Zunächst würde ich mal die v0.90 testen. Wenn die auch nicht geht, im z-push Ordner die Berechtigungen anpassen root/http 0775.
Thu Nov 1 11:31:50 2018: [error ] [26105] Connect to SMTP: Error while connecting socket.. E-Mail will be tried again later.
Thu Nov 1 11:31:50 2018: [warning] [26105] Unable to connect to SMTP server, retrying mail for user roman.aerni later
Thu Nov 1 11:31:50 2018: [error ] [26104] Connect to SMTP: Error while connecting socket.. E-Mail will be tried again later.
Thu Nov 1 11:31:50 2018: [warning] [26104] Unable to connect to SMTP server, retrying mail for user roman.aerni later
Thu Nov 1 11:31:50 2018: [error ] [26106] Connect to SMTP: Error while connecting socket.. E-Mail will be tried again later.
Thu Nov 1 11:31:50 2018: [warning] [26106] Unable to connect to SMTP server, retrying mail for user roman.aerni later
Thu Nov 1 11:31:50 2018: [error ] [26116] Connect to SMTP: Error while connecting socket.. E-Mail will be tried again later.
Thu Nov 1 11:31:50 2018: [warning] [26116] Unable to connect to SMTP server, retrying mail for user roman.aerni later
Nov 1 13:11:28 kopano4s postfix/master[11984]: fatal: remove public/pickup: Permission denied
Nov 1 13:14:40 kopano4s postfix/master[12539]: fatal: remove public/pickup: Permission denied
Nov 1 13:17:54 kopano4s postfix/master[13091]: fatal: remove public/pickup: Permission denied
Nov 1 13:21:07 kopano4s postfix/master[13647]: fatal: remove public/pickup: Permission denied
Nov 1 13:24:21 kopano4s postfix/master[14244]: fatal: remove public/pickup: Permission denied
Nov 1 13:27:35 kopano4s postfix/master[14852]: fatal: remove public/pickup: Permission denied
Nov 1 13:30:48 kopano4s postfix/master[15468]: fatal: remove public/pickup: Permission denied
01/11/2018 13:36:47 [29893] [ INFO] [#unknown] The configuration parameter 'USE_X_FORWARDED_FOR_HEADER' was deprecated in favor of 'USE_CUSTOM_REMOTE_IP_HEADER'. Please update your configuration.
01/11/2018 13:36:48 [29893] [ INFO] [#unknown] cmd='ItemOperations' memory='1.91 MiB/2.00 MiB' time='0.20s' devType='Android' devId='androidc327649311' getUser='roman.aerni' from='172.17.0.1' idle='0s' version='2.4.4+0-0' method='POST' httpcode='200'
01/11/2018 13:36:48 [ 3476] [ INFO] [#unknown] The configuration parameter 'USE_X_FORWARDED_FOR_HEADER' was deprecated in favor of 'USE_CUSTOM_REMOTE_IP_HEADER'. Please update your configuration.
01/11/2018 13:36:48 [ 3476] [ INFO] [#unknown] cmd='ItemOperations' memory='1.91 MiB/2.00 MiB' time='0.15s' devType='Android' devId='androidc327649311' getUser='roman.aerni' from='172.17.0.1' idle='0s' version='2.4.4+0-0' method='POST' httpcode='200'
01/11/2018 13:33:25 [ 9624] [ERROR] [#unknown] Please check your logs for this PID and errors like PHP-Fatals or Apache segmentation faults and report your results to the Z-Push dev team.
01/11/2018 13:33:28 [ 785] [WARN] [#unknown] SyncObject->Check(): object from type SyncMail: parameter 'from' contains an invalid email address '"" <>'. Address is removed.
01/11/2018 13:33:37 [ 787] [WARN] [#unknown] /usr/share/z-push/backend/kopano/mapiprovider.php:484 Invalid argument supplied for foreach() (2)
01/11/2018 13:33:37 [ 787] [WARN] [#unknown] /usr/share/z-push/backend/kopano/mapiprovider.php:544 Invalid argument supplied for foreach() (2)
01/11/2018 13:33:39 [ 798] [ERROR] [#unknown] LoopDetection->ProcessLoopDetectionPreviousConnectionFailed(): Command 'Sync' at 01/11/2018 13:33:35 with pid '5150' terminated unexpectedly or is still running.
01/11/2018 13:33:39 [ 798] [ERROR] [#unknown] Please check your logs for this PID and errors like PHP-Fatals or Apache segmentation faults and report your results to the Z-Push dev team.
