Mar 11 22:33:25 kernel: [ 24.250000] Brand: Synology
Mar 11 22:33:25 kernel: [ 24.260000] Model: DS-209
Mar 11 22:33:25 kernel: [ 24.260000] This is default settings: set group disks wakeup number to 1, spinup time deno 1
Mar 11 22:33:26 spacetool: spacetool.c:2491 [Info] Activate all VG
Mar 11 22:33:26 spacetool: spacetool.c:2525 space: [/dev/md2]
Mar 11 22:33:26 spacetool: spacetool.c:2553 space: [/dev/md2], ndisk: [2]
Mar 11 22:33:27 synovspace: virtual_space_conf_check.c:74 [INFO] No implementation, skip checking configuration of virtual space [HA]
Mar 11 22:33:27 synovspace: virtual_space_conf_check.c:74 [INFO] No implementation, skip checking configuration of virtual space [SNAPSHOT_ORG]
Mar 11 22:33:27 synovspace: virtual_space_implement.c:1100 [INFO] No config, skip it
Mar 11 22:33:27 synovspace: virtual_space_implement.c:1265 [INFO] No SSD Cache space, skip it.
Mar 11 22:33:27 synovspace: virtual_space_conf_check.c:78 [INFO] "PASS" checking configuration of virtual space [FCACHE], app: [1]
Mar 11 22:33:27 synovspace: vspace_wrapper_load_all.c:79 [INFO] Has virtual layer above space [/volume1]: [/dev/mapper/vol1-origin]
Mar 11 22:34:42 scemd: scemd.c:164 fan_type=7, raid_type=1, led_type=1, thermal_type=1, diskled_ctrl_type=1, auto_poweron_type=1, dual_power_type=1, usbcopy_type=1, fan_number=1, eunit_pwron_type=0, pis_type=1, rtc_type=1, lcm_type=2, wifi_wps_type=0
Mar 11 22:34:55 scemd: modules/fan_speed_adjust_common.c:115 Type: INTERNAL Fan Mode: HIGH
Mar 11 22:35:03 scemd: modules/raid_sys_volume_check.c:150 MD0 active disks 2, designed disks 2
Mar 11 22:35:03 scemd: modules/raid_sys_volume_check.c:150 MD1 active disks 2, designed disks 2
Mar 11 22:35:10 scemd: modules/disk_hibernation.c:1951 Force hibernation enable, idle minutes 20
Mar 11 22:35:11 scemd: modules/disk_hibernation.c:1983 Eunit Deep sleep timer 0
Mar 11 22:35:12 kernel: [ 134.240000] ata2.00: Disable disk write cache in EH
Mar 11 22:35:13 scemd: scemd.c:164 fan_type=7, raid_type=1, led_type=1, thermal_type=1, diskled_ctrl_type=1, auto_poweron_type=1, dual_power_type=1, usbcopy_type=1, fan_number=1, eunit_pwron_type=0, pis_type=1, rtc_type=1, lcm_type=2, wifi_wps_type=0
Mar 11 22:35:13 scemd: scemd.c:363 WIFI/WPS button is not support on this model.
Mar 11 22:35:13 scemd: modules/scemd_connector.c:103 scemd connector thread start.
Mar 11 22:35:14 kernel: [ 135.370000] Got empty serial number. Generate serial number from product.
Mar 11 22:35:14 kernel: [ 135.790000] Got empty serial number. Generate serial number from product.
Mar 11 22:35:27 kernel: [ 148.860000] Get empty minor:104
Mar 11 22:35:50 syno_hdd_util: Model:[WD10EADS-00M2B0], Firmware:[01.00A01], S/N:[WD-WCAV51632708] in [/dev/sdb] is not ssd
Mar 11 22:35:57 syno_hdd_util: Model:[WD10EADS-00M2B0], Firmware:[01.00A01], S/N:[WD-WCAV51602523] in [/dev/sda] is not ssd
Mar 11 22:36:14 kernel: [ 196.240000] nf_conntrack version 0.5.0 (3894 buckets, 15576 max)
Mar 11 22:37:11 scemd: scemd.c:420 stop manutild.
Mar 11 22:37:23 synoprint: synoprint.c:92 Failed to clean CUPS USB Printer config.[0x0900 printer_cups_usb_conf_rm_all.c:28]
Mar 11 22:37:53 synocheckshare: Fix shares in smb.conf.
