Was sagt das Diagramm oben links "Disk Space Used This Months" mit der Einheit TB*H aus?
sudo docker container create \
-p 28967:28967 \
-p 14002:14002 \
-e WALLET="0x########" \
-e EMAIL="#####@######.de" \
-e ADDRESS="#######.quickconnect.to:28967" \
-e BANDWIDTH="20TB" \
-e STORAGE="500GB" \
--mount type=bind,source="/volume1/docker/storj/storj_identity",destination=/app/identity \
--mount type=bind,source="/volume1/docker/storj/storj_data",destination=/app/config \
--name storagenode \
storjlabs/storagenode:beta
invalid reference format: repository name must be lowercase
Wie kommst du denn auf container create?
docker run -d --restart unless-stopped --stop-timeout 300 \
-p 28967:28967 \
-p 14002:14002 \
docker: invalid reference format: repository name must be lowercase.
See 'docker run --help'.
:~$ sudo docker images list
REPOSITORY TAG IMAGE ID CREATED SIZE
sudo docker pull storjlabs/storagenode:beta
docker stop -t 300 storagenode
docker rm storagenode
-p 28967:28967 \
-p 14002:14002 \
-e WALLET="0xXXXXXXXXXXXXXXXXXXXXXXXXXXXX" \
-e EMAIL="mail@XX.de" \
-e ADDRESS="DynDNS:28967" \
-e STORAGE="2TB" \
--mount type=bind,source="/volume1/storj/identity-dir",destination=/app/identity \
--mount type=bind,source="/volume1/storj/storage-dir",destination=/app/config \
--name storagenode storjlabs/storagenode:beta
mach das mal bitte alles ohne sudo.
docker: Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post http://%2Fvar%2Frun%2Fdocker.sock/v1.39/containers/create?name=storagenode: dial unix /var/run/docker.sock: connect: permission denied.
2020-04-04 23:38:12 stderr 2020-04-04T23:38:12.583Z [34mINFO[0m Configuration loaded from: /app/config/config.yaml
2020-04-04 23:37:18 stderr 2020-04-04T23:37:18.736Z [31mFATAL[0m file or directory not found error: open identity/identity.cert: no such file or directory
sudo docker image ls -a
Password:
storjlabs/storagenode beta 06cc0fb8e41a 5 days ago 30.1MB
portainer/portainer latest 2869fc110bf7 2 weeks ago 78.6MB
storjlabs/storagenode latest dbef10e5de67 6 months ago 33.1MB
docker ps - a
Dom@Server:~$ sudo docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
a56f63710c2a storjlabs/storagenode:beta "/entrypoint" 21 minutes ago Restarting (1) About a minute ago storagenode
0ca9f21cd553 portainer/portainer "/portainer" 3 days ago Up 3 days 0.0.0.0:9000->9000/tcp portainer
a56f63710c2a storjlabs/storagenode:beta "/entrypoint" 21 minutes ago Up Less than a second 0.0.0.0:14002->14002/tcp, 0.0.0.0:28967->28967/tcp storagenode
a56f63710c2a storjlabs/storagenode:beta "/entrypoint" 21 minutes ago Restarting (1) 5 seconds ago storagenode
