Teil 2:
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: classloader_00000000: org.jdownloader.update.launcher.ClassLoaderExtensionImpl
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.home: /root
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.timezone: GMT+01:00
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.awt.printerjob: sun.print.PSPrinterJob
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: file.encoding: UTF-8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.specification.version: 1.7
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.class.path: /volume2/@appstore/jdownloader/JDownloader.jar
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.name: root
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.specification.version: 1.7
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.java.command: /volume2/@appstore/jdownloader/JDownloader.jar
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.home: /volume2/@appstore/JavaManager/Java/jre
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.arch.data.model: 32
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: user.language: en
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.specification.vendor: Oracle Corporation
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: awt.toolkit: sun.awt.X11.XToolkit
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vm.info: mixed mode
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.version: 1.7.0_79
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.ext.dirs: /volume2/@appstore/JavaManager/Java/jre/lib/ext:/usr/java/packages/lib/ext
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.boot.class.path: /volume2/@appstore/JavaManager/Java/jre/lib/resources.jar:/volume2/@appstore/JavaManager/Java/jre/lib/rt.jar:/volume2/@appstore/JavaManager/Java/jre/lib/sunrsasign.jar:/volume2/@appstore/JavaManager/Java/jre/lib/jsse.jar:/volume2/@appstore/JavaManager/Java/jre/lib/jce.jar:/volume2/@appstore/JavaManager/Java/jre/lib/charsets.jar:/volume2/@appstore/JavaManager/Java/jre/lib/jfr.jar:/volume2/@appstore/JavaManager/Java/jre/classes
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.awt.headless: true
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vendor: Oracle Corporation
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: file.separator: /
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: k: 0dd0ecf7f742873d745106adea00b64a
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: java.vendor.url.bug:
http://bugreport.sun.com/bugreport/
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.io.unicode.encoding: UnicodeLittle
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.cpu.endian: little
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysProp: sun.cpu.isalist:
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: OLDPWD: /volume2/@appstore
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: TERM: xterm-256color
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: SHELL: /bin/ash
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: JAVA_HOME: /var/packages/JavaManager/target/Java/jre
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: CLASSPATH: .:/var/packages/JavaManager/target/Java/jre/lib
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: XFILESEARCHPATH: /usr/dt/app-defaults/%L/Dt
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: PATH: /sbin:/bin:/usr/sbin:/usr/bin:/usr/syno/sbin:/usr/syno/bin:/usr/local/sbin:/usr/local/bin:/var/packages/JavaManager/target/Java/bin:/var/packages/JavaManager/target/Java/jre/bin
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: SSH_CLIENT: 192.168.178.41 51539 22
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: MAIL: /var/mail/root
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LC_ALL: en_US.utf8
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: USER: root
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: PAGER: more
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: PWD: /root
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: HOME: /root
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: SSH_TTY: /dev/pts/0
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: LOGNAME: root
1|org.jdownloader.update.launcher.SecondLevelLauncher.log 8/13/15 12:47:39 PM - INFO [ org.appwork.utils.Application(printSystemProperties) ] -> SysEnv: PGDATA: /var/services/pgsql