Mar 11 22:38:28 synocheckshare: service_volume_getby_link.c(77)szLinkPath = /var/services/homes ,link value = , errno=Invalid argument
Mar 11 22:38:38 synocheckshare: service_volume_getby_link.c(77)szLinkPath = /var/services/homes ,link value = , errno=Invalid argument
Mar 11 22:38:38 synocheckshare: synocheckshare.c(613)[8000] Failed to get info of service ID=10
Mar 11 22:41:31 synousbdisk: RCClean succeeded
Mar 11 22:41:33 synosata: synosata.c:152 no external sata devices granted
Mar 11 22:41:35 hotplugd: hotplugd.c:1110 failed get usb status from usb config, DEVICE=/proc/bus/usb/001/001, usbid=1d6b:0002
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
rion-ehci.0
Mar 11 22:41:35 hotplugd: ##### ACTION:add
Mar 11 22:41:35 hotplugd: DEVICE:/proc/bus/usb/001/001
Mar 11 22:41:35 hotplugd: DEVPATH:usb1
Mar 11 22:41:35 hotplugd: SUBSYSTEM:usb
Mar 11 22:41:35 hotplugd: hotplugd.c:884 Fail to recognize usb DEVNAME=, DEVPATH=usb1
Mar 11 22:41:35 hotplugd: hotplugd.c:1409 failed to setup usb config, (DEVPATH, DEVICE, ACTION, DEVNAME, INTERFACE)=(usb1, /proc/bus/usb/001/001, add, , )
rion-ehci.0
Mar 11 22:41:35 hotplugd: DEVPATH:1-0:1.0
Mar 11 22:41:35 hotplugd: INTERFACE:9/0/0
Mar 11 22:41:39 hotplugd: ##### ACTION:add
Mar 11 22:41:39 hotplugd: DEVICE:/proc/bus/usb/001/002
Mar 11 22:41:39 hotplugd: DEVPATH:1-1
Mar 11 22:41:39 hotplugd: SUBSYSTEM:usb
Mar 11 22:41:39 hotplugd: external_disk_port_check.c:142 device path should not be NULL
Mar 11 22:41:45 hotplugd: ##### ACTION:add
Mar 11 22:41:45 hotplugd: DEVICE:/proc/bus/usb/001/002
Mar 11 22:41:45 hotplugd: DEVPATH:1-1:1.0
Mar 11 22:41:45 hotplugd: SUBSYSTEM:usb
Mar 11 22:41:45 hotplugd: INTERFACE:9/0/0
Mar 11 22:41:47 hotplugd: hotplugd.c:912 ##### complete device hotplug!!
Mar 11 22:41:53 hotplugd: ##### ACTION:add
Mar 11 22:41:53 hotplugd: DEVICE:/proc/bus/usb/001/003
Mar 11 22:41:53 hotplugd: DEVPATH:1-1.1
Mar 11 22:41:53 hotplugd: SUBSYSTEM:usb
Mar 11 22:41:53 hotplugd: external_disk_port_check.c:142 device path should not be NULL
Mar 11 22:42:01 hotplugd: ##### ACTION:add
Mar 11 22:42:01 hotplugd: DEVICE:/proc/bus/usb/001/003
Mar 11 22:42:01 hotplugd: DEVPATH:1-1.1:1.0
Mar 11 22:42:01 hotplugd: SUBSYSTEM:usb
Mar 11 22:42:01 hotplugd: INTERFACE:1/1/0
Mar 11 22:42:01 hotplugd: external_disk_port_check.c:142 device path should not be NULL
Mar 11 22:42:11 hotplugd: ##### ACTION:add
Mar 11 22:42:11 hotplugd: DEVICE:/proc/bus/usb/001/003
Mar 11 22:42:11 hotplugd: DEVPATH:1-1.1:1.1
Mar 11 22:42:11 hotplugd: SUBSYSTEM:usb
Mar 11 22:42:11 hotplugd: INTERFACE:1/2/0
Mar 11 22:42:11 hotplugd: external_disk_port_check.c:142 device path should not be NULL
Mar 11 22:42:15 hotplugd: ##### ACTION:add
Mar 11 22:42:15 hotplugd: DEVICE:/proc/bus/usb/001/003
Mar 11 22:42:15 hotplugd: DEVPATH:1-1.1:1.2
Mar 11 22:42:15 hotplugd: SUBSYSTEM:usb
Mar 11 22:42:15 hotplugd: INTERFACE:1/2/0
Mar 11 22:42:15 hotplugd: external_disk_port_check.c:142 device path should not be NULL
Mar 11 22:42:28 hotplugd: ##### ACTION:add
Mar 11 22:42:28 hotplugd: DEVICE:/proc/bus/usb/001/003
Mar 11 22:42:28 hotplugd: DEVPATH:1-1.1:1.3
Mar 11 22:42:28 hotplugd: SUBSYSTEM:usb
Mar 11 22:42:28 hotplugd: INTERFACE:3/0/0
Mar 11 22:42:28 hotplugd: hotplugd.c:912 ##### complete device hotplug!!
Mar 11 22:43:14 heartbeatd: heartbeatd.c:157 Heartbeat is not enabled, skip starting
Mar 11 22:43:32 ddnsd: IsDDNSEnable(ddnsd.c:2887): All Config are Disable, Stop daemon
Mar 11 22:52:07 cupsd[5567]: [conf.c:1893] Filter "pstoraster" not found.
Mar 11 22:58:17 syno_bkp_data_update: Fail to get share information (NetBackup)
Mar 11 22:58:17 syno_bkp_data_update: syno_bkp_data_update.c: main(231) - Fail to update netbakup data format.
Mar 11 23:10:24 avahi-daemon[6075]: write() failed while writing return value to pipe: Broken pipe
Mar 12 00:53:08 pulseaudio[8862]: [pulseaudio] shm.c: Failed to read /dev/shm/: No such file or directory
Mar 12 00:55:34 pulseaudio[8862]: [pulseaudio] bluetooth-util.c: org.bluez.Manager.ListAdapters() failed: org.freedesktop.DBus.Error.Spawn.ExecFailed: Failed to execute program /usr/syno/libexec/dbus-daemon-launch-helper: Success
Mar 12 00:56:19 synoaudiod: get_capability.cpp:144 Failed to download RCS SCPD xml, url [], rc[-108], msg[UPNP_E_INVALID_URL]
Mar 12 00:56:19 synoaudiod: upnp.cpp:825 Failed to get renderer capability
Mar 12 01:41:51 kernel: [11332.640000] RAID1 conf printout:
Mar 12 01:41:51 kernel: [11332.640000] --- wd:2 rd:2
Mar 12 01:41:51 kernel: [11332.640000] disk 0, wo:0, o:1, dev:sda1
Mar 12 01:41:51 kernel: [11332.650000] disk 1, wo:0, o:1, dev:sdb1