01/11/2018 13:33:47 [ 9993] [WARN] [#unknown] SyncObject->Check(): object from type SyncMail: parameter 'to' contains an invalid email address 'undisclosed-recipients:'. Address is removed.
01/11/2018 13:34:35 [12375] [WARN] [#unknown] SyncObject->Check(): object from type SyncMail: parameter 'to' contains an invalid email address 'undisclosed-recipients:'. Address is removed.
01/11/2018 13:34:55 [ 6330] [WARN] [#unknown] SyncObject->Check(): object from type SyncMail: parameter 'to' contains an invalid email address 'undisclosed-recipients:'. Address is removed.
01/11/2018 13:34:56 [ 6330] [WARN] [#unknown] SyncObject->Check(): object from type SyncMail: parameter 'to' contains an invalid email address 'undisclosed-recipients:'. Address is removed.
01/11/2018 13:35:15 [ 797] [WARN] [#unknown] SyncObject->Check(): object from type SyncMail: parameter 'to' contains an invalid email address 'undisclosed-recipients:'. Address is removed.
01/11/2018 13:36:43 [ 798] [ERROR] [#unknown] LoopDetection->ProcessLoopDetectionPreviousConnectionFailed(): Command 'Sync' at 01/11/2018 13:36:40 with pid '12048' terminated unexpectedly or is still running.
01/11/2018 13:36:43 [ 798] [ERROR] [#unknown] Please check your logs for this PID and errors like PHP-Fatals or Apache segmentation faults and report your results to the Z-Push dev team.
01/11/2018 13:37:01 [14670] [WARN] [#unknown] SyncObject->Check(): object from type SyncMail: parameter 'cc' contains an invalid email address '@'. Address is removed.
01/11/2018 13:37:21 [ 788] [WARN] [#unknown] SyncObject->Check(): object from type SyncMail: parameter 'to' contains an invalid email address '@'. Address is removed.
...............neusten Docker Image Core-8.7.80.27_Web-3.4.24.1914_Push-2.4.4 ............
[/CODE]
Fri Nov 2 00:22:38 2018: [error ] [15846] Connect to SMTP: Error while connecting socket.. E-Mail will be tried again later.
Fri Nov 2 00:22:38 2018: [warning] [15846] Unable to connect to SMTP server, retrying mail for user roman.aerni later
Fri Nov 2 00:22:40 2018: [error ] [15867] Connect to SMTP: Error while connecting socket.. E-Mail will be tried again later.
Fri Nov 2 00:22:40 2018: [warning] [15867] Unable to connect to SMTP server, retrying mail for user roman.aerni later
Fri Nov 2 00:22:40 2018: [error ] [15866] Connect to SMTP: Error while connecting socket.. E-Mail will be tried again later.
Fri Nov 2 00:22:40 2018: [warning] [15866] Unable to connect to SMTP server, retrying mail for user roman.aerni later
Fri Nov 2 00:22:40 2018: [error ] [15881] Connect to SMTP: Error while connecting socket.. E-Mail will be tried again later.
Fri Nov 2 00:22:40 2018: [warning] [15881] Unable to connect to SMTP server, retrying mail for user roman.aerni later
Fri Nov 2 00:22:40 2018: [error ] [15880] Connect to SMTP: Error while connecting socket.. E-Mail will be tried again later.
Fri Nov 2 00:22:40 2018: [warning] [15880] Unable to connect to SMTP server, retrying mail for user roman.aerni later
:/etc/kopano/postfix# kopano-postfix test-smtp
running test into telnet session to smpd on port 25 with ehelo lakehouse.ch to postmaster@lakehouse.ch Subject: testmail..
telnet: Unable to connect to remote host: Network is unreachable
Trying 127.0.0.1...
Trying ::1...
root@Lakehouse_2411:/etc/kopano# kopano-postfix restart
Stopping Postfix Mail Transport Agent: postfix.
Starting Postfix Mail Transport Agent: postfix.
root@Lakehouse_2411:/etc/kopano# kopano-status
Core: Kopano Server Running, Spooler Running, Dagent Running, Search Running, Monitor Disabled, Gateway Running, ICAL Running, Syslog Running
Mail: Postfix Not Running, Postgrey Disabled, Clamav Disabled, Amavis Disabled, Spamd Running, Fetchmail Running, Courier-Imap Disabled
Web: NGINX Running, PHP5-FPM Running, Presence Disabled, Webmeetings Disabled, CoTurn Disabled
