noch die Version für die DS 213+ hinbekommen
1sthandy
27. Feb 2011
@LoganMCV geb mir mal bitte die Datei: /volume1/@appstore/traccar/logs/tracker-server.log
die Traccar conf sieht so richtig für den geocoder aus, das funktioniert aber nur für ankommende Anfragen, bereits gespeicherte Anfragen aus der Datenbank werden nicht mehr über den Geocoder gejagt.
@DKeppi, an dieser Stelle habe ich schon lange nichts mehr gemacht, werde ich mal hinzufügen, Danke für den Hinweis.
