So,
ich habe bei Seagate nach dem SeaChest Tool angefragt,weil ich gerne das EPC deaktivieren würde. Leider sind die ganzen Download Links von dem Tool down.
Habe es kurzerhand runtergeladen und auf Zippyshare hochgeladen. Hier ist das Tool zum Download:
http://www112.zippyshare.com/v/bJfwsmGq/file.html Endlich ein funktionierender Link
Anbei noch die Beschreibung die mir Seagate per Mail zukommen hat lassen:
We understand you need the Seachest Tool to disable the EPC Feature. In this case, we request you try the following troubleshooting, to see if it helps to resolve the issue.
1. Connect the drive to a SATA port on a PC and boot to Windows.
2. Download the latest Sea Chest and install it in Windows.
Link ist oben
3. Open Sea Chest and its own command prompt will open.
4. First, get the drive's Handle which could be PD0, PD1, or PD2, etc.
Copy and paste or type the following in the command prompt and then press Enter.
SeaChest_PowerChoice --scan
5. Next, confirm if EPC (Extended Power Conditions) is supported and enabled for this drive. The following uses PD0 as an example and you should Use the correct drive handle in the command.
SeaChest_PowerChoice -d PD0 --deviceInfo
Locate EPC [Enabled] near the bottom of the list under Features Supported:
6. Next, to disable EPC, copy and paste or type the following in the command prompts and then hit Enter.
SeaChest_PowerChoice -d PD0 --EPCfeature disable
7. Confirm if EPC is disabled. Copy and paste or type the following in the command prompt and hit Enter to get the drive information again.
If an EPC is disabled, it will show EPC without the [Enabled].
8. Shut down the computer and then install the drive in the NAS.
Now monitor if the drive makes the clicking noise as it did before. If the issue persists, please reply to this email so that we could check for other possible troubleshooting. Awaiting your response at the earliest.
Und ich hatte bei Klarsicht IT nachgefragt wieso die 2 erst bestellten Ironwolf 10 TB HDD beim Zugriff lauter sind als meine 2 die ich vor Monaten gekauft habe. Ob dies ein Defekt ist oder sowas in der Art.
Antwort:
Seagate hat bei seinen Ironwolf Modellen in den letzten Monaten die Antriebs- und Stellmotoren gewechselt welche zwar stabiler laufen, jedoch lautere Antriebsgeräusche von sich geben. Wir hatten gerade vor in paar Tagen eine ähnliche Reklamation und konnten diese Information von unserem Ansprechpartner bei Seagate erhalten. Beim Tausch der Festplatten würde sich daher an den Geräuschen nichts ändern.
So hoffe es sind für euch ein paar nützliche Infos dabei.
MfG
n1Ko
