Hey,
Danke an euch alle, nur leider startet jetzt PyLoad nicht mehr, bzw. das WebGui... Der Prozess läuft zwar, aber mir wird nichts ausgegeben.
Screenshot's:
Gruß,
Michael
Mysteriöser Weise funktioniert nun alles auf einmal wie's soll ...
Hey,
Screenshot's:
Gruß,
Michael
#- - sourced, not executed -
#!/bin/sh
# uses UPnP-IGD on your router, enable UPnP
# DO NOT CHANGE PYLOAD RECONNECT SCRIPT LOCATION
# disable reconnects at all:
#exit 0
# general options
# send DSM notifications on successful reconnects (containing the new IP)
# values: 0 1
PYLOAD_DSM_NOTIFY_ENABLED=0
# user or group to notify. group notation example: @administrators
PYLOAD_DSM_NOTIFY_USER=admin
# use a preconfigured modem type:
# one of "ST585v7" "PRGAV4202N" "FRITZBox"
PYLOAD_MODEM=ST585v7 PRGAV4202N FRITZBox
# control your own UPnP-IGD router
# function upnpigd(controlURL,device,action)
# variable PYLOAD_GATEWAY == default gateway
#upnpigd \"http://\$PYLOAD_GATEWAY:port/control/WANConn1\" \"WANConn:1\" \"ForceTermination\"
#upnpigd \"http://\$PYLOAD_GATEWAY:49000/upnp/control/WANConn1\" \"WANConnn:1\" \"RequestConnection\"
#exit 0
# your own curl/netcat/upnpc script
# external ip:
#upnpc -s | grep ExternalIPAddress | sed 's/[^0-9\.]//g'
# curl example (see http://reconnect.thau-ex.de/)
#curl -s "http://dslservice.lan/example" -H "Content-type: text/xml; charset='utf-8'" -H "SOAPACTION: urn:schemas-upnp-org:service:example#action" -d "<?xml version='1.0' encoding='utf-8'?><s:Envelope s:encodingStyle='http://schemas.xmlsoap.org/soap/encoding/' xmlns:s='http://schemas.xmlsoap.org/soap/envelope/'><s:Body><u:example xmlns:u='urn:schemas-upnp-org:service:example' /></s:Body></s:Envelope>" >/dev/null
#exit 0
#EOF.
DiskStation> ps
PID USER VSZ STAT COMMAND
1 root 3020 S init
2 root 0 SW [kthreadd]
3 root 0 SW [ksoftirqd/0]
4 root 0 SW [events/0]
5 root 0 SW [khelper]
8 root 0 SW [async/mgr]
87 root 0 SW [sync_supers]
89 root 0 SW [bdi-default]
90 root 0 SW [kblockd/0]
96 root 0 SW [ata/0]
97 root 0 SW [ata_aux]
112 root 0 SW [rpciod/0]
120 root 0 DW< [kswapd0]
121 root 0 SW [nfsiod]
273 root 0 SW [scsi_eh_0]
275 root 0 SW [scsi_eh_1]
277 root 0 SW [scsi_eh_2]
279 root 0 SW [scsi_eh_3]
312 root 0 SW [scsi_eh_4]
314 root 0 SW [scsi_eh_5]
318 root 0 SW [mtdblockd]
365 root 0 SW [md0_raid1]
371 root 0 SW [md1_raid1]
413 root 0 SW [flush-9:0]
452 root 0 SW [kjournald]
1548 root 0 SW [kstriped]
1714 root 0 SW [khubd]
1769 root 0 SW [ksnapd]
1817 root 0 SW [crypto/0]
1967 root 0 SW [crypto]
1968 root 0 SW [crypto_ret]
2056 root 0 SW [ecryptfs-kthrea]
2541 root 1620 S /sbin/dhcpcd -n eth0 -t 30
2559 root 3020 S /sbin/syslogd -S
2564 root 3020 S /sbin/klogd
3081 root 0 SW [md2_raid1]
3155 root 0 SW [md3_raid1]
3321 root 0 SW [md4_raid1]
3644 root 0 SW [kdmflush]
3827 root 0 SW [kdmflush]
3938 root 0 SW [kdmflush]
5516 root 8172 S < /usr/syno/bin/findhostd
5791 root 0 SW [jbd2/dm-0-8]
5792 root 0 SW [ext4-dio-unwrit]
5823 root 0 SW [jbd2/dm-1-8]
5824 root 0 SW [ext4-dio-unwrit]
5850 root 0 SW [flush-253:0]
5857 root 0 SW [jbd2/dm-2-8]
5858 root 0 SW [ext4-dio-unwrit]
6517 root 2512 S avahi-daemon: running [DiskStation.local]
6981 admin 33756 S /usr/syno/pgsql/bin/postgres -D /var/services/pgsql
6982 root 8404 S /usr/syno/bin/scemd
