Berserker!
- 03. Sep. 2015
- Currently version is 2.0-006 though the status is stopped because when I try to launch the package stops
- In the main menu I have the icon JDownloader 2 but it makes me only access the site http://my.jdownloader.org/
Can someone please help me?
Version von Neutron ist 2.0. Soll ich das Update machen oder muss man was beachten?
As already said, please dont manually install the Package, it work's, but it's not the way it is meant. If you added my package source, you have to refresh package list, now look under community, you will find the package. If you do a fresh install, or a update, JDownloader downloads several files in background, this can take some minutes (depends on your internet connection and server status where the files are hosted). If this process is finished, package status will be "running" and you can access this instance via my.jdownloader.org or the shortcut under programs. Just a little bit patience.
I found your package (center packages> community) and I have installed it (version 2.0-006), then I launched it but the package is "not running". In fact, if I go my.jdownloader.org, I find no instance.
I would like to understand where I'm wrong to also help the 'cousins' of synologyitalia
As i already said, patience! Go to the package center, start the package once (as you did) and then just wait some minutes. It will download stuff in background. As soon as it is finished, package status show's "running" and you are good to go. Just close package center and re-open it to check the status.
Neutron I have a lot of patience, but if after hours or days I do not read "running" but the status is always "stopped", I believe that there is something wrong ... what I ask for your help to understand. Tell me If you need more information or screenshots to understand the problem
Well, ok. Let's start at the beginning. Which DS do you have, whicih Java is installed ? Go to the shell, show me the directory listing of the JD Installation. Also right after you started the package, please show me the process list of the ds (ps|grep java). Let's see where we get.
I need a little more input here. As i said, please go to the shell, start the package in package center, do a "ps|grep java" on the shell. I need this output.
Also do a "java -version" on the shell, does this produce any output? It seems your java setup is not working, JDownloader was not even started at all.
sehr nice! Kann das schon jemand bestätigen?
