Storj - Speicher vermieten
Welche Fehlermeldung kommt denn?
Und was erhälst du, wenn du per SSH folgendes eingibst:
curl localhost:14002
root@x:~# curl localhost:14002
<!DOCTYPE html><html lang=en><head><meta charset=utf-8><link rel=apple-touch-icon href="data:image/png;
base64,iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAYAAABzenr0AAAACXBIWXMAABYlAAAWJQFJUiTwAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAL8SURBVHgBxVcxTFNRFL01JvylrRsmNWETWWSybg5I3NTQBCdRFyfrDuoKMgMyOQgdTcDAJmrUrWWCgQIbhJKy0TJQpsc73P/S9
/tfP+8/GnqSn1fo77/3nnPufe8nhAR1ETeoy7hJjpj93/ycu0+UuUVuEA5Y2xaifirEVpX
/nvknnBFbgpMGUfmIKOkRLRT578oxXy6IJcFCialH0EyaaPoZBy7tEQ3NEY1IKd4
/iidHwqYLijLA559cuY6dT0RjBU5AAYm9fiivLFnBKMGBTyeqQ4BXhXDwdqjUiKZkskOzREsbzeeBNRMCEiDgr12uYl1WNbnW
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"
type=image/x-icon><meta name=apple-mobile-web-app-capable content=yes><meta name=apple-mobile-web-app-status-bar-style content=black><meta name=viewport content="width=device-width,initial-scale=1,viewport-fit=cover"><meta name=description content="Node Dashboard page"><link rel="shortcut icon" href="data:image/png;
base64,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"
type=image/x-icon><title>Node Dashboard</title><link href=/static/dist/css/app.082ee822.css rel=preload as=style><link href=/static/dist/js/app.js rel=preload as=script><link href=/static/dist/js/vendors.js rel=preload as=script><link href=/static/dist/css/app.082ee822.css rel=stylesheet></head><body><div id=app></div><script src=/static/dist/js/vendors.js></script><script src=/static/dist/js/app.js></script></body></html>
Na dann ist es ja schonmal erreichbar. Bleibt die Frage, warum nicht von deinem anderen PC.
Gib denBefehl mal auf deinem PC von wo aus du zugreifen willst in der Kommandozeile ein:
curl IP:14002
Im Terminal bekomme ich keine Antwort auf den Befehl, wenn ich auf das NAS zugreifen will.
Die IP hast du entsprechend angepasst?
Beim Zugriff über SSH auf das NAS nicht. Habs wohl überlesen.
P.S. Gibt es hier keine Möglichkeit einen Spoiler einzubauen, damit der Code nicht zu dominant wird?
Hier noch mal die erste Ausgabe:
root@x:~# curl 192.168.0.200:14002
<!DOCTYPE html><html lang=en><head><meta charset=utf-8><link rel=apple-touch-icon href="data:image/png;base64,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" type=image/x-icon><meta name=apple-mobile-web-app-capable content=yes><meta name=apple-mobile-web-app-status-bar-style content=black><meta name=viewport content="width=device-width,initial-scale=1,viewport-fit=cover"><meta name=description content="Node Dashboard page"><link rel="shortcut icon" href="data:image/png;base64,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" type=image/x-icon><title>Node Dashboard</title><link href=/static/dist/css/app.082ee822.css rel=preload as=style><link href=/static/dist/js/app.js rel=preload as=script><link href=/static/dist/js/vendors.js rel=preload as=script><link href=/static/dist/css/app.082ee822.css rel=stylesheet></head><body><div id=app></div><script src=/static/dist/js/vendors.js></script><script src=/static/dist/js/app.js></script></body></html>root@x:~#
setze den Code zwischen diese Tags
oder beim antworten auf Erweitert klicken und # Button verwenden.
Im
-Tag sollte der Inhalt eigentlich eingegrenzt werden.
Nein, du sollst in der Windows-Konsole cmd.exe folgendes eingeben:
curl 192.168.1.XX:14002
das XX natürlich auf die IP der Synology anpassen. Was kommt dann?
curl: (7) Failed to connect to 192.168.0.200 port 14002: Die Wartezeit für die Verbindung ist abgelaufen
Ich arbeite unter Linux.
Könnte ich irgendwie meinen externen Zugriff auf http://NAS:14002 per .htaccess absichern?
Hi Luddi, jetzt lief es einen Tag gut aber jetzt bekomme ich wieder keinen upload. Erst nachdem ich die Firewall nun aufgemacht habe, läuft es wieder rund.... wie sieht es bei dir aus?
meinst du mit NAS deine domain? falls ja, dann einfach den port nicht freigeben.
falls intern: welchen externen zugriff meinst du?
Hallo Maalik,
mit http://NAS:14002 meinte ich meine Domain, die über DDNS auf mein NAS zeigt.
Ja, ich könnte die Weiterleitung deaktivieren, aber dann komme ich überhaupt nicht mehr auf das Dashboard, da der interne Zugriff über 192.168.0.200:14002 nicht funktioniert.
Ja
Hast du noch andere Computer im Netzwerk, mit denen du das testen kannst?
Im Moment nicht, aber ich kann mal auf Win 10 rüber booten.
Ich teste das mal eben.
Wie hast du denn jetzt im Endeffekt den Docker gestartet? Also welcher Befehl?
docker stop -t 300 storagenode
docker rm storagenode
docker run -d --restart unless-stopped --stop-timeout 300 \
    -p 28967:28967 \
    -p 14002:14002 \
    -e WALLET="XXXXXXXXXXXXXXXXXXXXXXXXX" \
    -e EMAIL="Meine E-Mail" \
    -e ADDRESS="MeineDomain:28967" \
    -e STORAGE="2TB" \
    --mount type=bind,source="/volume1/storj/identity-dir",destination=/app/identity \
    --mount type=bind,source="/volume1/storj/storage-dir",destination=/app/config \
    --name storagenode storjlabs/storagenode:beta
So siehts bei mir auch aus, mit der Ausnahme dass ich kein --stop-timeout 300 gesetzt habe. Das sollte aber irrelevant sein. Kannst du denn auf andere Dienste per Lokale-IP:Port zugreifen? Oder hast du da keine anderen Dienste?