7330 root 0 SW [usbhid_resumer]
7555 root 83636 S python /opt/pyload/pyLoadCore.py --daemon
7561 root 3024 S /sbin/getty 115200 console
7564 admin 33888 S postgres: writer process
7565 admin 33756 S postgres: wal writer process
7620 root 8716 S /usr/syno/sbin/hotplugd
7638 root 5480 S /usr/sbin/inetd
7645 root 5480 S /usr/sbin/crond
8494 root 0 SW< [kslowd000]
8585 root 0 SW< [kslowd001]
8606 root 10508 S /usr/syno/sbin/ddnsd
9044 root 3020 S /bin/sh /usr/syno/mysql/bin/mysqld_safe --datadir=/v
9169 admin 108m S /usr/syno/mysql/libexec/mysqld --basedir=/usr/syno/m
10115 root 7880 S /usr/syno/sbin/cupsd -C /usr/local/cups/cupsd.conf
10192 root 12660 S /usr/syno/sbin/fileindexd
10203 root 27032 S N /usr/syno/sbin/synoindexd
10210 root 25980 S N /usr/syno/bin/synomkthumbd
10291 root 17024 S /usr/syno/sbin/nmbd -D
10346 root 21144 S /usr/syno/sbin/smbd -D
10349 root 21144 S /usr/syno/sbin/smbd -D
10368 root 7124 S /usr/syno/sbin/cnid_metad -l log_error
10370 root 13800 S /usr/syno/sbin/afpd -g guest -c 256 -n DiskStation A
10410 root 25980 S N /usr/syno/sbin/synomkflvd
10479 root 4116 S /usr/syno/sbin/sshd
10489 root 7388 S /usr/syno/apache/bin/httpd -DSSL -f /usr/syno/apache
10524 root 7584 S /usr/syno/apache/bin/httpd -DSSL -f /usr/syno/apache
10525 root 7576 S /usr/syno/apache/bin/httpd -DSSL -f /usr/syno/apache
10526 root 59400 S /usr/syno/apache/bin/httpd -DSSL -DHAVE_PHP
10560 nobody 59908 S /usr/syno/apache/bin/httpd -DSSL -DHAVE_PHP
10561 nobody 63368 S /usr/syno/apache/bin/httpd -DSSL -DHAVE_PHP
10562 nobody 59736 S /usr/syno/apache/bin/httpd -DSSL -DHAVE_PHP
10563 admin 34848 S postgres: admin mediaserver [local] idle
10564 root 12704 S /usr/syno/apache/bin/httpd -DSSL -f /usr/syno/apache
10569 root 12704 S /usr/syno/apache/bin/httpd -DSSL -f /usr/syno/apache
10570 root 12704 S /usr/syno/apache/bin/httpd -DSSL -f /usr/syno/apache
10668 root 9892 S /usr/syno/sbin/ftpd -D
10735 root 11624 S /var/packages/DownloadStation/target/sbin/scheduler
10742 admin 34848 S postgres: admin download [local] idle
10755 root 81312 S /var/packages/MediaServer/target/sbin/dms
10768 root 9368 S /var/packages/MediaServer/target/sbin/lighttpd -f /v
10867 nobody 59400 S /usr/syno/apache/bin/httpd -DSSL -DHAVE_PHP
10946 root 7576 S /usr/syno/apache/bin/httpd -DSSL -f /usr/syno/apache
10966 root 7576 S /usr/syno/apache/bin/httpd -DSSL -f /usr/syno/apache
11094 root 7576 S /usr/syno/apache/bin/httpd -DSSL -f /usr/syno/apache
11139 root 24488 S /var/packages/iTunesServer/target/sbin/mt-daapd
11158 admin 34792 S postgres: admin mediaserver [local] idle
11404 root 3024 S telnetd
11407 root 5484 S -ash
14710 root 18292 S /usr/syno/sbin/afpd -g guest -c 256 -n DiskStation A
14984 root 21660 S /usr/syno/sbin/cnid_dbd /volume3/@tmp/@pplepriv@te/D
15050 root 21660 S /usr/syno/sbin/cnid_dbd /volume2/@tmp/@pplepriv@te/H
15970 root 21660 S /usr/syno/sbin/cnid_dbd /volume1/@tmp/@pplepriv@te/P
16089 root 21660 S /usr/syno/sbin/cnid_dbd /volume1/@tmp/@pplepriv@te/H
16356 root 21660 S /usr/syno/sbin/cnid_dbd /volume3/@tmp/@pplepriv@te/H
17361 nobody 59400 S /usr/syno/apache/bin/httpd -DSSL -DHAVE_PHP
17444 root 43732 R N /usr/syno/sbin/synoindexd
17446 root 5484 R ps
Mal pyload neu installiert?
