Ich glaube, Synology hat das Update 1 zurückgezogen.
@Mischa42
Bei Dir ist das Update, wie man an dem Bild sieht, nicht installiert.
Schau mal hier auf Seite 70, Beitrag 3. So würde es dann bei Dir aussehen.
Das Update wurde wohl in der Zwischenzeit zurück gezogen.
Version: 6.0-7321-1
(2016/04/15)
Improved the stability when connecting via AFP protocol.
Fixed a security vulnerability regarding Samba file service (CVE-2016-2118, also known as Badlock).
Fixed an issue where a false-alarm warning about unexpected file changes occurs when saving files in Office Excel 2003.
Fixed an issue where Docker DSM might be terminated even when valid licenses are imported.
Fixed multiple issues that might cause iSCSI service to hang under heavy loading and performing Vmware VAAI commands.
Fixed an issue in which the configuration change of VLAN could result in abnormal functionality of certain packages. e.g. Surveillance Station
Fixed an issue where the DSM welcome title and message will be reset to default if users set it to blank.
Note: This update does not require system reboot.
